查看: 4445|回復: 0
MSP430F6736 PWM 無法調整duty cycle
ID:101175 發表于 2015-12-30 09:44 | 顯示全部樓層 |閱讀模式
各位大大:
      以下是我的source code ,照理說當我調整TA1CCR1 的數據時duty cycle就會隨之改變,但是不管我數值改多少duty cycle都沒有變,會是我clock選擇的問題嗎?
在麻煩各位前輩幫幫我看一下了>< 謝謝.
int main(void)
  // Stop watchdog
  WDTCTL = WDTPW + WDTHOLD;
  UCS_init();
  P8DIR |= BIT4;
  P8SEL |= BIT4;
  InitSystemCLK();
  TA1CCR1 = 0;
  __enable_interrupt();
  // LPM0 (shut down the CPU) with interrupts enabled
  //__bis_SR_register(CPUOFF | GIE);
// This will be called when timer counts to TACCR1.
#pragma vector=TIMER1_A0_VECTOR
__interrupt void TIMER1_A0_ISR(void)
  int new_ccr1 = 2000;
  // Clear interrupt flag
  TA1CCTL1 &= ~CCIFG;
  TA1CCR1 = new_ccr1 ;
void UCS_init(void)
   // Set Vcore to accomodate for max. allowed system speed
   PMM_setVCore(PMM_BASE,PMMCOREV_3);  // Used PMM_CORE_LEVEL_3
  // Initialize LFXT1
    UCSCTL6 &= ~(XT1OFF);                   // Enable XT1
    UCSCTL6 |= XCAP_3;                      // Internal load cap 12pF
  // Loop until XT1 fault flag is cleared
    do
        UCSCTL7 &= ~XT1LFOFFG;             // Clear XT1 fault flags
    } while (UCSCTL7 & XT1LFOFFG);         // Test XT1 fault flag
  // Use 32.768kHz XTAL as reference
  //  LFXT_Start(XT1DRIVE_3);
  // Setup UCS
    UCSCTL3 |= SELREF_0;                   // Set DCO FLL reference = REFO
    UCSCTL4 |= SELA_0;                     // Set ACLK = REFO
  // Initialize DCO to 2.45MHz
    __bis_SR_register(SCG0);               // Disable the FLL control loop
    UCSCTL0 = 0x0000;                      // Set lowest possible DCOx, MODx
    UCSCTL1 = DCORSEL_7;                   // Set RSELx for DCO = 24 MHz
    UCSCTL2 = FLLD_0 | 611;                 // Set DCO Multiplier for 20MHz
                                                            // (N + 1) * FLLRef = Fdco
                                                             // (611 + 1) * 32768 = 20MHz
                                                             // Set FLL Div = fDCOCLK/2
    __bic_SR_register(SCG0);               // Enable the FLL control loop
  // Worst-case settling time for the DCO when the DCO range bits have been
  // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
  // UG for optimization.
  // 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
  __delay_cycles(625000);
  // Loop until XT1, XT2 & DCO fault flag is cleared
  do
      UCSCTL7 &= ~(XT2OFFG | XT1LFOFFG | DCOFFG);
      // Clear XT2,XT1,DCO fault flags
      SFRIFG1 &= ~OFIFG;                 // Clear fault flags
  } while (SFRIFG1 & OFIFG);             // Test oscillator fault flag
     __no_operation();
void InitSystemCLK(void)
   // Setup TA1
   // PWM period
    TA1CCR0 = 4500;
    TA1CTL = TASSEL_2 | MC_1 ;       // SMCLK, upmode, clear TAR
    TA1CCTL0 = OUTMOD_7 | CCIE;      // CCR0 interrupt enabled
主站蜘蛛池模板: 亚洲成人毛片 | 精品综合网 | 午夜天堂av | 亚洲精品在线看 | 久久精品视频国产 | 日韩一级在线 | 久久国产精品免费 | 日韩视频网 | 日韩中文字幕视频 | 国产天天操 | 日韩欧美视频在线 | 国产一区欧美 | 日本视频免费观看 | 国产精品成人免费视频 | 国产h在线 | av不卡在线播放 | 亚洲一区二区久久 | 成人久久网 | 黄色网址在线免费观看 | 欧美一级欧美三级 | 成年人视频网站 | 免费在线看a | 色香蕉网 | 操小妹影院 | 国产欧美精品一区二区三区 | 日韩一区在线视频 | 国产黄色一级片 | 日韩在线资源 | 天天澡天天狠天天天做 | 五月天视频 | 视频一区在线播放 | 99视频网站 | 欧美专区在线观看 | 老司机精品福利视频 | 96av视频 | 黄色国产视频 | 99热在线播放 | 欧美激情国产精品 | 一级做a视频 | 国产一级一片免费播放放a 国产黄色大片 | 国产第五页 |
