查看: 14680|回復: 15
C51簡單計算器設計思想、Proteus仿真及源代碼
ID:98923 發表于 2015-12-9 00:36 | 顯示全部樓層 |閱讀模式
硬件部分比較簡單,當鍵盤按鍵按下時它的那一行、那一列的端口為低電平。因此,只要掃描行、列端口是否都為低電平就可以確定是哪個鍵被按下。
二、主程序流程圖
程序的主要思想是:將按鍵抽象為字符,然后就是對字符的處理。將操作數分別轉化為字符串存儲,操作符存儲為字符形式。然后調用compute()函數進行計算并返回結果。具體程序及看注釋還有流程圖。
三、程序源代碼
#include <reg51.h>#include <intrins.h>
#include <ctype.h>
#include <stdlib.h>
#define uchar unsigned char
#define uint unsigned int
uchar operand1[9], operand2[9];
uchar operator;
void delay(uint);
uchar keyscan();
void disp(void);
void buf(uint value);
uint compute(uint va1,uint va2,uchar optor);
uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
0x92,0x82,0xf8,0x80,0x90,0xff};
uchar dbuf[8] = {10,10,10,10,10,10,10,10};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
uchar keyscan()
uchar skey;
P1 = 0xfe;
while((P1 & 0xf0) != 0xf0)
delay(3);
switch(P1)
case 0xee: skey = '7'; break;
case 0xde: skey = '8'; break;
case 0xbe: skey = '9'; break;
case 0x7e: skey = '/'; break;
default: skey = '#';
P1 = 0xfd;
delay(3);
switch(P1)
case 0xed: skey = '4'; break;
case 0xdd: skey = '5'; break;
case 0xbd: skey = '6'; break;
case 0x7d: skey = '*'; break;
P1 = 0xfb;
delay(3);
switch(P1)
case 0xeb: skey = '1'; break;
case 0xdb: skey = '2'; break;
case 0xbb: skey = '3'; break;
case 0x7b: skey = '-'; break;
P1 = 0xf7;
delay(3);
switch(P1)
case 0xe7: skey = '$'; break;
case 0xd7: skey = '0'; break;
case 0xb7: skey = '='; break;
case 0x77: skey = '+'; break;
return skey;
uint value1, value2, value;
uchar ckey, cut1 = 0, cut2 = 0;
uchar operator;
uchar i, bool = 0;
init:
buf(0);
disp();
value = 0;
cut1 = cut2 = 0;
bool = 0;
for(i = 0;i < 9;i++)
operand1 = '\0';
operand2 = '\0';
ckey = keyscan();
if(ckey != '#')
if(isdigit(ckey))
switch(bool)
case 0:
operand1[cut1] = ckey;
operand1[cut1+1] = '\0';
value1 = atoi(operand1);
cut1++;
buf(value1);
disp();
break;
case 1:
operand2[cut2] = ckey;
operand2[cut2+1] = '\0';
value2 = atoi(operand2);
cut2++;
buf(value2);
disp();
break;
default: break;
else if(ckey=='+'||ckey=='-'||ckey=='*'||ckey=='/')
bool = 1;
operator = ckey;
buf(0);
dbuf[7] = 10;
disp();
else if(ckey == '=')
value = compute(value1,value2,operator);
buf(value);
disp();
ckey = keyscan();
if(ckey == '$')
goto init;
buf(value);
disp();
else if(ckey == '$')
{ goto init;}
disp();
uint value;
switch(optor)
case '+' : value = va1+va2; break;
case '-' : value = va1-va2; break;
case '*' : value = va1*va2; break;
case '/' : value = va1/va2; break;
default : break;
return value;
void buf(uint val)
uchar i;
if(val == 0)
dbuf[7] = 0;
i = 6;
for(i = 7; val > 0; i--)
dbuf = val % 10;
val /= 10;
for( ; i > 0; i--)
dbuf = 10;
void disp(void)
uchar bsel, n;
bsel=0x01;
for(n=0;n<8;n++)
P2=bsel;
P0=table[dbuf[n]];
bsel=_crol_(bsel,1);
delay(3);
P0=0xff;
C51簡單計算器.zip
1.24 MB, 下載次數: 244, 下載積分: 黑幣 -5
ID:112618 發表于 2016-4-10 10:08 | 顯示全部樓層
樓主你好,我剛入門,對51引腳不懂,下載你的帖子還是一部分看不懂,你能幫我改下這個嗎?
ID:117574 發表于 2016-5-10 18:33 來自觸屏版 | 顯示全部樓層
Fandy 發表于 2016-4-10 10:08
你現在回了嗎
ID:114732 發表于 2016-5-14 16:19 | 顯示全部樓層
先謝樓主的分享
ID:145691 發表于 2016-11-2 14:34 | 顯示全部樓層
負數能運算不
ID:146409 發表于 2016-11-6 14:01 | 顯示全部樓層
初學者來參考參考
ID:156892 發表于 2016-12-22 16:07 | 顯示全部樓層
計算按鍵和顯示屏元件名是什么呀
ID:157940 發表于 2016-12-27 08:53 | 顯示全部樓層
謝謝樓主
ID:153199 發表于 2017-1-1 12:22 | 顯示全部樓層
很詳細的資料
ID:171316 發表于 2017-3-16 20:05 | 顯示全部樓層
謝謝樓主
ID:168012 發表于 2017-3-17 08:57 | 顯示全部樓層
厲害,厲害
ID:212212 發表于 2017-6-19 09:26 | 顯示全部樓層
有沒有匯編語言的
ID:242365 發表于 2017-10-24 17:59 | 顯示全部樓層
可以共享一下嗎
ID:336429 發表于 2018-5-24 14:52 | 顯示全部樓層
被認為是不安全的文件不能下載,想要下載下來學習學習的。
ID:794325 發表于 2020-7-1 15:35 | 顯示全部樓層
樓主你好,用了你的代碼,有一些問題,不知道如何修改,想詢問一下您,不知道如何上傳圖片。。。
  1. operand1 = '\0';
這里出現錯誤
error C213: left side of asn-op not an lvalue,是下面這部分代碼中的
  1. init:
  2. buf(0);
  3. disp();
  4. value = 0;
  5. cut1 = cut2 = 0;
  6. bool = 0;
  7. for(i = 0;i < 9;i++)
  8. {
  9. operand1 = '\0';
  10. operand2 = '\0';
  11. }
ID:794325 發表于 2020-7-1 17:00 | 顯示全部樓層
上面那個我加了個[i]就可以了,但是運行的時候為什么數碼管不顯示數字啊
主站蜘蛛池模板: 欧美三级在线视频 | 蜜桃精品噜噜噜成人av | 亚洲国产欧美日韩在线 | 午夜在线免费视频 | 成人高潮片免费网站 | 日韩欧美在线观看 | 男人的天堂在线视频 | 国产成人影视 | 天天射夜夜操 | 亚洲一区二区久久 | 欧美999| 午夜精品久久久久久久99 | 欧美日韩一区二区三区 | 在线观看小视频 | 国产精品婷婷 | 久久精品国产免费 | av手机在线免费观看 | 日韩视频二区 | 性爱视频日本 | 国产午夜精品一区二区三区视频 | 久久久综合网 | 久久爱影视i | 亚洲福利一区二区 | 免费国产黄色 | 男同在线观看 | www.国产在线观看 | 国产日韩欧美日韩大片 | 国产精品高潮呻吟久久 | 日韩在线精品视频 | 欧美韩日 | 中文字幕一区在线 | 成人羞羞国产免费游戏 | 欧美色综合天天久久综合精品 | 亚洲一区二区免费视频 | 免费日韩视频 | 亚洲欧美视频 | 亚洲精品自拍视频 | 欧美a级黄色片 | 国产一级生活片 | 亚洲视频在线观看免费 | 亚洲第一区在线观看 |
