查看: 8555|回復: 1
MSP430F5529驅動LCD102x64液晶程序及電路圖
ID:89763 發表于 2015-9-12 20:08 | 顯示全部樓層 |閱讀模式
MSP430F5529開發板上的102x64LCD采用的是SPI通信模式,即一種全雙工串行通信模式
參考程序:
#include "msp430F5529.h"
void delay(int ms)
  int i;
  while(ms--)
    for(i=0;i<999;i++);
//        寫數據函數         //
void writedata(unsigned char dat)
  char i,temp;
  P5OUT |=BIT7;     //結束置位
  P5OUT |=BIT6;    //數據輸入模式
  P4OUT &=~BIT3;   //sclk=0
  P7OUT &=~BIT4;    //片選選中
  P3OUT |=0x80;
  for(i=0;i<8;i++)
     temp =dat<<i;
     if((temp & 0x80)==0x80)
            P4OUT |=BIT1;
            P4OUT &=~BIT1;
    __delay_cycles(3);
    P4OUT |=BIT3;     //sclk=1上升沿
     __delay_cycles(3);
    P4OUT &=~BIT3;    //下降沿
  P7OUT |=BIT4;  //釋放片選
//        寫指令函數         //
void writecomd(unsigned char comd)
  char i,temp;
  P5OUT &=~BIT6;    //指令輸入模式并置位
  P4OUT &=~BIT3;
  P3OUT |=0x80;
  for(i=0;i<8;i++)
     temp =comd<<i;
            P4OUT |=BIT1;
            P4OUT &=~BIT1;
    __delay_cycles(3);
    P4OUT |=BIT3;
     __delay_cycles(3);
    P4OUT &=~BIT3;
//       液晶顯示      //
void LCD_XYSet(unsigned char x,unsigned char y)
     LCD_SPISend(0,0xB0|y);           //y的值為0~8
     LCD_SPISend(0,0x10|(x>>4));
     LCD_SPISend(0,0x00|(x&0x0F));
// 顯示   y<8,x<127     //
void LCDdisplay(unsigned char x,unsigned char y)
   writecomd(0xB0|y);
   writecomd(0x10|(x>>4));
   writecomd(0x0F);
//    LCD初始化        //
void LCDinit(void)
   P7DIR |=BIT4+BIT6;             //P7.6為LCD背光燈和LCD_EN使能,1亮 0滅,P7.4為LED_CS片選
   P7OUT |=BIT6;              //點亮背光
   P5DIR |=BIT6+BIT7;         //P5.6為SPI之命令數據切換,P5.7為SPI之LCD_RST液晶復位
   P4DIR |=BIT1+BIT3;        //P4.1為SIMO從設備輸入主設備信號端,P4.3為SCK
   UCSCTL3 |=SELREF__REFOCLK;
   P5OUT &=~(BIT6+BIT7);    //LCD reset  指令輸入
   writecomd(0xAF);         //開顯示
   writecomd(0x8c);         //設置掃描方向。
//  主時鐘設置       //
void MCLKtimer(void)
   __bis_SR_register(SCG0);     //disable the FLL control loop
   UCSCTL0=0X0000;//            //Set lowest possible DCOx,MODxSCG0
   UCSCTL1=DCORSEL_7;           //Select DCO range 24MHz opreation
                               //DCORSEL_x,其中x可選3、4、5、6、7
   UCSCTL3=FLLD_0+731;          //Set DCO Multiplier for 24MHz
                                //(N+1)*FLLRef=Fdco
                                //(731+1)*32768=24MHz
                               //Set FLL DIV =fDCOCLK/2
   /*__bis_SR_register(SCG0);                 //Enable the FLL control loopSCG0
   UCSCTL4 |=SELA__DCOCLK+SELS__XT1CLK+SELM__DCOCLK;//MCLK Source select
   UCSCTL5 |=DIVPA_2;                       //ACLK output divide
   UCSCTL6 |=XT1DRIVE_3+XCAP_0;             //XT1 cap */
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  MCLKtimer();
  P1DIR |=BIT3;
  P4DIR |=BIT7;
  P5OUT &=~BIT7;
  LCDinit();
  LCDdisplay(3,100);
     writedata(0x2F);
     writedata(0x07);
     writedata(0x18);
     writedata(0x2F);
ID:150645 發表于 2016-11-27 22:20 | 顯示全部樓層
......沒反映呀
主站蜘蛛池模板: 黄色一级影片 | 中文字幕免费在线看线人动作大片 | 亚洲123区| 五月天婷婷在线观看 | 国产二区精品 | 国产一区二区久久 | 国产中文字幕在线 | 亚洲第一伊人 | 免费的黄网站 | 亚洲香蕉在线 | 一区二区三区在线免费 | www.粉色视频在线观看 | av播播| 国产精品久久午夜夜伦鲁鲁 | 91av免费在线观看 | 亚洲另类色综合网站 | 一区二区欧美日韩 | 欧美精品一二三 | 91国内精品 | 国产精品欧美在线 | 亚洲欧美日韩另类 | 成人黄色小视频 | 亚洲欧洲在线观看 | 中文字幕欧美激情 | 韩国黄色网址 | 亚洲在线视频观看 | 欧美在线观看一区 | 欧美激情精品 | 欧美成年人视频 | 欧美一区在线视频 | 在线一区二区三区 | 涩涩97 | 免费视频一区二区 | 五月婷婷综合网 | 婷婷久久综合 | 51免费看成人啪啪片 | 日韩在线视频观看 | 成人精品在线视频 | 国产一级片网站 | 国产成人亚洲精品自产在线 | 国产一区在线观看视频 |
