查看: 1713|回復: 0
nvidia install problem(網(wǎng)摘)
ID:107189 發(fā)表于 2016-3-6 16:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
I have Ubuntu 14.04 64bit and NVIDIA Geforce GTX 960 that caused me a lot of problems to install. Hopefully this can help somebody:
in terminal write
sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade && sudo apt-get install build-essential && sudo apt-get install linux-source && sudo apt-get install linux-headers-generic
sudo gedit /etc/default/grub #change line "GRUB_CMDLINE_LINUX_DEFAULT..."-line to
GRUB_CMDLINE_LINUX_DEFAULT="nouveau.blacklist=1     quiet splash nomodeset" #(forces low-level graphics to ensure putty does     not give black screen)
sudo update-grub2
sudo apt-get remove nvidia* && sudo apt-get autoremove #ensures no former installation clashes with new install
sudo reboot
After reboot get correct nvidia-driver (chose graphic-card and OS) at “http://www.nvidia.com/Download/index.aspx?lang=en-us" (or search webb with “nvidia download”). Right-click on downloaded file and change if to executable.
sudo gedit /etc/modprobe.d/blacklist.conf #add these lines at the end:
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
blacklist lbm-nouveua
options nouveau modeset=0
alias nouveau off
alias lbm-nouveau off
Open a putty-terminal with Ctrl + Alt     + F1
sudo service lightdm stop #stops graphic session to enable nvidiainstallation
cd Downloads #(or wherever you downloaded your nvidia-file)
sudo ./{the downloadedfilename.run} #follow installation-instructions (normally yes to all)sudo nvidia-xconfig #(if you did not chose “yes” to this in the installation”
sudo nano /etc/default/grub # change the "GRUB_CMBLINE_LINUX_DEFAULT..."-line to below:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset”
sudo update-grub2 #update grub!
sudo reboot
主站蜘蛛池模板: 久久精品视频一区二区 | 伊人9999| 久草手机在线视频 | 成人午夜免费视频 | 成年人免费看片 | 一区二区水蜜桃 | 日韩大片在线观看 | 国产精品黄 | 久久不射网 | 日本加勒比在线 | 黄色国产片 | 一级片日韩 | 国产三级在线免费观看 | 日韩一二区 | 国产黄色大片 | 91黄色片| 黄色特级片 | 国产999久久久 | 日韩精品一区在线观看 | 黄色片网站视频 | 深夜福利av | 成人在线免费视频观看 | 色婷婷在线播放 | 天天干天天舔 | 免费不卡视频 | 涩涩视频免费看 | 永久免费看片在线播放 | 丁香激情网 | 久久久久久亚洲 | 欧美久久一区二区 | 久久婷婷色 | 日韩av一区二区三区四区 | 一区二区三区四区视频 | 亚洲伦理精品 | 亚洲精品一二三四 | 欧美顶级黄色大片免费 | 日本欧美久久久久免费播放网 | 成人在线一区二区 | 成人免费视频视频 | 国产精品一区二区三 | 天天躁日日躁bbbbb |
