查看: 9434|回復: 0
IAR for ARM "Error[Pe147]" and "Error[Pe337]" solution
ID:82083 發表于 2015-6-9 02:00 | 顯示全部樓層 |閱讀模式
今天升級了一下IAR,發現之前編譯通過的程序報了很多類似的錯誤:Error[Pe147]: declaration is incompatible with "__nounwind__interwork __softfp unsigned long __get_PSP(void)"
(declared at linexx\CMSIS\CM3\CoreSupport\core_cm3.h)
報錯不約而同的指向了core_cm3.h這個文件。
百度了一下才知道:core_cm3.h文件太老了,與新版本的IAR6.5不兼容。
在IAR官網也找到了一篇描述相關問題的文章:
Problem
There is an issue with older versions of CMSIS and IAREmbedded Workbench for ARM (EWARM) version 6.20.1 and later. Thismay lead to build errors with CMSIS projects.
Theerrors are for example "Error[Pe147]" and "Error[Pe337]".Most ofthe errors comes from a CMSIS header file named core_cm3.h orsimilar.
緊接著也給出了具體辦法:
Solutions
Solution 1
Copya CMSIS based project from the present version, and use thatproject as the base to where you application is added.
Solution 2
Seethe release notes for the C/C++ Compiler (link to the right):
http://supp.iar.com/FilesPublic/UPDINFO/005832/arm/doc/infocenter/iccarm.ENU.html
Seethe chapter "A special note on CMSIS integration", specially thepart that starts with "However, ...".
Please note that excluding the CMSIS files from the exampleprojects, some functions required by the examples may disappear. Insuch a situation, just changing the include paths and excludingsome source files is not enough to fix the problem. If so,functions has to be moved from excluded files (likesystem_stm32f10x.c) to the source in the project in order to buildit.
Background
Thecompiler that comes with EWARM 6.20.1 and later has got support formore intrinsics than previous versions, which leads to anincompatibility issue with CMSIS source code that is included inprojects.
Theessence of the adjustment suggested in the release notes is to"remove" the CMSIS source code included in the project and insteaduse the CMSIS source code that is installed in EWARM, in the"arm\CMSIS" directory. Turn on
CMSIS usage in"Project>Options...>GeneralOptions>LibraryConfiguration>Use CMSIS".
Note that some of the CMSISexample projects in EWARM 6.20.1were affectedby the problem discussed above. This has been corrected inlater versions.
查了一下,網上也有類似解決方案的:
1,把老的core_cm3.h去掉,刪除,或者改成core_cm3.h.old。
2,Project -> Options -> General Options -> LibraryConfiguration -> Use CMSIS,右下角的選項中選擇 use CMSIS。
然后默默把core_cm3.h改為了core_cm3.h.old,勾選useCMSIS
0errors,0warnings
主站蜘蛛池模板: 国产精品一 | 亚洲一区二区三区在线播放 | 国产精品久久久国产盗摄 | 亚色视频 | 少妇一级淫片免费看 | 中文在线字幕观看 | 三级黄色在线观看 | 日产av在线 | 日韩高清一区 | 久久久97 | 亚洲三级黄色片 | av高清不卡 | 亚洲天堂一区 | 天天干夜夜草 | 欧美女同视频 | 在线播放黄色 | 综合网久久 | 国产视频一区二区在线 | 亚洲视频区 | 国产精品一品二区三区的使用体验 | 视色av| 91蜜桃视频 | 久久久久久久久国产 | 亚洲免费黄色 | 欧美综合激情 | 久久久久毛片 | 午夜爱| 一区二区三区视频 | 国产精品毛片久久久久久久 | 亚洲欧美精品一区 | 国产精品手机在线 | 亚洲天堂免费视频 | 亚洲免费婷婷 | 国产一级二级视频 | 久久少妇视频 | 国产精品久久免费 | 97精品超碰一区二区三区 | 99热99re6国产在线播放 | 欧美日韩国产在线播放 | 国产免费观看视频 | 四虎1515|
