;******************** (C) COPYRIGHT 2011 STMicroelectronics
;* File Name
startup_stm32f10x_hd.s
;* Author
: MCD Application Team
;* Version
: V3.5.0
;* Date
: 11-March-2011
;* Description
: STM32F10x High Density
Devices vector table for MDK-ARM
toolchain.
This module performs:
- Set the initial SP
- Set the initial PC ==
Reset_Handler
- Set the vector table entries
with the exceptions ISR address
- Configure the clock system
and also configure the external
SRAM
mounted on STM3210E-EVAL board to be used as
data
memory
(optional, to be enabled by user)
- Branches to __main in the C
library (which eventually
calls
main()).
After Reset the CortexM3
processor is in Thread mode,
priority is Privileged, and
the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu
; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT
PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER
FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR
ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS
ARISING FROM THE
; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF
THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR
PRODUCTS.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; Stack Configuration
; Stack Size (in Bytes)
<0x0-0xFFFFFFFF:8>
Stack_Size
EQU
0x00000400 EQU是代碼替換指令,是使0x00000400變的有意義易讀
AREA
STACK, NOINIT, READWRITE,
ALIGN=3 //定義一個(gè)數(shù)據(jù)段 按8字節(jié)對(duì)齊
;AREA 偽指令用于定義一個(gè)代碼段或數(shù)據(jù)段
NOINIT:指定此數(shù)據(jù)段僅僅保留了內(nèi)存單元,而沒(méi)有將各初始值寫(xiě)入內(nèi)存單元,或者將各個(gè)內(nèi)存單元值初始化為0
Stack_Mem
SPACE Stack_Size
為Stack_Mem 分配連續(xù)的0x00000400
字節(jié)空間,并且初始化為0
__initial_sp
_initial_sp
是個(gè)標(biāo)簽,代表當(dāng)前指令的地址,由匯編器計(jì)算出的,代碼里使用space分配了Stack_Size個(gè)內(nèi)存單元后再在之后加上_initial_sp,后面會(huì)用DCD __initial_sp
在向量表0初始化棧頂?shù)刂罚褂枚褩r(shí)棧頂?shù)刂窚p1恰好是分配的棧區(qū)間
; Heap Configuration
; Heap Size (in Bytes)
<0x0-0xFFFFFFFF:8>
Heap_Size
EQU
0x00000200
AREA
HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem
SPACE
Heap_Size
__heap_limit
PRESERVE8
THUMB
; Vector Table Mapped to Address 0 at Reset
AREA
RESET, DATA,
READONLY 定義一塊數(shù)據(jù)段,只可讀,段名字是RESET
EXPORT
__Vectors
EXPORT:在程序中聲明一個(gè)全局的標(biāo)號(hào)__Vectors,該標(biāo)號(hào)可在其他的文件中引用
EXPORT
__Vectors_End
EXPORT
__Vectors_Size
__Vectors
DCD
__initial_sp
; Top of Stack
__Vectors是個(gè)標(biāo)號(hào)
;該處物理地址值即為 __Vetors 標(biāo)號(hào)所表示的值,
;該地址中存儲(chǔ)__initial_sp所表示的地址值,
DCD (或 DCDU )偽指令用于分配一片連續(xù)的字存儲(chǔ)單元并用偽指令中指定的表達(dá)式初始化。其中,表達(dá)式可以為程序標(biāo)號(hào)或數(shù)字表達(dá)式。
DCD
Reset_Handler
; Reset
Handler
DCD
NMI_Handler
; NMI Handler
DCD
HardFault_Handler
; Hard Fault Handler
DCD
MemManage_Handler
; MPU Fault Handler
DCD
BusFault_Handler
; Bus Fault Handler
DCD
UsageFault_Handler
; Usage
Fault Handler
DCD
0
; Reserved
DCD
0
; Reserved
DCD
0
; Reserved
DCD
0
; Reserved
DCD
SVC_Handler
; SVCall Handler
DCD
DebugMon_Handler
; Debug Monitor Handler
DCD
0
; Reserved
DCD
PendSV_Handler
; PendSV Handler
DCD
SysTick_Handler
; SysTick Handler
; External Interrupts
DCD
WWDG_IRQHandler
; Window Watchdog
DCD
PVD_IRQHandler
; PVD through EXTI Line
detect
DCD
TAMPER_IRQHandler
; Tamper
DCD
RTC_IRQHandler
; RTC
DCD
FLASH_IRQHandler
; Flash
DCD
RCC_IRQHandler
; RCC
DCD
EXTI0_IRQHandler
; EXTI Line 0
DCD
EXTI1_IRQHandler
; EXTI Line 1
DCD
EXTI2_IRQHandler
; EXTI Line 2
DCD
EXTI3_IRQHandler
; EXTI Line 3
DCD
EXTI4_IRQHandler
; EXTI Line 4
DCD
DMA1_Channel1_IRQHandler ;
DMA1 Channel 1
DCD
DMA1_Channel2_IRQHandler ;
DMA1 Channel 2
DCD
DMA1_Channel3_IRQHandler ;
DMA1 Channel 3
DCD
DMA1_Channel4_IRQHandler ;
DMA1 Channel 4
DCD
DMA1_Channel5_IRQHandler ;
DMA1 Channel 5
DCD
DMA1_Channel6_IRQHandler ;
DMA1 Channel 6
DCD
DMA1_Channel7_IRQHandler ;
DMA1 Channel 7
DCD
ADC1_2_IRQHandler
; ADC1 & ADC2
DCD
USB_HP_CAN1_TX_IRQHandler ;
USB High Priority or CAN1 TX
DCD
USB_LP_CAN1_RX0_IRQHandler ; USB Low
Priority or CAN1 RX0
DCD
CAN1_RX1_IRQHandler
; CAN1
RX1
DCD
CAN1_SCE_IRQHandler
; CAN1
SCE
DCD
EXTI9_5_IRQHandler
; EXTI
Line 9..5
DCD
TIM1_BRK_IRQHandler
; TIM1
Break
DCD
TIM1_UP_IRQHandler
; TIM1
Update
DCD
TIM1_TRG_COM_IRQHandler
; TIM1 Trigger and Commutation
DCD
TIM1_CC_IRQHandler
; TIM1
Capture Compare
DCD
TIM2_IRQHandler
; TIM2
DCD
TIM3_IRQHandler
; TIM3
DCD
TIM4_IRQHandler
; TIM4
DCD
I2C1_EV_IRQHandler
; I2C1
Event
DCD
I2C1_ER_IRQHandler
; I2C1
Error
DCD
I2C2_EV_IRQHandler
; I2C2
Event
DCD
I2C2_ER_IRQHandler
; I2C2
Error
DCD
SPI1_IRQHandler
; SPI1
DCD
SPI2_IRQHandler
; SPI2
DCD
USART1_IRQHandler
; USART1
DCD
USART2_IRQHandler
; USART2
DCD
USART3_IRQHandler
; USART3
DCD
EXTI15_10_IRQHandler
; EXTI Line 15..10
DCD
RTCAlarm_IRQHandler
; RTC Alarm
through EXTI Line
DCD
USBWakeUp_IRQHandler
; USB Wakeup from
suspend
DCD
TIM8_BRK_IRQHandler
; TIM8
Break
DCD
TIM8_UP_IRQHandler
; TIM8
Update
DCD
TIM8_TRG_COM_IRQHandler
; TIM8 Trigger and Commutation
DCD
TIM8_CC_IRQHandler
; TIM8
Capture Compare
DCD
ADC3_IRQHandler
; ADC3
DCD
FSMC_IRQHandler
; FSMC
DCD
SDIO_IRQHandler
; SDIO
DCD
TIM5_IRQHandler
; TIM5
DCD
SPI3_IRQHandler
; SPI3
DCD
UART4_IRQHandler
; UART4
DCD
UART5_IRQHandler
; UART5
DCD
TIM6_IRQHandler
; TIM6
DCD
TIM7_IRQHandler
; TIM7
DCD
DMA2_Channel1_IRQHandler ;
DMA2 Channel1
DCD
DMA2_Channel2_IRQHandler ;
DMA2 Channel2
DCD
DMA2_Channel3_IRQHandler ;
DMA2 Channel3
DCD
DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 &
Channel5
__Vectors_End
__Vectors_Size EQU
__Vectors_End - __Vectors 計(jì)算出向量表的大小
AREA
|.text|, CODE, READONLY
//定義一個(gè)代碼段,可讀,段名字是.text 段名若以數(shù)字開(kāi)頭,則該段名需用"|"括起來(lái),如|1_test|。
;定義只讀數(shù)據(jù)段,實(shí)際上是在CODE區(qū),如果在FLASH區(qū)起動(dòng),則 中斷向量起始地址為0X8000000
;;CODE屬性:用于定義代碼段,默認(rèn)為READONLY
; Reset handler
Reset_Handler
是一個(gè)標(biāo)號(hào),相當(dāng)于一個(gè)函數(shù)名,
標(biāo)記一個(gè)函數(shù)的開(kāi)始;利用PROC、ENDP這一對(duì)偽指令把程序段分為若干個(gè)過(guò)程,使程序的結(jié)構(gòu)加清晰
Reset_Handler PROC
EXPORT
Reset_Handler
[WEAK]
IMPORT
__main偽指令用于通知編譯器要使用的標(biāo)號(hào)在其他的源文件中定義
IMPORT
SystemInit
LDR
R0, =SystemInit
BLX
R0
LDR
R0, =__main
BX
R0
ENDP
; Dummy Exception Handlers (infinite loops which can be
modified)
上面這句英語(yǔ)的意思是空的中斷處理函數(shù),他們是無(wú)線循環(huán),這些空的中斷處理函數(shù)和在it.c里面的中斷處理函數(shù)有什么區(qū)別呢????????????????????????
NMI_Handler PROC
EXPORT
NMI_Handler
[WEAK]
B
ENDP
HardFault_Handler\
PROC
EXPORT
HardFault_Handler
[WEAK]
B
ENDP
MemManage_Handler\
PROC
EXPORT
MemManage_Handler
[WEAK]
B
ENDP
BusFault_Handler\
PROC
EXPORT
BusFault_Handler
[WEAK]
B
ENDP
UsageFault_Handler\
PROC
EXPORT
UsageFault_Handler
[WEAK]
B
ENDP
SVC_Handler PROC
EXPORT
SVC_Handler
[WEAK]
B
ENDP
DebugMon_Handler\
PROC
EXPORT
DebugMon_Handler
[WEAK]
B
ENDP
PendSV_Handler PROC
EXPORT
PendSV_Handler
[WEAK]
B
ENDP
SysTick_Handler PROC
EXPORT
SysTick_Handler
[WEAK]
B
ENDP
Default_Handler PROC
EXPORT
WWDG_IRQHandler
[WEAK]
EXPORT
PVD_IRQHandler
[WEAK]
EXPORT
TAMPER_IRQHandler
[WEAK]
EXPORT
RTC_IRQHandler
[WEAK]
EXPORT
FLASH_IRQHandler
[WEAK]
EXPORT
RCC_IRQHandler
[WEAK]
EXPORT
EXTI0_IRQHandler
[WEAK]
EXPORT
EXTI1_IRQHandler
[WEAK]
EXPORT
EXTI2_IRQHandler
[WEAK]
EXPORT
EXTI3_IRQHandler
[WEAK]
EXPORT
EXTI4_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
ADC1_2_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
USB_LP_CAN1_RX0_IRQHandler [WEAK]
EXPORT
CAN1_RX1_IRQHandler
[WEAK]
EXPORT
CAN1_SCE_IRQHandler
[WEAK]
EXPORT
EXTI9_5_IRQHandler
[WEAK]
EXPORT
TIM1_BRK_IRQHandler
[WEAK]
EXPORT
TIM1_UP_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM1_CC_IRQHandler
[WEAK]
EXPORT
TIM2_IRQHandler
[WEAK]
EXPORT
TIM3_IRQHandler
[WEAK]
EXPORT
TIM4_IRQHandler
[WEAK]
EXPORT
I2C1_EV_IRQHandler
[WEAK]
EXPORT
I2C1_ER_IRQHandler
[WEAK]
EXPORT
I2C2_EV_IRQHandler
[WEAK]
EXPORT
I2C2_ER_IRQHandler
[WEAK]
EXPORT
SPI1_IRQHandler
[WEAK]
EXPORT
SPI2_IRQHandler
[WEAK]
EXPORT
USART1_IRQHandler
[WEAK]
EXPORT
USART2_IRQHandler
[WEAK]
EXPORT
USART3_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
RTCAlarm_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM8_BRK_IRQHandler
[WEAK]
EXPORT
TIM8_UP_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM8_CC_IRQHandler
[WEAK]
EXPORT
ADC3_IRQHandler
[WEAK]
EXPORT
FSMC_IRQHandler
[WEAK]
EXPORT
SDIO_IRQHandler
[WEAK]
EXPORT
TIM5_IRQHandler
[WEAK]
EXPORT
SPI3_IRQHandler
[WEAK]
EXPORT
UART4_IRQHandler
[WEAK]
EXPORT
UART5_IRQHandler
[WEAK]
EXPORT
TIM6_IRQHandler
[WEAK]
EXPORT
TIM7_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
DMA2_Channel4_5_IRQHandler [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
TIM8_BRK_IRQHandler
TIM8_UP_IRQHandler
TIM8_CC_IRQHandler
ADC3_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
B
ENDP
ALIGN
; User Stack and Heap initialization
IF
:DEF:__MICROLIB 判斷是否使用DEF:__MICROLIB(micro lib)
EXPORT
__initial_sp
EXPORT
__heap_base
EXPORT
__heap_limit
ELSE
IMPORT
__use_two_region_memory 定義全局標(biāo)號(hào)__use_two_region_memory
EXPORT
__user_initial_stackheap聲明全局標(biāo)號(hào)__user_initial_stackheap,這樣外程序也可調(diào)用此標(biāo)號(hào)
LDR
R0, =
Heap_Mem
LDR
R1, =(Stack_Mem +
Stack_Size)
LDR
R2, = (Heap_Mem +
Heap_Size)
LDR
R3, = Stack_Mem
BX
LR
ALIGN
ENDIF
END
;******************* (C) COPYRIGHT 2011 STMicroelectronics
*****END OF FILE***** |
