查看: 8550|回復: 2
requires ANSI-style prototype c語言程序有個錯誤找不出來,附加了程序,求大神看看
ID:102197 發表于 2016-1-7 09:30 | 顯示全部樓層 |閱讀模式
compiling 11.c...
11.c(4): warning C318: can't open file 'lcd_1602.h'
11.c(5): warning C318: can't open file 'key.h'
11.c(6): warning C318: can't open file 'IIC_24C04.h'
11.C(55): warning C206: 'lcd_init': missing function-prototype
11.C(56): warning C206: 'IIC_24C04_Init': missing function-prototype
11.C(62): warning C206: 'keys_scan': missing function-prototype
11.C(120): warning C206: 'sendstring': missing function-prototype
11.C(120): error C267: 'sendstring': requires ANSI-style prototype
11.c(360): warning C316: unterminated conditionals
11.c - 1 Error(s), 8 Warning(s).
有一個錯誤怎么都看不出來,求大神幫下忙 啊
#include<reg52.h>
#include<string.h>
#include<intrins.h>
#include<lcd_1602.h>
#include<key.h>
#include<IIC_24C04.h>
#define uchar unsigned char
#define uint unsigned int
uchar pre_keyno=16,keyno=16;
uchar code Title_Text[]="your password...";
uchar DSY_BUFFER[16]="                ";
uchar userpassword[7]="       ";
uchar IIC_Password[7];
uchar lS_Valid_User=0;
uchar i=0;
void display_string(uchar *str,uchar lineno);
void beep();
uchar Clear_Password();
sbit LED_OPEN=P2^0;
sbit BEEP=P3^7;
void delay(uint x)
      uchar i;
      while (x--)
      for(i=0;i<120;i++);
void beep()
uchar i;
for(i=0;i<100;i++)
    BEEP=~BEEP;
   BEEP=0;
void clear_password()
      uchar i;
      for(i=0;i<6;i++)
        userpassword[ i]=' ';
                DSY_BUFFER[ i]=' ';
void init_main()
  P0=0xFF;
  P1=0xFF;
  P2=0xFF;
  TMOD=0x02;
  TH0=175;
  TL0=175;
  TR0=1;
  delay(10);
  lcd_init();
  IIC_24C04_Init();
void key_main()
P1=0xF0;
if(P1!=0xF0) keyno=keys_scan();
if(pre_keyno!=keyno)
  if(i<=6)
     switch(keyno)
        case 0:  case 1: case 2: case 3: case 4:
        case 5:  case 6: case 7: case 8: case 9:
                if(i<=6)
                   if(i==0)display_string("         ",0x40);
           userpassword[ i]=keyno+'0';
                   userpassword[i+1]=' ';
                   DSY_BUFFER[ i]='*';
                   DSY_BUFFER[i+1]=' ';
                   display_string(DSY_BUFFER,0x40);
                   i++;
             break;
         case 10:
                 if(strcmp(userpassword,IIC_Password)==0)
                            LED_OPEN=0;
                                Clear_Password();
                                display_string("Unlock ok!    ",0x40);
                                lS_Valid_User=1;
                           LED_OPEN=1;
                           Clear_Password();
                           display_string("ERROR!    ",0x40);
                           lS_Valid_User=0;
                         i=0;
                         break;
        case 11:
                LED_OPEN=1;
                        Clear_Password();
                        display_string(Title_Text,0x00);
                        i=0;
                        lS_Valid_User=0;
                        break;
        case 12:
                    if(!lS_Valid_User)display_string("No rights !",0x40);
                     i=0;
                         display_string("New Password:  ",0x00);
                        break;
        case 13:
                          sendstring(0xa0,0,userpassword,6);
                          recstring(0xa0,0,IIC_Password,6);
                          IIC_Password[6]='';
                          i=0;
                          display_string("Password Saved! ",0x40);
                        break;
        case 14:
                    i=0;
                        Clear_Password();
燈    }
     beep();
         pre_keyno=keyno;
}鳴器
   beep();
   delay(100)
   P1=0xF0;
   while(P1==0xF0);
   init_main();
   IIC_Password[6]='\0';
   while(l)
    key_main();
    P1=0xF0;
    while(P1!=0xF0);
    while(P1==0xF0);
#ifndef  _LCD1602_H_
#define  _LCD1602_H_
#include<reg52.h>
sbit rs=P2^1;
sbit rw=P2^2;
sbit eq=P2^3;
void delay_lcd(uchar n)
uchar i;
while(n--)
   for(i=0;i<250;i++)
     _nop_(); _nop_(); _nop_(); _nop_();
bit lcd_bz()
  bit result;
  rs=0;
  rw=1;
  eq=1;
  _nop_(); _nop_();_nop_(); _nop_();
  result=(bit)(P0&0x80);
  eq=0;
  return result;
void lcd_wcmd(uchar cmd)
rs=0;
rw=0;
eq=0;
P0=cmd;
eq=1;
delay_lcd(1);
eq=0;
void lcd_wdat(uchar dat)
while(lcd_bz());
rs=1;
rw=0;
P0=dat;
delay_lcd(1);
eq=1;
eq=0;
void lcd_init()
lcd_wcmd(0x38);
while(lcd_bz());
lcd_wcmd(0x0c);
lcd_wcmd(0x06);
lcd_wcmd(0x01);
uchar i;
lcd_wcmd(0x80+lineno);
for (i=0;i<16;i++)
  lcd_wdat(str[ i]);
  #endif
  #ifndef _key_H_
  #define _key_H_
#include<reg52.h>
void delay_key(uint x)
  uchar i;
  while (x--)
  for(i=0;i<120;i++);
uchar keys_scan()
uchar temp,k;
P1=0x0F;
delay_key(2);
temp=P1^0x0F;
switch(temp)
  case 1: k=0;break;
  case 2: k=1;break;
  case 4: k=2;break;
  case 8: k=3;break;
  default: break;
P1=0xF0;
delay_key(2);
temp=(P1>>4)^0x0F;
switch(temp)
  case 1: k+=0;break;
  case 2: k+=4;break;
  case 4: k+=8;break;
  case 8: k+=12;break;
  default: break;
return k;
#ifndef _IIC_24C04_H_
#define _IIC_24C04_H_
#include<reg52.h>
#include<string.h>
#include<intrins.h>
#define delay4us();
sbit SCL=P3^2;
sbit SDA=P3^3;
void start()
SDA=1;SCL=1;delay4us();
SDA=0;delay4us();SCL=0;
void stop()
SDA=0;SCL=1;delay4us();
SDA=1;delay4us();SCL=0;
void IIC_24C04_Init()
SCL=0;stop();
void ACK()
SDA=1;SCL=0;
void no_ACK()
SDA=0;SCL=0;
uchar recbyte()
uchar i;rd;
rd=0x00;
SDA=1;
for(i=0;i<8;i++)
SCL=1;rd<<=1;rd|=SDA; delay4us(); SCL=0;delay4us();
SCL=0;
delay4us();
return rd;
uchar sendbyte(uchar wd)
uchar i;
bit  ACK0;
for(i=0;i<8;i++)
  SDA=(bit)(wd&0x80);
  _nop_();_nop_();SCL=1;delay4us();SCL=0;wd<<=1;
delay4us();
SDA=1;
SCL=1;
delay4us();
ACK0=!SDA;
SCL=0;
delay4us();
return ACK0;
uchar sendstring(uchar slave,uchar subaddr,uchar *buffer,uchar N);
uchar i;
start();
if(!sendbyte(slave))
  return 0;
if(!sendbyte(subaddr))
  return 0;
for(i=0;i<N-1;i++)
          if(!sendbyte(buffer[ i])) return 0;
        stop();
        return 1;
uchar recstring(uchar slave,uchar subaddr,ucahr *buffer,uchar N);
uchar i;
start();
if(!sendbyte(slave))  return 0;
if(!sendbyte(subaddr))        return 0;
start();
if(!sendbyte(slave+1))  return 0;
for(i=0;i<N-1;i++)
    buffer[ i]=recbyte();
        ACK();
  buffer[N-1]=recbyte();
  no_ACK();
  stop();
  return 1;
ID:1 發表于 2016-1-10 01:36 | 顯示全部樓層
11.C(120): error C267: 'sendstring': requires ANSI-style prototype 是說sendstring可能沒有定義,你應該上傳完整的壓縮包,才能方便查找呢.
主站蜘蛛池模板: 黄色精品网站 | 国产成人三级一区二区在线观看一 | 午夜国产 | 性做久久久久久久免费看 | 精品久久一区二区三区 | 狠狠干影院 | 亚洲综合在线视频 | 日韩精品成人 | 成人午夜又粗又硬又大 | 一级片在线 | 精品久久国产 | 国产一级在线播放 | 国产欧美一区二区 | 手机看片在线 | 午夜免费av| 超碰成人免费 | 黄色国产视频 | 午夜免费剧场 | 久久久国产视频 | 午夜婷婷| 一区二区三区四区在线视频 | 久艹视频在线观看 | 日本久久综合 | 中文字幕不卡视频 | 一区视频 | 黄色一级片黄色一级片 | 毛片毛片毛片毛片毛片 | 国产一区二区在线看 | 亚洲天堂成人 | 欧美日韩一二三区 | 黄色成人在线视频 | 久久九九国产 | 黄色av免费观看 | 五月开心激情网 | 色综合天天综合网天天狠天天 | 日本天堂在线 | 日韩欧美一区二区三区四区 | 亚洲成人av在线播放 | 欧美日韩在线一区二区三区 | 男女啪啪免费视频 | 三级视频在线 |
