查看: 5276|回復(fù): 0
PIC16F877矩陣鍵盤的識別
ID:105323 發(fā)表于 2016-2-13 02:19 | 顯示全部樓層 |閱讀模式
關(guān)于矩陣鍵盤的識別方法在51矩陣鍵盤識別中已經(jīng)說過,現(xiàn)在要說的是PIC單片機(jī)與51單片機(jī)的區(qū)別,主要是PIC單片機(jī)的口子的輸入輸出需要TRISn寄存器設(shè)置,具體如下:
掃描法:
#include<pic.h>
#define uchar unsigned char
#define uint unsigned int
uchar num;
const ucharSSEG[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay1ms(uint z)
uint x;
uchar y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void keyscan()
uchar temp;
TRISB=0x0f;
PORTB=0x7f;
temp=PORTB&0x0f;
if(temp!=0x0f)
  delay1ms(10);
  temp=PORTB&0x0f;
  if(temp!=0x0f)
   num=temp|0x70;
  temp=PORTB&0x0f;
  while(temp!=0x0f)
   temp=PORTB&0x0f;
  switch(num)
   case 0x7e:num =12;break;
    case0x7d: num =13;break;
   case 0x7b:num =14;break;
   case 0x77:num =15;break;
PORTB=0xbf;
temp=PORTB&0x0f;
if(temp!=0x0f)
  delay1ms(10);
  temp=PORTB&0x0f;
  if(temp!=0x0f)
   num=temp|0xb0;
  temp=PORTB&0x0f;
  while(temp!=0x0f)
   temp=PORTB&0x0f;
  switch(num)
   case 0xbe:num =8;break;
    case0xbd: num =9;break;
   case 0xbb:num =10;break;
   case 0xb7:num =11;break;
PORTB=0xdf;
temp=PORTB&0x0f;
if(temp!=0x0f)
  delay1ms(10);
  temp=PORTB&0x0f;
  if(temp!=0x0f)
   num=temp|0xd0;
  temp=PORTB&0x0f;
  while(temp!=0x0f)
   temp=PORTB&0x0f;
  switch(num)
   case 0xde:num =4;break;
    case0xdd: num =5;break;
   case 0xdb:num =6;break;
   case 0xd7:num =7;break;
PORTB=0xef;
temp=PORTB&0x0f;
if(temp!=0x0f)
  delay1ms(10);
  temp=PORTB&0x0f;
  if(temp!=0x0f)
   num=temp|0xe0;
  temp=PORTB&0x0f;
  while(temp!=0x0f)
   temp=PORTB&0x0f;
  switch(num)
   case 0xee:num =0;break;
    case0xed: num =1;break;
   case 0xeb:num =2;break;
   case 0xe7:num =3;break;
num=0xff;
TRISD=0;
PORTD=0;
  keyscan();
  PORTD=~SSEG[num];
線反轉(zhuǎn)法:
#include<pic.h>
uchar num;
uint x;
uchar y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void keyscan()
uchar temp,z,x;
TRISB=0x0f;
PORTB=0x0f;
x=PORTB&0x0f;
if(x!=0x0f)
  delay1ms(10);
  x=PORTB&0x0f;
  if(x!=0x0f)
   temp=PORTB&0x0f;
   TRISB=0xf0;
   PORTB=0xf0;
   z=temp|PORTB;
   x=PORTB&0xf0;
   while(x!=0xf0)//松手檢測
    x=PORTB&0xf0;
   switch(z)
    case0xee: num =0; break;
         case 0xde: num =4; break;
         case 0xbe: num =8; break;
         case 0x7e: num =12; break;
         case 0xed: num =1; break;
         case 0xdd: num =5; break;
         case 0xbd: num =9; break;
         case 0x7d: num =13; break;
         case 0xeb: num =2; break;
         case 0xdb: num =6;break;
         case 0xbb: num =10;break;
         case 0x7b: num =14;break;
         case 0xe7: num =3;break;
         case 0xd7: num =7;break;
         case 0xb7: num =11;break;
         case 0x77: num =15;break;
num=0xff;
TRISD=0;
PORTD=0;
  keyscan();
  PORTD=~SSEG[num];
主站蜘蛛池模板: 九九热九九 | 久久久久久国产 | 久久在线 | 99视频免费在线观看 | 欧美激情自拍 | 日韩在线观看 | 成人自拍视频在线观看 | 91操操操 | 午夜在线视频观看 | 手机看片国产 | 男女在线视频 | 青青av| 亚洲精品中文字幕乱码三区91 | 91精品国产色综合久久不卡98 | 乳色吐息樱花 | 色婷婷av一区二区三区之e本道 | 日韩在线免费观看视频 | 国产成人在线视频 | 日本中文字幕在线 | 欧美成人精品一区二区三区在线看 | 欧美日韩第一区 | www.97超碰 | 成人免费在线视频观看 | 亚洲视频一区二区三区 | 国产欧美一区二区精品性色超碰 | 国产精品6| 麻豆一区二区三区 | 免费a网站 | 亚洲成人a v | 91麻豆精品国产91久久久久久 | 成人三级在线观看 | 亚洲精品成人网 | 色爱综合区 | 亚洲精品在线看 | 在线看成人片 | 国产理论在线观看 | 免费网站av| 欧美一区二区三区视频 | 五月天在线观看 | 国产精品麻豆免费版 | 日韩黄色片 |
