查看: 3674|回復: 0
分塊內存映射處理大文件-例子
ID:77367 發表于 2015-4-18 20:40 | 顯示全部樓層 |閱讀模式
// 該函數用于讀取從CCD攝像頭采集來的RAW視頻數據當中的某一幀圖像,
// RAW視頻前596字節為頭部信息,可以從其中讀出視頻總的幀數,
// 幀格式為1024*576*8
參數:
pszPath:文件名
dwFrame: 要讀取第幾幀,默認讀取第2幀
BOOL  MyFreeImage::LoadXRFrames(TCHAR *pszPath, DWORD dwFrame/* = 2*/ )
// get the frames of X-Ray frames
BOOL bLoop = TRUE;
inti;
int width = 1024;
int height = 576;
int bitcount = 8;//1, 4, 8, 24, 32
//Build bitmap header
BITMAPFILEHEADER bitmapFileHeader;
BITMAPINFOHEADER bitmapInfoHeader;
BYTE rgbquad[4];// RGBQUAD
int index = 0;
DWORD widthbytes = ((bitcount*width + 31)/32)*4;//每行都是4的倍數  DWORD的倍數  這里是 576-
TRACE1("widthbytes=%d\n", widthbytes);
switch(bitcount) {
case 1:
index = 2;
bitmapFileHeader.bfOffBits = (DWORD)(sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER) + 2*4);
break;
case 4:
index = 16;
bitmapFileHeader.bfOffBits = (DWORD)(sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER) + 16*4);
break;
case 8:
index = 256;
bitmapFileHeader.bfOffBits = (DWORD)(sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER) + 256*sizeof(RGBQUAD));
break;
case 24:
case 32:
index = 0;
bitmapFileHeader.bfOffBits = (DWORD)(sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER));
break;
default:
break;
//構造Bitmap文件頭BITMAPFILEHEADER
bitmapFileHeader.bfType = 0x4d42;    // 很重要的標志位  BM 標識
bitmapFileHeader.bfSize = (DWORD)(bitmapFileHeader.bfOffBits + height * widthbytes);//bmp文件長度
bitmapFileHeader.bfReserved1 = 0;
bitmapFileHeader.bfReserved2 = 0;
//構造Bitmap文件信息頭BITMAPINFOHEADER
bitmapInfoHeader.biSize = sizeof(BITMAPINFOHEADER);
bitmapInfoHeader.biWidth = width;
bitmapInfoHeader.biHeight = height;
bitmapInfoHeader.biPlanes = 1;
bitmapInfoHeader.biBitCount = bitcount;
bitmapInfoHeader.biCompression = BI_RGB;  // 未壓縮
bitmapInfoHeader.biSizeImage = height * widthbytes;
bitmapInfoHeader.biXPelsPerMeter = 3780;
bitmapInfoHeader.biYPelsPerMeter = 3780;
bitmapInfoHeader.biClrUsed = 0;
bitmapInfoHeader.biClrImportant = 0;
//創建BMP內存映像,寫入位圖頭部
BYTE *pMyBmp = new BYTE[bitmapFileHeader.bfSize];// 我的位圖pMyBmp
BYTE *curr = pMyBmp;// curr指針指示pMyBmp的位置
memset(curr, 0, bitmapFileHeader.bfSize);
//寫入頭信息
memcpy(curr, &bitmapFileHeader,sizeof(BITMAPFILEHEADER));
curr = pMyBmp + sizeof(BITMAPFILEHEADER);
memcpy(curr, &bitmapInfoHeader,sizeof(BITMAPINFOHEADER));
curr += sizeof(BITMAPINFOHEADER);
//構造調色板 , 當像素大于8位時,就沒有調色板了。
if(bitcount == 8)
rgbquad[3] = 0;//rgbReserved
for(i = 0; i < index; i++)
rgbquad[0] = rgbquad[1] = rgbquad[2] = i;
memcpy(curr, rgbquad, sizeof(RGBQUAD));
curr += sizeof(RGBQUAD);
}else if(bitcount == 1)
rgbquad[0] = rgbquad[1] = rgbquad[2] = (256 - i)%256;
// 文件映射,從文件中查找圖像的數據
//Open the real file on the file system
HANDLE hFile = CreateFile(pszPath, GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
if (hFile == INVALID_HANDLE_VALUE)
DWORD dwError = GetLastError();
ATLTRACE(_T("MapFile, Failed in call to CreateFile, Error:%d\n"), dwError);
SetLastError(dwError);
bLoop = FALSE;
return FALSE;
//Create the file mapping object
HANDLE hMapping = CreateFileMapping(hFile, NULL, PAGE_READWRITE, 0, 0, NULL);
if (hMapping == NULL)
ATLTRACE(_T("MapFile, Failed in call to CreateFileMapping, Error:%d\n"), dwError);
// Close handle
if (hFile != INVALID_HANDLE_VALUE)
CloseHandle(hFile);
hFile = INVALID_HANDLE_VALUE;
bLoop = FALSE;
return FALSE;
// Retrieve allocation  granularity
SYSTEM_INFO sinf;
GetSystemInfo(&sinf);
DWORD dwAllocationGranularity = sinf.dwAllocationGranularity;
// Retrieve file size
DWORD dwFileSizeHigh;
__int64 qwFileSize = GetFileSize(hFile, &dwFileSizeHigh);
qwFileSize |= (((__int64)dwFileSizeHigh) << 32);
CloseHandle(hFile);
// Read Image
__int64 qwFileOffset = 0;// 偏移地址
DWORD   dwBytesInBlock = 0,// 映射的塊大小
dwStandardBlock = 100* dwAllocationGranularity ;// 標準塊大小
DWORD   dwFrameSize = height*width;        // 計算一幀圖像的數據量,不包括頭部信息
DWORD   dwCurrentFrame = 1;
dwBytesInBlock = dwStandardBlock;
if (qwFileSize < dwStandardBlock)
dwBytesInBlock  = (DWORD)qwFileSize;
//Map the view
LPVOID lpData = MapViewOfFile(hMapping,  FILE_MAP_ALL_ACCESS,
static_cast<DWORD>((qwFileOffset & 0xFFFFFFFF00000000) >> 32), static_cast<DWORD>(qwFileOffset & 0xFFFFFFFF), dwBytesInBlock);
if (lpData == NULL)
ATLTRACE(_T("MapFile, Failed in call to MapViewOfFile, Error:%d\n"), dwError);
// Close Handle
if (hMapping != NULL)
CloseHandle(hMapping);
hMapping = NULL;
bLoop = FALSE;
return FALSE;
BYTE  *lpBits = (BYTE *)lpData;
BYTE  *curr1, *curr2, *lpEnd;
curr1 = lpBits;// seek to start
curr2 = lpBits + 596;// seek to first frame
lpEnd = lpBits + dwBytesInBlock;// seek to end
// Read video infomation
KMemDataStream streamData( curr1, dwBytesInBlock);
ReadXRHeader(streamData);
while(bLoop)
DWORD dwTmp = lpEnd - curr2;//內存緩沖剩余的字節
if ( dwTmp >= dwFrameSize )
if(dwCurrentFrame == dwFrame)
memcpy(curr, curr2, dwFrameSize);
bLoop = FALSE;
curr2 += dwFrameSize;
}else//內存中不夠一幀數據
DWORD dwTmp2 = dwFrameSize - dwTmp;// 一副完整的幀還需要dwTmp2字節
if (dwCurrentFrame == dwFrame)
memcpy(curr, curr2, dwTmp);
curr += dwTmp;
// 檢查還可以映射多少字節的東東到內存里面
if (  qwFileSize - qwFileOffset < dwStandardBlock)
dwBytesInBlock  = (DWORD)(qwFileSize - qwFileOffset);
qwFileOffset += dwBytesInBlock;
UnmapViewOfFile(lpData);
if (lpData == NULL)// 一定要檢查,不然可能內存映射失敗
bLoop = FALSE;
break;
curr2 = lpBits = (BYTE *)lpData;
memcpy(curr, curr2, dwTmp2);
bLoop = FALSE;
curr2 += dwTmp2;
dwCurrentFrame++;
if (dwCurrentFrame > ((LPKINFO)m_VideoInfoHeader)->frames )  // 到達文件末尾
bLoop = FALSE;
//將內存流 pMyBmp 轉為bitmap
KMemDataStream stream(pMyBmp, bitmapFileHeader.bfSize, true);
if(!LoadFromMemory(FIF_BMP, stream))
return FALSE;
if (lpData != NULL)
//FlushViewOfFile(lpData, 0);
lpData = NULL;
//remove the file mapping
hMapping = NULL;
return TRUE;
主站蜘蛛池模板: 午夜在线观看免费视频 | 国产精品成人一区二区三区 | 欧美综合一区二区三区 | 国产精品国产三级国产 | 国产在线视频一区二区 | 久久免费观看视频 | 免费一区二区三区 | 国产999久久久 | 视频爱爱免费视频爱爱太爽 | jlzzjlzz欧美大全| 国内精品久久久久久久久 | 国产亚洲欧洲 | 91最新视频 | 成人在线视频网 | 精品免费视频 | 日本香蕉视频 | 久久cao| 在线观看二区 | 久久黄色录像 | www.黄色av| 亚洲成人免费在线观看 | 成人高潮片免费视频 | 青青五月天 | 视频一区在线观看 | 在线看黄的网站 | 九九久久精品视频 | 色综合久久久 | 久久久一区二区 | 免费一级大片 | 国产一区二区影院 | 国产1级片 | 亚洲视频一区在线观看 | 第一福利丝瓜av导航 | 欧美成人精品 | 亚洲天堂中文字幕 | 日韩中文字幕精品 | 亚洲一区二区三区 | 欧美一级做性受免费大片免费 | 在线a视频 | 国产一级片视频 | 毛片tv|
