查看: 1801|回復: 0
Bus Error
ID:107189 發表于 2016-3-5 18:10 | 顯示全部樓層 |閱讀模式
在x86+Linux上寫的程序,在PC機上運行得很好。可是使用ARM的gcc進行交叉編譯,再送到DaVinci目標板上運行的時候,出現了Bus error。
出現的位置如下(其中Debug的內容是我在程序中添加的調試信息):
root@211.69.193.189:~# arm_v5t_le-gcc -g shit.c
root@211.69.193.189:~# ./a.out
Debug: malloc space for the actual data: temp_buf = 0x13118
Debug: in my_recvn()
Debug: nleft = 52
Bus error
打開調試器進行調試:
root@211.69.193.189:~# gdb a.out
GNU gdb 6.3 (MontaVista 6.3-20.0.22.0501131 2005-07-22)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "armv5tl-montavista-linuxeabi"...Using host libthread_db library "/lib/tls/libthread_db.so.1".
(gdb) run // 運行程序
Starting program: /home/zpf/a.out
Debug: in get_program_info()
Debug: in conn_server(char *err_buf_ptr)
Debug: gonna create a socket
Debug: gonna fill in the serv_addr structure
Debug: gonna connect to a server
Debug: gonna send LIN_RST
Debug: in my_sendn()
Debug: send 4 bytes to server:
Debug: gonna receive LIN_RSP
Debug: nleft = 3
Debug: received first 3 bytes from server: 7
Debug: gonna check if 3rd byte is the package type
Debug: received package length = 55
Debug: nleft = 52
Program received signal SIGBUS, Bus error. // 在這里出現了錯誤
0x00009624 in alloc_prog_mem (detail_buf=0x13118 "\001\002",
err_buf_ptr=0xbefffc40 "") at shit.c:631
631 g_data_ptr->progtype_num = *(short *)ptr ;
(gdb) print ptr // 查看一下ptr的值
$1 = 0x13119 "\002" // 地址起始是奇數!!!
(gdb) set ptr=0x1311a // 想改一下
(gdb) continue
Continuing.
Program terminated with signal SIGBUS, Bus error.
The program no longer exists. // 可惜程序已經退出
(gdb) quit
其中,g_data_ptr->progtype_num是一個short類型的值。
把強制類型轉換改為用memcpy()寫值之后,再調試
root@211.69.193.189:~# gdb test
(gdb) break 626 // 把剛剛的那句強制類型轉換變成內存拷貝
Breakpoint 1 at 0x9630: file test.c, line 626.
(gdb) run
Starting program: /home/zpf/test
Debug: nleft = 3
Debug: nleft = 52
Breakpoint 1, alloc_prog_mem (detail_buf=0x13118 "\001\002",
err_buf_ptr=0xbefffc40 "") at test.c:626
warning: Source file is more recent than executable.
626 memcpy(&(g_data_ptr->prog_num), ptr, 2) ; // 在這一句中斷
(gdb) print ptr // 再看看ptr
$1 = 0x1311b "\003" // 還是奇數地址
(gdb) continue // 繼續執行
Continuing.
Debug: sum_progtype = 2 , sum_prog = 3
Debug: gonna malloc space for progtype_ptr
Debug: gonna malloc space for prog_ptr
Debug: in mv_pkg2prog_list()
Debug: gonna set ProgramType program_type_name
Debug: ProgramType program_type_name set OK
Debug: in $ == *ptr, j = 0
Debug: g_data_ptr->progtype_ptr[j].prog_ptr = temp_prog_ptr
Debug: in @ == *ptr, ptr = 0x13126
Debug: temp_prog_ptr->format = *ptr
Debug: temp_prog_ptr->program_id = *(int *)ptr
Debug: gonna set Program program_name
Debug: Program program_name set OK
Debug: finished one loop of while
Debug: in @ == *ptr, ptr = 0x1312f
Debug: in $ == *ptr, j = 1
Debug: in @ == *ptr, ptr = 0x13142
program type[0]
program_type_id = 1
program_type_name = love
program_num = 2
prog_ptr = 0x131d8
program[0]
program_id = 1001
program_name = you
format = 1
program[1]
program_id = 1002
program_name = me
format = 2
program type[1]
program_type_id = 2
program_type_name = hatred
program_num = 1
prog_ptr = 0x13248
program[0]
program_id = 2005
program_name = kill
format = 5
Debug: gonna return an OK
Debug: Entering send_exit_requstion()
Debug: gonna send EXIT_RST
Debug: nleft = 4
Program exited normally. // 執行通過了!!!!
(gdb)
總結:
問題總算找到了,就是我企圖在一個奇數地址起始的地方強制類型轉換得到一個short值。
在Intel系列處理器上,可以在任一奇數內存地址儲存任何變量或數組,不會導致任何致命的錯誤影響,只是效率可能會降低。但在DaVinci上,這一點不行。所以必須對大于一個字節的數據類型小心謹慎,比較安全的方法是使用內存拷貝函數memcpy(),或者使用下面的代替方法:
// 先定義一個聯合體
union {
short short_val ;
char short_byte[2] ;
} myshort ;
// 然后,把程序中本來應該是
// g_data_ptr->progtype_num = *(short *)ptr ;
// ptr += 2 ;
// 這兩句的地方換成下面五句:
myshort.short_byte[0] = *ptr ;
ptr++ ;
myshort.short_byte[1] = *ptr ;
ptr++ ;
g_data_ptr->progtype_num = myshort.short_val ;
// 當然,最簡單的方法是換成下面兩句:
// memcpy(&(g_data_ptr->progtype_num), ptr, 2) ;
// ptr += 2 ;
對于這個問題的進一步探討:
在DaVinci上應該注意內存編址模式的問題。
struct {
char struc_char ;
int struc_int ;
short struc_short ;
long struct_long ;
} struc_val ;
在寬松模式下,盡管struc_char只有1個字節,struc_short占2個字節,但編譯器可能給這兩個變量分別分配了4個字節,結果整個結構的大小變成了16個字節,而在編譯器設為緊湊模式時,則正好是11個字節。根據計算機數據總線的位數,不同的編址模式存取數據的速度不一樣。我認為在符合總線字長的情況下,效率是最高的,因為只需進行一次總線操作。
內存編址模式會影響字節對齊方式,字節對齊操作可以解決以下兩個主要的問題:
1.訪存效率問題;一般的編譯器要對內存進行對齊,在處理變量時,編譯器會根據一定的設置將長短不同的變量的數據長度進行對齊以加快內存處理速度。
2.強制類型轉換問題:在x86上,字節不對齊的操作只會影響效率,但是在DaVinci上,可能就是一個Bus error, 因為它要求必須字節對齊。
字節對齊的準則
1.數據類型自身的對齊值:對于char型數據,其自身對齊值為1,對于short型為2,對于int,long,float,double類型,其自身對齊值為4字節。
2.結構體的自身對齊值:其成員中自身對齊值最大的那個值。
3.指定對齊值:#pragma pack (value)時的指定對齊值value。
4.數據成員、結構體和類的有效對齊值:自身對齊值和指定對齊值中小的那個值。
對于平時定義變量,盡可能先定義長度為4的倍數的變量,然后是長度是2的變量,最后是長度為1的變量。
通過測試,GCC編譯器是按照4字節對齊存放于內存的。而我還沒有發現更改編址模式的參數。程序如下:
#include
int main()
struct {
char struc_char ;
int struc_int ;
short struc_short ;
long struct_long ;
} struc_val ;
char c_char ;
int i_int ;
short s_short ;
long l_long ;
printf("sizeof(struc_val) = %d\n", sizeof(struc_val));
printf("sizeof(c_char) = %d\n", sizeof(c_char));
printf("sizeof(i_int) = %d\n", sizeof(i_int));
printf("sizeof(s_short) = %d\n", sizeof(s_short));
printf("sizeof(l_long) = %d\n", sizeof(l_long));
printf("address of struc_val = %p\n", &struc_val);
printf("address of struc_char = %p\n", &(struc_val.struc_char));
printf("address of struc_int = %p\n", &(struc_val.struc_int));
printf("address of struc_short = %p\n", &(struc_val.struc_short));
printf("address of struct_long = %p\n", &(struc_val.struct_long));
printf("address of c_char = %p\n", &c_char);
printf("address of i_int = %p\n", &i_int);
printf("address of s_short = %p\n", &s_short);
printf("address of l_long = %p\n", &l_long);
return 0 ;
測試結果:
sizeof(struc_val) = 16
sizeof(c_char) = 1
sizeof(i_int) = 4
sizeof(s_short) = 2
sizeof(l_long) = 4
address of struc_val = 0xbf885278
address of struc_char = 0xbf885278
address of struc_int = 0xbf88527c
address of struc_short = 0xbf885280
address of struct_long = 0xbf885284
address of c_char = 0xbf885277
address of i_int = 0xbf885270
address of s_short = 0xbf88526e
address of l_long = 0xbf885268
所以對于一個32位的數據來講,如果其沒有在4字節整除的內存地址處存放,那么處理器就需要2個總線周期對其進行訪問。
0x08 | byte8 | byte9 | byteA | byteB |
0x04 | byte4 | byte5 | byte6 | byte7 |
0x00 | byte0 | byte1 | byte2 | byte3 |
對于我剛剛的那個出現Bus error的程序,假設指針ptr剛好是指向了byte3(地址是0x0),然后想進行short強制類型轉換,使用byte3,byte4來構成一個short類型的值,由于第一次總線的數據只有byte0,byte1,byte2,byte3,取不到byte4,這在DaVinci板子上,就是一個Bus error了,因為沒有達到邊界對齊。如果ptr指的是byte2(地址0x02),就沒有問題了。因為0x02地址值是sizeof(short)的整數倍。
理解SIGBUS與SIGSEGV
Q: SIGSEGV我能理解,但有時碰上SIGBUS,這該如何理解。
A: nkwht@SMTH
nkwht用Google獲取這樣一些知識。有多種可能導致SIGBUS信號:
1) 硬件故障,不用說,程序員最常碰上的肯定不是這種情形。
2) Linux平臺上執行malloc(),如果沒有足夠的RAM,Linux不是讓malloc()失敗返回,
而是向當前進程分發SIGBUS信號。
注: 對該點執懷疑態度,有機會可自行測試確認當前系統反應。
3) 某些架構上訪問數據時有對齊的要求,比如只能從4字節邊界上讀取一個4字節的
數據類型。IA-32架構沒有硬性要求對齊,盡管未對齊的訪問降低執行效率。另外
一些架構,比如SPARC、m68k,要求對齊訪問,否則向當前進程分發SIGBUS信號。
SIGBUS與SIGSEGV信號一樣,可以正常捕獲。SIGBUS的缺省行為是終止當前進程并產
生core dump。
A: Marc Rochkind <
rochkind@basepath.com>
SIGBUS與SIGSEGV信號的一般區別如下:
1) SIGBUS(Bus error)意味著指針所對應的地址是有效地址,但總線不能正常使用該
指針。通常是未對齊的數據訪問所致。
2) SIGSEGV(Segment fault)意味著指針所對應的地址是無效地址,沒有物理內存對
應該地址。
主站蜘蛛池模板: 久久最新视频 | 中文字幕一区二区三区四区视频 | 欧美在线中文字幕 | 福利视频网址 | 久久精品中文字幕 | 免费黄色小网站 | 国产午夜在线 | 亚洲精品日韩丝袜精品 | 亚洲激情一区二区 | www..com黄 | 亚欧在线观看 | 成人激情视频在线观看 | 国产精品国产三级国产专区52 | 日韩欧美在线观看 | 日韩一区不卡 | 久久久不卡 | 色交视频 | 久久久久久久成人 | 91综合在线 | 日韩视频免费在线观看 | 男女操网站| 中文字幕在线一区二区三区 | 国产视频一区在线观看 | 亚洲久久久 | 成人一区二区三区 | 欧美日韩第一区 | 欧美国产日韩视频 | 亚洲午夜视频在线观看 | 午夜影院免费观看 | 欧美日韩免费在线观看 | 激情影院在线观看 | 国产特黄 | 日韩在线一区二区 | 欧美精品第一页 | 岛国精品在线播放 | 国产视频99 | 黄色一级片视频 | 午夜视频一区 | 国产精品av在线 | 国产欧美视频在线观看 | 久久久久毛片 |
