查看: 4710|回復: 0
紅外線遙控碼單片機測試程序
ID:101489 發表于 2016-1-2 20:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
轉自:http://m.zg4o1577.cn/mcu/1488.html
以前在仕創時,總是奇怪 周工為什么可以編出一個能測試任何遙控的遙控碼 和用戶碼的單片機程序!周工還將此程序視為寶貝,每次測試完都將那只已經燒錄好的單片機拿回去!!在這幾年 本人也接觸單片機,嘗試寫出測試遙控碼的程序!!但只是能測試出遙控碼 并未能測試出用戶碼!!!所以當時周工還是相當厲害的!!
       下面放出剛剛編錄完成的程序,暫時只能測試遙控碼!!
     下載地址:http://m.zg4o1577.cn/f/hw51d.rar
下載軟件界面,用于燒錄單片機!!
USB下載器
剛燒錄好程序,單片機加電時顯示“00”
測試遙控碼(家里電視機待機按鍵遙控碼)
程序是由C語言編寫,單片機使用AT89C52       下面是程序:
#include<reg51.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#defineNop(){_nop_(); _nop_(); _nop_(); _nop_(); _nop_();}
volatile ulong IRcode=0x00000000;
volatile ulong Irdcode=0x00000000;
volatile uint customcode=0x0000;
volatile uint time_us=0x0000;
volatile uchar timeH,timeL;
uchar Lcustomcode;
uchar Hcustomcode;
uchar datacode;
uchar mycode;
uchar Rdatacode;
uchar uc1ms;
uchar uc10ms;
uchar uc3ms;
uchar  ucDispTime;
uchar  ucDispOrder;
uchar  ucDispCon;
uchar ucSpeakerTime;
unsigned char code LedData[16] = { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char code LedCon[2] = {0x8f,0x4f};
unsigned char ucDispData[2];
sbit led1 = P3^7;
sbit led2 = P3^6;
sbit power=P1^0;
sbit BEEP= P2^1;
bit NewIRcode=0;
bit DataRight=0;
bit bSampleOk;
bit bSampling;
bit b10msInt;
bit  b1msInt;
bit bKeySound;
bit b1msMain;
bit IR_E;
bit b3msint;
void SendDataToDispDevice();
void Ir_process();
void display();
void beeping();
void init()
  IP=0x09;
  TMOD=0x11;
  TCON=0x01;
  TH0=0xff;
  TL0=0x47;
  TH1=0x00;
  TL1=0x00;
  EA=1;
  ET0=1;
  ET1=1;
  EX0=1;
  TR1=0;
  TR0=1;
void TimeProg(void)
b1msMain = b1msInt;
   b1msMain=0;
b10msInt = 0;
if(b1msInt == 1)
         b1msMain=1;
   if(++uc10ms == 10)
uc10ms = 0;
b10msInt = 1;
if(bKeySound==1)
  {beeping();
bKeySound=0;
}//void TimeProg(void)
void IR_ISR() interrupt 0 using 1
  static uchar cn;
  TR1=0;
  timeH=TH1;
  timeL=TL1;
  TH1=0;
  TL1=0;
  TR1=1;
  time_us=(unsigned int)timeH;
  time_us=time_us<<8;
  time_us=time_us|timeL;
  if(time_us>12200&&time_us<13000) {cn=1;IRcode=0;}
  if(cn<34)
          if(time_us>950&&time_us<1120)                   //0
             IRcode=IRcode|0x00000000;
             if(cn<33) IRcode=IRcode>>1;
      else if(time_us>1920&&time_us<2120)        //1t > 1950 && t < 2150
             IRcode=IRcode|0x80000000;
  //else if(time_us>10000&&time_us<11000) {Irdcode=IRcode;cn=34; }
cn++;
  if(cn==34)
   { NewIRcode=1;
     TR1=0;
     Irdcode= IRcode;  cn=0;
void Timer0_ISR() interrupt 1 using 2
  TR0=0;
  TH0=0xff;
  TL0=0x47;
  TR0=1;
  if(++uc1ms == 5)
uc1ms = 0;
        b1msInt=1;
if(++uc3ms==8)
   uc3ms=0;
   b3msint=1;
}//void Timer0IntProg() interrupt 1 using 1
void Timer1_ISR() interrupt 3 using 3
  TR1=0;
  TH1=0x00;
  TL1=0x00;
  TR1=1;
unsigned char n;
    //watchdog();
if(++ucDispOrder >= 2)  ucDispOrder = 0;
         if(ucDispOrder==0)
      {led1=0;
           led2=1;
       Nop();
            Nop();
if(b3msint==1)
       {if(ucDispOrder==1)
       {led2=0;
            led1=1;
    Nop();
            Nop();
       n = LedData[ucDispData[ucDispOrder]];
      P0=n;
} //void SendDataToDispDevice()
    init();
  beeping();
     TimeProg();
     Ir_process();
     display();
void Ir_process()
  if(NewIRcode==1)
    NewIRcode=0;
    customcode=(Irdcode>>16);
                          Lcustomcode=customcode>>8;
    datacode=(unsigned char)(customcode&0x00ff);
       Rdatacode=Lcustomcode;
      if(~Rdatacode!=datacode)
  {  DataRight=0;
     Irdcode=0;
     datacode=Rdatacode=0;
{ DataRight=1;
   IR_E=1;
   mycode=datacode;}
     if(DataRight==1)  { bKeySound = 1;DataRight=0;  }
void display()
  /*  unsigned char a[2];
a[0] = mycode & 0x0f;
mycode = mycode >> 4;
a[1] = mycode & 0x0f;
ET0 = 0;
ucDispData[0] = a[0];
ucDispData[1] = a[1];
ET0 = 1;*/
if(IR_E==1)
ET0 = 0;
ucDispData[0] = mycode & 0x0f;
ucDispData[1] = mycode & 0x0f;
    IR_E=0;
ET0 = 1;
void delay(unsigned char x)    //x*0.14MS
unsigned char a;
  while(x--)
  for (a = 0; a<13; a++) {;}
void beeping()
  unsigned char i;
  for (i=0;i<100;i++)
     delay(4);
     BEEP=!BEEP;
  BEEP=1;
收藏收藏2 分享淘帖 頂 踩
主站蜘蛛池模板: 99精品在线 | 亚洲精品久久久 | 日韩免费成人 | 天天舔天天干 | 国产福利视频在线 | 国产成人在线观看免费网站 | 日韩免费视频一区二区 | 欧美www| 色偷偷噜噜噜亚洲男人 | 免费看黄色小视频 | 日韩精品在线免费观看 | 国产51自产区 | 97在线播放 | 中文字幕一区二区三区四区 | av观看网站| 国产综合自拍 | 午夜黄色小视频 | 日韩国产在线 | 天天燥日日燥 | 老司机精品福利视频 | 日本在线观看网站 | 欧美精品区 | 午夜精品久久久久久久 | 日韩少妇 | 91久久精品日日躁夜夜躁欧美 | 自拍偷拍亚洲 | 国产小视频在线 | 免费在线观看毛片 | 日韩精品一区在线观看 | 国产成年妇视频 | 99精品视频在线观看 | 国产午夜影院 | 中国少妇xxxxhd做受 | 五月网站 | 玖玖在线视频 | 国产a久久麻豆入口 | 亚洲色在线视频 | 男女av在线| 中国特级毛片 | www.中文字幕 | 国产成人免费观看 |
