查看: 4159|回復: 5
循跡小車程序
ID:83710 發表于 2015-6-23 23:53 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit IN1=P2^0;
sbit ENA=P2^1;
sbit IN2=P2^2;
sbit IN4=P2^3;
sbit ENB=P2^4;
sbit IN3=P2^5;
sbit hw1=P1^0;
sbit hw2=P1^1;
sbit hw3=P1^2;
sbit hw4=P1^3;
uchar PWM1=0 ;    //**右邊電機的占空比**//
uchar PWM2=0 ;    //**左邊電機的占空比**//
uchar num=0;        //**定時器中斷計數器**//
uchar flag;
void init()
    TMOD=0x01;
        TH0=(65536-50)/256;
        TL0=(65536-50)%256;
        EA=1;
        ET0=1;
        TR0=1;
        IN1=0;
        IN2=0;
        IN3=0;
        IN4=0;
     init();
                 if(hw1||hw2||hw3||hw4)//如果檢測到信號
                             if(hw1&&hw2&&hw3&&hw4)
                                     ENA=0;
                                         ENB=0;
                                 if(hw1&&!hw2&&!hw3&&!hw4)
                                                 IN1=1;
                                                 IN2=0;
                                                 IN3=1;
                                                 IN4=0;
                                                 PWM1=0;
                                                 PWM2=15;
                                                 flag=1;
                                 if(!hw1&&hw2&&!hw3&&!hw4)
                                             IN1=1;
                                                 IN2=0;
                                                 IN3=1;
                                                 IN4=0;
                                                 PWM1=0;
                                                 PWM2=13;
                                                 flag=2;
                                 if(!hw1&&!hw2&&hw3&&!hw4)
                                            IN1=1;
                                            IN2=0;
                                            IN3=1;
                                                IN4=0;
                                                PWM1=13;
                                                PWM2=0;
                                                flag=3;
                                 if(!hw1&&!hw2&&!hw3&&hw4)
                                             IN1=1;
                                                 IN2=0;
                                                 IN3=1;
                                                 IN4=0;
                                                 PWM1=15;
                                                 PWM2=0;
                                                 flag=4;
                 else  //如果檢測不到信號
                       switch(flag)
                              case 1:
//                                                            IN1=1;
//                                                         IN2=0;
//                                                         IN3=1;
//                                                         IN4=0;
//                                                         PWM1=10;
//                                                         PWM2=5;
                                                 IN1=0;
                                                 IN2=1;
                                                 IN3=1;
                                                 IN4=0;
                                                 PWM1=12;
                                                 PWM2=12;
                                                         //flag=0;
                                                }        break;
                              case 2:
                                                            IN1=1;
                                                         IN2=0;
                                                         IN3=1;
                                                         IN4=0;
                                                         PWM1=8;
                                                         PWM2=8;
                                                         flag=0;
                                                }         break;
                              case 3:
                                                            IN1=1;
                                                         IN2=0;
                                                         IN3=1;
                                                         IN4=0;
                                                         PWM1=8;
                                                         PWM2=8;
                                                         flag=0;
                                                }        break;
                              case 4:
                                                 IN1=1;
                                                 IN2=0;
                                                 IN3=0;
                                                 IN4=1;
                                                 PWM1=12;
                                                 PWM2=12;
                                                        // flag=0;
                                                }          break;
                              default:
                                                            IN1=1;
                                                         IN2=0;
                                                         IN3=1;
                                                         IN4=0;
                                                         PWM1=12;
                                                         PWM2=12;
void timer0() interrupt 1
     TH0=(65536-50)/256;
         TL0=(65536-50)%256;
         num++;
         if(num>=40)num=0;
         if(num<PWM1)ENA=1;
         else ENA=0;
         if(num<PWM2)ENB=1;
         else ENB=0;
ID:235166 發表于 2017-9-24 12:49 | 顯示全部樓層
                                      ENA=0;
                                          ENB=0;
                                                  IN1=1;
                                                  IN2=0;
                                                  IN3=1;
                                                  IN4=0;
                                                  PWM1=0;
                                                  PWM2=15;
                                                  flag=1;
樓主你好,請問這段可否給我細講一下,看到這兒就有點不懂了,我正在寫小車PWM程序,萬分感謝。
ID:228550 發表于 2017-9-10 18:22 | 顯示全部樓層
未接到信號的由哪幾種情況,可以詳細說明一下嗎
ID:219135 發表于 2017-7-12 15:45 | 顯示全部樓層
學習學習
ID:142243 發表于 2016-10-12 21:54 | 顯示全部樓層
新手,不知道怎么接線
ID:88399 發表于 2015-8-15 19:31 | 顯示全部樓層
在做小車,來學習~~~~~
主站蜘蛛池模板: www.黄色片 | 国产美女精品 | 狠狠干影院 | 一区二区影院 | 美日韩在线视频 | 亚洲美女一区 | 国产精品偷乱一区二区三区 | 日本三级大片 | 日韩成人中文字幕 | 亚洲欧美视频 | 欧美亚洲国产日韩 | 色噜噜狠狠一区二区三区 | 亚洲国产精品久久久 | 伊人干综合 | www.99色 | 久草福利资源 | 日韩专区在线观看 | 午夜成人在线视频 | 福利视频在线 | 国产中文字幕一区 | 成人免费激情视频 | 午夜激情视频 | 午夜国产在线观看 | 国产理论在线观看 | 一级片aa| 亚洲精品黄 | 天堂成人在线 | 国产成人在线免费观看 | 欧美日韩国产片 | 久久久亚洲精品视频 | 国产视频一区在线 | 国产欧美综合一区二区三区 | a级片免费| 亚洲视频不卡 | www.久久久久 | 久久精品国产一区二区 | 国产精品成人免费一区久久羞羞 | 国产在线小视频 | 欧美亚洲 | 亚洲欧美综合 | 黄色一区二区三区 |
