查看: 6997|回復(fù): 14
毫秒定時(shí)器制作
ID:75575 發(fā)表于 2015-3-28 23:18 | 顯示全部樓層 |閱讀模式
實(shí)驗(yàn)室儀器壞了,自己制作了一個(gè),新手,因?yàn)閮x器要求,精確度1ms,最大值9999ms,要求為接通開關(guān)K1開始計(jì)時(shí);接通開關(guān)K2暫停計(jì)時(shí)并顯示。
評(píng)分
參與人數(shù) 1威望 +50 黑幣 +50 收起 理由
admin + 50 + 50 共享資料的積分獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:75575 發(fā)表于 2015-3-28 23:21 | 顯示全部樓層
  1. /**********
  2. 功能:秒表
  3. MCU  : STC89C52     11.0592MHz
  4. 編譯器: Keil C51 V4.22
  5. 描述: 精確度1ms,曹老師要求為接通開關(guān)K1開始計(jì)時(shí);接通開關(guān)K2暫停計(jì)時(shí)并顯示。
  6. 作者:NCUT_glx
  7. *********/
  8. #include"reg52.h"
  9. typedef        unsigned char UINT8;
  10. typedef unsigned int  UINT16;
  11. UINT16 Num;
  12.
  13. #define DataPort P0
  14. sbit LE1 = P2^2;                        //duan
  15. sbit LE2 = P2^3;                        //wei
  16. sbit K1 = P2^4;
  17. sbit K2 = P2^5;
  18. UINT8 code DuanMa[ ] = { 0x3F,0x06,0x5B,0x4F,
  19.                                      0x66,0x6D,0x7D,0x07,
  20.                                      0x7F,0x6F };
  21. UINT8 code WeiMa[] = { 0xFE,0xFD,0xFB,0xF7,
  22.                                    0xEF,0xDF,0xBF,0x7F };
  23. UINT8 StorageData[8];
  24. void DelayMs( UINT16 Ms )
  25. {
  26.                 UINT8 i;
  27.
  28.                 while (Ms--)
  29.                 {
  30.                         for ( i = 0; i < 114; i++ );
  31.                 }
  32. }
  33. void chushihua(void)
  34. {
  35.         TMOD |= 0x01;
  36.         TH0 =        (65536-917)/256;
  37.         TL0 =        (65536-917)%256;
  38.         ET0 =        1;
  39.         EA        =        1;
  40.         TR0=1;
  41. }
  42. void TIMER1(void) interrupt 1
  43.                 {
  44.                         TH0 =(65536-917)/256;
  45.                          TL0 =(65536-917)%256;
  46.                         Num++;
  47.                         if (Num==10000)
  48.                                 {
  49.                                         Num==0;
  50.                                 }
  51.                                         StorageData[ 0 ] = DuanMa[ Num / 1000 ];
  52.                                                            StorageData[ 1 ] = DuanMa[ ( Num % 1000 ) / 100 ];
  53.                                                            StorageData[ 2 ] = DuanMa[ ( ( Num % 1000 ) % 100 ) / 10 ];
  54.                                                            StorageData[ 3 ] = DuanMa[ ( ( Num % 1000 ) % 100 ) % 10 ];
  55.                 }
  56. void Display( UINT8 FirstBit, UINT8 Num )//UINT8 FirstBit:要顯示的位;UINT8 Num:要顯示的數(shù)碼管的位數(shù)
  57. {
  58.                 UINT8 i;
  59.                 for( i = 0; i < Num; i++ )
  60.                 {
  61.                         DataPort=0;
  62.                            LE1 = 1;
  63.                            LE1 = 0;
  64.
  65.                            DataPort = WeiMa[ i + FirstBit ];
  66.                            LE2 = 1;
  67.                            LE2 = 0;
  68.
  69.                            DataPort = StorageData[ i ];
  70.                            LE1 = 1;
  71.                            LE1 = 0;
  72.
  73.                            DelayMs(1);
  74.                 }
  75. }
  76. void main (void)
  77. {
  78.         chushihua();
  79.         if(K1==0)
  80.         {
  81.                 while(1)
  82.                 {
  83.                         if (K2==0)
  84.                         {
  85.                                 TR0=0;
  86.                         }
  87.                         Display( 2, 4 );
  88.                 }
  89.         }
  90. }
  91.
  92.
ID:75575 發(fā)表于 2015-3-29 10:40 | 顯示全部樓層
所有資料都在這里啦,比較全,還有74hc373 鎖存器資料以及自制protues 仿真圖。
所有資料.zip
319.74 KB, 下載次數(shù): 80, 下載積分: 黑幣 -5
ID:73762 發(fā)表于 2015-3-29 11:12 | 顯示全部樓層
下載了,謝謝樓主共享
ID:75575 發(fā)表于 2015-3-29 13:52 | 顯示全部樓層
mirage 發(fā)表于 2015-3-29 11:12
下載了,謝謝樓主共享
恩呢  我也是新人    摸著石頭過(guò)河    多交流
ID:72611 發(fā)表于 2015-3-29 20:40 | 顯示全部樓層
謝謝分享,51hei有你更精彩
ID:72611 發(fā)表于 2015-3-29 20:47 | 顯示全部樓層
很厲害,謝謝分享
ID:79149 發(fā)表于 2015-6-2 17:16 | 顯示全部樓層
不錯(cuò)啊
ID:38546 發(fā)表于 2015-8-21 10:25 | 顯示全部樓層
想學(xué)習(xí)下,沒有黑幣,嗚
ID:88070 發(fā)表于 2015-9-11 17:00 | 顯示全部樓層
謝謝分享!
ID:104142 發(fā)表于 2016-1-24 20:26 | 顯示全部樓層
謝謝分享,51hei有你更精彩
ID:112605 發(fā)表于 2016-4-7 07:32 | 顯示全部樓層
謝謝分享,51hei有你更精彩
ID:162112 發(fā)表于 2017-2-28 09:59 | 顯示全部樓層
感謝分享,和我目前需要的有相似之處!
ID:112517 發(fā)表于 2017-3-1 11:21 | 顯示全部樓層
我也是新人  .是我目前需要的.有相似之處.
ID:169145 發(fā)表于 2017-3-8 16:25 | 顯示全部樓層
謝謝分享,51hei有你更精彩
主站蜘蛛池模板: 天天天天天干 | 久久小视频 | 欧美黄色一级 | 福利视频网站 | 成人小视频在线 | 欧美日韩一区二区三区 | 欧美日韩综合网 | 超碰一区二区 | 黄色小视频在线观看 | 三级黄色片 | 久久久久久一区 | 91久久久精品 | 久久久综合视频 | 欧美一级大片 | 日韩免费在线 | av入口 | 日韩欧美网站 | av女人的天堂 | 亚洲福利一区 | 日本天堂网 | 免费三级网站 | 自拍偷拍一区二区三区 | 中文字幕精品一区久久久久 | 日韩一区二区在线播放 | 久久久久一区二区 | 懂色av一区二区三区 | 精品久久久久久 | 91精品在线免费观看 | 日韩在线专区 | 天天躁日日躁狠狠很躁 | 亚洲伦理在线观看 | 天堂资源中文在线 | av网址在线播放 | 成人在线免费av | 久久国内视频 | 亚洲精品一区二区三区在线观看 | 黄色a毛片 | 天天爽| 日韩在线高清 | 国产综合自拍 | 国产视频一区在线播放 |
