查看: 12167|回復(fù): 30
立體旋轉(zhuǎn)LED制作
ID:76190 發(fā)表于 2015-4-5 16:46 | 顯示全部樓層 |閱讀模式
相信這東西沒(méi)什么新鮮了,很多人都做過(guò),我也來(lái)分享一下制作的心得!
   由我的平面旋轉(zhuǎn)LED改造的,改造很容易,就把平面的LED改成的立體的不就是了。因?yàn)橛玫氖菬o(wú)線供電方式,旋轉(zhuǎn)起來(lái)很安靜,很平穩(wěn),電機(jī)的速度也夠快的,旋轉(zhuǎn)時(shí)不怎么閃爍。但是相機(jī)拍來(lái)視頻來(lái)還是會(huì)有點(diǎn)閃,眼睛看不怎么覺(jué)得會(huì)閃。‍‍‍‍
       電源輸入是6V1A的,經(jīng)過(guò)無(wú)線供電模塊后變成交流電用兩個(gè)線圈感應(yīng)電壓來(lái)供旋轉(zhuǎn)部分的電,PCB板上有簡(jiǎn)單的整流濾波電路。時(shí)鐘的效果在這里就沒(méi)演示了。板上的1302和后背電池在這里沒(méi)用到,板子剛好平衡,旋轉(zhuǎn)起來(lái)沒(méi)什么太大的晃動(dòng)。限流電阻改小點(diǎn)亮度估計(jì)會(huì)好很多!
小小玩意,忘論壇里的高手們多多指教!
視頻效果:
程序比較簡(jiǎn)單:
  1. /*************************************************************
  2.                       旋轉(zhuǎn)LED字體程序
  3. 單片機(jī) STC89C52
  4. 字模軟件用的PC2002
  5. 逐列取模方式
  6. ***************************************************************/
  7. #include <AT89X52.h>
  8. #define uchar unsigned char
  9. #define uint unsigned int    //宏定義
  10. sbit KEY=P3^2;
  11. sbit led1=P1^1;
  12. unsigned char code love[] = {
  13. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  14. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  15. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
  16. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
  17. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  18. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  19. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",6*/
  20. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",7*/
  21. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",8*/
  22. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/
  23. 0xF7,0xDF,0xF7,0xE7,0x06,0xD8,0xB1,0xBF,0xB7,0xDF,0x37,0x60,0xEF,0x9F,0x57,0xE0,
  24. 0xD8,0xEF,0xDB,0xDF,0x1B,0xC0,0xDB,0xBD,0xDB,0xBD,0x9B,0xBD,0xDB,0xBF,0xFF,0xFF,/*"旋",0*/
  25. 0x37,0xF7,0x57,0xF7,0x63,0xFB,0x14,0x00,0x77,0xFB,0x77,0xFB,0x77,0xFF,0xBF,0xFD,
  26. 0xB7,0xF4,0x07,0xED,0xB0,0xDD,0xB7,0x2D,0xB7,0xF1,0xB7,0xFD,0xBF,0xFF,0xFF,0xFF,/*"轉(zhuǎn)",1*/
  27. 0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xCF,0xFF,0xFF,/*"L",2*/
  28. 0xF7,0xDF,0x07,0xC0,0x77,0xDF,0x77,0xDF,0x17,0xDC,0xF7,0xDF,0xEF,0xE7,0xFF,0xFF,/*"E",3*/
  29. 0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xEF,0xEF,0x1F,0xF0,0xFF,0xFF,/*"D",4*/
  30. 0xF7,0xFB,0xCE,0x03,0x79,0xFC,0x9F,0xFF,0xFF,0x7F,0x01,0xB8,0xFD,0xCF,0x0D,0xF0,
  31. 0xFD,0xEF,0x01,0x98,0xFF,0xFF,0x07,0xF8,0xFF,0xBF,0xFF,0x7F,0x00,0x80,0xFF,0xFF,/*"測(cè)",5*/
  32. 0xBF,0xFF,0xBD,0xFF,0x23,0x80,0xF7,0xDF,0xFF,0xEF,0x6F,0xDF,0x6F,0xDF,0x6F,0xE0,
  33. 0x6F,0xEF,0x6F,0xEF,0x00,0xFE,0xEF,0xF9,0xED,0xE7,0xE3,0xDF,0xEF,0x87,0xFF,0xFF,/*"試",6*/
  34. 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,
  35. 0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",7*/
  36. 0xDF,0xFF,0xDF,0x7F,0xDF,0xBF,0xDF,0xDF,0xDF,0xEF,0xDF,0xF3,0x5F,0xFC,0x80,0xFF,
  37. 0x5F,0xFE,0xDF,0xF9,0xDF,0xF7,0xDF,0xCF,0xDF,0x9F,0xDF,0x3F,0xDF,0xBF,0xFF,0xFF,/*"大",8*/
  38. 0xFF,0xFF,0xE7,0xD6,0xFB,0xD6,0xEB,0xEA,0x6B,0xEB,0x6B,0xB5,0x2A,0x76,0x49,0xBB,
  39. 0xEB,0xC0,0xEB,0xF9,0x6B,0xF6,0xFB,0xF6,0xEB,0xEF,0xF3,0xCF,0xFB,0xEF,0xFF,0xFF,/*"家",9*/
  40. 0xBF,0xFF,0xCF,0xFD,0xEF,0xFD,0xED,0xFD,0xA3,0xFD,0xAB,0xFD,0xAF,0xBD,0xAE,0x7D,
  41. 0xA1,0x80,0x2B,0xFD,0xAF,0xFD,0xE7,0xFD,0xA8,0xFD,0xCD,0xFD,0xEF,0xFD,0xFF,0xFF,/*"學(xué)",10*/
  42. 0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xFD,0xF3,0xF5,0xFB,0xED,0xFD,0xDD,0xFD,0x9D,0xFE,
  43. 0xFD,0xFE,0x7D,0xFF,0x7D,0xDF,0xBD,0xBF,0xFD,0x7F,0x01,0x80,0xFF,0xFF,0xFF,0xFF,/*"習(xí)",11*/
  44. 0x7F,0xFF,0x7D,0xBF,0x63,0xDF,0x77,0xE0,0xFF,0xDF,0x77,0xAF,0x77,0xB3,0x00,0xBC,
  45. 0x77,0xBF,0x77,0xBF,0x77,0xBF,0x00,0xA0,0x77,0xBF,0x77,0xBF,0x7F,0xBF,0xFF,0xFF,/*"進(jìn)",12*/
  46. 0xFF,0xFF,0xDF,0xBB,0xDF,0xBB,0xDF,0xBD,0x43,0xBE,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,
  47. 0x00,0xE8,0xDB,0xEF,0xDB,0xF7,0xDB,0xFB,0xDB,0xFC,0xDF,0xFD,0xDF,0xFF,0xFF,0xFF,/*"步",13*/
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xA0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  49. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"!",14*/
  50. 0xFF,0xFF,0x1F,0xF0,0xEF,0xEF,0xF7,0xDF,0xF7,0xDF,0xEF,0xEF,0x1F,0xF0,0xFF,0xFF,/*"0",15*/
  51. 0xFF,0xFF,0xC7,0xFF,0xF7,0xFF,0xF7,0xC0,0x37,0xFF,0xC7,0xFF,0xF7,0xFF,0xFF,0xFF,/*"7",16*/
  52. 0xFF,0xFF,0xFF,0xFF,0x07,0xF0,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0x00,0xC0,
  53. 0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0xB0,0xFF,0xBF,0xFF,0x8F,0xFF,0xFF,/*"電",17*/
  54. 0xFF,0xFF,0xDF,0xFF,0xEF,0xFF,0x73,0xFF,0x58,0xFF,0x5B,0xFF,0x5B,0xFF,0x5B,0xFF,
  55. 0x5B,0xFF,0x5B,0xFF,0x5B,0xFF,0x5B,0xF0,0xDB,0xCF,0xFB,0xBF,0xFB,0x0F,0xFF,0xFF,/*"氣",18*/
  56. 0xFF,0xDF,0xFF,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0x01,0xC0,
  57. 0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFF,0xDF,0xFF,0xFF,/*"工",19*/
  58. 0xEF,0xFB,0xED,0xFC,0x2D,0xFF,0x01,0x00,0x6E,0xFF,0xEE,0xBE,0x7F,0xBB,0x40,0xBB,
  59. 0x5E,0xBB,0x5E,0x80,0x5E,0xBB,0x5E,0xBB,0x40,0xBB,0x7F,0xBB,0xFF,0xBF,0xFF,0xFF,/*"程",20*/
  60. 0xFF,0xFF,0xAF,0xFF,0xB0,0xC0,0xB5,0xFE,0xB7,0xFE,0x00,0x00,0xB7,0xDE,0xB7,0x9E,
  61. 0xB7,0xC0,0xFF,0xFF,0x03,0xF0,0xFF,0xBF,0xFF,0x7F,0x00,0x80,0xFF,0xFF,0xFF,0xFF,/*"制",21*/
  62. 0x7F,0xFF,0xBF,0xFF,0xDF,0xFF,0x07,0x00,0xF8,0xFF,0xDD,0xFF,0xE7,0xFF,0xF3,0xFF,
  63. 0x04,0x00,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0x97,0xFB,0xB7,0xF9,0xF7,0xFB,0xFF,0xFF,/*"作",22*/
  64. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xA0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  65. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"!",23*/
  66. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  67. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  68. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
  69. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
  70. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  71. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  72. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  73. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  74. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  75. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  76. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  77. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  78. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  79. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  80. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  81. };
  82. /*****n(us)延時(shí)子程序*****/
  83. void DelayUs(uint N)
  84. {
  85.     uint x ;
  86.     for(x=0;x<=N;x++);
  87. }
  88. /*****主函數(shù)*****/
  89. void main(void)
  90. {
  91.     uint i=0,j=0 ;
  92.     led1=0 ;
  93.     //主程序中只檢測(cè)按鍵
  94.     while(1)
  95.     {
  96.         if(KEY==0)
  97.         {
  98.             j++;
  99.             if(j>580)
  100.             {
  101.                 j=0 ;
  102.             }
  103.             for(i=j;i<128+j;i++)
  104.             {
  105.                 P0=love[i*2];
  106.                 P2=love[i*2+1];
  107.                 DelayUs(60);
  108.                 P0=0XFF;
  109.                 P2=0XFF;
  110.
  111.             }
  112.         }
  113.     }
  114. }
  115. /*****END*****/
ID:76209 發(fā)表于 2015-4-5 23:36 | 顯示全部樓層
棒棒的
ID:76671 發(fā)表于 2015-4-25 12:37 來(lái)自觸屏版 | 顯示全部樓層
厲害,求資料
ID:76671 發(fā)表于 2015-4-25 13:03 來(lái)自觸屏版 | 顯示全部樓層
求高清原理圖,812175465@qq.com
ID:78880 發(fā)表于 2015-5-4 22:01 | 顯示全部樓層
樓主您好,有高清原理圖嗎,736092685@qq.com
ID:76671 發(fā)表于 2015-5-7 18:33 來(lái)自觸屏版 | 顯示全部樓層
nlztc77 發(fā)表于 2015-5-4 22:01
樓主您好,有高清原理圖嗎,
我找到高清原理圖了!可是不知道怎么下載程序!交流交流下唄!
ID:77383 發(fā)表于 2015-6-7 11:36 | 顯示全部樓層
厲害,求資料
ID:82852 發(fā)表于 2015-6-12 22:49 | 顯示全部樓層
6666大神啊
ID:97369 發(fā)表于 2015-11-27 16:38 | 顯示全部樓層
求高清原理圖605613364@qq.com
ID:97673 發(fā)表于 2015-11-30 13:06 | 顯示全部樓層
太厲害壓
魚(yú)魚(yú)yy語(yǔ)音
ID:98638 發(fā)表于 2015-12-8 18:14 | 顯示全部樓層
底下電源是怎么做的?
ID:44267 發(fā)表于 2015-12-26 07:58 | 顯示全部樓層
幫樓主頂起
ID:104450 發(fā)表于 2016-2-17 21:34 | 顯示全部樓層
感覺(jué)比其他的簡(jiǎn)單多了!有資料的話就好了
ID:104763 發(fā)表于 2016-2-18 09:46 | 顯示全部樓層
樓主厲害
ID:100985 發(fā)表于 2016-3-8 18:18 | 顯示全部樓層
好厲害!學(xué)習(xí)了、
ID:108140 發(fā)表于 2016-3-10 00:09 來(lái)自觸屏版 | 顯示全部樓層
樓主有高清圖嗎?更新一下吧
這東西太好了
ID:100985 發(fā)表于 2016-3-12 18:04 來(lái)自觸屏版 | 顯示全部樓層
求效果圖啊!
ID:111164 發(fā)表于 2016-3-28 17:34 | 顯示全部樓層
求資料!
ID:39025 發(fā)表于 2016-4-3 11:51 | 顯示全部樓層
幫樓主頂起
ID:103831 發(fā)表于 2016-4-4 11:58 | 顯示全部樓層
無(wú)線供電部分 有什么特殊要求嗎?比如222的電容 瓷片電容可以嗎,線圈L的繞制  是采用多少線徑的漆包線呢,我弄得 無(wú)線供電 不能實(shí)現(xiàn),不起振 是咋回事
ID:99130 發(fā)表于 2016-6-26 17:27 | 顯示全部樓層
原理圖有高清的嗎
ID:128560 發(fā)表于 2016-7-1 13:42 | 顯示全部樓層
非常棒,求資料
ID:145294 發(fā)表于 2016-10-31 11:04 | 顯示全部樓層
求資料
ID:145320 發(fā)表于 2016-10-31 13:06 | 顯示全部樓層
厲害!!!!!!!!!!!!!
ID:65581 發(fā)表于 2016-10-31 14:12 | 顯示全部樓層
贊!!!最好有效果圖看一下。
ID:233756 發(fā)表于 2017-11-29 09:00 | 顯示全部樓層
6666大神啊
ID:187478 發(fā)表于 2017-11-29 10:50 | 顯示全部樓層
我有問(wèn)題 ,板子自己做嗎???因?yàn)槲易约鹤龅陌遄犹亓?/td>
ID:313953 發(fā)表于 2018-6-7 01:46 來(lái)自觸屏版 | 顯示全部樓層
樓主你好,請(qǐng)問(wèn)你用的是哪種取模軟件
主站蜘蛛池模板: 日日夜夜精品 | 99精品久久久 | www.av在线 | 欧美视频区 | 国产一区不卡 | 国产综合久久久 | 午夜爽爽影院 | 国内自拍xxxx18 | 午夜精品在线 | 黄色在线观看免费 | 欧美日韩免费视频 | 999毛片 | 日本久久精品视频 | 久久国产精品一区二区 | 亚洲一区二区三区免费视频 | 69国产精品 | 欧美在线视频一区二区 | www99热| 天堂中文字幕免费一区 | 成人自拍视频 | 国产一区二区三区视频 | 欧美视频区 | 中文字幕一区在线观看 | 亚洲视频在线观看 | 中文字幕三区 | 91精品国产99久久久久久红楼 | 精品国产99久久久久久宅男i | 亚洲精品在线视频 | 日日夜夜av | 日韩一区二区在线观看视频 | 国产精品美女久久久久久久久 | 国产午夜三级 | 黄色成人在线视频 | 欧美成人毛片 | 久久日韩精品 | 青青草视频网站 | 福利视频1000| 四虎影视av | 亚洲激情综合网 | 亚洲亚洲人成综合网络 | 波多野结衣亚洲一区 |
