查看: 3020|回復: 1
實訓單片機交通燈軟件程序
ID:81203 發表于 2015-5-26 19:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar count=0,i;
uchar num=30;
uchar flag=0,flag2=0,flag3=0;
sbit K1=P2^0;
sbit Stop=P3^4;
sbit LEDGreen_ew=P1^0;
sbit LEDYellow_ew=P1^1;
sbit LEDRed_ew=P1^2;
sbit LEDGreen_sn=P1^3;
sbit LEDYellow_sn=P1^4;
sbit LEDRed_sn=P1^5;
void Turn_LED();
void Delay(uint z);
void Sys_Inital();
void Turnkey();
void delay10ms();
  Sys_Inital();
                 Turnkey();
void Turn_LED()
if(count==20)          //定時時間為1s
   count=0;
    num--;
  if(num==0)
    flag++;
     if(flag==3)
           {flag=0;}
           if(flag==1)
           {num=2;}
       switch(flag%3)
         case 0:
                         LEDGreen_ew=0;LEDYellow_ew=1;LEDRed_ew=1;
                         LEDGreen_sn=1;LEDYellow_sn=1;LEDRed_sn=0;
                            break;
         case 1:
                         LEDGreen_ew=1;LEDYellow_ew=0;LEDRed_ew=1;
                         LEDGreen_sn=1;LEDYellow_sn=0;LEDRed_sn=1;
                         break;
         case 2:
                          LEDGreen_ew=1;LEDYellow_ew=1;LEDRed_ew=0;
                 LEDGreen_sn=0;LEDYellow_sn=1;LEDRed_sn=1;
                         break;
         num=30;
void Delay(uint z)
uint x,y;
for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void delay10ms()
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
void Sys_Inital()
        TMOD = 0x01;
        TH0 = 0x3C;         //定時器0高8位
        TL0 = 0xB0;         //定時器0低8位
        EA = 1;          //開總中斷
        ET0 = 1;          //定時器0中斷允許
        TR0=1;             //定時器0開始計時
        EX0=1;              //外部中斷0允許
        IT0=1;
        LEDGreen_ew=1;
        LEDYellow_ew=1;
        LEDRed_ew=1;
        LEDGreen_sn=1;
        LEDYellow_sn=1;
        LEDRed_sn=1;
void Turnkey()
                        if(K1==0)
                         delay10ms();
                        if(K1==0)
                                flag3++;
                                while((i<50)&&(K1==0))
                                        delay10ms();
                                        i++;
                                i=0;
                if(flag3==2)
                flag3=0;
                num=30;
void int0() interrupt 0
             EA=0;        //關中斷
          Delay(10);    //設置鍵消抖  10ms
            if(!Stop)
                flag2++;
              if(flag2==2)
                      {flag2=0;}
                  switch(flag2)
                   case 0:TMOD=0x01;TR0=1; break;
                   case 1:TMOD=0x00; TR0=0; break;
                         while((i<50)&&(Stop==0))
                                        delay10ms();
                                        i++;
                                i=0;
      EA=1;  //開中斷
void time0() interrupt 1
        TH0=0x3c;               //定時時間為50ms
        TL0=0xb0;
        count++;
ID:81203 發表于 2015-5-26 19:43 | 只看該作者
  1. #include<reg52.h>
  3. #define uint unsigned int   //***********參數初始化********************
  4. uchar count=0,count2=0;     //定時器0,定時器1的計數初值
  5. uchar green_ns=60,green_ew=30,red_ns=34,red_ew=64,yellow_ns=4,yellow_ew=4;//南北綠燈亮60 東西綠燈30 南北紅燈34 東西紅燈64 南北黃燈4 東西黃燈4
  6. uchar snorth=60,ewest=64;   //上電后南北綠燈亮60秒,東西紅燈亮64秒
  7. uchar ding_ns=0,ding_ew=0;  //南北狀態轉換標志位,東西狀態轉換標志位
  8. uchar flag=0,flag2=0;       //設置鍵按下次數的標志位,長按鍵的標志位
  9. //***********引腳定義**********************
  10. sbit wela=P2^0;     //鎖存器位選
  11. sbit dula=P2^1;     //鎖存器位選
  12. sbit NS_R=P2^2;     //南北發光二極管
  13. sbit NS_Y=P2^3;
  14. sbit NS_G=P2^4;
  15. sbit EW_R=P2^5;     //東西發光二極管
  16. sbit EW_Y=P2^6;
  17. sbit EW_G=P2^7;
  18. sbit set=P3^2;      //按鍵 設置鍵 加1鍵  減1鍵
  19. sbit up=P3^4;
  20. sbit down=P3^5;
  21. //*********函數聲明部分******************
  22. void delay(uint z);
  23. void Inital();
  24. void display(uchar s);
  25. void display_ew(uchar w)
  26. void display_ns(uchar r);
  27. void turnkey();
  28. void show();
  29. //*********共陽數碼管段碼***************
  30. unsigned char code SEG7[10]= { 0xC0,/*0*/ 0xF9,/*1*/ 0xA4,/*2*/ 0xB0,/*3*/0x99,/*4*/0x92,/*5*/0x82,/*6*/0xF8,/*7*/0x80,/*8*/0x90,/*9*/};
  31. //*******軟件延時函數 延時1毫秒*********
  32. void delay(uint z)
  33. {
  34. uint x,y;
  35. for(x=z;x>0;x--)
  36. for(y=110;y>0;y--);
  37. }
  38. //********初始化函數*******************
  39. void Inital()
  40. {
  41. wela=0;             //鎖存器初始化
  42. dula=0;
  43. TMOD = 0x11;
  44. //計數器0,1工作在方式1,數值大小16位,定時時間=12*(65536-x)/f  x為初值,f為時鐘頻率
  45. TH0 = 0xD8;         //定時器0高8位
  46. TL0 = 0xF0;         //定時器0低8位
  47. EA = 1;          //開總中斷
  48. ET0 = 1;          //定時器0中斷允許
  49. TR0=1;             //定時器0開始計時
  50. TH1=0xD8;           //定時器1高8位
  51. TL1=0xF0;           //定時器1低8位
  52. ET1 = 1;            //定時器1中斷允許
  53. EX0=1;              //外部中斷0允許
  54. IT0=0;              //外部中斷0電平觸發
  55. NS_R=1;             //南北發光二極管初始化
  56. NS_G=0;
  57. NS_Y=1;
  58. EW_R=0;             //東西發光二極管初始化
  59. EW_G=1;
  60. EW_Y=1;
  61. }
  62. //**********數碼管顯示函數*************
  63. void display(uchar s)
  64. {
  65. P1=SEG7[s];
  66. }
  67. //*******數碼管顯示東西方向數字********
  68. void display_ew(uchar w)
  69. {
  70. uchar x,y,i=0;
  71. x=w%10;                 //個位
  72. y=w/10;                 //十位
  73. dula=1;
  74. display(x);
  75. dula=0;
  76. P1=0x00;
  77. wela=1;
  78. P1=0x04;
  79. wela=0;
  80. delay(5);
  81. dula=1;
  82. display(y);
  83. dula=0;
  84. P1=0x00;
  85. wela=1;
  86. P1=0x08;
  87. wela=0;
  88. delay(5);
  89. }
  90.   //*******數碼管顯示南北方向數字********
  91. void display_ns(uchar r)
  92. {
  93. uchar x,y,i=0;
  94. x=r%10;                //個位
  95. y=r/10;                //十位
  96. dula=1;
  97. display(x);
  98.   dula=0;
  99. P1=0x00;
  100. wela=1;
  101. P1=0x01;
  102. wela=0;
  103. delay(5);
  104. dula=1;
  105. display(y);
  106. dula=0;
  107. P1=0x00;
  108. wela=1;
  109. P1=0x02;
  110. wela=0;
  111. delay(5);
  112. }
  113.   // **********鍵盤掃描函數************
  114. void turnkey()
  115. {
  116. flag2=0;               //掃描之前加10減10標志位清零
  117. if(!up)
  118. {
  119. delay(10);       //按鍵消抖 時10ms
  120. if(!up)
  121. {
  122. TR1=1;        //定時器1開始1s定時,用于鍵盤掃描的定時數值加10
  123. while(!up)
  124. {
  125. switch(flag)
  126. {
  127. case 0:break;
  128.
  129. case 1:
  130. display_ns(green_ns);
  131. NS_G=0;
  132. break;
  133.
  134. case 2:
  135. display_ns(yellow_ns);
  136. NS_Y=0;break;
  137. case 3:
  138. display_ew(green_ew);
  139. EW_G=0;
  140. break;
  141.
  142. case 4:
  143. display_ew(yellow_ew);
  144. EW_Y=0;
  145. break;
  146. }
  147. }
  148. while(!up);  //等待按鍵結束
  149. delay(10);   //按鍵消抖   延時10ms
  150. while(!up);
  151. TR1=0;      //定時器1結束
  152. if(count2>=100)
  153. {
  154. flag2=1;
  155. count2=0;
  156. switch(flag2%3)
  157. {
  158. case 0:break;
  159. case 1:
  160. switch(flag)
  161. {
  162. case 0:break;
  163. case 1:
  164. green_ns+=9;
  165. if(green_ns>99)
  166. green_ns=0;
  167. break;
  168. case 2:break;
  169. case 3:
  170. green_ew+=9;
  171. if(green_ew>99)
  172. green_ew=0;
  173. break;
  174. case 4:break;
  175. }
  176. break;
  177. case 2:
  178. switch(flag)
  179. {
  180. case 0:break;
  181. case 1:
  182. green_ns-=9;
  183. if(green_ns<=0)
  184. {
  185. green_ns=99;
  186. }
  187. break;
  188. case 2:break;
  189. case 3:
  190. green_ew-=9;
  191. if(green_ew<=0)
  192. {
  193. green_ew=99;
  194. }
  195. break;
  196. case 4:break;
  197. }
  198. break;
  199. }
  200. }
  201. switch(flag)              //短按鍵加一
  202. {
  203. case 0:break;
  204. case 1:
  205. //南北綠燈加一
  206. green_ns++;
  207. if(green_ns==100)
  208. green_ns=0;
  209. red_ew=green_ns+yellow_ns;
  210. break;
  211. case 2:
  212. //南北黃燈加一
  213. yellow_ns++;
  214. if(yellow_ns==10)
  215. yellow_ns=0;
  216. red_ew=green_ns+yellow_ns;
  217. break;
  218. case 3:
  219. //東西綠燈加一
  220. green_ew++;
  221. if(green_ew==100)
  222. green_ew=0;
  223. red_ns=green_ew+yellow_ew;
  224.   break;
  225. case 4:
  226. //東西黃燈處理加一
  227. yellow_ew++;
  228. if(yellow_ew==10)
  229. yellow_ew=0;
  230. red_ns=green_ew+yellow_ew;
  231. break;
  232. }
  233. }
  234. }
  235. if(!down)
  236. {
  237. delay(10);       //按鍵消抖   延時10ms
  238. if(!down)
  239. {
  240. TR1=1;        //定時器1開始計時
  241. while(!down)
  242. {
  243. switch(flag)
  244. {
  245. case 0:break;
  246. case 1:
  247. display_ns(green_ns);
  248. NS_G=0;
  249. break;
  250. case 2:
  251. display_ns(yellow_ns);
  252. NS_Y=0;
  253. break;
  254. case 3:
  255. display_ew(green_ew);
  256. EW_G=0;
  257. break;
  258. case 4:
  259. display_ew(yellow_ew);
  260. EW_Y=0;
  261. break;
  262. }
  263. }
  264. while(!down);   //等待按鍵結束
  265. delay(10);      //按鍵消抖   延時10ms
  266. while(!down);
  267. TR1=0;          //定時器1結束計時
  268. if(count2>=100)
  269. {
  270. flag2=2;
  271. count2=0;
  272. switch(flag2%3)
  273. {
  274. case 0:break;
  275. case 1:
  276. switch(flag)
  277. {
  278. case 0:break;
  279. case 1:
  280. green_ns+=9;
  281. if(green_ns>99)
  282. green_ns=0;
  283. break;
  284. case 2:
  285. break;
  286. case 3:
  287. green_ew+=9;
  288. if(green_ew>99)
  289. green_ew=0;
  290. break;
  291. case 4:
  292. break;
  293. }
  294. break;
  295. case 2:
  296. switch(flag)
  297. {
  298. case 0:break;
  299. case 1:
  300. green_ns-=9;
  301. if(green_ns<=0)
  302. {
  303. green_ns=99;
  304. }
  305. break;
  306. case 2:break;
  307.               case 3:
  308.           green_ew-=9;
  309.               if(green_ew<=0)
  310.             {
  311.           green_ew=99;
  312.            }
  313.           break;
  314.         case 4:break;
  315.       }
  316.     break;
  317.          }
  318.      }
  319. switch(flag)               //短按鍵減一
  320.             {
  321.    case 0:break;
  322.    case 1:                //南北綠燈減一
  323.   green_ns--;
  324.      if(green_ns==255)
  325.                 {
  326.   green_ns=99;
  327.        }
  328. red_ew=green_ns+yellow_ns;
  329.       break;
  330.      case 2:                //南北黃燈減一
  331.     yellow_ns--;
  332.             if(yellow_ns==255)
  333.       yellow_ns=9;
  334.       red_ew=green_ns+yellow_ns;
  335.      break;
  336.    case 3:
  337.                green_ew--;
  338.                   if(green_ew==255)
  339.       green_ew=99;
  340.      red_ns=green_ew+yellow_ew;
  341.      break;
  342.    case 4:                //東西黃燈減一
  343.    yellow_ew--;
  344.          if(yellow_ew==255)
  345.    {
  346. yellow_ew=9;
  347.     }
  348. red_ns=green_ew+yellow_ew;
  349.       break;
  350.    }
  351. }
  352. }
  353.   }  //*************閃爍顯示函數*****************
  354. void show()
  355. {
  356.       switch(count/17)                   //1秒 亮3次滅3次
  357.     {
  358.   case 0:
  359.       switch(flag)
  360.       {
  361.       case 0:break;
  362.          case 1:
  363.       display_ns(green_ns);
  364.          break;
  365.     case 2:
  366.       display_ns(yellow_ns);
  367.         break;
  368.     case 3:
  369.       display_ew(green_ew);
  370.         break;
  371.      case 4:
  372.      display_ew(yellow_ew);
  373.         break;
  374.     }
  375.     break;
  376.     case 1:break;
  377.    case 2:
  378.    switch(flag)
  379.     {
  380.     case 0:break;
  381.       case 1:
  382.        display_ns(green_ns);
  383.        break;
  384.     case 2:
  385.     display_ns(yellow_ns);
  386.       break;
  387.        case 3:
  388.     display_ew(green_ew);
  389.        break;
  390.     case 4:
  391. display_ew(yellow_ew);
  392.       break;
  393.        }
  394.     break;
  395.    case 3:break;
  396.    case 4:
  397.   switch(flag)
  398.       {
  399.     case 0:break;
  400.      case 1:
  401.      display_ns(green_ns);
  402.         break;
  403.     case 2:
  404.       display_ns(yellow_ns);
  405.       break;
  406.       case 3:
  407.        display_ew(green_ew);
  408.      break;
  409.      case 4:
  410.    display_ew(yellow_ew);
  411.        break;
  412.   }
  413.     break;
  414.     }
  415. }
  416.    //***************主函數*********************
  417. void main()
  418. {
  419.   Inital();                //初始化函數
  420.    while(1)
  421. {
  422.   if(flag==0)
  423.     {
  424.   display_ns(snorth);
  425.     display_ew(ewest);
  426.   }
  427.    else
  428. if(flag!=0)
  429.   {
  430.     turnkey();       // 鍵盤掃描函數
  431.                                    show();
  432.        //閃爍顯示函數
  433. }
  434.    }
  435. }
  436.   //*************定時器0中斷函數**************
  437.    void time0() interrupt 1
  438. {
  439. TH0=0xD8;               //定時時間為10ms
  440.   TL0=0xF0;
  441.    count++;
  442.    if(count==100)
  443.   //定時時間為1s
  444.    {
  445. count=0;
  446. if(flag==0)
  447.    {
  448. snorth--;
  449.     //南北數字減1
  450.   ewest--;
  451.     //東西數字減1
  452.   if(snorth==0)
  453.      {
  454.     ding_ns++;
  455.     //南北下一狀態處理
  456.   switch(ding_ns%3)
  457.       {
  458.    case 0: snorth=green_ns;
  459.       NS_R=1;
  460.       NS_G=0;
  461.       NS_Y=1;
  462.         break;
  463.     case 1: snorth=yellow_ns;
  464.         NS_R=1;
  465.       NS_G=1;
  466.      NS_Y=0;
  467.       break;
  468.      case 2: snorth=red_ns;
  469.       NS_R=0;
  470.       NS_G=1;
  471.     NS_Y=1;
  472.       break;
  473.        }
  474.   }
  475.    if(ewest==0)
  476. {
  477.      ding_ew++;
  478.         //東西下一狀態處理
  479. switch(ding_ew%3)
  480.    {
  481.   case 0:ewest=red_ew;
  482.    EW_R=0
  483. EW_G=1;
  484. EW_Y=1;
  485. break;
  486. case 1:ewest=green_ew;
  487. EW_R=1;
  488.   EW_G=0;
  489. EW_Y=1;
  490. break;
  491. case 2: ewest=yellow_ew;
  492. EW_R=1;
  493. EW_G=1;
  494. EW_Y=0;
  495. break;
  496.     }
  497.    }
  498. }
  499.   }
  500.    }  //*********外部中斷處理函數(設置鍵)************
  501. void int0() interrupt 0
  502. {
  503. EA=0;        //關中斷
  504.   if(!set)
  505.     {
  506. delay(10);    //設置鍵消抖  10ms
  507.   if(!set)
  508.     {
  509.   NS_R=1;
  510. NS_G=1;
  511. NS_Y=1;
  512. EW_R=1;
  513. EW_G=1;
  514. EW_Y=1;
  515. flag++;
  516. }
  517. while(!set);
  518. delay(10);
  519.   while(!set);
  520.      switch(flag)
  521.     {
  522.   case 0:break;
  523.      case 1:
  524.        NS_R=1;
  525. //南北發光二極管
  526.     NS_G=0;
  527.    NS_Y=1;
  528.        EW_R=1;
  529. //東西發光二極管
  530.   EW_G=1;
  531.     EW_Y=1;
  532. display_ns(green_ns);
  533.    break;
  534. case 2:
  535.   NS_R=1;
  536.      //南北發光二極管
  537.    NS_G=1;
  538. NS_Y=0;
  539.       EW_R=1;
  540.        //東西發光二極管
  541.    EW_G=1;
  542.   EW_Y=1;
  543.      display_ns(yellow_ns);
  544.       break;
  545.      case 3:
  546.       NS_R=1;
  547.        //南北發光二極管
  548.    NS_G=1;
  549.     NS_Y=1;
  550.         EW_R=1;
  551.       //東西發光二極管
  552. EW_G=0;
  553. EW_Y=1;
  554. display_ew(green_ew);
  555.      break;
  556.    case 4:
  557.   NS_R=1;
  558.   //南北發光二極管
  559.   NS_G=1;
  560. NS_Y=1;
  561.   EW_R=1;
  562.           //東西發光二極管
  563.   EW_G=1;
  564.        EW_Y=0;
  565.   display_ew(yellow_ew);
  566.       break;
  567.      }
  568.     if(flag==5)
  569.     {
  570.    flag=0;
  571.     //改值后的初始化紅綠燈狀態和數碼管數字
  572.    snorth=green_ns;
  573.   ewest=red_ew;
  574.     NS_R=1;
  575.    NS_G=0;
  576.      NS_Y=1;
  577.        EW_R=0;
  578.    EW_G=1;
  579.    EW_Y=1;
  580.    ding_ns=0;
  581.     ding_ew=0;
  582.     }
  583.   }
  584.     EA=1;
  585.   //開中斷
  586.    }
  587. //***********定時器1中斷函數****************
  588. void time1() interrupt 3
  589. {
  590.    TH1=0xD8;
  591. TL1=0xF0;
  592.            count2++;
  593. }         紅
  594. #include<reg52.h>
  595.   #define uint unsigned int
  596.    #define uchar unsigned char
  597. sbit  AA=P2^2;   //   南北紅
  598. sbit  BB=P2^3;   //   南北黃
  599. sbit  CC=P2^4;   //   南北綠
  600. sbit  DD=P2^5;  //    東西紅
  601. sbit  EE=P2^6;  //    東西黃
  602. sbit  FF=P2^7;  //    東西綠
  603.   void delay(uint z);
  604.    void main()
  605. {
  606. while(1)
  607.    {
  608.     AA=0;
  609.   BB=0;
  610.     CC=0;
  611.   DD=0;
  612.     EE=0;
  613.   FF=0;
  614.     delay(500);
  615.    AA=1;
  616.   BB=1;
  617.    CC=1;
  618. DD=1;
  619.    EE=1;
  620.   FF=1;
  621.       delay(500);
  622.       }
  623.    }
  624. void delay(uint z)
  625. {
  626.   uint x,y;
  627.    for(x=z;x>0;x--)
  628. for(y=110;y>0;y--);
  629. }    數碼管顯示檢測程序
  630. #include<reg52.h>
  631.   #define uchar unsigned char
  632.   #define uint unsigned int
  633.   uchar count=0;
  634.    ucharcount2=0,green_ns=60,
  635. green_ew=30,red_ns=34,red_ew=64,
  636. yellow_ns=4,yellow_ew=4;//南北綠燈亮60 東西綠燈30 南北紅燈34 東西紅燈64 南北黃燈4 東西黃燈4
  637. uchar ding_ns=0,ding_ew=0,flag=0,snorth=60,ewest=64;   //計數到0后的處理,開始南北綠燈亮的時間,東西紅燈亮的時間
  638. void delay(uint z);
  639. void display(uchar s);
  640.    sbit LED_EW_0=P2^0; //數碼管 位選段
  641. sbit LED_EW_1=P2^1;
  642. sbit LED_NS_0=P2^2;
  643. sbit LED_NS_1=P2^3;
  644. unsigned char code SEG7[10]=
  645. {  0xC0,/*0*/ // 共陽數碼管  0xF9,/*1*/  0xA4,/*2*/  0xB0,/*3*/ 0x99,/*4*/  0x92,/*5*/ 0x82,/*6*/ 0xF8,/*7*/ 0x80,/*8*/0x90,/*9*/  };
  646.    void delay(uint z)                                          //1ms
  647. {
  648. uint x,y;
  649.    for(x=z;x>0;x--)
  650. for(y=110;y>0;y--);
  651.   }
  652.   void display(uchar s)       //數碼管顯示程序
  653.   {
  654.     P1=SEG7[s];
  655. }
  656.   void main()
  657.    {
  658. while(1)
  659. {
  660.       LED_EW_0=1;
  661.     LED_EW_1=1;
  662. LED_NS_0=1;
  663.    LED_NS_1=1;
  664.   P1=0x00;
  665.    }
  666. }
  667. }
主站蜘蛛池模板: 国产天天操| www.天堂av| 四虎8848 | 亚洲一区二区在线 | 国产探花视频在线观看 | 日韩毛片网站 | 黄色片网站视频 | 亚洲香蕉视频 | 欧美午夜理伦三级在线观看 | av片在线观看 | 色综合久久天天综合网 | 国产理论在线观看 | 天天综合色 | 精品久久一区二区 | 黄色片中文字幕 | 国产亚洲视频在线观看 | 一级片在线免费观看 | 他揉捏她两乳不停呻吟动态图 | 婷婷综合网 | 免费观看全黄做爰视频 | 日韩在线视频网站 | 久久久网 | 黄色大片在线 | 午夜黄色大片 | 国产性hd| 欧美一区二区免费 | 中文字幕按摩做爰 | 国产一区二区三区在线 | 色天堂影院 | 亚洲www| 91久久综合亚洲鲁鲁五月天 | 日韩a级片 | 日韩福利片 | 欧美激情区 | 国产视频一区二区在线 | 国产精品成人网 | 亚洲一区二区三区在线播放 | 91日韩欧美 | 网站av | 在线播放中文字幕 | 久久怡红院|
