查看: 2967|回復: 0
php中 數據庫操作類
ID:90084 發表于 2015-9-14 20:41 | 顯示全部樓層 |閱讀模式
由于經常要操作新浪云數據庫,特寫了如下數據庫操作類,留做后續學習使用。
sqlTool.class.php源碼如下
<?php
class sqlTool{
    private  $conn ; // = NULL;
    private  $port ="3**7";
    private  $host = SAE_MYSQL_HOST_M;
    private  $user = "2*wx2*****0";
    private  $password = "ylx5lj101w****mh1l5i4****h5zzm***3yz";
    private  $db =  "app_s***e*";
    public function dblink(){
        $this->conn = mysql_connect($this->host.':'.$this->port,$this->user,$this->password);
        if(!$this->conn){
           die("連接數據庫失敗".mysql_error());
        mysql_select_db($this->db,$this->conn);
        mysql_query("SET names 'UTF8'");
        return $this->conn;  //為了取$this->conn加上的,如不取這個值,可以不用
    //完成select語句
   public function excute_dql($sql){
        $res = mysql_query($sql) or die(mysql_error());
        return $res;
        //完成update,delete,insert
    public function excute_dml($sql){
       $b = mysql_query($sql,$this->conn);
          if(!$b){
                          return 0; //失敗
                    if(mysql_affected_rows($this->conn)>0){
                         return 1; //表示成功
                         return 2; //表示沒有影響到行數
//引用類來操作數據庫
//dml操作
        $sql = "insert into slb (hyh,guige,menfu,kezhong,dlj,dlw,slj,slw,spj,spw) values('D15086003FY','50*50 144*80 府綢','57/58',120,150,140,3,3,8,8)";
        $a = new sqlTool();
        $conn1 = $a->dblink();
       $res = $a->excute_dml($sql);
        if(!$res){
                return 0;
           else if(mysql_affected_rows($conn1)>0){
                    echo "操作成功";  // retrun 1;
            else {
                    return 2;
//dql操作
     $sql = "select * from slb ";
     $b = new sqlTool();
     $b->dblink();
     $res = $b->excute_dql($sql);
     var_dump($res);
     echo "hell";
    while($row = mysql_fetch_row($res)){
        foreach($row as $key=>$val){
           echo "$key-->$val";
        echo "<br/>";
    mysql_free_result($res);
sqlTool_demo.PHP 源碼
<?php
    require_once "sqlTool.class.php";
//引用類來操作數據庫
//dml操作
//  $sql = "insert into slb (hyh,guige,menfu,kezhong,dlj,dlw,slj,slw,spj,spw) values('D15086003FY','50*50 144*80 府綢','57/58',120,150,140,3,3,8,8)";
      $sql = "delete  from slb where hyh = 'D15086003FY'";
        $a = new sqlTool();
        if(!$res){
                return 0;
            else {
                    return 2;
echo "<br>";
//dql操作
     $b = new sqlTool();
   $b->dblink();  //因為前面dml操作$conn1 = $a->dblink();此處可以不要,也可以要
     var_dump($res);
     echo "hell";
           echo "$key-->$val";
        echo "<br/>";
調用演示
主站蜘蛛池模板: 在线观看的av| 久久久夜 | 91精品视频在线播放 | 欧洲精品一区二区 | av四虎| 成人精品免费 | 一级做a爱片性色毛片 | 在线观看黄网站 | 91一级片 | 久久综合久色欧美综合狠狠 | 亚洲黄色小视频 | 伊人天堂网 | 亚洲精品视频免费在线观看 | 国产一级二级三级 | 欧美专区在线 | 免费激情网站 | 国产一区二区三区在线视频 | 狠狠网| 国产一级视频在线观看 | 成人网在线| 成人精品在线观看 | 国产无精乱码一区二区三区 | 久综合| 欧美一级在线观看 | 一级a毛片 | 日韩精品国产精品 | 又黄又爽又色视频 | 国产一级18片视频 | 日韩av毛片 | 国产成人在线免费观看 | 福利视频网址 | 亚洲成人福利 | 99精品视频在线观看 | 超碰成人福利 | 久久精品视频网站 | 91一级片| 日本一级淫片 | 狠狠干综合| 日日干日日射 | 亚洲视频不卡 | 国产高清视频在线播放 |
