先上代碼
#include <string.h>
#include <stdio.h>
#include "RobotLib.h"
int flag=0;
PID Function
The PID function is used in mainly
control applications. PIDCalc performs one iteration of the PID
algorithm.
While the PID function works, main is just a dummy program showing
a typical usage.
typedef struct PID {
int SetPoint; // ???? Desired Value
int Proportion; // ???? Proportional Const
int Integral; // ???? Integral Const
int Derivative; // ???? Derivative Const
int LastError; // Error[-1]
int PrevError; // Error[-2]
int SumError; // Sums of Errors
} PID;
位置式PID
int PIDCalc( PID *pp, int NextPoint )
int dError,
Error;
Error = pp->SetPoint - NextPoint; // ??
pp->SumError += Error; // ??
dError = pp->LastError - pp->PrevError; // ????
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error // ???
+ pp->Integral * pp->SumError // ???
+ pp->Derivative * dError // ???
增量式PID
double PIDCalc_delt( PID *pp, double NextPoint )
double dError, Error;
Error = pp->SetPoint - NextPoint; // ????? ???????????
dError= pp->Proportion * Error + pp->Integral * pp->LastError + pp->Derivative * pp->PrevError;
pp->PrevError = pp->LastError; // ????? ????????????
return (dError);
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
Main Program
/*#define N 12
int sensor (void) // Dummy Sensor Function
char count,i,j;
int ad_data[N];
int sum=0;
int advalue=0;
int temp=0;
for (count = 0; count<=N; count++)
ad_data[count]=AI(1);
for (j=0;j<N-1;j++)
for (i=0;i<N-1;i++)
if (ad_data[i]>ad_data[i+1])
temp=ad_data[i];
ad_data[i]=ad_data[i+1];
ad_data[i+1]=temp;
for (count=0;count<N;count++)
sum=ad_data[count];
advalue=sum/(N-2);
return advalue;
void Run(int left_speed,int right_speed)
SetMoto(0,-left_speed);
SetMoto(1,-right_speed);
int speed=0;
void actuator(int rDelta) // Dummy Actuator Function
speed=rDelta;
if(flag==1)
if (speed>100)
speed=100;
else if(speed<-100)
speed=-100;
else if(flag==2)
speed=rDelta/3;
if (speed>50)
speed=50;
else if(speed<-50)
speed=-50;
else if (speed<10 && speed>0)//電機(jī)死區(qū)
speed=8;
else if (speed>-10 && speed<0) //電機(jī)死區(qū)
speed=-8;
Run(speed,speed);
#define N 12
int sensor1(void)//均值濾波。最簡(jiǎn)單的一種
int buffer[N];
int count=0;
int sum=0;
int ad=0;
buffer[count]=AI(1);
wait(0.001);
sum+=buffer[count];
ad=sum/N;
return ad;
void main(void)
PID setPID; // PID Control Structure
int OutPut; // PID Response (Output)
int InPut; // PID Feedback (Input)
PIDInit ( &setPID ); // Initialize Structure
setPID.Proportion = 20; // Set PID Coefficients
setPID.Integral = 0.5;
setPID.Derivative = 0.5;
setPID.SetPoint = 150; // Set PID Setpoint
while(0)
printf("%d\n", sensor1());
// wait(0.2);
{ // Mock Up of PID Processing
InPut = sensor1(); // Read Input
if(InPut-setPID.SetPoint>80 ||InPut-setPID.SetPoint<-80)//分段式PID.距離遠(yuǎn),比例系數(shù)大點(diǎn)
flag=1;
else if (InPut-setPID.SetPoint<20 ||InPut-setPID.SetPoint<-20)//距離近,PID參數(shù)相應(yīng)小一點(diǎn)
flag=2;
setPID.Proportion = 2; // Set PID Coefficients
setPID.Integral = 0.3;
setPID.Derivative = 0;
// wait(0.05);
OutPut = PIDCalc ( &setPID,InPut ); // Perform PID Interation
actuator ( OutPut ); // Effect Needed Changes
printf("InPut=%d\n,Output=%d\n",InPut,OutPut );
// wait(0.1);
效果還不錯(cuò)(手機(jī)錄像不行,改天補(bǔ)上視頻)。(控制器性能強(qiáng)大。主頻144M RAM 1M ROM 2M)基本沒有超調(diào),兩個(gè)震蕩周期就穩(wěn)定了。設(shè)定的目標(biāo)是150(測(cè)距傳感器返回值).小車在距離150很遠(yuǎn)時(shí)是100%的速度跑的。快接近150時(shí),速度馬上降得很快。第一次到150時(shí),會(huì)超前1cm左右,然后往回跑,逼近150時(shí),剛好停下,趨于穩(wěn)定。傳感器在149 150 151左右跳動(dòng)。小車也在不斷微調(diào)。反應(yīng)非常靈敏。最后基本上小車在+-1mm左右晃或者不動(dòng)的狀態(tài)。
我后面試過不用PID來做位置控制。也是可以,效果不好就是。震蕩比較劇烈。需要調(diào)整6 7表周期才會(huì)停到目標(biāo)點(diǎn)。沒有PID那么迅速 靈敏。
簡(jiǎn)單許多,代碼如下,非常簡(jiǎn)單。
distance=sensor1();
NeedSpeed=distance-SetPoint;
printf("distance=%d\n,NeedSpeed=%d\n",distance,NeedSpeed );
Run(NeedSpeed,NeedSpeed);
