用合作式時(shí)間觸發(fā)的方法對C51進(jìn)行編程,模擬調(diào)試的時(shí)候可以通過,在線編譯就出錯(cuò)。編譯器用的是星研的star51ph。請高手指點(diǎn)問題出在哪里?
/*============================================================== 1ms時(shí)標(biāo)的合作式調(diào)度器(多個(gè)合作式任務(wù)) 作者:shadow.hu
時(shí)間:2008-4-23
#include<reg52.h> #define uchar unsigned char #define ushort unsigned short #define SCH_MAX_TASKS 5 #define SCHTASKS (1)
#define INTERRPT_Timer_2_Overflow 5 #define ERROR_SCH_TOO_MANY_TASKS 6 #define ERROR_SCH_CANOT_DELETE_TASK 1 #define RETURN_ERROR 0 #define RETURN_NORMAL 1
#define SCH_REPORT_ERRORS #ifdef SCH_REPORT_ERRORS #define Error_Port P1 #endif
typedef data struct { void (code *pTask)(void); ushort Delay; ushort Period; ushort RunMe; }sTask; sTask SCH_tasks_G[SCH_MAX_TASKS];
void SCH_Init_T2(void); uchar SCH_Add_Task(void (code * pFunction)(),const ushort Delay, ushort PERIOD); void SCH_Dispatch_Tasks(void); void SCH_Start(void); bit SCH_Delete_Task(const ushort TASK_INDEX); void SCH_Go_To_Sleep(void); void SCH_Report_Status(void);//報(bào)告系統(tǒng)狀況 void LED_Flash_Init(void); void LED_Flash_Update(void);
uchar Error_code_G = 0; uchar LED_State_G = 0;
sbit LED_pin = P1^7; //Error_code_G = ERROR_SCH_TOO_MANY_TASKS; //Error_code_G = ERROR_SCH_WAITING_FOR_SLAVE_TO_ACK; //Error_code_G = ERROR_SCH_WAITING_FOR_START_COMAND_FROM_MASTER; //Error_code_G = ERROR_SCH_ONE_OR_MORE_SLAVES_DID_NOT_START; //Error_code_G = ERROR_SCH_LOST_SLAVE; //Error_code_G = ERROR_SCH_CAN_BUS_ERROR; //Error_code_G = ERROR_I2C_WRITE_BYTE_AT24C64;
void main(void) { SCH_Init_T2(); LED_Flash_Init(); SCH_Add_Task(LED_Flash_Update,0,1000); SCH_Start(); while(1) { SCH_Dispatch_Tasks(); } }
void SCH_Update(void) interrupt INTERRPT_Timer_2_Overflow { //刷新任務(wù)隊(duì)列 uchar Index; TF2 = 0; for(Index = 0;Index < SCH_MAX_TASKS;Index++) { if(SCH_tasks_G[Index].pTask) { if(SCH_tasks_G[Index].Delay == 0) { //任務(wù)需要運(yùn)行 SCH_tasks_G[Index].RunMe += 1; if(SCH_tasks_G[Index].Period) { //調(diào)度周期性的任務(wù)再次運(yùn)行 SCH_tasks_G[Index].Delay = SCH_tasks_G[Index].Period; } } else { //還沒有準(zhǔn)備好運(yùn)行,延遲減1 SCH_tasks_G[Index].Delay -= 1; } } } }
void SCH_Init_T2(void) { uchar i; for(i=0;i<SCH_MAX_TASKS;i++) { SCH_Delete_Task(i); } Error_code_G = 0; T2CON = 0x04; TMOD = 0x00; TH2 = 0xfc; RCAP2H = 0xfc; TL2 = 0x18; RCAP2L = 0x18; ET2 = 1; TR2 = 1; }
uchar SCH_Add_Task(void (code * pFunction)(),const ushort DELAY, ushort PERIOD) { uchar Index = 0; while((SCH_tasks_G[Index].pTask != 0)&&(Index < SCH_MAX_TASKS)) { Index++; } if(Index == SCH_MAX_TASKS) { Error_code_G = ERROR_SCH_TOO_MANY_TASKS; return SCH_MAX_TASKS; } SCH_tasks_G[Index].pTask = pFunction; SCH_tasks_G[Index].Delay = DELAY; SCH_tasks_G[Index].Period = PERIOD; SCH_tasks_G[Index].RunMe = 0; return Index;//返回任務(wù)的位置 }
void SCH_Dispatch_Tasks(void) { uchar Index; for(Index = 0;Index < SCH_MAX_TASKS;Index++) { if(SCH_tasks_G[Index].RunMe > 0) { (*SCH_tasks_G[Index].pTask)() ;//執(zhí)行任務(wù) SCH_tasks_G[Index].RunMe -= 1; } if(SCH_tasks_G[Index].Period == 0) { SCH_Delete_Task(Index); } } SCH_Report_Status();//報(bào)告系統(tǒng)狀況 SCH_Go_To_Sleep(); }
void SCH_Start(void) { EA = 1; }
bit SCH_Delete_Task(const ushort TASK_INDEX) { bit Return_code; if(SCH_tasks_G[TASK_INDEX].pTask == 0) { Error_code_G = ERROR_SCH_CANOT_DELETE_TASK; Return_code = RETURN_ERROR; } else { Return_code = RETURN_NORMAL; } SCH_tasks_G[TASK_INDEX].pTask = 0x0000; SCH_tasks_G[TASK_INDEX].Delay = 0; SCH_tasks_G[TASK_INDEX].Period = 0; SCH_tasks_G[TASK_INDEX].RunMe = 0; return Return_code; }
void SCH_Go_To_Sleep() { PCON |= 0x01; }
void SCH_Report_Status(void) { /* #ifdef SCH_REPORT_ERRORS if(Error_code_G != Last_error_code_G) { Error_Port = 255 - Error_code_G; Last_error_code_G = Error_code_G; if(Error_code_G != 0) { Error_tick_count_G = 60000; } else { Error_tick_count_G = 0; } } else { if(Error_tick_count_G != 0) { if(--Error_count_G == 0) { Error_code_G = 0; } } } #endif */ }
void LED_Flash_Update(void) { if(LED_State_G == 1) { LED_State_G = 0; LED_pin = 0; } else { LED_State_G = 1; LED_pin = 1; } }
void LED_Flash_Init(void) { LED_State_G= 0; }
