查看: 4033|回復: 1
STM32 驅動美新加速度傳感器MXC6202(模擬IIC)
ID:85764 發表于 2015-7-16 23:59 | 顯示全部樓層 |閱讀模式
                        參加了美新杯MEMS應用大賽,之前剛學過STM32,就用它來練習練習。我用的是2.0的固件庫
1.模擬IIC文件
iic_driver.h文件
宏定義模擬IIC要用到的管腳和說明模擬IIC函數
PB0模擬IIC SCL管腳,PB1模擬IIC SDA管腳
#ifndef __I2C_Driver_H
#define __I2C_Driver_H
#include "stm32f10x_lib.h"
#defineSCL_H        GPIOB->BSRR =GPIO_Pin_0 //模擬IIC時鐘線置高
#defineSCL_L        GPIOB->BRR  = GPIO_Pin_0 //模擬IIC時鐘線置低
#defineSDA_H        GPIOB->BSRR = GPIO_Pin_1 //模擬IIC數據線置高
#defineSDA_L        GPIOB->BRR  =GPIO_Pin_1  //模擬IIC數據線置低
#defineSCL_read     GPIOB->IDR  &GPIO_Pin_0  //讀到模擬IIC時鐘線上電平
#defineSDA_read     GPIOB->IDR  &GPIO_Pin_1   //讀到模擬IIC時數據上電平
void I2C_GPIO_Config(void);  //模擬IIC的端口配置
bool iic_write(void);  //IIC寫命令函數
void iic_read(void);  //IIC讀數據函數
voidgetdata(void);   //提取加速度值函數
void I2C_delay(void);  //模擬IIC時的延時函數
void Delay_nms(u16 n);
#endif
iic_driver.c文件
模擬IIC時序文件
#include "iic_driver.h"
u8  table[4],datax,datay;
u16   datamx,datamy;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_OD;
  GPIO_Init(GPIOB,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
   u8 i=5;//這里可以優化速度 ,經測試最低到5還能寫入
   while(i)
    i--;
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)returnFALSE; //SDA線為低電平則總線忙,退出
SDA_L;
I2C_delay();
if(SDA_read) returnFALSE; //SDA線為高電平則總線出錯,退出
SDA_L;
I2C_delay();
return TRUE;
void I2C_Stop(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SDA_H;
I2C_delay();
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
bool I2C_WaitAck(void)   //返回為:=1有ACK,=0無ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
     SCL_L;
     return FALSE;
SCL_L;
return TRUE;
void I2C_SendByte(u8 SendByte) //數據從高位到低位//
    u8i=8;
   while(i--)
       SCL_L;
       I2C_delay();
     if(SendByte&0x80)
       SDA_H;
       SDA_L;
       SendByte<<=1;
       I2C_delay();
  SCL_H;
       I2C_delay();
    SCL_L;
u8 I2C_RadeByte(void)  //數據從高位到低位//
    u8i=8;
    u8ReceiveByte=0;
   SDA_H;
   while(i--)
     ReceiveByte<<=1;
     SCL_L;
     I2C_delay();
   SCL_H;
     I2C_delay();
     if(SDA_read)
       ReceiveByte|=0x01;
    SCL_L;
    returnReceiveByte;
I2C_Start();//開始
I2C_SendByte(0x20);//寫入從寫設備MXC62022地址
if(I2C_WaitAck()) I2C_SendByte(0x00);//寫入從設備寄叢器首地址
if(I2C_WaitAck()) I2C_SendByte(0x00);//將從設備從低功耗模式喚醒
if(I2C_WaitAck()) I2C_Stop();//停止
Delay_nms(80);
I2C_Start();//開始
I2C_SendByte(0x20);//寫入寫從設備MXC62022地址
if(I2C_WaitAck()) I2C_SendByte(0x01);//寫入讀設備寄叢器首地址
I2C_Start();//開始
I2C_SendByte(0x21);//寫入讀從設備MXC62022地址
if(I2C_WaitAck()==0);returnTRUE;
void iic_read(void)
table[0]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[1]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[2]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[3]=I2C_RadeByte();I2C_delay();I2C_NoAck();//X高八位
I2C_Stop();//停止
void getdata(void)
datamx=(table[0]<<8)+table[1];
datamx&=0x0fff;
datax=datamx>>4;
datamy=(table[2]<<8)+table[3];
datamy&=0x0fff;
datay=datamy>>4;
2,數碼管顯示文件
led.h文件
用8個數碼管顯示讀到的加速度X,Y軸值
段選和位選由同一個引腳輸出,通過鎖存器協調顯示
#ifndef __LED_H
#define __LED_H
段選和位選鎖存器鎖存管腳定義
#define  D_LE0   GPIO_ResetBits(GPIOA,GPIO_Pin_6); //數碼管段控制位為0
#define  D_LE1   GPIO_SetBits(GPIOA,GPIO_Pin_6); //數碼管段控制位為1
#define  W_LE0   GPIO_ResetBits(GPIOA,GPIO_Pin_7); //數碼管位控制位為0
#define  W_LE1   GPIO_SetBits(GPIOA,GPIO_Pin_7); //數碼管位控制位為1
void Delay_nus(u16 m);  //延時函數
void INIT_LedGpio(void);
void LED(void);   //LED閃爍
void display(u8 datax,u8 datay); //數碼管顯示加速度計數據
#endif
led.c文件
#include"led.h"
extern u8 datax,datay;
u8tabledate[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰數碼管數據碼值0..9
u8tablecs[10]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//數碼管段選
u8  datas[8];//個、十、百、千位值
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF,ENABLE);//打開用到的gpioF時鐘
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6;//選擇要配置的端口
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;//配置為推免輸出
  GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;//轉換速度
  GPIO_Init(GPIOF,&GPIO_InitStructure);//初始化gpio
  GPIO_ResetBits(GPIOF,GPIO_Pin_6); //先復位
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_All;//選擇要配置的端口
  GPIO_Init(GPIOC,&GPIO_InitStructure);//初始化gpio
  GPIO_ResetBits(GPIOC,GPIO_Pin_All); //先復位
   鎖存器595控制端口配置
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//打開用到的gpioA時鐘
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6|GPIO_Pin_7;//選擇要配置的端口
  GPIO_Init(GPIOA,&GPIO_InitStructure);//初始化gpio
  GPIO_ResetBits(GPIOA,GPIO_Pin_6|GPIO_Pin_7); //先復位
void LED(void)
if(datax<135)
GPIO_ResetBits(GPIOF, GPIO_Pin_6 );//點亮led
//Delay_nms(60);
   GPIO_SetBits(GPIOF, GPIO_Pin_6);//熄滅led
//Delay_nms(60);
void display(u8 x,u8 y)
u8 i;
datas[0]=datax/1000;
datas[1]=datax%1000/100;
datas[2]=datax%100/10;
datas[3]=datax%1000;
datas[4]=datay/1000;
datas[5]=datay%1000/100;
datas[6]=datay%100/10;
datas[7]=datay%1000;
  for(i=0;i<8;i++)
   D_LE1;                   //控制數碼管段數據的74HC573的LE管腳置高
   W_LE1;                   //控制數碼管位的74HC573的LE管腳置高
   GPIOC->ODR=tablecs[ i];              //設置要顯示的位,也就是哪一個數碼管亮
   W_LE0;                   //鎖存位數據,下面送上段數據以后,就顯示出來了
   GPIOC->ODR=tabledate[datas[ i]];        //送要顯示的數據,就是段數據,如顯示0送的是0x3f
   D_LE0;                   //鎖存段數據,數碼管亮一個時間片刻
   Delay_nus(150);             //顯示一個時間片刻,會影響亮度和閃爍性
Delay_nms(100);
u16 i,j;
  for(i=0; i< m; i++)
     for(j=0;j< 72; j++);
void Delay_nms(u16n)
u16 i;
  for(i=0; i< n; i++)
    Delay_nus(1000);
3,主函數
main.h文件
#include"iic_driver.h"
#include"led.h"
void RCC_Configuration(void);
void NVIC_Configuration(void);//中斷和向量表
#endif
main.c文件
#include "main.h"
ErrorStatus HSEStartUpStatus;
int main(void)
  //GPIO_InitTypeDef GPIO_InitStructure;
RCC_Configuration();   //配置時鐘
  NVIC_Configuration();
  I2C_GPIO_Config();
  INIT_LedGpio();
  while (1)
  if(iic_write());
  iic_read();
   getdata();
   display(datax,datay);
   LED();
  RCC_DeInit();//復位rcc寄存器
  RCC_HSEConfig(RCC_HSE_ON);//使能外部晶振
  HSEStartUpStatus =RCC_WaitForHSEStartUp();//等待外部晶振ok
  if(HSEStartUpStatus == SUCCESS)
   FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
   FLASH_SetLatency(FLASH_Latency_2);//設定flash等待周期
   RCC_HCLKConfig(RCC_SYSCLK_Div1);
   RCC_PCLK2Config(RCC_HCLK_Div1);
   RCC_PCLK1Config(RCC_HCLK_Div2);
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
   RCC_PLLCmd(ENABLE);//使能倍頻模塊
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
   while(RCC_GetSYSCLKSource() != 0x08)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);//打開用到的gpioc時鐘
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//打開用到的gpioc時鐘
#ifdef  VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
#endif
ID:58625 發表于 2017-9-24 18:15 | 顯示全部樓層
學習下真的不錯
主站蜘蛛池模板: 亚洲综合二区 | 久久视频在线免费观看 | 欧美日韩在线视频观看 | 99国产视频| 免费黄色小视频 | 国产女人18毛片水18精品 | 日日不卡av| 久久综合五月天 | 亚洲国产精品久久久久久久 | 香蕉视频在线免费看 | 国产毛片在线 | 成人在线免费视频观看 | 91视频精品 | 一区二区在线看 | 中文字幕精品在线 | 日日操夜夜| 免费国产精品视频 | www.一区| 色爽视频 | 成人观看视频 | 簧片在线免费观看 | 日韩欧美专区 | 一级特黄妇女高潮 | 爱情岛论坛av | 香蕉视频免费看 | 色综合小说 | 欧美黑人一区二区三区 | 亚洲69视频| 触手繁殖の地狱3d啪啪 | 91视频成人 | 人成在线| 婷婷视频在线 | 一区二区高清视频 | 成人免费毛片嘿嘿连载视频 | 亚洲精品大片 | 国产成人免费在线 | 中文字幕一区在线观看 | 99一区二区| 91导航 | 色综合视频在线观看 | 日日夜夜操操 |
