查看: 4672|回復(fù): 2
STM32單片機(jī)模擬I2C讀寫
ID:102668 發(fā)表于 2016-1-16 06:48 | 顯示全部樓層 |閱讀模式
都說STM32I2C有問題,不好用。我之前,在論壇上看到了Mcuplayer分享的一段代碼,拿來測試了一下,讀寫正常,心想還挺不錯。
但是等到真正做程序時,發(fā)現(xiàn)總是在while()循環(huán)處等待。無奈,只好用軟件模擬I2C
從網(wǎng)上找了一段程序,發(fā)現(xiàn)好多地方下載的代碼都一樣的。
代碼如下:
i nclude "includes.h"
i nclude "24cxx.h"
#define ADDR_24CXX       0xA0
#define SCLH        GPIOB->BSRR = GPIO_Pin_6
#define SCLL        GPIOB->BRR  = GPIO_Pin_6
#define SDAH        GPIOB->BSRR = GPIO_Pin_7
#define SDAL        GPIOB->BRR  = GPIO_Pin_7
#define SCLread     GPIOB->IDR  & GPIO_Pin_6
#define SDAread     GPIOB->IDR  & GPIO_Pin_7
static void I2C_GPIO_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  // Configure I2C1 pins: SCL and SDA
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
void I2C_delay(void)
   u8 i=50; //這里可以優(yōu)化速度 ,經(jīng)測試最低到5還能寫入
   while(i)
     i--;
bool I2C_Start(void)
 SDAH;
 SCLH;
 I2C_delay();
 if(!SDAread)return FALSE; //SDA線為低電平則總線忙,退出
 SDAL;
 I2C_delay();
 if(SDAread) return FALSE; //SDA線為高電平則總線出錯,退出
 SDAL;
 I2C_delay();
 return TRUE;
void I2C_Stop(void)
 SCLL;
 I2C_delay();
 SDAL;
 I2C_delay();
 SCLH;
 I2C_delay();
 SDAH;
 I2C_delay();
void I2C_Ack(void)
 SCLL;
 I2C_delay();
 SDAL;
 I2C_delay();
 SCLH;
 I2C_delay();
 SCLL;
 I2C_delay();
void I2C_NoAck(void)
 SCLL;
 I2C_delay();
 SDAH;
 I2C_delay();
 SCLH;
 I2C_delay();
 SCLL;
 I2C_delay();
bool I2C_WaitAck(void)  //返回為:=1ACK,=0ACK
 SCLL;
 I2C_delay();
 SDAH;
 I2C_delay();
 SCLH;
 I2C_delay();
 if(SDAread)
         SCLL;
         return FALSE;
 SCLL;
 return TRUE;
void I2C_SendByte(u8 SendByte) //數(shù)據(jù)從高位到低位//
    u8 i=8;
    while(i--)
       SCLL;
       I2C_delay();
       if(SendByte&0x80)
         SDAH;
       SDAL;
       SendByte<<=1;
       I2C_delay();
 SCLH;
       I2C_delay();
    SCLL;
u8 I2C_ReceiveByte(void) //數(shù)據(jù)從高位到低位//
    u8 i=8;
    u8 ReceiveByte=0;
   SDAH;
    while(i--)
      ReceiveByte<<=1;
      SCLL;
      I2C_delay();
      SCLH;
      I2C_delay();
      if(SDAread)
       ReceiveByte|=0x01;
    SCLL;
    return ReceiveByte;
//寫入1字節(jié)數(shù)據(jù)       待寫入數(shù)據(jù)    待寫入地址       器件類型(24c16SD2403)
bool I2C_WriteByte(u8 SendByte, u16 WriteAddress, u8 DeviceAddress)
    u32 j;
    if(!I2C_Start())return FALSE;
    //I2C_SendByte(((WriteAddress & 0x0700) >>7) | DeviceAddress & 0xFFFE);//設(shè)置高起始地址+器件地址
    I2C_SendByte( DeviceAddress & 0xFE);//寫器件地址
    if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
    I2C_SendByte((u8)((WriteAddress>>8) & 0xFF));   //設(shè)置高起始地址
    I2C_WaitAck();
    I2C_SendByte((u8)((WriteAddress) & 0xFF));   //設(shè)置低起始地址
    I2C_WaitAck();
    I2C_SendByte(SendByte);          //寫數(shù)據(jù)
    I2C_WaitAck();
    I2C_Stop();
 //注意:因為這里要等待EEPROM寫完,可以采用查詢或延時方式(10ms)
    for(j=0;j<1500;j++)
      I2C_delay();
    return TRUE;
//讀出1字節(jié)數(shù)據(jù)         存放讀出數(shù)據(jù)  待讀出長度      待讀出地址       器件類型(24c16SD2403)
u8 I2C_ReadByte( u16 ReadAddress,  u8 DeviceAddress)
    u8 temp;
    //I2C_SendByte(((ReadAddress & 0x0700) >>7) | DeviceAddress & 0xFFFE);//設(shè)置高起始地址+器件地址
    I2C_SendByte((DeviceAddress & 0xFE));//寫器件地址
    I2C_SendByte((u8)((ReadAddress>>8) & 0xFF));   //設(shè)置高起始地址
    I2C_WaitAck();
    I2C_SendByte((u8)((ReadAddress) & 0xFF));   //設(shè)置低起始地址
    I2C_WaitAck();
    I2C_Start();
    I2C_SendByte((DeviceAddress & 0xFE)|0x01);    //讀器件地址
    I2C_WaitAck();
    //*pDat = I2C_ReceiveByte();
    temp = I2C_ReceiveByte();
    I2C_NoAck();
    I2C_Stop();
    return temp;
void I2C_24CXX_Init(void)
  I2C_GPIO_Config();
void I2C_24CXX_Write(u16 nAddr, u8* pDat, u16 nLen)
  u16 i,j;
  for(i=0;i
    I2C_WriteByte(*(pDat+i), nAddr+i, ADDR_24CXX);
void I2C_24CXX_Read(u16 nAddr, u8* pDat, u16 nLen)
    u16 i;
    for(i=0;i
      *(pDat+i)=I2C_ReadByte( nAddr+i, ADDR_24CXX);
可是,反復(fù)試了多次,貌似很不穩(wěn)定,有時正確,有時錯誤。最后添加了紅字處的的延時,讀寫完全正常。用示波器觀察,延時大概7.5ms
ID:613800 發(fā)表于 2019-12-24 11:32 | 顯示全部樓層
寫的很好,,,多謝
ID:59423 發(fā)表于 2020-2-8 19:32 | 顯示全部樓層
謝謝樓主,程序正常運(yùn)行。
主站蜘蛛池模板: 国产激情在线视频 | 久草福利在线观看 | 国产精品第一 | 国产精品美女在线观看 | 日本中文字幕在线 | 亚洲视频免费看 | 解开岳的丰满奶罩bd | 国产免费成人 | 97色伦图片 | 国产99页 | 一区二区三区免费观看 | 午夜伦理福利 | 欧美性受xxxx黑人xyx性爽 | 免费毛片在线 | www.日韩| 免费成人毛片 | 欧美一区二区三区在线观看 | 久久久精品一区 | 久久99深爱久久99精品 | 色综合久久天天综合网 | 国产三级在线观看视频 | 午夜不卡视频 | 国产女人18毛片18精品 | 久久久天堂国产精品女人 | 日韩精品视频免费 | 欧美人与野 | 特级毛片爽www免费版 | 国产欧美日韩一区二区三区 | 精品国产成人 | 亚洲综合色网 | 精品久久久久久久久久久久久久久久 | 99热国产| 欧美成人久久 | 国产精品99久久久久久久久 | 亚洲欧美日韩在线 | 8x8ⅹ国产精品一区二区 | 欧美日韩一区二区三区视频 | 日韩中文字幕在线视频 | 中文字幕在线观看网站 | 国产精品一区二区在线免费观看 | 精品久久久一区二区 |
