查看: 6485|回復: 0
excel vba 實現自動排單功能
ID:114320 發表于 2016-5-8 01:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
           工作中發現每次排翻縫計劃時,總要把excel總表的訂單信息按每個訂單預定計劃領坯日期,復制到翻縫計劃表對應的日期下。今天就琢磨著能否一鍵搞定,實現自動翻縫排單,沒有想到41行代碼就能搞定每天要花20分鐘的工作量,把過程記錄下:
源表一(總表)
目標表二(翻縫計劃)
實現思路:
        先獲取總表中選取行的所有行號并存入數組中,然后把所在行對應的計劃領坯日期去翻縫計劃中去查找,找到后獲得翻縫計劃表里
的日期所在的行號,并向下移動3行插入一空白行,再把總表中相應的訂單信息數據對應填下到翻縫計劃表的空白行中,同時把對應合約號以紅色底紋標識。
自動排單按鈕后的vba代碼:
Public Sub getrows_to_fanbu()
    Dim a() As Integer
    k = Selection.Cells.Count
    ReDim a(k)
    a(0) = -1
    n = 0
    For Each c In Selection.Cells
    n = n + 1
    a(n) = c.Row
    For i = 0 To n - 1
    If a(n) = a(i) Then
    n = n - 1
    End If
    Next i
    Next c
    Application.StatusBar = "系統正在自動排單中,請耐心等待1分鐘左右...."
    Dim currow As Double
    Application.ScreenUpdating = False
    Application.Calculation = xlCalculationManual
    Application.MaxChange = 0.001
   For i = 1 To n
   currow = Application.WorksheetFunction.Match(Sheets("總表").Cells(a(i), 16), Sheets("翻縫計劃").Range("k:k"), 1)
   Sheets("翻縫計劃").Rows(currow + 3).Resize(1).Insert   '翻縫日期下第二行處插入一空白行
   '翻縫計劃表里寫入數據
    Sheets("翻縫計劃").Cells(currow + 3, 1) = Sheets("總表").Cells(a(i), 2)
    Sheets("翻縫計劃").Cells(currow + 3, 2) = Sheets("總表").Cells(a(i), 3)
    Sheets("翻縫計劃").Cells(currow + 3, 3) = Sheets("總表").Cells(a(i), 4)
    Sheets("翻縫計劃").Cells(currow + 3, 4) = Sheets("總表").Cells(a(i), 5)
    Sheets("翻縫計劃").Cells(currow + 3, 5) = Sheets("總表").Cells(a(i), 6)
    Sheets("翻縫計劃").Cells(currow + 3, 6) = Sheets("總表").Cells(a(i), 7)
    Sheets("翻縫計劃").Cells(currow + 3, 7) = Sheets("總表").Cells(a(i), 8)
    Sheets("翻縫計劃").Cells(currow + 3, 8) = Sheets("總表").Cells(a(i), 9)
    Sheets("翻縫計劃").Cells(currow + 3, 9) = Sheets("總表").Cells(a(i), 10)
    Sheets("翻縫計劃").Cells(currow + 3, 10) = Sheets("總表").Cells(a(i), 11)
    Sheets("翻縫計劃").Cells(currow + 3, 11) = Sheets("總表").Cells(a(i), 12)
    Sheets("翻縫計劃").Cells(currow + 3, 12) = Sheets("總表").Cells(a(i), 13)
    Sheets("翻縫計劃").Cells(currow + 3, 13) = Sheets("總表").Cells(a(i), 14)
    '格式化填寫的數據
     Sheets("翻縫計劃").Cells(currow + 3, 2).Interior.Color = RGB(255, 0, 0)  '設置合約號單元格的背景色為紅色
    'Sheets("").Activate
  '' Sheets("").Range(Cells(currow + 3, 1), Cells(currow + 3, 14)).Select
   'With Selection
    '  .Font.Name = ""
    '  .Font.Size = 10
    '   .Font.FontStyle = ""
  ' End With
   'MsgBox currow
   Next i
   Application.Calculation = xlCalculationAutomatic
   Application.ScreenUpdating = True
   Application.StatusBar = "自動排單成功"
' Dim oe As New Excel.Application
'       Dim ow As Workbook
'       Dim os As Worksheet
'      Set ow = oe.Workbooks.Open("E:\\.xls")
'       Set os = ow.Worksheets("")
'        oe.Visible = False
'For i = 1 To n
          'a(i)
  ' '       os.Cells(2, 4) = ""
   '       os.Cells(3, 2) = ""
   '       os.Cells(4, 2) = ""
   '       os.Cells(4, 6) = "0 "
   '       os.Cells(5, 2) = ""
   '       os.Cells(2, 4) = Trim(Cells(a(i), 2))
   '       os.Cells(3, 2) = Trim(Cells(a(i), 3)) & " " & Trim(Cells(a(i), 4)) & " " & Trim(Cells(a(i), 5))
    '      os.Cells(4, 2) = Trim(Cells(a(i), 6))
    '      os.Cells(4, 6) = Cells(a(i), 7) & " "
    '      os.Cells(5, 2) = Trim(Cells(a(i), 12))
    '      os.PrintOut
'Next i
      ' ow.Save
      ' ow.Close
   '  Set ow = Nothing
   '   oe.Quit
End Sub
使用方法:
      1、選定總表中需要排單的所在行(可以同時選多行)
      2、點擊自動排單按鈕
編程中遇到的問題:
       因為數據量很大,插入空白行-復制--黏貼,excel每次都要自動計算很耗時,操作10行數據基本需要5分鐘左右,為了優化問題,vba源碼里在操作數據前,先讓excel關閉自動刷新屏幕和關閉自動重算功能,當數據填寫完畢并格式化好文本后,再次開啟自動重算和自動刷新屏幕,這時會發現自動排單時間由原來5分鐘變為12秒鐘。
主站蜘蛛池模板: 99热网站 | 欧美性爽 | 久久99精品久久久久久水蜜桃 | 天堂综合网 | 免费在线观看黄色片 | 国产高潮在线观看 | 精品一二区| av毛片在线看 | 国产精品99久久久久久www | 一区二区三区四区在线视频 | 日韩av一区二区三区四区 | av黄色网| 99精品久久久久久中文字幕 | 亚洲欧美日韩一区二区三区四区 | 日韩久久一区 | 伊人精品在线 | 色综合久久88 | 亚洲精品乱码久久久久 | 在线观看国产一区二区 | 午夜黄色影院 | 日本人の夫妇交换 | 欧美 日韩 国产 成人 在线 | 国产黄色在线观看 | 香蕉视频免费看 | 欧美精品久久久久 | 日韩免费视频一区二区 | 国产精品免费在线 | 久久艳片www.17c.com | 丁香婷婷网| 日韩在线播放视频 | 久草网在线 | 天堂网亚洲 | 亚洲欧洲视频 | 国产一级在线 | 一级肉体全黄裸片 | 成人在线免费观看视频 | 91黄色大片| 色视频www在线播放国产人成 | 国内精品视频在线观看 | 欧美激情精品 | www亚洲精品|
