查看: 2968|回復: 0
android Multi-Thread
ID:104287 發表于 2016-1-31 02:39 | 顯示全部樓層 |閱讀模式
*2015年3月2日 11:18:37
*功能:通過多線程從互聯網現在一幅圖片并顯示、
*知識點:
*                        Runnable多線程類
*                        圖片的解碼:BitmapFactory.decodeByteArray(data,0,data.length);
*step:1 Runnable多線程類run方法中寫多線程函數并通過Message類傳給Handler
*                2 Handler中過public void handleMessage(Message msg)獲取多線程中傳回的數據
*      3 onClick()通過new Thread(new MyThread()).start();開啟線程
package com.example.handler;
import java.io.InputStream;
import org.apache.http.HttpResponse;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.util.EntityUtils;
import android.R.string;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.app.Activity;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.view.Menu;
import android.view.View;
import android.widget.Button;
import android.widget.ImageView;
import android.widget.Toast;
public class MainActivity extends Activity {
        private Button button;
        private ImageView imagineView;
        private String image_path="http://m.zg4o1577.cn/bbs/static/image/common/logo.png";
        private final int IS_FINISH=1;
        private Handler handler=new Handler(){   //   step3:獲取數據
                @Override
                public void handleMessage(Message msg) {
                        // TODO Auto-generated method
                        byte[] data=(byte[])msg.obj;//取書據
                        Bitmap bm=BitmapFactory.decodeByteArray(data,0,data.length);//圖片解碼
                        imagineView.setImageBitmap(bm);
                        if(msg.what==IS_FINISH)
                                Toast.makeText(MainActivity.this,"下載成功",Toast.LENGTH_SHORT).show();
                        super.handleMessage(msg);
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        button=(Button)this.findViewById(R.id.button1);
        imagineView=(ImageView)this.findViewById(R.id.imageView1);
        button.setOnClickListener(new View.OnClickListener() {
                        @Override
                        public void onClick(View arg0) {
                                // TODO Auto-generated method stub
                new Thread(new MyThread()).start();      //step4:開線程
    public class MyThread implements Runnable      //step1:定義多線程類
             @Override
                    public void run() { //   step2:線程耗時,完成下載
                            HttpClient httpClient=new DefaultHttpClient();//獲取網絡數據
                            HttpGet httpGet=new HttpGet(image_path);
                            HttpResponse httpResponse=null;
                            //InputStream inputStream=null;
                            try{
                                    httpResponse=httpClient.execute(httpGet);
                                    if(httpResponse.getStatusLine().getStatusCode()==200)
                                            //inputStream=httpResponse.getEntity().getContent();
                                            byte[]data=EntityUtils.toByteArray(httpResponse.getEntity());
                                        //把數據發送給Handler
                                            //Message可以攜帶數據返回給Handler
                                            Message message=Message.obtain();//攜帶數據
                                            message.obj=data;
                                            message.what=IS_FINISH;
                                            handler.sendMessage(message);//發送到handler
                            }catch(Exception e)
                                    Toast.makeText(MainActivity.this,"捕獲異常信息1",Toast.LENGTH_SHORT).show();
        @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
主站蜘蛛池模板: av看片 | 日韩一区二区中文字幕 | 草草视频在线 | 日韩在线一区二区三区 | 男男巨肉啪啪动漫3d | 69福利视频 | 不卡av在线播放 | 欧美日韩成人在线 | 日韩视频免费观看 | 久草福利资源 | 欧美区日韩区 | 日韩欧美黄色 | 久久激情综合 | 97福利视频| 成人深夜福利视频 | 91成人精品一区在线播放 | 日日日操| 日韩专区中文字幕 | 日本熟妇毛耸耸xxxxxx | 亚洲国产成人精品女人久久久 | 韩国三级av| 在线色 | 黄色免费毛片 | 巨骚综合 | 中文字幕永久 | 欧美有码视频 | av天天干 | 亚洲精品成a人在线观看 | 成人免费在线视频观看 | 久久久夜色精品 | 成人免费毛片aaaaaa片 | 久久都是精品 | 日本黄色中文字幕 | 日本一级淫片色费放 | 免费日韩av| 中文在线资源 | 成人香蕉网 | 99婷婷| 日韩黄色av | 国产成人午夜 | 视频一二区 |
