查看: 3048|回復: 0
inline hook -- NtGetContextThread
ID:108531 發表于 2016-3-12 16:03 | 顯示全部樓層 |閱讀模式
#include <ntddk.h>
//#include <ntifs.h>
#include <windef.h>
ULONG g_NtGetContextThread;
ULONG g_uCr0;
BYTE g_HookCode[5] = { 0xe9, 0, 0, 0, 0 };
BYTE g_OrigCode[5] = { 0 }; // 原函數的前字節內容
BYTE jmp_orig_code[7] = { 0xEA, 0, 0, 0, 0, 0x08, 0x00 };
BOOL g_bHooked = FALSE;
typedef struct _SERVICE_DESCRIPTOR_TABLE
PVOID ServiceTableBase;
PULONG ServiceCounterTableBase;
ULONG NumberOfService;
ULONG ParamTableBase;
}SERVICE_DESCRIPTOR_TABLE,*PSERVICE_DESCRIPTOR_TABLE;
NTSTATUS  PsLookupProcessByProcessId(IN ULONG ulProcId, OUT PEPROCESS * pEProcess);
VOID NtGetContextThread
  IN HANDLE ThreadHandle,
  OUT PCONTEXT pContext
VOID NewNtGetContextThread
extern PSERVICE_DESCRIPTOR_TABLE KeServiceDescriptorTable;
typedef struct _THREAD_BASIC_INFORMATION
NTSTATUS                ExitStatus;
PVOID                   TebBaseAddress;
CLIENT_ID               ClientId;
KAFFINITY               AffinityMask;
KPRIORITY               Priority;
KPRIORITY               BasePriority;
} THREAD_BASIC_INFORMATION, *PTHREAD_BASIC_INFORMATION;
NTSYSAPI NTSTATUS NTAPI NtQueryInformationThread
IN THREADINFOCLASS ThreadInformationClass,
OUT PVOID               ThreadInformation,
IN ULONG                ThreadInformationLength,
OUT PULONG              ReturnLength OPTIONAL
void WPOFF()
    ULONG uAttr;
    _asm
        push eax;
        mov eax, cr0;
        mov uAttr, eax;
        and eax, 0FFFEFFFFh; // CR0 16 BIT = 0
        mov cr0, eax;
        pop eax;
        cli
    g_uCr0 = uAttr; //保存原有的 CRO 屬性
VOID WPON()
    _asm
        sti
        push eax;
        mov eax, g_uCr0; //恢復原有 CR0 屬性
        mov cr0, eax;
        pop eax;
// 停止inline hook
VOID UnHookNtGetContextThread()
    KIRQL  oldIrql;
    WPOFF();
    oldIrql = KeRaiseIrqlToDpcLevel();
if(g_NtGetContextThread)
  RtlCopyMemory ( (BYTE*)g_NtGetContextThread, g_OrigCode, 5 );
    KeLowerIrql(oldIrql);
    WPON();
    g_bHooked = FALSE;
// 開始inline hook --  NtGetContextThread
VOID HookNtGetContextThread()
    KIRQL  oldIrql;
    if (g_NtGetContextThread == 0) {
        DbgPrint("NtGetContextThread == NULL\n");
        return;
    //DbgPrint("開始inline hook --  NtGetContextThread\n");
    DbgPrint( "NtGetContextThread Addrress is:0x%08x\n", (ULONG)g_NtGetContextThread );
    // 保存原函數的前字節內容
    RtlCopyMemory (g_OrigCode, (BYTE*)g_NtGetContextThread, 5);
    *( (ULONG*)(g_HookCode + 1) ) = (ULONG)NtGetContextThread - (ULONG)g_NtGetContextThread - 5;
    // 禁止系統寫保護,提升IRQL到DPC
    WPOFF();
    RtlCopyMemory ( (BYTE*)g_NtGetContextThread, g_HookCode, 5 );
    *( (ULONG*)(jmp_orig_code + 1) ) = (ULONG) ( (BYTE*)g_NtGetContextThread + 5 );
    RtlCopyMemory ( (BYTE*)NewNtGetContextThread+0x4E, g_OrigCode, 5);
    RtlCopyMemory ( (BYTE*)NewNtGetContextThread + 0x53, jmp_orig_code, 7);
    // 恢復寫保護,降低IRQL
    WPON();
    g_bHooked = TRUE;
// 跳轉到我們的函數里面進行預處理
__declspec (naked)
    //DbgPrint("inline hook --  KiInsertQueueApc 成功\n");
    __asm
               jmp NewNtGetContextThread
// 代理函數,負責跳轉到原函數中繼續執行
DWORD __stdcall GetProcessIdOfThread(HANDLE Thread)
THREAD_BASIC_INFORMATION ThreadBasic;
NTSTATUS Status;
Status = NtQueryInformationThread(Thread,
  ThreadBasicInformation,
  &ThreadBasic,
  sizeof(THREAD_BASIC_INFORMATION),
  NULL);
if(!NT_SUCCESS(Status))
  return 0;
return (DWORD)ThreadBasic.ClientId.UniqueProcess;
__declspec (naked)
PEPROCESS uEprocess ;
DWORD pid;
NTSTATUS status;
LPTSTR ProcessName;
pid=GetProcessIdOfThread(ThreadHandle);
DbgPrint("pid=%0x,ChaoNiMa\n",pid);
status= PsLookupProcessByProcessId(pid,&uEprocess);
ProcessName = (LPTSTR)uEprocess+0x1FC;
DbgPrint("ThreadHandle=%s,pContext=%0x,ChaoNiMa\n",ProcessName,pContext);
    __asm {  // 共字節
            _emit 0x90
            _emit 0x90
            _emit 0x90
            _emit 0x90
            _emit 0x90  // 前字節實現原函數的頭字節功能
            _emit 0x90  // 這個填充jmp
            _emit 0x90
            _emit 0x90
            _emit 0x90
            _emit 0x90  // 這字節保存原函數+5處的地址
            _emit 0x90
            _emit 0x90  // 因為是長轉移,所以必須是0x0080
ULONG GetFunctionAddr(IN PCWSTR FunctionName)
    UNICODE_STRING UniCodeFunctionName;
    RtlInitUnicodeString(&UniCodeFunctionName, FunctionName);
    return (ULONG)MmGetSystemRoutineAddress(&UniCodeFunctionName);
//根據特征值,從KeInsertQueueApc搜索中搜索KiInsertQueueApc
ULONG FindKiInsertQueueApcAddress()
  char * Addr_KeInsertQueueApc = 0;
  int i = 0;
  char Findcode[] = { 0xE8, 0xcc, 0x29, 0x00, 0x00 };
  ULONG Addr_KiInsertQueueApc = 0;
    Addr_KeInsertQueueApc = (char *) GetFunctionAddr(L"KeInsertQueueApc");
  for(i = 0; i < 100; i ++)
    if(  Addr_KeInsertQueueApc[i] == Findcode[0] &&
  Addr_KeInsertQueueApc[i + 1] == Findcode[1] &&
  Addr_KeInsertQueueApc[i + 2] == Findcode[2] &&
  Addr_KeInsertQueueApc[i + 3] == Findcode[3] &&
  Addr_KeInsertQueueApc[i + 4] == Findcode[4]
      Addr_KiInsertQueueApc = (ULONG)&Addr_KeInsertQueueApc[i] + 0x29cc + 5;
      break;
  return Addr_KiInsertQueueApc;
VOID OnUnload( IN PDRIVER_OBJECT DriverObject )
  DbgPrint("UnHookNtGetContextThread");
  UnHookNtGetContextThread();
NTSTATUS DriverEntry( IN PDRIVER_OBJECT theDriverObject, IN PUNICODE_STRING theRegistryPath )
//UNICODE_STRING UniCodeFunctionName;
DbgPrint("HooK NtGetContextThread Sample!\n");
theDriverObject->DriverUnload = OnUnload;
//RtlInitUnicodeString(&UniCodeFunctionName, L"NtGetContextThread");
//g_NtGetContextThread=(ULONG)MmGetSystemRoutineAddress(&UniCodeFunctionName);
//p=(ULONG *)((ULONG)KeServiceDescriptorTable->ServiceTableBase + 0x55*4);
//NtQueryInformationThread =(NTSTATUS )*(ULONG *)((ULONG)KeServiceDescriptorTable->ServiceTableBase + 0x9B*4);;
g_NtGetContextThread=*(ULONG *)((ULONG)KeServiceDescriptorTable->ServiceTableBase + 0x55*4);;
return STATUS_SUCCESS;
主站蜘蛛池模板: 日本视频一区二区三区 | 日本一级淫片色费放 | 久久久久久久 | 激情综合久久 | 岛国精品在线播放 | 日韩视频免费看 | 亚洲在线观看视频 | 中文字幕免费观看视频 | 亚州成人 | 天天草天天| 欧美精产国品一二三区 | 夜夜嗨av一区二区三区网页 | 欧美久久网 | 日韩精品免费观看 | 亚洲69视频 | 一区二区精品 | 久久精品视频一区二区 | 久久精品二区 | 午夜一区| 亚洲成人一区二区三区 | 精品一区视频 | 色综合天天 | 成人毛片100免费观看 | 亚洲成人精品在线观看 | 亚洲天堂男人天堂 | 天堂中文字幕免费一区 | 丁香花在线观看 | 四虎影音 | 国产三级在线 | 国产黄色在线观看 | 日本高清www | 九九爱视频 | 密乳av| a天堂在线视频 | 蜜臀久久99精品久久久久久宅男 | 亚洲欧美高清 | 欧美一二 | 日本亚洲精品 | 国产精品免费在线播放 | 午夜精品999 | 青青国产视频 |
