查看: 9805|回復: 0
EEPROM.H頭文件下載<51單片機使用Flash ROM模擬EEPROM 先擦除后編輯>
ID:80436 發表于 2015-5-19 01:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
EEPROM.H stc單片機片內存儲器的操作頭文件下載:
#ifndef
_EERPOM_H_
#define _EEPROM_H_
#include <reg51.h>
#include "intrins.h"
#define nop() _nop_()
#define uint8   unsigned char
#define uint16  unsigned int
/*Declare SFR associated with the IAP */
sfr IAP_DATA    =   0xC2;       //Flash data register
sfr IAP_ADDRH   =   0xC3;       //Flash address HIGH
sfr IAP_ADDRL   =   0xC4;       //Flash address LOW
sfr IAP_CMD     =   0xC5;       //Flash command register
sfr IAP_TRIG    =   0xC6;       //Flash command trigger
sfr IAP_CONTR   =   0xC7;       //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE    0           //Stand-By
#define CMD_READ    1           //Byte-Read
#define CMD_PROGRAM 2           //Byte-Program
#define CMD_ERASE   3           //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
        //#define ENABLE_IAP 0x80       //if SYSCLK<30MHz
#define ENABLE_IAP 0x81       //if SYSCLK<24MHz
        //#define ENABLE_IAP 0x82       //if SYSCLK<20MHz
        //#define ENABLE_IAP 0x83       //if SYSCLK<12MHz
        //#define ENABLE_IAP 0x84       //if SYSCLK<6MHz
        //#define ENABLE_IAP 0x85       //if SYSCLK<3MHz
        //#define ENABLE_IAP 0x86       //if SYSCLK<2MHz
        //#define ENABLE_IAP 0x87       //if SYSCLK<1MHz
        //Start address for STC11/10xx EEPROM
        //#define IAP_ADDRESS 0x0400
        //Start address for STC12C5A60S2 EEPROM
#define IAP_ADDRESS 0x0000
void EEPROMDelay(uint8 n)
    uint16 x;
    while (n--)
        x =125;
        while (x--);
* 名稱 : IapIdle();
* 功能 : 關閉IAP EEPROM編輯功能,安全操作
void IapIdle()
    IAP_CONTR = 0;              //Close IAP function
    IAP_CMD = 0;                //Clear command to standby
    IAP_TRIG = 0;               //Clear trigger register
    IAP_ADDRH = 0x80;           //Data ptr point to non-EEPROM area
    IAP_ADDRL = 0;              //Clear IAP address to prevent misuse
* 名稱 : IapReadByte(0x0000);
* 功能 : 讀扇區
uint8 IapReadByte(uint16 addr)
    uint8 dat;                   //Data buffer
    IAP_CONTR = ENABLE_IAP;     //Open IAP function, and set wait time
    IAP_CMD = CMD_READ;         //Set ISP/IAP/EEPROM READ command
    IAP_ADDRL = addr;           //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = addr >> 8;      //Set ISP/IAP/EEPROM address high
    IAP_TRIG = 0x5a;            //Send trigger command1 (0x5a)
    IAP_TRIG = 0xa5;            //Send trigger command2 (0xa5)
    nop();                    //MCU will hold here until ISP/IAP/EEPROM operation complete
    dat = IAP_DATA;             //Read ISP/IAP/EEPROM data
    IapIdle();                  //Close ISP/IAP/EEPROM function
    return dat;                 //Return Flash data
* 名稱 : IapEraseSector(0x0000);
* 功能 : 扇區擦除
void IapEraseSector(uint16 addr)
    IAP_CMD = CMD_ERASE;        //Set ISP/IAP/EEPROM ERASE command
    IapIdle();
* 名稱 : IapProgramByte(0x0000,data);
* 功能 : 扇區編輯
void IapProgramByte(uint16 addr, uint8 dat)
    IAP_CMD = CMD_PROGRAM;      //Set ISP/IAP/EEPROM PROGRAM command
    IAP_DATA = dat;             //Write ISP/IAP/EEPROM data
    IapIdle();
* 名稱 : IapProgramWord(0x0000,data);
* 功能 : 十六位扇區編輯
void IapProgramWord(uint16 addr, uint16 dat)
    uint8 dat_L,dat_H;
    dat_L=dat;
    dat_H=dat >> 8;
    IAP_ADDRL = addr+0x0001;
    IAP_ADDRH = (addr+0x0001)>> 8;
    IAP_DATA = dat_H;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    nop();
    IapIdle();
    IAP_ADDRL = addr;
    IAP_DATA = dat_L;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    nop();
    IapIdle();
* 名稱 : IapReadWord(0x0000);
* 功能 : 讀十六位扇區
uint16 IapReadWord(uint16 addr)
    uint16 dat;                   //Data buffer
    uint8 dat_H,dat_L;
    IAP_ADDRL = (addr+0x0001);           //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = (addr+0x0001) >> 8;      //Set ISP/IAP/EEPROM address high
    dat_H = IAP_DATA;             //Read ISP/IAP/EEPROM data
    IapIdle();
    dat_L= IAP_DATA;            //Read ISP/IAP/EEPROM data
        dat=(dat_H << 8)+dat_L;
#endif
主站蜘蛛池模板: 99伊人| 日本精品视频 | 国产一级黄色 | 国产h视频 | 国产h在线 | 国产又粗又猛视频免费 | 亚洲国产伦理 | 在线日韩视频 | 国产网站视频 | 激情五月综合色婷婷一区二区 | 精品久久网站 | 欧美日韩免费 | 羞羞网站在线观看 | 中文字幕日韩在线观看 | 九九在线免费视频 | 蜜桃精品一区二区 | 亚洲免费久久 | 欧美日韩在线一区二区三区 | 午夜精品视频 | 精品三级在线观看 | 午夜a级片| 亚洲国产第一页 | 日韩在线一区二区三区 | 久久免费观看视频 | 欧美视频一二三区 | 成人av一区二区三区在线观看 | 九九热在线播放 | 欧美激情自拍 | 欧美在线播放 | 国产中文字幕在线播放 | 日本一级黄色大片 | 91精品久久久久 | 国产黄网| 黄色国产网站 | 福利视频网站 | 看片黄全部免费 | 色交视频 | 在线看的av | 69免费视频| 一本在线| 91久久精品日日躁夜夜躁欧美 |
