以下代碼參考了網(wǎng)絡(luò)資料, 代碼通過(guò)實(shí)測(cè)驗(yàn)證。
在main.c文件中的相關(guān)代碼:
uint16_t ADC_Value[10][4];
uint16_t Flag_ADC_Finished = 0;
void ADC_Config(void);
ADC_Config();
while (1)
if(Flag_ADC_Finished){
DMA2_Stream0->M0AR = (uint32_t)(&ADC_Value[0][0]);
DMA2_Stream0->NDTR = 40;
DMA_Cmd(DMA2_Stream0, ENABLE);
ADC_Cmd(ADC1, ENABLE);
ADC_SoftwareStartConv(ADC1);
* @brief ADC_Config
* @note This function Configure the ADC peripheral
* 1) Enable peripheral clocks
* 2) Configure ADC Channel 12、8、13、9 pin as analog input
* 3) DMA2_Stream0 channel0 configuration
* 4) Configure ADC1 Channel 12、8、13、9(PC2 PC3 PB0 PB1)
* @param None
* @retval None
void ADC_Config()
GPIO_InitTypeDef GPIO_InitStruct;
ADC_InitTypeDef ADC_InitStruct;
ADC_CommonInitTypeDef ADC_CommonInitStruct;
DMA_InitTypeDef DMA_InitStruct;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
ADC_DeInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
DMA_InitStruct.DMA_Channel = DMA_Channel_0;
DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)(&ADC1->DR);
DMA_InitStruct.DMA_Memory0BaseAddr = (uint32_t)(&ADC_Value[0][0]);
DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStruct.DMA_BufferSize = 40;
DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStruct.DMA_Mode = DMA_Mode_Normal;
DMA_InitStruct.DMA_Priority = DMA_Priority_Low;
DMA_InitStruct.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStruct.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStruct.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStruct.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStruct);
/* DMA2_Stream0 Channel 0 */
DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
PC2: ADC_Channel_12 --> AIW0 (0~5V)
PB0: ADC_Channel_8 --> AIW2 (0~5V)
PC3: ADC_Channel_13 --> AIW4 (0~5V)
PB1: ADC_Channel_9 --> AIW6 (0~5V)
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
GPIO_Init(GPIOC, &GPIO_InitStruct);
/* ADC Common Init **********************************************************/
ADC_CommonInitStruct.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStruct.ADC_Prescaler = ADC_Prescaler_Div6;
ADC_CommonInitStruct.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStruct.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStruct);
/* ADC1 Init ****************************************************************/
ADC_StructInit(&ADC_InitStruct);
ADC_InitStruct.ADC_ScanConvMode = ENABLE;
ADC_InitStruct.ADC_ContinuousConvMode = ENABLE;
ADC_InitStruct.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStruct.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
ADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStruct.ADC_NbrOfConversion = 4; /* for PC2 PC3 PB0 PB1 */
ADC_Init(ADC1,&ADC_InitStruct);
ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_56Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 2, ADC_SampleTime_56Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 3, ADC_SampleTime_56Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 4, ADC_SampleTime_56Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
ADC_DMACmd(ADC1, ENABLE);
在stm32fxxx_it.c文件中的相關(guān)代碼:
extern uint16_t Flag_ADC_Finished;
* @brief This function handles DMA2_Stream0_IRQHandler global interrupt request.
* @param None
* @retval None
void DMA2_Stream0_IRQHandler(void)
if (DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0) != RESET) {
DMA_Cmd(DMA2_Stream0, DISABLE);
DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
ADC_Cmd(ADC1, DISABLE);
Flag_ADC_Finished = 1;
