查看: 3145|回復: 0
iOS開發之頭像裁剪
ID:85764 發表于 2015-7-18 00:34 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
//  CrapPhotoViewController.h
//  StupidFM
//  Created by 寒竹子 on 15/6/18.
//  Copyright (c) 2015年 寒竹子. All rights reserved.
#import "ParentViewController.h"
@class CrapPhotoViewController;
@protocol CrapPhotoViewControllerDelegate <NSObject>
// 點擊確定完成圖片裁剪的代理方法
- (void)imageCrap:(CrapPhotoViewController *)crapViewController didFinished:(UIImage *)editedImage;
// 點擊取消后的代理方法
- (void)imageCrapDidCancel:(CrapPhotoViewController *)crapViewController;
@end
@interface CrapPhotoViewController : ParentViewController
@property (nonatomic, assign) NSInteger tag;
@property (nonatomic, weak)   id<CrapPhotoViewControllerDelegate> delegate;
@property (nonatomic, assign)  CGRect cropFrame;
// 初始化方法
- (instancetype)initWithImage:(UIImage *)orignalImage
                    cropFrame:(CGRect)cropFrame
              limitScaleRatio:(NSInteger)limitRatio;
@end
//  CrapPhotoViewController.m
//  StupidFM
#import "CrapPhotoViewController.h"
#define Scale_Y          100.0f
#define Boundce_Duration .3f
@interface CrapPhotoViewController ()
@property (nonatomic, strong) UIImage * orignalImage;
@property (nonatomic, strong) UIImage * editedImage;
@property (nonatomic, strong) UIImageView * showImageView;
@property (nonatomic, strong) UIView * overlayView;
@property (nonatomic, strong) UIView * ratioView;
@property (nonatomic, assign) CGRect oldFrame;
@property (nonatomic, assign) CGRect largeFrame;
@property (nonatomic, assign) CGFloat limitRatio;
@property (nonatomic, assign) CGRect lastFrame;
@end
@implementation CrapPhotoViewController
- (instancetype)initWithImage:(UIImage *)orignalImage cropFrame:(CGRect)cropFrame limitScaleRatio:(NSInteger)limitRatio
    if (self = [super init]) {
        self.cropFrame    = cropFrame;
        self.limitRatio   = limitRatio;
        self.orignalImage = orignalImage;
    return self;
* @brief  初始化View
* @param
* @return
- (void)initialView
    self.showImageView = [[UIImageView alloc] initWithFrame:CGRectMake(0, 0, self.width, self.height)];
    [self.showImageView setMultipleTouchEnabled:YES];
    [self.showImageView setUserInteractionEnabled:YES];
    [self.showImageView setImage:self.orignalImage];
    // 縮放適應屏幕
    CGFloat oriWidth = self.cropFrame.size.width;
    CGFloat oriHeight = self.orignalImage.size.height * (oriWidth / self.orignalImage.size.width);
    CGFloat oriX = self.cropFrame.origin.x + (self.cropFrame.size.width - oriWidth) / 2.0f;
    CGFloat oriY = self.cropFrame.origin.y + (self.cropFrame.size.height - oriHeight) / 2.0f;
    self.oldFrame = CGRectMake(oriX, oriY, oriWidth, oriHeight);
    self.lastFrame = self.oldFrame;
    self.showImageView.frame = self.oldFrame;
    self.largeFrame = CGRectMake(0, 0, self.limitRatio * self.oldFrame.size.width, self.limitRatio * self.oldFrame.size.height);
    [self addGestureRecognizers];
    [self.view addSubview:self.showImageView];
    self.overlayView = [[UIView alloc] initWithFrame:self.view.bounds];
    self.overlayView.alpha = .3f;
    self.overlayView.backgroundColor = [UIColor blackColor];
    self.overlayView.userInteractionEnabled = NO;
    self.overlayView.autoresizingMask = UIViewAutoresizingFlexibleHeight | UIViewAutoresizingFlexibleWidth;
    [self.view addSubview:self.overlayView];
    self.ratioView = [[UIView alloc] initWithFrame:self.cropFrame];
    self.ratioView.layer.borderColor = [UIColor redColor].CGColor;
    self.ratioView.layer.borderWidth = 2.0f;
    self.ratioView.autoresizingMask = UIViewAutoresizingNone;
    [self.view addSubview:self.ratioView];
    [self overlayClipping];
- (void)initControlBtn {
    UIButton *cancelBtn = [[UIButton alloc] initWithFrame:CGRectMake(0, self.view.frame.size.height - 50.0f, 100, 50)];
    cancelBtn.backgroundColor = [UIColor clearColor];
    cancelBtn.titleLabel.textColor = [UIColor whiteColor];
    [cancelBtn setTitle:@"取消" forState:UIControlStateNormal];
    [cancelBtn.titleLabel setFont:[UIFont fontWithName:@"Arial Unicode MS" size:16.0f]];
    [cancelBtn.titleLabel setTextAlignment:NSTextAlignmentCenter];
    [cancelBtn.titleLabel setLineBreakMode:NSLineBreakByWordWrapping];
    [cancelBtn setTitleEdgeInsets:UIEdgeInsetsMake(5.0f, 5.0f, 5.0f, 5.0f)];
    [cancelBtn addTarget:self action:@selector(cancelAction:) forControlEvents:UIControlEventTouchUpInside];
    [self.view addSubview:cancelBtn];
    // 完成
    UIButton *confirmBtn = [[UIButton alloc] initWithFrame:CGRectMake(self.view.frame.size.width - 100.0f, self.view.frame.size.height - 50.0f, 100, 50)];
    confirmBtn.backgroundColor = [UIColor clearColor];
    confirmBtn.titleLabel.textColor = [UIColor whiteColor];
    [confirmBtn setTitle:@"確定" forState:UIControlStateNormal];
    [confirmBtn.titleLabel setFont:[UIFont fontWithName:@"Arial Unicode MS" size:16.0f]];
    [confirmBtn.titleLabel setTextAlignment:NSTextAlignmentCenter];
    [confirmBtn.titleLabel setLineBreakMode:NSLineBreakByWordWrapping];
    [confirmBtn.titleLabel setNumberOfLines:0];
    [confirmBtn setTitleEdgeInsets:UIEdgeInsetsMake(5.0f, 5.0f, 5.0f, 5.0f)];
    [confirmBtn addTarget:self action:@selector(sureAction:) forControlEvents:UIControlEventTouchUpInside];
    [self.view addSubview:confirmBtn];
// 取消
- (void)cancelAction:(UIButton *)btn
    if ([self.delegate respondsToSelector:@selector(imageCrapDidCancel:)]) {
        [self.delegate imageCrapDidCancel:self];
// 確定
- (void)sureAction:(UIButton *)btn
    if ([self.delegate respondsToSelector:@selector(imageCrap:didFinished:)]) {
        [self.delegate imageCrap:self didFinished:self.editedImage];
* @brief  圖片裁剪
* @param
* @return
- (void)overlayClipping
    CAShapeLayer *maskLayer = [[CAShapeLayer alloc] init];
    CGMutablePathRef path = CGPathCreateMutable();
    // 畫左邊的line
    CGPathAddRect(path, nil, CGRectMake(0, 0,
                                        self.ratioView.frame.origin.x,
                                        self.overlayView.frame.size.height));
    // 畫右邊的line
                                        self.ratioView.frame.origin.x + self.ratioView.frame.size.width,
                                        0,
                                        self.overlayView.frame.size.width - self.ratioView.frame.origin.x - self.ratioView.frame.size.width,
    // 畫上邊的line
                                        self.overlayView.frame.size.width,
                                        self.ratioView.frame.origin.y));
    // 畫下邊的line
                                        self.ratioView.frame.origin.y + self.ratioView.frame.size.height,
                                        self.overlayView.frame.size.height - self.ratioView.frame.origin.y + self.ratioView.frame.size.height));
    maskLayer.path = path;
    self.overlayView.layer.mask = maskLayer;
    CGPathRelease(path);
* @brief  添加縮放手勢 和 拖動手勢
* @param
* @return
- (void)addGestureRecognizers
    // 添加縮放手勢
    UIPinchGestureRecognizer * pinch = [[UIPinchGestureRecognizer alloc] initWithTarget:self action:@selector(pinchAction:)];
    [self.view addGestureRecognizer:pinch];
    // 添加拖動手勢
    UIPanGestureRecognizer * pan = [[UIPanGestureRecognizer alloc] initWithTarget:self action:@selector(panAction:)];
    [self.view addGestureRecognizer:pan];
* @brief  縮放手勢事件
* @param
* @return
- (void)pinchAction:(UIPinchGestureRecognizer *)pinch
    UIView * view = self.showImageView;
    if (pinch.state == UIGestureRecognizerStateBegan || pinch.state == UIGestureRecognizerStateChanged) {
        // 通過手勢的縮放系數改變view的transform
        view.transform = CGAffineTransformScale(view.transform, pinch.scale, pinch.scale);
        // 然后將縮放系數置為1
        pinch.scale = 1.0f;
    }else if (pinch.state == UIGestureRecognizerStateEnded) {
        // 縮放結束
        CGRect newFrame = self.showImageView.frame;
        newFrame = [self hanleScaleOverFrame:newFrame];
        newFrame = [self handleBorderOverFlow:newFrame];
        [UIView animateWithDuration:Boundce_Duration animations:^{
            self.showImageView.frame = newFrame;
            self.lastFrame = newFrame;
* @brief  計算縮放后的新的frame
* @param
* @return
- (CGRect)hanleScaleOverFrame:(CGRect)newFrame
    CGPoint oriCenter = CGPointMake(newFrame.origin.x + newFrame.size.width / 2.0f, newFrame.origin.y + newFrame.size.height / 2.0f);
    if (newFrame.size.width < self.oldFrame.size.width) {
        // 設置原始frame
        newFrame = self.oldFrame;
    if (newFrame.size.width > self.largeFrame.size.width) {
        // 超出范圍
        newFrame = self.largeFrame;
    newFrame.origin.x = oriCenter.x - newFrame.size.width / 2.0f;
    newFrame.origin.y = oriCenter.y - newFrame.size.height / 2.0f;
    return newFrame;
* @brief  根據邊框來設置frame
* @param
* @return
- (CGRect)handleBorderOverFlow:(CGRect)newFrame
    // x坐標 計算不能超過裁剪的坐標x
    if (newFrame.origin.x > self.cropFrame.origin.x) {
        newFrame.origin.x = self.cropFrame.origin.x;
    if (CGRectGetMaxX(newFrame) < self.cropFrame.size.width) {
        newFrame.origin.x = self.cropFrame.size.width - newFrame.size.width;
    // y坐標
    if (newFrame.origin.y > self.cropFrame.origin.y) {
        newFrame.origin.y = self.cropFrame.origin.y;
    if (CGRectGetMaxY(newFrame) < self.cropFrame.origin.y + self.cropFrame.size.height) {
        newFrame.origin.y = self.cropFrame.origin.y + self.cropFrame.size.height - newFrame.size.height;
    if (self.showImageView.frame.size.width > self.showImageView.frame.size.height && newFrame.size.height <= self.cropFrame.size.height) {
        newFrame.origin.y = self.cropFrame.origin.y + (self.cropFrame.size.height - newFrame.size.height) / 2.0f;
    return newFrame;
* @brief  拖動手勢
* @param
* @return
- (void)panAction:(UIPanGestureRecognizer *)pan
    if (pan.state == UIGestureRecognizerStateBegan || pan.state == UIGestureRecognizerStateChanged) {
        CGFloat absCenterX = self.cropFrame.origin.x + self.cropFrame.size.width / 2.0f;
        CGFloat absCenterY = self.cropFrame.origin.y + self.cropFrame.size.height / 2.0f;
        CGFloat scaleRatio = self.showImageView.frame.size.width / self.cropFrame.size.width;
        CGFloat acceleratorX = 1 - ABS(absCenterX - view.center.x) / (scaleRatio * absCenterX);
        CGFloat acceleratorY = 1 - ABS(absCenterY - view.center.y) / (scaleRatio * absCenterY);
        CGPoint translation = [pan translationInView:view.superview];
        [view setCenter:(CGPoint){view.center.x + translation.x * acceleratorX, view.center.y + translation.y * acceleratorY}];
        [pan setTranslation:CGPointZero inView:view.superview];
    }else if (pan.state == UIGestureRecognizerStateEnded){
// 得到裁剪后的小圖片
-(UIImage *)getSubImage{
    CGRect squareFrame = self.cropFrame;
    CGFloat scaleRatio = self.lastFrame.size.width / self.orignalImage.size.width;
    CGFloat x = (squareFrame.origin.x - self.lastFrame.origin.x) / scaleRatio;
    CGFloat y = (squareFrame.origin.y - self.lastFrame.origin.y) / scaleRatio;
    CGFloat w = squareFrame.size.width / scaleRatio;
    CGFloat h = squareFrame.size.width / scaleRatio;
    if (self.lastFrame.size.width < self.cropFrame.size.width) {
        CGFloat newW = self.orignalImage.size.width;
        CGFloat newH = newW * (self.cropFrame.size.height / self.cropFrame.size.width);
        x = 0; y = y + (h - newH) / 2;
        w = newH; h = newH;
    if (self.lastFrame.size.height < self.cropFrame.size.height) {
        CGFloat newH = self.orignalImage.size.height;
        CGFloat newW = newH * (self.cropFrame.size.width / self.cropFrame.size.height);
        x = x + (w - newW) / 2; y = 0;
        w = newH; h = newH;
    CGRect myImageRect = CGRectMake(x, y, w, h);
    CGImageRef imageRef = self.orignalImage.CGImage;
    CGImageRef subImageRef = CGImageCreateWithImageInRect(imageRef, myImageRect);
    CGSize size;
    size.width = myImageRect.size.width;
    size.height = myImageRect.size.height;
    UIGraphicsBeginImageContext(size);
    CGContextRef context = UIGraphicsGetCurrentContext();
    CGContextDrawImage(context, myImageRect, subImageRef);
    UIImage* smallImage = [UIImage imageWithCGImage:subImageRef];
    UIGraphicsEndImageContext();
    return smallImage;
- (void)viewDidLoad {
    [super viewDidLoad];
    [self initialView];
    [self initControlBtn];
@end
主站蜘蛛池模板: 亚洲一区在线观看视频 | 国产一区二区久久 | 国产精品美女在线观看 | 一区二区三区久久 | 国产伦精品一区二区三区视频网站 | 99精品网站| 午夜影院在线观看视频 | 一区二区三区视频 | 日韩国产在线观看 | 国产伦精品一区二区免费 | 日韩中文字幕精品 | 狠狠操天天干 | 人人射人人干 | 死神来了4无删减版在线观看 | 日韩三级免费 | 国产精品成人国产乱一区 | 黄色网在线 | 国产二三区 | 欧美一区二区三区免费 | 精品一区二区在线视频 | 欧美性猛交xxxx免费看久久久 | 亚洲精品www久久久久久广东 | 免费一级a毛片 | 欧美a级黄色片 | 欧美色图在线视频 | 超碰91在线| 九色在线播放 | 国产精品一区二区三区四区 | 麻豆成人免费视频 | 亚洲天天 | 高清一级片 | 五月天婷婷基地 | 黄色成人在线视频 | 日韩在线视频免费观看 | 久久黄色录像 | 日韩精品视频在线播放 | 久久黄色大片 | a在线播放| 91视频亚洲 | 日韩不卡一区二区 | 欧美日韩一区二区三区 |
