查看: 1277|回復(fù): 0
apt 更新錯誤。
ID:107189 發(fā)表于 2016-3-6 16:01 | 顯示全部樓層 |閱讀模式
There are many problem due to which this issue has come. Some of then are :
  • Any entry in you apt.list is not working. You or any application has created a wrong entry.
  • apt repository are not currently working.
  • Corrupt in /var/lib/apt/lists/ folder.
So for both of them there are different solution, if you didn't know the exact problem then follow following steps:
  • Use another mirrors of apt. In ubuntu there is file name /etc/apt/sources.list and folder containing some files in /etc/apt/sources.list.d/. So, from there you can change use any other mirrors of apt. Like you can change your India repository to US repository, etc. by editing these files.
  • There is another possibility too that you having any other repository link (third party) which is not responding for the moment. So, you can also delete them from the above given files. You can also remove all third party repositories from list
    rm -rf /etc/apt/sources.list.d/*
  • Remove all contents from /var/lib/apt/lists/
    rm -rf /var/lib/apt/lists/*
  • I had this issue on my ubuntu on virtualbox before. I tried all above but that won't help.
    When I worked on other backup script and I recognized that my server had incorrect date/time. I have change that and the apt-get update works like a charm.
主站蜘蛛池模板: 亚洲免费二区 | 国产成人精品亚洲男人的天堂 | 国产精品区二区三区日本 | 久久日av | 久久成人免费视频 | 一级片在线观看视频 | 老女人丨91丨九色 | 国产欧美一区二区三区在线看蜜臀 | 成人在线视频免费 | 天天爽天天操 | 少妇高潮毛片 | 国产性生活 | 一区二区三区不卡视频 | 午夜黄色大片 | 久久一区二区视频 | 黄片毛片在线观看 | 三级av在线 | 欧美在线视频一区 | www久久| 黄视频免费在线观看 | 91av在线免费观看 | 亚洲免费精品 | 黄色成人在线视频 | 欧美日韩免费 | 九九精品视频在线观看 | 亚洲一区中文 | 精品网站999www | 69av在线播放| 国产小视频在线 | 中文字幕丰满人伦在线 | 久久小视频 | 欧美精品xxx| 日韩伦理视频 | 日本亚洲欧美 | 亚州av在线 | 国产精品高清在线观看 | 中文字幕在线观看不卡 | 日韩国产欧美 | 亚洲国产精品久久久久 | 精品黄色片 | 日韩免费在线观看 |
