查看: 3499|回復: 0
STM32 USB校時RTC時鐘
ID:80436 發表于 2015-5-21 16:46 | 顯示全部樓層 |閱讀模式
這兩天閑暇沒事,用STM32寫了個校時時鐘的小程序。基本功能:手動校時,usb校時(可設定鬧鐘),掉電保存數據。自己配套了個校時上位機,如圖:截取電腦實時時間,并設定鬧鐘時間,再由串口通訊傳給STM32.
使用到的STM32資源:定時器2作數碼管顯示實時掃描,USART1用來校時,PWR,BKP,作掉電數據保存,RTC秒中斷作為時鐘時基。
中斷優先級概述:1級優先:串口中斷 2級優先:秒中斷 3級優先:定時器2     PS:波特率默認115200
以下是代碼:
/*WRITER:YQ
#include "stm32f10x.h"
#define PORTA GPIOA->ODR //定義PORTA指向GPIOA的數據寄存器
#define PORTD GPIOD->ODR //定義PORTC指向GPIOC的數據寄存器
#define PORTC GPIOC->ODR
#define key1 GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_2)   //定義按鍵  key1 切換鍵
#define key2 GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_3)   // key2 退出鍵
#define key3 GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_4)   // key3 確定鍵
#define key4 GPIO_ReadInputDataBit(GPIOE,GPIO_Pin_5)   // key4 鬧鐘鍵
const u8 table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
u8 Mode,nude;
int wan,wan1,qian,bai,shi,ge,time,i,butter,buzzer;
USART_InitTypeDef USART_InitStructure;
uint8_t TxBuf[13];
uint8_t RxBuf[13];
uint8_t num1;
int newtime,Alarm;
* 名    稱:GPIO_Configuration()
* 功    能:配置輸入輸出
* 入口參數:
* 出口參數:
* 說明:使用庫函數,配置IO口
void GPIO_Configuration()
SystemInit();
RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;  //D1 D2
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;   //D3,D4
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;          //USART1 TX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //復用推挽輸出
  GPIO_Init(GPIOA, &GPIO_InitStructure);      //A端口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;          //USART1 RX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //復用開漏輸入
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;  //D1 D2
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE,ENABLE);
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_2 | GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_10MHz;
  GPIO_Init(GPIOE,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
void RTC_Configuration() //RTC初始化
RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP|RCC_APB1Periph_PWR,ENABLE);  //開備份寄存器和電源管理時鐘
BKP_DeInit(); //備份寄存器缺省值填入
PWR_BackupAccessCmd(ENABLE);  //使能RTC和備份寄存器的訪問
RCC_LSEConfig(RCC_LSE_ON);    //使能LSE晶振
while(RCC_GetFlagStatus(RCC_FLAG_LSERDY)==RESET);//等待LSE晶振就緒
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);    //把LSE晶振作為RTC的時鐘源
RCC_RTCCLKCmd(ENABLE);   //使能RTC時鐘
RTC_WaitForSynchro();
RTC_WaitForLastTask();    //等待最近一次寫操作完成
RTC_ITConfig(RTC_IT_SEC,ENABLE);//RTC秒中斷使能
   RTC_SetCounter(newtime);  //更新時鐘
RTC_SetPrescaler(32767);  //
RTC_SetAlarm(Alarm);
void RTC_Configuration1() //RTC初始化
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR|RCC_APB1Periph_BKP,ENABLE);
   RCC_GetFlagStatus(RCC_FLAG_LSIRDY);
   RTC_SetAlarm(3600);
   RTC_ITConfig(RTC_IT_ALR,ENABLE);
void TIM2_Configuration() //定時器初始化
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); // 使能定時器時鐘
TIM_TimeBaseStructure.TIM_Period = 9;    // 自動重載值
TIM_TimeBaseStructure.TIM_Prescaler = 7199;   // 時鐘預分頻值
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;  //采樣分頻
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計數模式
TIM_TimeBaseInit(TIM2, & TIM_TimeBaseStructure);  //
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);    //使能定時器2中斷
TIM_Cmd(TIM2,ENABLE);         //使能定時器2這個外設
void USART_Configuration()
USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* Configure USART1 */
  USART_Init(USART1, &USART_InitStructure);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
   USART_Cmd(USART1, ENABLE);
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);   // 搶占式優先級別
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;//指定中斷源
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;// 指定響應優先級別1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;//指定中斷源
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;// 指定響應優先級別1
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;// 指定響應優先級別1
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void Delay(__IO uint32_t nCount)
  for(; nCount != 0; nCount--);
void GPIOYB(unsigned int t)
    unsigned int c;
for(c=0;c<t;c++)
    GPIO_SetBits(GPIOE, GPIO_Pin_0);//
    Delay(0x1AFF);
    GPIO_ResetBits(GPIOE, GPIO_Pin_0);
    Delay(0x1AFF);
* 名    稱:main()
* 功    能:主函數
* 入口參數:
* 出口參數:
* 說明:
int main (void)
    GPIO_Configuration();
    NVIC_Configuration();
TIM2_Configuration();
    RTC_Configuration1();
    USART_Configuration();
   if(key1==0)
  while(!key1);
     Mode=1;   //模式切換,Mode=1為校時模式 Mode=0為正常模式
  while(key2)
   if(key1==0)
  while(!key1);
  butter++;
  if(butter>3)
  butter=0;
  switch(butter)
   case 0:
     if(key3==0)
     while(!key3);
     bai++;
     if(bai>9)
     bai=0;
     break;
   case 1:
     if(key3==0)
     while(!key3);
     qian++;
     if(qian>5)
     qian=0;
     break;
   case 2:
     if(key3==0)
     while(!key3);
     wan++;
     if(wan>9)
     wan=0;
     break;
   case 3:
     if(key3==0)
     while(!key3);
     wan1++;
     if(wan1>2)
     wan1=0;
     break;
   default:     break;
  newtime=ge+shi*10+(bai+qian*10)*60+(wan+wan1*10)*3600; //計算出重新設定的時間值
    RCC_BackupResetCmd(ENABLE);  //清除備份域的數據
  RTC_Configuration(); //配置RTC
  Mode=0;
if (BKP_ReadBackupRegister(BKP_DR1) != 0xf312)  //檢測特殊值,如果不是證明是第一次上電
    BKP_WriteBackupRegister(BKP_DR1, 0xf312); //寫入特殊值,下次不再配置RTC
void TIM2_IRQHandler(void)  //用定時器1ms進行數碼管的動態掃描
if(TIM_GetITStatus(TIM2,TIM_IT_Update)==SET)
TIM_ClearFlag(TIM2,TIM_IT_Update); //清定時器中斷標志
if(Mode==0)
time=RTC_GetCounter();
ge=time%3600%60%10;
shi=time%3600%60/10;
bai=time%3600/60%10;
qian=time%3600/60/10;
wan=time/3600%10;
wan1=time/3600/10;
if(wan1==2&&wan==4)
wan1=0;
wan=0;
qian=0;
bai=0;
shi=0;
ge=0;
switch(i)
case 0: PORTD=0;PORTA=table[wan1];
      PORTD|=(1<<7); break;
case 1: PORTD=0;PORTA=table[wan];
   PORTD|=(1<<8); break;
case 2: PORTD=0;PORTA=table[qian];
   PORTD|=(1<<10); break;
case 3: PORTD=0;PORTA=table[bai];
   PORTD|=(1<<9); break;
default: break;
  i++;
  if(i==4)
  i=0;
void RTC_IRQHandler(void)
  if(RTC_GetITStatus(RTC_IT_SEC) != RESET)
    PORTC^=(1<<7);
   RTC_ClearITPendingBit(RTC_IT_SEC);
  if(RTC_GetITStatus(RTC_IT_ALR) != RESET)
   for(buzzer=0;buzzer<50;buzzer++)
    GPIOYB(100);
Delay(0xfffff);
    RTC_ClearITPendingBit(RTC_IT_ALR);
void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
       RxBuf[num1++]=USART_ReceiveData(USART1);
    if(num1==12)
    for(num1=0;num1<12;num1++)
    TxBuf[num1]=RxBuf[num1]-48;
    num1=0;
     if(num1==0)
  newtime=TxBuf[5]+TxBuf[4]*10+(TxBuf[3]+TxBuf[2]*10)*60+(TxBuf[1]+TxBuf[0]*10)*3600; //計算出重新設定的時間值
  Alarm=TxBuf[11]+TxBuf[10]*10+(TxBuf[9]+TxBuf[8]*10)*60+(TxBuf[7]+TxBuf[6]*10)*3600;
主站蜘蛛池模板: av在线播放网站 | 久久机热这里只有精品 | 国产美女视频 | www.久久久久久 | 97色在线 | 久久xxxx| 成人一区二区三区在线 | 中文字幕丰满人伦在线 | 国产精品99久久久久久久久 | 久久精品国产精品 | 午夜精品福利视频 | 三级黄色片网站 | 午夜黄视频| 国产精品一区一区三区 | 日韩免费小视频 | 日韩精品久久久 | 久久黄色影院 | 黄色特级毛片 | 黄色一级大片 | 国产一区二区免费看 | 老女人毛片 | 中文字幕丰满人伦在线 | 欧美激情成人 | 中文字幕在线观看网址 | 在线免费成人 | 成人羞羞网站 | 91在线精品秘密一区二区 | 97人人艹 | 国产一级二级 | 丁香五香天堂网 | 日韩一级av毛片 | 91精品国产综合久久久蜜臀 | 日本国产欧美 | 欧美色婷婷 | 黄色片视频 | 99av| av免费网 | 日韩亚洲在线 | 国产91精品看黄网站在线观看 | 国产农村妇女aaaaa视频 | 久久国产美女 |
