查看: 2075|回復(fù): 0
51溫控程序
ID:117626 發(fā)表于 2016-4-30 09:05 | 顯示全部樓層 |閱讀模式
#include"reg52.h"
#include"intrins.h"
#include"math.h"
#define uchar unsigned char
#define uint unsigned int
#define Lcd_Data P0
uchar code dispbuf[33]={"Temperature:`CSX: `C XX: `C"};
uchar numcode[10]={'0','1','2','3','4','5','6','7','8','9'};
uint num[30]={0};
uchar count=0;//10秒記次數(shù)
sbit RS=P2^0;//lcdrs
sbit RW=P2^1;//lcdrw
sbit E=P2^2;//lcde
sbit Busy=P0^7;//lcd忙
sbit LED=P3^4;
sbit BUZZER=P3^5;
sbit jidianqi=P3^6;
sbit K0=P1^0;
sbit K1=P1^1;
sbit ON=P1^2;
sbit OFF=P1^3;
uchar bdata flag;
sbit DQ  =P2^7;
uint temp,shangxian,xiaxian,xianwen;
void delay(void);
void Init_LCD(void);
void Write_Comm(uchar);
void Write_Data(uchar);
void Read_Busy(void);
void Init_18B20(void);
uchar ReadOneChar(void);
void WriteOneChar(uchar dat);
void tessttemp(void);
uint wd(void);
void Delay(uint time);
sbit sta_flag=flag^0;
sbit fuhao=flag^1;
void timer1(void);
void delay1ms(void);
void sys_init(void);
void display(void);
void hextobcd(bit flag,uchar num);
void bm(void);
void delay15(uchar us);
void keyscan(void);
void delay3(uint z)
  uint x,y;
  for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void main(void)
{LED=0;
BUZZER=0;
shangxian=99,xiaxian=5;
delay1ms();
sys_init();
delay1ms();
TR0=1;
ET0=1;
testtemp();
while(!ON)
if(OFF==0) break;
{if(OFF==0)break;
xianwen=temp*0.0625;
keyscan();
if(15==count)
temp=wd();
count=0;
testtemp();
display();
hextobcd();
if(xianwen<xiaxian)
LED=1;
jidianqi=0;
if(xianwen>=shangxian)
{LED=0;
jidianqi=1;
BUZZER=1;
delay3(5);
BUZZER=0;
Write_Comm(0x01);
void keyscan()
{uchar num;
if(K0=0)
{delay3(150);
if(K0=0)
num++;
if(num==5)num=0;
if(K1==0)
{delay3(150);
if(num==0)
{xiaxian++;
if(xiaxian==50)
   xiaxian=5;
void timer0(void)interrupt 1 using 0
TH0=0x15;
TL0=0xA0;
TH1=0;
TL1=0;
count++;
_nop_();
_nop_();
_nop_();
_nop_();
void sys_init(void)
uchar i;
for(i=0;i<29;i++)
num[i]=0;}
TMOD=0x11;
TH0=0x15;
TL0=0xA0;
P0=0;
EA=1;
void hextobcd(void)
float tp;
unsigned long int tmp;
fuhao=0;
if(temp<0x8000)
tp=temp*0.0625;
bm();
tp=temp*0.0625;
fuhao=1;
tp*=10;
tmp=tp;
num[12]=tmp/100;
if(fuhao)
num[12]=num[12]|0x80;
num[13]=tmp/10-(tmp/100)*10;
num[19]=shangxian/10;
num[20]=shangxian%10;
num[28]=xiaxian/10;
num[29]=xiaxian%10;
Init_18B20();
if(flag)
WriteOneChar(0xCC);
WriteOneChar(0x44);
uint wd(void)
unsigned int a=0,b=0,t=0;
Init_18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
return(t);
DQ=1;
Delay(10);
DQ=0;
Delay(80);
DQ=1;
Delay(10);
if(DQ)
flag=0;
flag=1;
Delay(20);
uchar i=0;
uchar dat=0;
for(i=8;i>0;i--)
DQ=0;
dat>>=1;
DQ=1;
if(DQ)
dat|=0x80;
Delay(15);
return(dat);
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for(i=8;i>0;i--)
DQ=0;
DQ=dat&0x01;
Delay(5);
DQ=1;
dat>>=1;
void bm(void)
temp=~temp;
temp+=1;
void display(void)
uchar a,b,d;
Init_LCD();
Write_Comm(0x01);
Write_Comm(0x80);
for(a=0;a<16;a++)
d=dispbuf[a];
if((a>11)&&(a<14))
d=numcode[num[a]];
if(14==a)
d=0xdf;
Write_Data(d);
Write_Comm(0xc0);
for(b=16;b<33;b++)
d=dispbuf[b];
if((b>18)&&(b<21))
d=numcode[num[b]];
if((b>27)&&(b<30))
d=numcode[num[b]];
if(b==21)
d=0xdf;
if(30==b)
d=0xdf;
Write_Data(d);
do{
Lcd_Data=0xff;
RS=0;
RW=1;
E=0;
delay();
E=1;
}while(Busy);
void Write_Comm(uchar lcdcomm)
Lcd_Data=lcdcomm;
RS=0;
RW=0;
E=0;
Read_Busy();
E=1;
void Write_Data(uchar lcddata)
Lcd_Data=lcddata;
RS=1;
RW=0;
E=0;
Read_Busy();
E=1;
void Init_LCD(void)
delay();
Write_Comm(0x01);
Write_Comm(0x38);
Write_Comm(0x06);
Write_Comm(0x0c);
do
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
us--;
while(us);
while(time--);
void delay1ms(void)
uchar i,j;
for(i=0;i<2;i++)
   for(j=0;j<255;j++);
void delay()
uchar y;
for(y=0;y<0xff;y++);
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 天堂av资源 | 成 人 黄 色 片 在线播放 | 五月天婷婷影院 | 国产视频一区在线观看 | 久久99精品久久久久久国产越南 | 激情久久网| 香蕉视频在线播放 | 中文字幕第三页 | 久久精品久久精品 | 欧美中文字幕在线观看 | 国产伦精品一区二区三区视频网站 | 青青草网站 | 日韩av在线免费 | 国产精品日日摸天天碰 | 在线免费黄色 | 欧美精品在线观看 | 久久青 | 国产麻豆精品视频 | 久久av一区| 国产在线天堂 | 一级片黄色 | 黄色一及片 | 自拍偷拍中文字幕 | av动漫在线观看 | 成人日韩在线 | 美日韩在线视频 | 黄色一级影片 | 欧美福利在线 | 国产色视频一区二区三区qq号 | 国产一级片在线播放 | 91婷婷| 中文av网站 | 超碰在线91 | 日韩国产精品视频 | 午夜影院黄 | 欧美精品一级片 | 久久久久久久久国产精品 | 一区二区三区四区在线视频 | 精品国产一二三区 | 国产寡妇亲子伦一区二区三区四区 | 成人精品免费 |
