查看: 13291|回復: 1
51單片機LED16*16點陣滾動顯示電路圖+源程序
ID:76190 發表于 2015-4-5 18:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. /******************************************************************
  2. 功能:LED16*16點陣滾動顯示
  3. 說明:74LS164用作發送數據,P0,P2口用來列選
  4. 看本程序最好的工具最好旁邊有標號和語法著色,推薦keil或UltraEdit
  5. 懶人提示:要改成自己所要的顯示內容,要怎么改?
  6. 1.要改顯示內容改第23~92行代碼,還有第119行代碼,具體改法見下面注釋
  7. 2.要改滾動速度改第102行代碼
  8. *******************************************************************/
  9. /*頭文件*/
  10. #include<reg52.h>
  11. #include<intrins.h>
  12. /*宏定義*/
  13. #define uchar unsigned char
  14. #define uint  unsigned int
  15. /*函數聲明*/
  16. void delay();
  17. /*全局變量*/
  18. uint lie; //列選標志
  19. /** 字模:反顯,縱向取模,開頭和結尾均加入32個0xFF,用于改善屏滾動顯示時循環的連貫性   **/
  20. /** 北京市公交公司 T8 路,開往北京西站,發車時間20:30,歡迎大家乘坐!  --  **  宋體, 12  **/
  21. /** 當前所選字體下一個漢字對應的點陣為:  寬度x高度=496x16,  調整后為: 496x16          **/
  22. uchar code text[1056]={   //這里的數據為你要顯示的內容的數據量+64(前后各32個0xff)
  23. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  24. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  25. //改顯示內容以上兩行別改
  26. 0xEF,0xDF,0xEF,0x3F,0xE8,0xFF,0x00,0x00,0xED,0xFF,0xFE,0xFD,0xEF,0xF3,0xEC,0x0F,
  27. 0x6D,0xFF,0x8D,0xFF,0xED,0xFF,0xEC,0x03,0xEF,0xFD,0xEF,0xFD,0xEF,0xE1,0xFF,0xFF,
  28. 0xFF,0x7F,0xF8,0xFE,0xFF,0xF9,0xFF,0xE7,0x00,0x1F,0xFB,0xFF,0xFC,0xFF,0xFF,0xFF,
  29. 0x80,0x01,0xF7,0xFF,0xF9,0xFF,0xFE,0x7F,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
  30. 0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xD8,0x03,0xDB,0xFF,0xDB,0xFF,0x5B,0xFF,0x80,0x00,
  31. 0xDB,0xFF,0xDB,0xFF,0xDB,0xF7,0xDB,0xFB,0xD8,0x07,0xDF,0xFF,0xDF,0xFF,0xFF,0xFF,
  32. 0xFF,0xFF,0xFF,0x7F,0xFE,0xFB,0xFD,0xF1,0xF3,0xEB,0x8F,0xDB,0xDE,0x3B,0xFF,0x73,
  33. 0xFF,0xF7,0x8F,0xF7,0xF7,0xD7,0xF9,0xE1,0xFC,0xF3,0xFE,0x7F,0xFE,0xFF,0xFF,0xFF,
  34. 0xFF,0xFF,0xEF,0xFE,0xEE,0xFE,0xED,0xFD,0xE3,0x7D,0xEB,0xBB,0x6F,0xD7,0x8F,0xE7,
  35. 0xCF,0xCF,0xEF,0x97,0xE6,0x3B,0xEB,0x79,0xE9,0xFC,0xED,0xFD,0xEF,0xFF,0xFF,0xFF,
  36. 0xFF,0xFF,0xFF,0x7F,0xFE,0xFB,0xFD,0xF1,0xF3,0xEB,0x8F,0xDB,0xDE,0x3B,0xFF,0x73,
  37. 0xFF,0xF7,0x8F,0xF7,0xF7,0xD7,0xF9,0xE1,0xFC,0xF3,0xFE,0x7F,0xFE,0xFF,0xFF,0xFF,
  38. 0xFF,0xFF,0xF7,0xFF,0xB6,0x07,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,
  39. 0xB6,0xDF,0xB6,0x0F,0xB7,0xFF,0xBF,0xFB,0xBF,0xFD,0x80,0x03,0xFF,0xFF,0xFF,0xFF,
  40. 0xEF,0xFB,0xE0,0x03,0xEE,0xFB,0xFC,0x7F,0xEB,0x9B,0xE7,0xE3,0xEF,0xFB,0xFF,0xFF,
  41. 0xFF,0xFF,0xF3,0xE7,0xEF,0xFB,0xEE,0xFB,0xEE,0xFB,0xED,0x77,0xF3,0x8F,0xFF,0xFF,
  42. 0xFF,0xFF,0xF7,0xFB,0xF7,0xFB,0xE0,0x03,0xFF,0xFB,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,
  43. 0xFF,0xFF,0xF8,0x0F,0xF7,0x77,0xEE,0xFB,0xEE,0xFB,0xE7,0x77,0xFF,0x8F,0xFF,0xFF,
  44. 0xFF,0xFB,0x81,0x03,0xBB,0xFB,0xB8,0x07,0x83,0x77,0xFB,0x77,0xF7,0xBF,0xEF,0x01,
  45. 0x0F,0x3B,0xD2,0xBB,0xDD,0xBB,0xDA,0xBB,0xC6,0x81,0xDF,0x3F,0xFF,0x7F,0xFF,0xFF,
  46. 0xFF,0xFE,0xFF,0xF2,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFD,0xFF,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xCF,0x80,0x3F,0xBD,0xFF,0xBD,0xFF,
  48. 0xBD,0xFF,0xBD,0xFF,0x80,0x01,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,
  49. 0xFB,0xBF,0xF7,0x7F,0xEE,0xFF,0x10,0x00,0xBB,0xFF,0xEF,0xFD,0xEF,0x7D,0xEF,0x7D,
  50. 0x6F,0x7D,0x80,0x01,0xAF,0x7D,0xEF,0x7D,0xEF,0x7D,0xEF,0x7D,0xEF,0xFD,0xFF,0xFF,
  51. 0xF7,0xFD,0xF7,0xFD,0xD7,0x01,0xD7,0xFB,0xD7,0xFB,0xD4,0x07,0xD7,0x77,0xD7,0x77,
  52. 0xF7,0x7F,0x01,0xFF,0xF6,0x1F,0xB7,0xE7,0xD7,0xFB,0xF7,0xFD,0xF7,0xF0,0xFF,0xFF,
  53. 0xF7,0xEF,0xF7,0x9F,0xF6,0x7F,0x00,0x00,0xF6,0xFF,0xF7,0x37,0xFF,0xEF,0xF7,0xDF,
  54. 0xF7,0x3F,0xF4,0xFF,0x00,0x00,0xF6,0x7F,0xF7,0x9F,0xF7,0xE7,0xF7,0xEF,0xFF,0xFF,
  55. 0xFF,0xFD,0xFF,0xF3,0xC0,0x0F,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0x5F,0xFF,
  56. 0x9F,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xFF,0xFF,
  57. 0xF7,0xEF,0xF7,0xE7,0xF7,0xEF,0x00,0x1F,0xF7,0xDF,0xF7,0xBF,0xBF,0xAD,0xBD,0xDB,
  58. 0xB9,0xB7,0xB4,0x6F,0xAD,0x9F,0x9C,0x7D,0xBD,0xFE,0xF8,0x01,0xFD,0xFF,0xFF,0xFF,
  59. 0xFF,0xFE,0xFF,0xF2,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  60. 0xFF,0xFD,0xF7,0xFB,0x83,0xF7,0xF7,0xEE,0xF7,0x1E,0xF0,0x7D,0x06,0x9D,0xF6,0xEB,
  61. 0xF6,0xF7,0xB6,0xEB,0xD6,0x1B,0xC7,0xFD,0xF7,0xFC,0xF7,0xFD,0xF7,0xFF,0xFF,0xFF,
  62. 0xFF,0xDF,0xDF,0xDF,0xDE,0xDF,0xDC,0xDF,0xDA,0xDF,0xC6,0xDF,0x1E,0xDF,0xDE,0xDF,
  63. 0xD0,0x00,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xFF,0xDF,0xFF,0xFF,
  64. 0xFF,0xFF,0xC0,0x1F,0xDD,0xDF,0xDD,0xDF,0xDD,0xDF,0xC0,0x1F,0xF7,0xFF,0xF6,0xFF,
  65. 0xF7,0x3F,0xF7,0xFD,0xF7,0xFE,0x00,0x01,0xF7,0xFF,0xF7,0xFF,0xF7,0xFF,0xFF,0xFF,
  66. 0xFF,0xFF,0xE0,0x00,0x7F,0xFF,0x9F,0xFF,0xFF,0xFF,0xF0,0x1F,0xB6,0xDF,0xB6,0xDF,
  67. 0xB6,0xDF,0xB6,0xDF,0xB0,0x1F,0xBF,0xFD,0xBF,0xFE,0x80,0x01,0xFF,0xFF,0xFF,0xFF,
  68. 0xFF,0xFF,0xF1,0xF3,0xEF,0xEB,0xEF,0xDB,0xEF,0xBB,0xEE,0x7B,0xF1,0xF3,0xFF,0xFF,
  69. 0xFF,0xFF,0xF8,0x0F,0xF7,0xF7,0xEF,0xFB,0xEF,0xFB,0xF7,0xF7,0xF8,0x0F,0xFF,0xFF,
  70. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xF3,0xFC,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  71. 0xFF,0xFF,0xF3,0xE7,0xEF,0xFB,0xEE,0xFB,0xEE,0xFB,0xED,0x77,0xF3,0x8F,0xFF,0xFF,
  72. 0xFF,0xFF,0xF8,0x0F,0xF7,0xF7,0xEF,0xFB,0xEF,0xFB,0xF7,0xF7,0xF8,0x0F,0xFF,0xFF,
  73. 0xFF,0xFE,0xFF,0xF2,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  74. 0xD7,0xFB,0xDB,0xF7,0xDD,0xCD,0xDE,0x3D,0xD9,0x3D,0xC7,0xCB,0xFB,0xFB,0xE7,0xF7,
  75. 0x0F,0xCF,0xE8,0x3F,0xEF,0x9F,0xEF,0xE7,0xEB,0xF3,0xE7,0xF9,0xEF,0xFB,0xFF,0xFF,
  76. 0xFD,0xFD,0x7D,0xFB,0x8C,0x07,0xDF,0xFB,0xFF,0xFD,0xC0,0x1D,0xDF,0xBD,0xBF,0x7D,
  77. 0xBF,0xFD,0xC0,0x05,0xDF,0xFD,0xDF,0xBD,0xDF,0xDD,0xC0,0x3D,0xFF,0xFD,0xFF,0xFF,
  78. 0xFB,0xFF,0xFB,0xFE,0xFB,0xFD,0xFB,0xFB,0xFB,0xF7,0xFB,0xCF,0xFA,0x3F,0x01,0xFF,
  79. 0xFA,0x7F,0xFB,0x9F,0xFB,0xEF,0xFB,0xF3,0xFB,0xF9,0xFB,0xFC,0xFB,0xFD,0xFF,0xFF,
  80. 0xFF,0xFF,0xE7,0x6B,0xDF,0x6B,0xD7,0x57,0xD6,0xD7,0xD6,0xAD,0x54,0x6E,0x92,0xDD,
  81. 0xD7,0x03,0xD7,0x9F,0xD6,0x6F,0xDF,0x6F,0xD7,0xF7,0xCF,0xF3,0xDF,0xF7,0xFF,0xFF,
  82. 0xEF,0xBB,0xEB,0xBB,0xAB,0x77,0xAB,0x77,0xA0,0x2F,0xAF,0xCF,0xAF,0x9F,0x80,0x01,
  83. 0xAF,0xBF,0x6F,0xDF,0x60,0x4F,0x6D,0x67,0x6B,0x73,0xCB,0x77,0xEE,0x7F,0xFF,0xFF,
  84. 0xFF,0x7D,0xFE,0xFD,0xF9,0xDD,0xC7,0xDD,0xFB,0xDD,0xFC,0xDD,0xFF,0xDD,0x00,0x01,
  85. 0xFF,0x5D,0xFE,0xDD,0xFD,0xDD,0xC3,0xDD,0xFD,0xDD,0xFE,0xFD,0xFF,0xFD,0xFF,0xFF,
  86. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  87. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  88. //改顯示內容以下兩行別改
  89. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  90. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
  91. };
  92. /*主函數*/
  93. void main()
  94. {uchar i,j;
  95. uint m=0;//m是從字模數組里向后取數據時的計數器,用以改變顯示文字的內容,及滾動顯示效果
  96. SCON=0;  //初始化串口為工作方式0(同步通信方式,TxD輸出同步脈沖)
  97. lie=0x7fff; //列選標志初始化
  98. while(1) //重復循環顯示
  99. {for(j=0;j<10;j++) //j用來控制屏上1幀顯示內容停留的時間,即用來控制滾動速度
  100. { for(i=1;i<=31;i+=2)
  101.     {P0=0xff;//先關顯示,以免164內數據移動過程中在屏上產生不良影響,大家可以把這兩句去掉比較下顯示效果
  102.      P2=0xff;
  103.      SBUF=text[i+m];//從串口發送字模數據(為什么要先發后一個數據,看下電路應該會明白吧:)
  104.      while(TI==0);  //等待發送完畢
  105.      TI=0;
  106.      SBUF=text[i+m-1];//從串口發送數據,補全整一列數據
  107.      while(TI==0);
  108.      TI=0;
  109.   P0=lie%256;//選中要顯示的那列,同時等于打開了那列的顯示
  110.      P2=lie/256;
  111.      delay(); //延時,等待一段時間,讓這列顯示的內容在人眼內產生“視覺暫留”現象,略知生理的人應該都知道吧。
  112.   lie=_iror_(lie,1); //列選標志移位,準備用來選中下一列
  113.       }
  114.   }//返回顯示下一列,直到16列都顯示完成
  115.   m+=2;//顯示內容向后移一列
  116.   if(m>1024)//這個數據為你的字模數組的大小-32,我的是1056-32=1024
  117.   m=0;
  118.     }
  119. }
  120. /*延時子程序*/
  121. void delay()
  122. {uint n;
  123. for(n=0;n<90;n++)
  124.    {;}
  125. }
ID:79544 發表于 2015-12-20 13:29 | 只看該作者
樓主你的程序不全啊,
主站蜘蛛池模板: 国产精品入口66mio男同 | 亚洲一区高清 | av三级在线观看 | 午夜精品999 | 免费高清av | 国产精品一区一区三区 | 中国美女乱淫免费看视频 | 91欧美激情一区二区三区成人 | 日韩av高清在线观看 | 成人福利在线观看 | 欧美黄色免费网站 | 天天射日日干 | 国产成人精品一区二区 | 久久久久综合 | 一区二区三区日韩 | 男人天堂av网 | 欧美日韩国产中文字幕 | 亚洲欧美日韩国产 | 久久久久久久久国产 | 成人永久免费 | 日韩精品一区二区三区免费视频 | 国产精品视频久久久 | 91青青草| 欧美性一区二区 | 精品欧美黑人一区二区三区 | 亚洲免费观看视频 | 3d动漫精品h区xxxxx区 | 曰本一级片 | 网站av | 欧洲性视频 | 天天看天天干 | 在线免费观看日韩av | 亚洲一区二区三区四区在线 | 国产性生活 | 成人毛片网 | 在线观看日韩精品 | av网站免费看 | 欧美日韩在线观看视频 | 国产精品3| 毛片免费播放 | 欧美日韩三区 |
