查看: 5401|回復: 0
三星S3C2440 ARM920T內核處理器寄存器整理--非常有用的資料
ID:104126 發表于 2016-1-24 02:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
對于從事嵌入式和硬件開發的工程師來說以下資料非常有用,從內存、USB、DMA到中斷非常全。
// Memory control  13
#define rBWSCON    (*(volatile unsigned *)0x48000000) //Bus width & wait status
#define rBANKCON0  (*(volatile unsigned *)0x48000004) //Boot ROM control
#define rBANKCON1  (*(volatile unsigned *)0x48000008) //BANK1 control
#define rBANKCON2  (*(volatile unsigned *)0x4800000c) //BANK2 cControl
#define rBANKCON3  (*(volatile unsigned *)0x48000010) //BANK3 control
#define rBANKCON4  (*(volatile unsigned *)0x48000014) //BANK4 control
#define rBANKCON5  (*(volatile unsigned *)0x48000018) //BANK5 control
#define rBANKCON6  (*(volatile unsigned *)0x4800001c) //BANK6 control
#define rBANKCON7  (*(volatile unsigned *)0x48000020) //BANK7 control
#define rREFRESH   (*(volatile unsigned *)0x48000024) //DRAM/SDRAM refresh
#define rBANKSIZE  (*(volatile unsigned *)0x48000028) //Flexible Bank Size
#define rMRSRB6    (*(volatile unsigned *)0x4800002c) //Mode register set for SDRAM
#define rMRSRB7    (*(volatile unsigned *)0x48000030) //Mode register set for SDRAM
// USB Host
// INTERRUPT   8
#define rSRCPND     (*(volatile unsigned *)0x4a000000) //Interrupt request status
#define rINTMOD     (*(volatile unsigned *)0x4a000004) //Interrupt mode control
#define rINTMSK     (*(volatile unsigned *)0x4a000008) //Interrupt mask control
#define rPRIORITY   (*(volatile unsigned *)0x4a00000a) //IRQ priority control
#define rINTPND     (*(volatile unsigned *)0x4a000010) //Interrupt request status
#define rINTOFFSET  (*(volatile unsigned *)0x4a000014) //Interruot request source offset
#define rSUBSRCPND  (*(volatile unsigned *)0x4a000018) //Sub source pending
#define rINTSUBMSK  (*(volatile unsigned *)0x4a00001c) //Interrupt sub mask
// DMA   36
#define rDISRC0     (*(volatile unsigned *)0x4b000000) //DMA 0 Initial source
#define rDISRCC0    (*(volatile unsigned *)0x4b000004) //DMA 0 Initial source control
#define rDIDST0     (*(volatile unsigned *)0x4b000008) //DMA 0 Initial Destination
#define rDIDSTC0    (*(volatile unsigned *)0x4b00000c) //DMA 0 Initial Destination control
#define rDCON0      (*(volatile unsigned *)0x4b000010) //DMA 0 Control
#define rDSTAT0     (*(volatile unsigned *)0x4b000014) //DMA 0 Status
#define rDCSRC0     (*(volatile unsigned *)0x4b000018) //DMA 0 Current source
#define rDCDST0     (*(volatile unsigned *)0x4b00001c) //DMA 0 Current destination
#define rDMASKTRIG0 (*(volatile unsigned *)0x4b000020) //DMA 0 Mask trigger
#define rDISRC1     (*(volatile unsigned *)0x4b000040) //DMA 1 Initial source
#define rDISRCC1    (*(volatile unsigned *)0x4b000044) //DMA 1 Initial source control
#define rDIDST1     (*(volatile unsigned *)0x4b000048) //DMA 1 Initial Destination
#define rDIDSTC1    (*(volatile unsigned *)0x4b00004c) //DMA 1 Initial Destination control
#define rDCON1      (*(volatile unsigned *)0x4b000050) //DMA 1 Control
#define rDSTAT1     (*(volatile unsigned *)0x4b000054) //DMA 1 Status
#define rDCSRC1     (*(volatile unsigned *)0x4b000058) //DMA 1 Current source
#define rDCDST1     (*(volatile unsigned *)0x4b00005c) //DMA 1 Current destination
#define rDMASKTRIG1 (*(volatile unsigned *)0x4b000060) //DMA 1 Mask trigger
#define rDISRC2     (*(volatile unsigned *)0x4b000080) //DMA 2 Initial source
#define rDISRCC2    (*(volatile unsigned *)0x4b000084) //DMA 2 Initial source control
#define rDIDST2     (*(volatile unsigned *)0x4b000088) //DMA 2 Initial Destination
#define rDIDSTC2    (*(volatile unsigned *)0x4b00008c) //DMA 2 Initial Destination control
#define rDCON2      (*(volatile unsigned *)0x4b000090) //DMA 2 Control
#define rDSTAT2     (*(volatile unsigned *)0x4b000094) //DMA 2 Status
#define rDCSRC2     (*(volatile unsigned *)0x4b000098) //DMA 2 Current source
#define rDCDST2     (*(volatile unsigned *)0x4b00009c) //DMA 2 Current destination
#define rDMASKTRIG2 (*(volatile unsigned *)0x4b0000a0) //DMA 2 Mask trigger
#define rDISRC3     (*(volatile unsigned *)0x4b0000c0) //DMA 3 Initial source
#define rDISRCC3    (*(volatile unsigned *)0x4b0000c4) //DMA 3 Initial source control
#define rDIDST3     (*(volatile unsigned *)0x4b0000c8) //DMA 3 Initial Destination
#define rDIDSTC3    (*(volatile unsigned *)0x4b0000cc) //DMA 3 Initial Destination control
#define rDCON3      (*(volatile unsigned *)0x4b0000d0) //DMA 3 Control
#define rDSTAT3     (*(volatile unsigned *)0x4b0000d4) //DMA 3 Status
#define rDCSRC3     (*(volatile unsigned *)0x4b0000d8) //DMA 3 Current source
#define rDCDST3     (*(volatile unsigned *)0x4b0000dc) //DMA 3 Current destination
#define rDMASKTRIG3 (*(volatile unsigned *)0x4b0000e0) //DMA 3 Mask trigger
// CLOCK & POWER MANAGEMENT  7
#define rLOCKTIME   (*(volatile unsigned *)0x4c000000) //PLL lock time counter
#define rMPLLCON    (*(volatile unsigned *)0x4c000004) //MPLL Control//系統主頻配置寄存器基地址
#define rUPLLCON    (*(volatile unsigned *)0x4c000008) //UPLL Control//USB時鐘頻率配置寄存器基地址
#define rCLKCON     (*(volatile unsigned *)0x4c00000c) //Clock generator control
#define rCLKSLOW    (*(volatile unsigned *)0x4c000010) //Slow clock control
#define rCLKDIVN    (*(volatile unsigned *)0x4c000014) //Clock divider control
#define rCAMDIVN    (*(volatile unsigned *)0x4c000018) //USB, CAM Clock divider control
// LCD CONTROLLER  18
#define rLCDCON1    (*(volatile unsigned *)0x4d000000) //LCD control 1
#define rLCDCON2    (*(volatile unsigned *)0x4d000004) //LCD control 2
#define rLCDCON3    (*(volatile unsigned *)0x4d000008) //LCD control 3
#define rLCDCON4    (*(volatile unsigned *)0x4d00000c) //LCD control 4
#define rLCDCON5    (*(volatile unsigned *)0x4d000010) //LCD control 5
#define rLCDSADDR1  (*(volatile unsigned *)0x4d000014) //STN/TFT Frame buffer start address 1
#define rLCDSADDR2  (*(volatile unsigned *)0x4d000018) //STN/TFT Frame buffer start address 2
#define rLCDSADDR3  (*(volatile unsigned *)0x4d00001c) //STN/TFT Virtual screen address set
#define rREDLUT     (*(volatile unsigned *)0x4d000020) //STN Red lookup table
#define rGREENLUT   (*(volatile unsigned *)0x4d000024) //STN Green lookup table
#define rBLUELUT    (*(volatile unsigned *)0x4d000028) //STN Blue lookup table
#define rDITHMODE   (*(volatile unsigned *)0x4d00004c) //STN Dithering mode
#define rTPAL       (*(volatile unsigned *)0x4d000050) //TFT Temporary palette
#define rLCDINTPND  (*(volatile unsigned *)0x4d000054) //LCD Interrupt pending
#define rLCDSRCPND  (*(volatile unsigned *)0x4d000058) //LCD Interrupt source
#define rLCDINTMSK  (*(volatile unsigned *)0x4d00005c) //LCD Interrupt mask
#define rLPCSEL     (*(volatile unsigned *)0x4d000060) //LPC3600 Control
#define PALETTE     0x4d000400                         //Palette start address
//Nand Flash   17
#define rNFCONF  (*(volatile unsigned *)0x4E000000)  //NAND Flash configuration
#define rNFCONT  (*(volatile unsigned *)0x4E000004)      //NAND Flash control
#define rNFCMD  (*(volatile unsigned *)0x4E000008)      //NAND Flash command
#define rNFADDR  (*(volatile unsigned *)0x4E00000C)      //NAND Flash address
#define rNFDATA  (*(volatile unsigned *)0x4E000010)      //NAND Flash data
#define rNFDATA8 (*(volatile unsigned char *)0x4E000010)     //NAND Flash data
#define rNFMECCD0 (*(volatile unsigned *)0x4E000014)      //NAND Flash ECC for Main Area
#define rNFMECCD1 (*(volatile unsigned *)0x4E000018)
#define rNFSECCD (*(volatile unsigned *)0x4E00001C)  //NAND Flash ECC for Spare Area
#define rNFSTAT  (*(volatile unsigned *)0x4E000020)  //NAND Flash operation status
#define rNFESTAT0 (*(volatile unsigned *)0x4E000024)
#define rNFESTAT1 (*(volatile unsigned *)0x4E000028)
#define rNFMECC0 (*(volatile unsigned *)0x4E00002C)
#define rNFMECC1 (*(volatile unsigned *)0x4E000030)
#define rNFSECC  (*(volatile unsigned *)0x4E000034)
#define rNFSBLK  (*(volatile unsigned *)0x4E000038)  //NAND Flash Start block address
#define rNFEBLK  (*(volatile unsigned *)0x4E00003C)  //NAND Flash End block address
// UART    45
#define rULCON0     (*(volatile unsigned *)0x50000000) //UART 0 Line control
#define rUCON0      (*(volatile unsigned *)0x50000004) //UART 0 Control
#define rUFCON0     (*(volatile unsigned *)0x50000008) //UART 0 FIFO control
#define rUMCON0     (*(volatile unsigned *)0x5000000c) //UART 0 Modem control
#define rUTRSTAT0   (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status
#define rUERSTAT0   (*(volatile unsigned *)0x50000014) //UART 0 Rx error status
#define rUFSTAT0    (*(volatile unsigned *)0x50000018) //UART 0 FIFO status
#define rUMSTAT0    (*(volatile unsigned *)0x5000001c) //UART 0 Modem status
#define rUBRDIV0    (*(volatile unsigned *)0x50000028) //UART 0 Baud rate divisor
#define rULCON1     (*(volatile unsigned *)0x50004000) //UART 1 Line control
#define rUCON1      (*(volatile unsigned *)0x50004004) //UART 1 Control
#define rUFCON1     (*(volatile unsigned *)0x50004008) //UART 1 FIFO control
#define rUMCON1     (*(volatile unsigned *)0x5000400c) //UART 1 Modem control
#define rUTRSTAT1   (*(volatile unsigned *)0x50004010) //UART 1 Tx/Rx status
#define rUERSTAT1   (*(volatile unsigned *)0x50004014) //UART 1 Rx error status
#define rUFSTAT1    (*(volatile unsigned *)0x50004018) //UART 1 FIFO status
#define rUMSTAT1    (*(volatile unsigned *)0x5000401c) //UART 1 Modem status
#define rUBRDIV1    (*(volatile unsigned *)0x50004028) //UART 1 Baud rate divisor
#define rULCON2     (*(volatile unsigned *)0x50008000) //UART 2 Line control
#define rUCON2      (*(volatile unsigned *)0x50008004) //UART 2 Control
#define rUFCON2     (*(volatile unsigned *)0x50008008) //UART 2 FIFO control
#define rUMCON2     (*(volatile unsigned *)0x5000800c) //UART 2 Modem control
#define rUTRSTAT2   (*(volatile unsigned *)0x50008010) //UART 2 Tx/Rx status
#define rUERSTAT2   (*(volatile unsigned *)0x50008014) //UART 2 Rx error status
#define rUFSTAT2    (*(volatile unsigned *)0x50008018) //UART 2 FIFO status
#define rUMSTAT2    (*(volatile unsigned *)0x5000801c) //UART 2 Modem status
#define rUBRDIV2    (*(volatile unsigned *)0x50008028) //UART 2 Baud rate divisor
#ifdef __BIG_ENDIAN
#define rUTXH0      (*(volatile unsigned char *)0x50000023) //UART 0 Transmission Hold
#define rURXH0      (*(volatile unsigned char *)0x50000027) //UART 0 Receive buffer
#define rUTXH1      (*(volatile unsigned char *)0x50004023) //UART 1 Transmission Hold
#define rURXH1      (*(volatile unsigned char *)0x50004027) //UART 1 Receive buffer
#define rUTXH2      (*(volatile unsigned char *)0x50008023) //UART 2 Transmission Hold
#define rURXH2      (*(volatile unsigned char *)0x50008027) //UART 2 Receive buffer
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000023)=(unsigned char)(ch)
#define RdURXH0()   (*(volatile unsigned char *)0x50000027)
#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004023)=(unsigned char)(ch)
#define RdURXH1()   (*(volatile unsigned char *)0x50004027)
#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008023)=(unsigned char)(ch)
#define RdURXH2()   (*(volatile unsigned char *)0x50008027)
#define UTXH0       (0x50000020+3)  //Byte_access address by DMA
#define URXH0       (0x50000024+3)
#define UTXH1       (0x50004020+3)
#define URXH1       (0x50004024+3)
#define UTXH2       (0x50008020+3)
#define URXH2       (0x50008024+3)
#else //Little Endian
#define rUTXH0 (*(volatile unsigned char *)0x50000020) //UART 0 Transmission Hold
#define rURXH0 (*(volatile unsigned char *)0x50000024) //UART 0 Receive buffer
#define rUTXH1 (*(volatile unsigned char *)0x50004020) //UART 1 Transmission Hold
#define rURXH1 (*(volatile unsigned char *)0x50004024) //UART 1 Receive buffer
#define rUTXH2 (*(volatile unsigned char *)0x50008020) //UART 2 Transmission Hold
#define rURXH2 (*(volatile unsigned char *)0x50008024) //UART 2 Receive buffer
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
#define RdURXH0()   (*(volatile unsigned char *)0x50000024)
#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004020)=(unsigned char)(ch)
#define RdURXH1()   (*(volatile unsigned char *)0x50004024)
#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008020)=(unsigned char)(ch)
#define RdURXH2()   (*(volatile unsigned char *)0x50008024)
#define UTXH0       (0x50000020)    //Byte_access address by DMA
#define URXH0       (0x50000024)
#define UTXH1       (0x50004020)
#define URXH1       (0x50004024)
#define UTXH2       (0x50008020)
#define URXH2       (0x50008024)
#endif
// PWM TIMER  17
#define rTCFG0  (*(volatile unsigned *)0x51000000) //Timer 0 configuration
#define rTCFG1  (*(volatile unsigned *)0x51000004) //Timer 1 configuration
#define rTCON   (*(volatile unsigned *)0x51000008) //Timer control
#define rTCNTB0 (*(volatile unsigned *)0x5100000c) //Timer count buffer 0
#define rTCMPB0 (*(volatile unsigned *)0x51000010) //Timer compare buffer 0
#define rTCNTO0 (*(volatile unsigned *)0x51000014) //Timer count observation 0
#define rTCNTB1 (*(volatile unsigned *)0x51000018) //Timer count buffer 1
#define rTCMPB1 (*(volatile unsigned *)0x5100001c) //Timer compare buffer 1
#define rTCNTO1 (*(volatile unsigned *)0x51000020) //Timer count observation 1
#define rTCNTB2 (*(volatile unsigned *)0x51000024) //Timer count buffer 2
#define rTCMPB2 (*(volatile unsigned *)0x51000028) //Timer compare buffer 2
#define rTCNTO2 (*(volatile unsigned *)0x5100002c) //Timer count observation 2
#define rTCNTB3 (*(volatile unsigned *)0x51000030) //Timer count buffer 3
#define rTCMPB3 (*(volatile unsigned *)0x51000034) //Timer compare buffer 3
#define rTCNTO3 (*(volatile unsigned *)0x51000038) //Timer count observation 3
#define rTCNTB4 (*(volatile unsigned *)0x5100003c) //Timer count buffer 4
#define rTCNTO4 (*(volatile unsigned *)0x51000040) //Timer count observation 4
// USB DEVICE   47
#ifdef __BIG_ENDIAN
<ERROR IF BIG_ENDIAN>
#define rFUNC_ADDR_REG     (*(volatile unsigned char *)0x52000143) //Function address
#define rPWR_REG           (*(volatile unsigned char *)0x52000147) //Power management
#define rEP_INT_REG        (*(volatile unsigned char *)0x5200014b) //EP Interrupt pending and clear
#define rUSB_INT_REG       (*(volatile unsigned char *)0x5200015b) //USB Interrupt pending and clear
#define rEP_INT_EN_REG     (*(volatile unsigned char *)0x5200015f) //Interrupt enable
#define rUSB_INT_EN_REG    (*(volatile unsigned char *)0x5200016f)
#define rFRAME_NUM1_REG    (*(volatile unsigned char *)0x52000173) //Frame number lower byte
#define rFRAME_NUM2_REG    (*(volatile unsigned char *)0x52000177) //Frame number higher byte
#define rINDEX_REG         (*(volatile unsigned char *)0x5200017b) //Register index
#define rMAXP_REG          (*(volatile unsigned char *)0x52000183) //Endpoint max packet
#define rEP0_CSR           (*(volatile unsigned char *)0x52000187) //Endpoint 0 status
#define rIN_CSR1_REG       (*(volatile unsigned char *)0x52000187) //In endpoint control status
#define rIN_CSR2_REG       (*(volatile unsigned char *)0x5200018b)
#define rOUT_CSR1_REG      (*(volatile unsigned char *)0x52000193) //Out endpoint control status
#define rOUT_CSR2_REG      (*(volatile unsigned char *)0x52000197)
#define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x5200019b) //Endpoint out write count
#define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019f)
#define rEP0_FIFO          (*(volatile unsigned char *)0x520001c3) //Endpoint 0 FIFO
#define rEP1_FIFO          (*(volatile unsigned char *)0x520001c7) //Endpoint 1 FIFO
#define rEP2_FIFO          (*(volatile unsigned char *)0x520001cb) //Endpoint 2 FIFO
#define rEP3_FIFO          (*(volatile unsigned char *)0x520001cf) //Endpoint 3 FIFO
#define rEP4_FIFO          (*(volatile unsigned char *)0x520001d3) //Endpoint 4 FIFO
#define rEP1_DMA_CON       (*(volatile unsigned char *)0x52000203) //EP1 DMA interface control
#define rEP1_DMA_UNIT      (*(volatile unsigned char *)0x52000207) //EP1 DMA Tx unit counter
#define rEP1_DMA_FIFO      (*(volatile unsigned char *)0x5200020b) //EP1 DMA Tx FIFO counter
#define rEP1_DMA_TTC_L     (*(volatile unsigned char *)0x5200020f) //EP1 DMA total Tx counter
#define rEP1_DMA_TTC_M     (*(volatile unsigned char *)0x52000213)
#define rEP1_DMA_TTC_H     (*(volatile unsigned char *)0x52000217)
#define rEP2_DMA_CON       (*(volatile unsigned char *)0x5200021b) //EP2 DMA interface control
#define rEP2_DMA_UNIT      (*(volatile unsigned char *)0x5200021f) //EP2 DMA Tx unit counter
#define rEP2_DMA_FIFO      (*(volatile unsigned char *)0x52000223) //EP2 DMA Tx FIFO counter
#define rEP2_DMA_TTC_L     (*(volatile unsigned char *)0x52000227) //EP2 DMA total Tx counter
#define rEP2_DMA_TTC_M     (*(volatile unsigned char *)0x5200022b)
#define rEP2_DMA_TTC_H     (*(volatile unsigned char *)0x5200022f)
#define rEP3_DMA_CON       (*(volatile unsigned char *)0x52000243) //EP3 DMA interface control
#define rEP3_DMA_UNIT      (*(volatile unsigned char *)0x52000247) //EP3 DMA Tx unit counter
#define rEP3_DMA_FIFO      (*(volatile unsigned char *)0x5200024b) //EP3 DMA Tx FIFO counter
#define rEP3_DMA_TTC_L     (*(volatile unsigned char *)0x5200024f) //EP3 DMA total Tx counter
#define rEP3_DMA_TTC_M     (*(volatile unsigned char *)0x52000253)
#define rEP3_DMA_TTC_H     (*(volatile unsigned char *)0x52000257)
#define rEP4_DMA_CON       (*(volatile unsigned char *)0x5200025b) //EP4 DMA interface control
#define rEP4_DMA_UNIT      (*(volatile unsigned char *)0x5200025f) //EP4 DMA Tx unit counter
#define rEP4_DMA_FIFO      (*(volatile unsigned char *)0x52000263) //EP4 DMA Tx FIFO counter
#define rEP4_DMA_TTC_L     (*(volatile unsigned char *)0x52000267) //EP4 DMA total Tx counter
#define rEP4_DMA_TTC_M     (*(volatile unsigned char *)0x5200026b)
#define rEP4_DMA_TTC_H     (*(volatile unsigned char *)0x5200026f)
#else  // Little Endian
#define rFUNC_ADDR_REG     (*(volatile unsigned char *)0x52000140) //Function address
#define rPWR_REG           (*(volatile unsigned char *)0x52000144) //Power management
#define rEP_INT_REG        (*(volatile unsigned char *)0x52000148) //EP Interrupt pending and clear
#define rUSB_INT_REG       (*(volatile unsigned char *)0x52000158) //USB Interrupt pending and clear
#define rEP_INT_EN_REG     (*(volatile unsigned char *)0x5200015c) //Interrupt enable
#define rUSB_INT_EN_REG    (*(volatile unsigned char *)0x5200016c)
#define rFRAME_NUM1_REG    (*(volatile unsigned char *)0x52000170) //Frame number lower byte
#define rFRAME_NUM2_REG    (*(volatile unsigned char *)0x52000174) //Frame number higher byte
#define rINDEX_REG         (*(volatile unsigned char *)0x52000178) //Register index
#define rMAXP_REG          (*(volatile unsigned char *)0x52000180) //Endpoint max packet
#define rEP0_CSR           (*(volatile unsigned char *)0x52000184) //Endpoint 0 status
#define rIN_CSR1_REG       (*(volatile unsigned char *)0x52000184) //In endpoint control status
#define rIN_CSR2_REG       (*(volatile unsigned char *)0x52000188)
#define rOUT_CSR1_REG      (*(volatile unsigned char *)0x52000190) //Out endpoint control status
#define rOUT_CSR2_REG      (*(volatile unsigned char *)0x52000194)
#define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x52000198) //Endpoint out write count
#define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019c)
#define rEP0_FIFO          (*(volatile unsigned char *)0x520001c0) //Endpoint 0 FIFO
#define rEP1_FIFO          (*(volatile unsigned char *)0x520001c4) //Endpoint 1 FIFO
#define rEP2_FIFO          (*(volatile unsigned char *)0x520001c8) //Endpoint 2 FIFO
#define rEP3_FIFO          (*(volatile unsigned char *)0x520001cc) //Endpoint 3 FIFO
#define rEP4_FIFO          (*(volatile unsigned char *)0x520001d0) //Endpoint 4 FIFO
#define rEP1_DMA_CON       (*(volatile unsigned char *)0x52000200) //EP1 DMA interface control
#define rEP1_DMA_UNIT      (*(volatile unsigned char *)0x52000204) //EP1 DMA Tx unit counter
#define rEP1_DMA_FIFO      (*(volatile unsigned char *)0x52000208) //EP1 DMA Tx FIFO counter
#define rEP1_DMA_TTC_L     (*(volatile unsigned char *)0x5200020c) //EP1 DMA total Tx counter
#define rEP1_DMA_TTC_M     (*(volatile unsigned char *)0x52000210)
#define rEP1_DMA_TTC_H     (*(volatile unsigned char *)0x52000214)
#define rEP2_DMA_CON       (*(volatile unsigned char *)0x52000218) //EP2 DMA interface control
#define rEP2_DMA_UNIT      (*(volatile unsigned char *)0x5200021c) //EP2 DMA Tx unit counter
#define rEP2_DMA_FIFO      (*(volatile unsigned char *)0x52000220) //EP2 DMA Tx FIFO counter
#define rEP2_DMA_TTC_L     (*(volatile unsigned char *)0x52000224) //EP2 DMA total Tx counter
#define rEP2_DMA_TTC_M     (*(volatile unsigned char *)0x52000228)
#define rEP2_DMA_TTC_H     (*(volatile unsigned char *)0x5200022c)
#define rEP3_DMA_CON       (*(volatile unsigned char *)0x52000240) //EP3 DMA interface control
#define rEP3_DMA_UNIT      (*(volatile unsigned char *)0x52000244) //EP3 DMA Tx unit counter
#define rEP3_DMA_FIFO      (*(volatile unsigned char *)0x52000248) //EP3 DMA Tx FIFO counter
#define rEP3_DMA_TTC_L     (*(volatile unsigned char *)0x5200024c) //EP3 DMA total Tx counter
#define rEP3_DMA_TTC_M     (*(volatile unsigned char *)0x52000250)
#define rEP3_DMA_TTC_H     (*(volatile unsigned char *)0x52000254)
#define rEP4_DMA_CON       (*(volatile unsigned char *)0x52000258) //EP4 DMA interface control
#define rEP4_DMA_UNIT      (*(volatile unsigned char *)0x5200025c) //EP4 DMA Tx unit counter
#define rEP4_DMA_FIFO      (*(volatile unsigned char *)0x52000260) //EP4 DMA Tx FIFO counter
#define rEP4_DMA_TTC_L     (*(volatile unsigned char *)0x52000264) //EP4 DMA total Tx counter
#define rEP4_DMA_TTC_M     (*(volatile unsigned char *)0x52000268)
#define rEP4_DMA_TTC_H     (*(volatile unsigned char *)0x5200026c)
#endif   // __BIG_ENDIAN
// WATCH DOG TIMER  3
#define rWTCON   (*(volatile unsigned *)0x53000000) //Watch-dog timer mode
#define rWTDAT   (*(volatile unsigned *)0x53000004) //Watch-dog timer data
#define rWTCNT   (*(volatile unsigned *)0x53000008) //Eatch-dog timer count
// IIC  5
#define rIICCON  (*(volatile unsigned *)0x54000000) //IIC control
#define rIICSTAT (*(volatile unsigned *)0x54000004) //IIC status
#define rIICADD  (*(volatile unsigned *)0x54000008) //IIC address
#define rIICDS   (*(volatile unsigned *)0x5400000c) //IIC data shift
#define rIICLC  (*(volatile unsigned *)0x54000010) //IIC multi-master line control
// IIS  5
#define rIISCON  (*(volatile unsigned *)0x55000000) //IIS Control
#define rIISMOD  (*(volatile unsigned *)0x55000004) //IIS Mode
#define rIISPSR  (*(volatile unsigned *)0x55000008) //IIS Prescaler
#define rIISFCON (*(volatile unsigned *)0x5500000c) //IIS FIFO control
#ifdef __BIG_ENDIAN
#define IISFIFO  ((volatile unsigned short *)0x55000012) //IIS FIFO entry
#define IISFIFO  ((volatile unsigned short *)0x55000010) //IIS FIFO entry
#endif
//Camera Interface.  Edited for 2440A     34
#define rCISRCFMT           (*(volatile unsigned *)0x4F000000)
#define rCIWDOFST           (*(volatile unsigned *)0x4F000004)
#define rCIGCTRL            (*(volatile unsigned *)0x4F000008)
#define rCICOYSA1           (*(volatile unsigned *)0x4F000018)
#define rCICOYSA2           (*(volatile unsigned *)0x4F00001C)
#define rCICOYSA3           (*(volatile unsigned *)0x4F000020)
#define rCICOYSA4           (*(volatile unsigned *)0x4F000024)
#define rCICOCBSA1          (*(volatile unsigned *)0x4F000028)
#define rCICOCBSA2          (*(volatile unsigned *)0x4F00002C)
#define rCICOCBSA3          (*(volatile unsigned *)0x4F000030)
#define rCICOCBSA4          (*(volatile unsigned *)0x4F000034)
#define rCICOCRSA1          (*(volatile unsigned *)0x4F000038)
#define rCICOCRSA2          (*(volatile unsigned *)0x4F00003C)
#define rCICOCRSA3          (*(volatile unsigned *)0x4F000040)
#define rCICOCRSA4          (*(volatile unsigned *)0x4F000044)
#define rCICOTRGFMT         (*(volatile unsigned *)0x4F000048)
#define rCICOCTRL           (*(volatile unsigned *)0x4F00004C)
#define rCICOSCPRERATIO     (*(volatile unsigned *)0x4F000050)
#define rCICOSCPREDST       (*(volatile unsigned *)0x4F000054)
#define rCICOSCCTRL         (*(volatile unsigned *)0x4F000058)
#define rCICOTAREA          (*(volatile unsigned *)0x4F00005C)
#define rCICOSTATUS         (*(volatile unsigned *)0x4F000064)
#define rCIPRCLRSA1         (*(volatile unsigned *)0x4F00006C)
#define rCIPRCLRSA2         (*(volatile unsigned *)0x4F000070)
#define rCIPRCLRSA3         (*(volatile unsigned *)0x4F000074)
#define rCIPRCLRSA4         (*(volatile unsigned *)0x4F000078)
#define rCIPRTRGFMT         (*(volatile unsigned *)0x4F00007C)
#define rCIPRCTRL           (*(volatile unsigned *)0x4F000080)
#define rCIPRSCPRERATIO     (*(volatile unsigned *)0x4F000084)
#define rCIPRSCPREDST       (*(volatile unsigned *)0x4F000088)
#define rCIPRSCCTRL         (*(volatile unsigned *)0x4F00008C)
#define rCIPRTAREA          (*(volatile unsigned *)0x4F000090)
#define rCIPRSTATUS         (*(volatile unsigned *)0x4F000098)
#define rCIIMGCPT           (*(volatile unsigned *)0x4F0000A0)
//AC97, Added for S3C2440A  10
#define rAC_GLBCTRL  *(volatile unsigned *)0x5b000000
#define rAC_GLBSTAT  *(volatile unsigned *)0x5b000004
#define rAC_CODEC_CMD  *(volatile unsigned *)0x5b000008
#define rAC_CODEC_STAT  *(volatile unsigned *)0x5b00000C
#define rAC_PCMADDR  *(volatile unsigned *)0x5b000010
#define rAC_MICADDR  *(volatile unsigned *)0x5b000014
#define rAC_PCMDATA  *(volatile unsigned *)0x5b000018
#define rAC_MICDATA  *(volatile unsigned *)0x5b00001C
#define AC_PCMDATA  0x5b000018
#define AC_MICDATA  0x5b00001C
// I/O PORT   42
#define rGPACON    (*(volatile unsigned *)0x56000000) //Port A control
#define rGPADAT    (*(volatile unsigned *)0x56000004) //Port A data
#define rGPBCON    (*(volatile unsigned *)0x56000010) //Port B control
#define rGPBDAT    (*(volatile unsigned *)0x56000014) //Port B data
#define rGPBUP     (*(volatile unsigned *)0x56000018) //Pull-up control B
#define rGPCCON    (*(volatile unsigned *)0x56000020) //Port C control
#define rGPCDAT    (*(volatile unsigned *)0x56000024) //Port C data
#define rGPCUP     (*(volatile unsigned *)0x56000028) //Pull-up control C
#define rGPDCON    (*(volatile unsigned *)0x56000030) //Port D control
#define rGPDDAT    (*(volatile unsigned *)0x56000034) //Port D data
#define rGPDUP     (*(volatile unsigned *)0x56000038) //Pull-up control D
#define rGPECON    (*(volatile unsigned *)0x56000040) //Port E control
#define rGPEDAT    (*(volatile unsigned *)0x56000044) //Port E data
#define rGPEUP     (*(volatile unsigned *)0x56000048) //Pull-up control E
#define rGPFCON    (*(volatile unsigned *)0x56000050) //Port F control
#define rGPFDAT    (*(volatile unsigned *)0x56000054) //Port F data
#define rGPFUP     (*(volatile unsigned *)0x56000058) //Pull-up control F
#define rGPGCON    (*(volatile unsigned *)0x56000060) //Port G control
#define rGPGDAT    (*(volatile unsigned *)0x56000064) //Port G data
#define rGPGUP     (*(volatile unsigned *)0x56000068) //Pull-up control G
#define rGPHCON    (*(volatile unsigned *)0x56000070) //Port H control
#define rGPHDAT    (*(volatile unsigned *)0x56000074) //Port H data
#define rGPHUP     (*(volatile unsigned *)0x56000078) //Pull-up control H
#define rGPJCON    (*(volatile unsigned *)0x560000d0) //Port J control
#define rGPJDAT    (*(volatile unsigned *)0x560000d4) //Port J data
#define rGPJUP     (*(volatile unsigned *)0x560000d8) //Pull-up control J
#define rMISCCR    (*(volatile unsigned *)0x56000080) //Miscellaneous control
#define rDCLKCON   (*(volatile unsigned *)0x56000084) //DCLK0/1 control
#define rEXTINT0   (*(volatile unsigned *)0x56000088) //External interrupt control register 0
#define rEXTINT1   (*(volatile unsigned *)0x5600008c) //External interrupt control register 1
#define rEXTINT2   (*(volatile unsigned *)0x56000090) //External interrupt control register 2
#define rEINTFLT0  (*(volatile unsigned *)0x56000094) //Reserved
#define rEINTFLT1  (*(volatile unsigned *)0x56000098) //Reserved
#define rEINTFLT2  (*(volatile unsigned *)0x5600009c) //External interrupt filter control register 2
#define rEINTFLT3  (*(volatile unsigned *)0x560000a0) //External interrupt filter control register 3
#define rEINTMASK  (*(volatile unsigned *)0x560000a4) //External interrupt mask
#define rEINTPEND  (*(volatile unsigned *)0x560000a8) //External interrupt pending
#define rGSTATUS0  (*(volatile unsigned *)0x560000ac) //External pin status
#define rGSTATUS1  (*(volatile unsigned *)0x560000b0) //Chip ID(0x32410000)
#define rGSTATUS2  (*(volatile unsigned *)0x560000b4) //Reset type
#define rGSTATUS3  (*(volatile unsigned *)0x560000b8) //Saved data0(32-bit) before entering POWER_OFF mode
#define rGSTATUS4  (*(volatile unsigned *)0x560000bc) //Saved data0(32-bit) before entering POWER_OFF mode
// RTC     17
#ifdef __BIG_ENDIAN
#define rRTCCON    (*(volatile unsigned char *)0x57000043) //RTC control
#define rTICNT     (*(volatile unsigned char *)0x57000047) //Tick time count
#define rRTCALM    (*(volatile unsigned char *)0x57000053) //RTC alarm control
#define rALMSEC    (*(volatile unsigned char *)0x57000057) //Alarm second
#define rALMMIN    (*(volatile unsigned char *)0x5700005b) //Alarm minute
#define rALMHOUR   (*(volatile unsigned char *)0x5700005f) //Alarm Hour
#define rALMDAY    (*(volatile unsigned char *)0x57000063) //Alarm day
#define rALMMON    (*(volatile unsigned char *)0x57000067) //Alarm month
#define rALMYEAR   (*(volatile unsigned char *)0x5700006b) //Alarm year
#define rRTCRST    (*(volatile unsigned char *)0x5700006f) //RTC round reset
#define rBCDSEC    (*(volatile unsigned char *)0x57000073) //BCD second
#define rBCDMIN    (*(volatile unsigned char *)0x57000077) //BCD minute
#define rBCDHOUR   (*(volatile unsigned char *)0x5700007b) //BCD hour
#define rBCDDAY    (*(volatile unsigned char *)0x5700007f) //BCD day
#define rBCDDATE   (*(volatile unsigned char *)0x57000083) //BCD date
#define rBCDMON    (*(volatile unsigned char *)0x57000087) //BCD month
#define rBCDYEAR   (*(volatile unsigned char *)0x5700008b) //BCD year
#define rRTCCON    (*(volatile unsigned char *)0x57000040) //RTC control
#define rTICNT     (*(volatile unsigned char *)0x57000044) //Tick time count
#define rRTCALM    (*(volatile unsigned char *)0x57000050) //RTC alarm control
#define rALMSEC    (*(volatile unsigned char *)0x57000054) //Alarm second
#define rALMMIN    (*(volatile unsigned char *)0x57000058) //Alarm minute
#define rALMHOUR   (*(volatile unsigned char *)0x5700005c) //Alarm Hour
#define rALMDAY    (*(volatile unsigned char *)0x57000060) //Alarm day
#define rALMMON    (*(volatile unsigned char *)0x57000064) //Alarm month
#define rALMYEAR   (*(volatile unsigned char *)0x57000068) //Alarm year
#define rRTCRST    (*(volatile unsigned char *)0x5700006c) //RTC round reset
#define rBCDSEC    (*(volatile unsigned char *)0x57000070) //BCD second
#define rBCDMIN    (*(volatile unsigned char *)0x57000074) //BCD minute
#define rBCDHOUR   (*(volatile unsigned char *)0x57000078) //BCD hour
#define rBCDDAY    (*(volatile unsigned char *)0x5700007c) //BCD day
#define rBCDDATE   (*(volatile unsigned char *)0x57000080) //BCD date
#define rBCDMON    (*(volatile unsigned char *)0x57000084) //BCD month
#define rBCDYEAR   (*(volatile unsigned char *)0x57000088) //BCD year
#endif  //RTC
// ADC     5
#define rADCCON    (*(volatile unsigned *)0x58000000) //ADC control
#define rADCTSC    (*(volatile unsigned *)0x58000004) //ADC touch screen control
#define rADCDLY    (*(volatile unsigned *)0x58000008) //ADC start or Interval Delay
#define rADCDAT0   (*(volatile unsigned *)0x5800000c) //ADC conversion data 0
#define rADCDAT1   (*(volatile unsigned *)0x58000010) //ADC conversion data 1
// SPI     12
#define rSPCON0    (*(volatile unsigned *)0x59000000) //SPI0 control
#define rSPSTA0    (*(volatile unsigned *)0x59000004) //SPI0 status
#define rSPPIN0    (*(volatile unsigned *)0x59000008) //SPI0 pin control
#define rSPPRE0    (*(volatile unsigned *)0x5900000c) //SPI0 baud rate prescaler
#define rSPTDAT0   (*(volatile unsigned *)0x59000010) //SPI0 Tx data
#define rSPRDAT0   (*(volatile unsigned *)0x59000014) //SPI0 Rx data
#define rSPCON1    (*(volatile unsigned *)0x59000020) //SPI1 control
#define rSPSTA1    (*(volatile unsigned *)0x59000024) //SPI1 status
#define rSPPIN1    (*(volatile unsigned *)0x59000028) //SPI1 pin control
#define rSPPRE1    (*(volatile unsigned *)0x5900002c) //SPI1 baud rate prescaler
#define rSPTDAT1   (*(volatile unsigned *)0x59000030) //SPI1 Tx data
#define rSPRDAT1   (*(volatile unsigned *)0x59000034) //SPI1 Rx data
// SD Interface 18個
#define rSDICON     (*(volatile unsigned *)0x5a000000) //SDI control
#define rSDIPRE     (*(volatile unsigned *)0x5a000004) //SDI baud rate prescaler
#define rSDICARG    (*(volatile unsigned *)0x5a000008) //SDI command argument
#define rSDICCON    (*(volatile unsigned *)0x5a00000c) //SDI command control
#define rSDICSTA    (*(volatile unsigned *)0x5a000010) //SDI command status
#define rSDIRSP0    (*(volatile unsigned *)0x5a000014) //SDI response 0
#define rSDIRSP1    (*(volatile unsigned *)0x5a000018) //SDI response 1
#define rSDIRSP2    (*(volatile unsigned *)0x5a00001c) //SDI response 2
#define rSDIRSP3    (*(volatile unsigned *)0x5a000020) //SDI response 3
#define rSDIDTIMER  (*(volatile unsigned *)0x5a000024) //SDI data/busy timer
#define rSDIBSIZE   (*(volatile unsigned *)0x5a000028) //SDI block size
#define rSDIDCON    (*(volatile unsigned *)0x5a00002c) //SDI data control
#define rSDIDCNT    (*(volatile unsigned *)0x5a000030) //SDI data remain counter
#define rSDIDSTA    (*(volatile unsigned *)0x5a000034) //SDI data status
#define rSDIFSTA    (*(volatile unsigned *)0x5a000038) //SDI FIFO status
#define rSDIIMSK    (*(volatile unsigned *)0x5a000040) //SDI interrupt mask
#ifdef __BIG_ENDIAN
#define rSDIDAT    (*(volatile unsigned *)0x5a00003f) //SDI data
#define SDIDAT     0x5a00003f
#define rSDIDAT    (*(volatile unsigned *)0x5a00003c) //SDI data
#define SDIDAT     0x5a00003c
#endif   //SD Interface
// ISR 40個
#define pISR_RESET     (*(unsigned *)(_ISR_STARTADDRESS+0x0))
#define pISR_UNDEF     (*(unsigned *)(_ISR_STARTADDRESS+0x4))
#define pISR_SWI       (*(unsigned *)(_ISR_STARTADDRESS+0x8))
#define pISR_PABORT    (*(unsigned *)(_ISR_STARTADDRESS+0xc))
#define pISR_DABORT    (*(unsigned *)(_ISR_STARTADDRESS+0x10))
#define pISR_RESERVED  (*(unsigned *)(_ISR_STARTADDRESS+0x14))
#define pISR_IRQ       (*(unsigned *)(_ISR_STARTADDRESS+0x18))
#define pISR_FIQ       (*(unsigned *)(_ISR_STARTADDRESS+0x1c))
#define pISR_EINT0     (*(unsigned *)(_ISR_STARTADDRESS+0x20))
#define pISR_EINT1     (*(unsigned *)(_ISR_STARTADDRESS+0x24))
#define pISR_EINT2     (*(unsigned *)(_ISR_STARTADDRESS+0x28))
#define pISR_EINT3     (*(unsigned *)(_ISR_STARTADDRESS+0x2c))
#define pISR_EINT4_7   (*(unsigned *)(_ISR_STARTADDRESS+0x30))
#define pISR_EINT8_23  (*(unsigned *)(_ISR_STARTADDRESS+0x34))
#define pISR_CAM    (*(unsigned *)(_ISR_STARTADDRESS+0x38))  // Added for 2440.
#define pISR_BAT_FLT   (*(unsigned *)(_ISR_STARTADDRESS+0x3c))
#define pISR_TICK      (*(unsigned *)(_ISR_STARTADDRESS+0x40))
#define pISR_WDT_AC97  (*(unsigned *)(_ISR_STARTADDRESS+0x44))
#define pISR_TIMER0    (*(unsigned *)(_ISR_STARTADDRESS+0x48))
#define pISR_TIMER1    (*(unsigned *)(_ISR_STARTADDRESS+0x4c))
#define pISR_TIMER2    (*(unsigned *)(_ISR_STARTADDRESS+0x50))
#define pISR_TIMER3    (*(unsigned *)(_ISR_STARTADDRESS+0x54))
#define pISR_TIMER4    (*(unsigned *)(_ISR_STARTADDRESS+0x58))
#define pISR_UART2     (*(unsigned *)(_ISR_STARTADDRESS+0x5c))
#define pISR_LCD       (*(unsigned *)(_ISR_STARTADDRESS+0x60))
#define pISR_DMA0      (*(unsigned *)(_ISR_STARTADDRESS+0x64))
#define pISR_DMA1      (*(unsigned *)(_ISR_STARTADDRESS+0x68))
#define pISR_DMA2      (*(unsigned *)(_ISR_STARTADDRESS+0x6c))
#define pISR_DMA3      (*(unsigned *)(_ISR_STARTADDRESS+0x70))
#define pISR_SDI       (*(unsigned *)(_ISR_STARTADDRESS+0x74))
#define pISR_SPI0      (*(unsigned *)(_ISR_STARTADDRESS+0x78))
#define pISR_UART1     (*(unsigned *)(_ISR_STARTADDRESS+0x7c))
#define pISR_NFCON  (*(unsigned *)(_ISR_STARTADDRESS+0x80))  // Added for 2440.
#define pISR_USBD      (*(unsigned *)(_ISR_STARTADDRESS+0x84))
#define pISR_USBH      (*(unsigned *)(_ISR_STARTADDRESS+0x88))
#define pISR_IIC       (*(unsigned *)(_ISR_STARTADDRESS+0x8c))
#define pISR_UART0     (*(unsigned *)(_ISR_STARTADDRESS+0x90))
#define pISR_SPI1      (*(unsigned *)(_ISR_STARTADDRESS+0x94))
#define pISR_RTC       (*(unsigned *)(_ISR_STARTADDRESS+0x98))
#define pISR_ADC       (*(unsigned *)(_ISR_STARTADDRESS+0x9c))
主站蜘蛛池模板: 久久久久成人网 | 日本中文在线观看 | 不卡的av网站 | 久久久久国产一区二区三区 | 亚洲精品大片 | 超碰在线99 | 日韩一区二区三区在线 | 亚洲精品1 | 91久久久精品 | 青青在线视频 | 黄色大片免费观看 | 黄色网址免费看 | 我要看一级黄色片 | 能看的毛片 | 国产一区二区三区免费 | 91在线观看 | 色偷偷噜噜噜亚洲男人 | 日本少妇中文字幕 | 亚洲色欲色欲www在线观看 | 一级特黄妇女高潮 | 国产精品成人一区二区网站软件 | 国产日韩中文字幕 | 99热国产在线| 日韩黄色片 | 欧美视频久久 | 日韩精品视频一区二区三区 | 精品福利在线观看 | 伊人网址| 国产一区二区三区视频在线 | 在线伊人 | 精品在线播放 | 国产日韩视频 | 黑人精品xxx一区一二区 | 青青草综合网 | 国产精彩视频 | 亚洲欧美日韩一区二区三区四区 | 97人人草 | 九九超碰| 日韩黄色大片 | 日本天堂网 | 羞羞的视频在线观看 |
