本帖最后由 liuqq 于 2015-5-20 18:20 編輯
/*生日快樂歌曲*/
/*******************************************/- #include <reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit beep = P1^5;
- uchar code SONG_TONE[]={212,212,190,212,159,169,212,212,190,212,142,159,
- 212,212,106,126,159,169,190,119,119,126,159,142,159,0};
- uchar code SONG_LONG[]={9,3,12,12,12,24,9,3,12,12,12,24,
- 9,3,12,12,12,12,12,9,3,12,12,12,24,0};
- //延時
- void DelayMS(uint x)
- uchar t;
- while(x--) for(t=0;t<120;t++);
- void PlayMusic()
- uint i=0,j,k;
- while(SONG_LONG[i]!=0||SONG_TONE[i]!=0)
- { //播放各個音符,SONG_LONG 為拍子長度
- for(j=0;j<SONG_LONG[i]*20;j++)
- beep=~beep;
- //SONG_TONE 延時表決定了每個音符的頻率
- for(k=0;k<SONG_TONE[i]/3;k++);
- DelayMS(10);
- i++;
- void main()
- beep=0;
- while(1)
- PlayMusic(); //播放生日快樂
- DelayMS(500); //播放完后暫停一段時間
/*兩只蝴蝶歌曲*/
- #include <reg51.h> // 這是 單片機音樂代碼生成器 生成的代碼
- sbit beepIO=P1^5; // 輸出 為 P1.5 可以修改 成 其它 IO 口
- uchar m,n;
- uchar code T[49][2]={{0,0},
- {0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},{0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},{0xFB,0x4A},{0xFB,0x8F},{0xFB,0xCF},{0xFC,0x0B},
- {0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},{0xFC,0xDB},{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},{0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},
- {0xFE,0x21},{0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},{0xFE,0xAD},{0xFE,0xC0},{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},{0xFF,0x02},
- {0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},{0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},{0xFF,0x71},{0xFF,0x79},{0xFF,0x81}
- uchar code music[][2]={{0,4},
- {23,4},{21,4},{23,16},{23,4},{21,4},{23,4},{21,4},{19,16},{16,4},{19,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{19,4},{14,24},
- {23,4},{21,4},{23,16},{23,4},{21,4},{23,4},{21,4},{19,24},{16,4},{19,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{19,4},{21,24},
- {23,4},{26,4},{26,16},{26,4},{28,4},{26,4},{23,24},{21,4},{23,4},{21,8},{21,4},{23,4},{21,4},{19,4},{16,4},{16,2},{19,2},{19,24},{0,20},
- {26,4},{26,4},{28,4},{31,4},{30,4},{30,4},{28,4},{23,4},{21,4},{21,4},{23,16},{0,4},{23,4},{23,4},{26,4},{28,8},{28,12},{16,4},{23,4},{21,4},
- {21,24},{23,4},{26,4},{26,4},{23,4},{26,8},{0,4},{31,8},{30,4},{28,4},{30,4},{23,8},{0,4},{28,4},{28,4},{30,4},{28,4},{26,4},{23,4},{21,8},{23,4},{21,4},{23,4},{26,16},
- {0xFF,0xFF}};
- void delay(uchar p)
- uchar i,j;
- for(;p>0;p--)
- for(i=181;i>0;i--)
- for(j=181;j>0;j--);
- void pause()
- uchar i,j;
- for(i=150;i>0;i--)
- for(j=150;j>0;j--);
- void T0_int() interrupt 1
- beepIO=!beepIO;
- TH0=T[m][0]; TL0=T[m][1];
- void main()
- uchar i=0;
- TMOD=0x01; EA=1; ET0=1;
- while(1)
- m=music[i][0];n=music[i][1];
- if(m==0x00)
- {TR0=0;delay(n);i++;}
- else if(m==0xFF)
- {TR0=0;delay(30);i=0;}
- else if(m==music[i+1][0])
- {TR0=1;delay(n);TR0=0;pause();i++;}
- else
- {TR0=1;delay(n);i++;}
祝你平安:
- #include "reg52.h"
- unsigned char Count;
- sbit _Speak =P1^5 ;
- unsigned char code SONG[] ={ //祝你平安
- 0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
- 0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
- 0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
- 0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
- 0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
- 0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
- 0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
- 0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
- 0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
- 0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
- 0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
- 0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
- 0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
- 0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00};
- void Time0_Init()
- TMOD = 0x01;
- IE = 0x82;
- TH0 = 0xD8;
- TL0 = 0xEF; //12MZ晶振,10ms
- void Time0_Int() interrupt 1
- TH0 = 0xD8;
- TL0 = 0xEF;
- Count++; //長度加1
- 功能:1MS延時子程序
- void Delay_xMs(unsigned int x)
- unsigned int i,j;
- for( i =0;i < x;i++ )
- for( j =0;j<3;j++ );
- void Play_Song(unsigned char i)
- unsigned char Temp1,Temp2;
- unsigned int Addr;
- Count = 0; //中斷計數器清0
- Addr = i * 217;
- while(1)
- Temp1 = SONG[Addr++];
- if ( Temp1 == 0xFF ) //休止符
- TR0 = 0;
- Delay_xMs(100);
- else if ( Temp1 == 0x00 ) //歌曲結束符
- return;
- else
- Temp2 = SONG[Addr++];
- TR0 = 1;
- while(1)
- _Speak = ~_Speak;
- Delay_xMs(Temp1);
- if ( Temp2 == Count )
- Count = 0;
- break;
- 功能:主程序
- void main()
- Time0_Init(); //定時器0中斷初始化
- while(1)
- Play_Song(0); //播放
其他的可以使用音樂代碼轉換器轉換即可,不過很麻煩而已!。
