查看: 1826|回復(fù): 0
stm32f0 MCU brief and Eval board
ID:98924 發(fā)表于 2015-12-9 02:40 | 顯示全部樓層 |閱讀模式
Arm's Cortex-M0 is at the low end of the 32-bit spectrum. It is designed to compete with 8- and 16-bit micrcontrollers while providing the power and flexibility of the Cortex architecture. STMicroelectronics adds to its Cortex portfolio with the STM F0 that is priced around $1.
The STM32 F0 Series (Fig. 1) runs at 48 MHz. It has up to 128 Kbytes flash and 20 Kbytes SRAM. Some chips have RAM parity support. The F0 also has DMA-support CRC integrity check of flash memory. These are required for Class B-ready, safety-related applications. There are two watchdog timers as well. Memory and peripherals are linked via a bus matrix that allows the 5-channel DMA to operate in parallel with the processor.
ig. 1: STM32 F0 includes support for HDMI Consumer Electronics Control (CEC).
The Cortex-M0 is at the low end of the power and performance spectrum but the STM32 F0 performs very well. It's CoreMark result is over 1.6 CoreMarks/MHz besting may 8- and 16-bit processors. It is designed to be very power efficient drawing only 5μA in stop mode and 2μA in standby mode. It also has a very fast wake up time.
HDMI Consumer Electronics Control (CEC) is part of the HDMI specification. CEC allows an HDMI connection to control up to 10 CEC devices. The STM32 F0 can be one of those CEC devices. STMicroelectronics includes a software library that supports CEC.
The analog peripheral set is similar to that found on other STMicroelectronics microcontrollers. The STM32 F0 has 12-bit, 1 Msample/s ADC as well as a 12-bit DAC and a pair of comparators. The analog subsystem has a separate power supply. Capacitive touch support can handle 18 keys as well as sliders and wheels.
The digital peripheral set includes serial ports with IrDA support. There is an infrared software library to simplify development chores. The I2C interface runs at speeds up to 1 Mbit/s. SPI is also supported. The 32-bit timers work with up to 17 capture-compare pins. They have PWM support but there is also a motor control subsystem designed to handle permanant magnet synchronous motors (PMSM). STMicroelectronics provides a motor control library.
The real time clock (RTC) supports sub-second alarms with a 31μs step designed for RF applications. The calendar used a BCD format. It has configurable windows/step calibration trimming support.
Development can start using a number of eval boards. The STM320518 evaluation kit (Fig. 2) is priced at $199. The board includes a QVGA LCD display. Developers have access to a graphics libraries that work with the display.
Fig. 2: The STM320518 includes a QVGA display.
The $7.99 STM32F0Discovery (Fig. 3) follows STMicroelectronics Discovery line. This DIP module has a USB debug interface and exposes most of the chip's peripheral pins.
Fig. 3: STM32F0Discovery is a low cost eval platform.
The STM32 F0 requires a 1.8V to 3.6V power supply. Battery backup support in standby mode includes 20 bytes of backup registers. Standby mode uses only 0.43 μA including RTC support. It is available in a range of chip packages that can handle temperature extremes.
主站蜘蛛池模板: 欧美激情在线观看 | 国产午夜精品一区二区三区四区 | 精品国产乱码久久久久久蜜柚 | 欧美一区二区三区在线观看 | 国产一级特黄 | 国产福利在线播放 | 美女视频一区二区 | 婷婷狠狠爱 | 深夜福利视频网站 | 久久成人精品视频 | 超碰99在线| 这里只有精品视频在线观看 | 久久久久久亚洲 | 国产成人在线观看免费网站 | 日韩免费大片 | 国产一级视频在线观看 | 国产主播精品 | 欧美精品在线观看视频 | 一区二区三区国产视频 | 一级黄色片免费 | 草草视频在线观看 | 欧美激情在线播放 | 少妇一级淫片 | 性久久久久久久 | 在线观看欧美日韩 | 一区二区三区中文字幕 | 国产一区二区三区 | 国产视频一区二区在线 | 日韩资源在线 | a天堂在线视频 | 特级黄色大片 | 久久久久久久 | 国产区视频 | 狠狠干网| 午夜性视频 | 久久在线精品 | a级片网站 | 中文字幕在线观看一区二区三区 | 国产日韩欧美精品 | 中文字幕欧美日韩 | 一区二区网站 |
