本帖最后由 51黑專家 于 2016-5-8 01:30 編輯
先通過arduino R3 串口輸出字串,然后用processing來讀取串口數據,并且繪制折線圖進行顯示。
arduino源碼:
void setup(){
Serial.begin(115200);
void loop(){
int num = random(0,1023);
Serial.print("S");
Serial.println(num);
delay(100);
Serial.print("B");
delay(100);
Serial.print("Q");
delay(100);
processing源碼:
- THIS PROGRAM WORKS WITH PulseSensorAmped_Arduino-xx ARDUINO CODE
- THE PULSE DATA WINDOW IS SCALEABLE WITH SCROLLBAR AT BOTTOM OF SCREEN
- PRESS 'S' OR 's' KEY TO SAVE A PICTURE OF THE SCREEN IN SKETCH FOLDER (.jpg)
- MADE BY JOEL MURPHY AUGUST, 2012
- import processing.serial.*;
- PFont font;
- Scrollbar scaleBar;
- Serial port;
- int Sensor; // HOLDS PULSE SENSOR DATA FROM ARDUINO
- int IBI; // HOLDS TIME BETWEN HEARTBEATS FROM ARDUINO
- int BPM; // HOLDS HEART RATE VALUE FROM ARDUINO
- int[] RawY; // HOLDS HEARTBEAT WAVEFORM DATA BEFORE SCALING
- int[] ScaledY; // USED TO POSITION SCALED HEARTBEAT WAVEFORM
- int[] rate; // USED TO POSITION BPM DATA WAVEFORM
- float zoom; // USED WHEN SCALING PULSE WAVEFORM TO PULSE WINDOW
- float offset; // USED WHEN SCALING PULSE WAVEFORM TO PULSE WINDOW
- color eggshell = color(255, 253, 248);
- int heart = 0; // This variable times the heart image 'pulse' on screen
- // THESE VARIABLES DETERMINE THE SIZE OF THE DATA WINDOWS
- int PulseWindowWidth = 490;
- int PulseWindowHeight = 512;
- int BPMWindowWidth = 180;
- int BPMWindowHeight = 340;
- boolean beat = false; // set when a heart beat is detected, then cleared when the BPM graph is advanced
- void setup() {
- size(700, 600); // Stage size
- frameRate(100);
- font = loadFont("Arial-BoldMT-24.vlw");
- textFont(font);
- textAlign(CENTER);
- rectMode(CENTER);
- ellipseMode(CENTER);
- // Scrollbar constructor inputs: x,y,width,height,minVal,maxVal
- scaleBar = new Scrollbar (400, 575, 180, 12, 0.5, 1.0); // set parameters for the scale bar
- RawY = new int[PulseWindowWidth]; // initialize raw pulse waveform array
- ScaledY = new int[PulseWindowWidth]; // initialize scaled pulse waveform array
- rate = new int [BPMWindowWidth]; // initialize BPM waveform array
- zoom = 0.75; // initialize scale of heartbeat window
- // set the visualizer lines to 0
- for (int i=0; i<rate.length; i++){
- rate[i] = 555; // Place BPM graph line at bottom of BPM Window
- for (int i=0; i<RawY.length; i++){
- RawY[i] = height/2; // initialize the pulse window data line to V/2
- // GO FIND THE ARDUINO
- println(Serial.list()); // print a list of available serial ports
- // choose the number between the [] that is connected to the Arduino
- port = new Serial(this, Serial.list()[1], 115200); // make sure Arduino is talking serial at this baud rate
- port.clear(); // flush buffer
- port.bufferUntil('\n'); // set buffer full flag on receipt of carriage return
- void draw() {
- background(0);
- noStroke();
- // DRAW OUT THE PULSE WINDOW AND BPM WINDOW RECTANGLES
- fill(eggshell); // color for the window background
- rect(255,height/2,PulseWindowWidth,PulseWindowHeight);
- rect(600,385,BPMWindowWidth,BPMWindowHeight);
- // DRAW THE PULSE WAVEFORM
- // prepare pulse data points
- RawY[RawY.length-1] = (1023 - Sensor) - 212; // place the new raw datapoint at the end of the array
- zoom = scaleBar.getPos(); // get current waveform scale value
- offset = map(zoom,0.5,1,150,0); // calculate the offset needed at this scale
- for (int i = 0; i < RawY.length-1; i++) { // move the pulse waveform by
- RawY[i] = RawY[i+1]; // shifting all raw datapoints one pixel left
- float dummy = RawY[i] * zoom + offset; // adjust the raw data to the selected scale
- ScaledY[i] = constrain(int(dummy),44,556); // transfer the raw data array to the scaled array
- stroke(250,0,0); // red is a good color for the pulse waveform
- noFill();
- beginShape(); // using beginShape() renders fast
- for (int x = 1; x < ScaledY.length-1; x++) {
- vertex(x+10, ScaledY[x]); //draw a line connecting the data points
- endShape();
- // DRAW THE BPM WAVE FORM
- // first, shift the BPM waveform over to fit then next data point only when a beat is found
- if (beat == true){ // move the heart rate line over one pixel every time the heart beats
- beat = false; // clear beat flag (beat flag waset in serialEvent tab)
- for (int i=0; i<rate.length-1; i++){
- rate[i] = rate[i+1]; // shift the bpm Y coordinates over one pixel to the left
- // then limit and scale the BPM value
- BPM = min(BPM,200); // limit the highest BPM value to 200
- float dummy = map(BPM,0,200,555,215); // map it to the heart rate window Y
- rate[rate.length-1] = int(dummy); // set the rightmost pixel to the new data point value
- // GRAPH THE HEART RATE WAVEFORM
- stroke(250,0,0); // color of heart rate graph
- strokeWeight(2); // thicker line is easier to read
- noFill();
- beginShape();
- for (int i=0; i < rate.length-1; i++){ // variable 'i' will take the place of pixel x position
- vertex(i+510, rate[i]); // display history of heart rate datapoints
- endShape();
- // DRAW THE HEART AND MAYBE MAKE IT BEAT
- fill(250,0,0);
- stroke(250,0,0);
- // the 'heart' variable is set in serialEvent when arduino sees a beat happen
- heart--; // heart is used to time how long the heart graphic swells when your heart beats
- heart = max(heart,0); // don't let the heart variable go into negative numbers
- if (heart > 0){ // if a beat happened recently,
- strokeWeight(8); // make the heart big
- smooth(); // draw the heart with two bezier curves
- bezier(width-100,50, width-20,-20, width,140, width-100,150);
- bezier(width-100,50, width-190,-20, width-200,140, width-100,150);
- strokeWeight(1); // reset the strokeWeight for next time
- // PRINT THE DATA AND VARIABLE VALUES
- fill(eggshell); // get ready to print text
- text("Pulse Sensor Amped Visualizer 1.1",245,30); // tell them what you are
- text("IBI " + IBI + "mS",600,585); // print the time between heartbeats in mS
- text(BPM + " BPM",600,200); // print the Beats Per Minute
- text("Pulse Window Scale " + nf(zoom,1,2), 150, 585); // show the current scale of Pulse Window
- // DO THE SCROLLBAR THINGS
- scaleBar.update (mouseX, mouseY);
- scaleBar.display();
- } //end of draw loop
- //.............................................scalebar (name of file)............................................................................................................
- THIS SCROLLBAR OBJECT IS BASED ON THE ONE FROM THE BOOK "Processing" by Reas and Fry
- class Scrollbar{
- int x,y; // the x and y coordinates
- float sw, sh; // width and height of scrollbar
- float pos; // position of thumb
- float posMin, posMax; // max and min values of thumb
- boolean rollover; // true when the mouse is over
- boolean locked; // true when it's the active scrollbar
- float minVal, maxVal; // min and max values for the thumb
- Scrollbar (int xp, int yp, int w, int h, float miv, float mav){ // values passed from the constructor
- x = xp;
- y = yp;
- sw = w;
- sh = h;
- minVal = miv;
- maxVal = mav;
- pos = x - sh/2;
- posMin = x-sw/2;
- posMax = x + sw/2; // - sh;
- // updates the 'over' boolean and position of thumb
- void update(int mx, int my) {
- if (over(mx, my) == true){
- rollover = true; // when the mouse is over the scrollbar, rollover is true
- } else {
- rollover = false;
- if (locked == true){
- pos = constrain (mx, posMin, posMax);
- // locks the thumb so the mouse can move off and still update
- void press(int mx, int my){
- if (rollover == true){
- locked = true; // when rollover is true, pressing the mouse button will lock the scrollbar on
- }else{
- locked = false;
- // resets the scrollbar to neutral
- void release(){
- locked = false;
- // returns true if the cursor is over the scrollbar
- boolean over(int mx, int my){
- if ((mx > x-sw/2) && (mx < x+sw/2) && (my > y-sh/2) && (my < y+sh/2)){
- return true;
- }else{
- return false;
- // draws the scrollbar on the screen
- void display (){
- noStroke();
- fill(255);
- rect(x, y, sw, sh); // create the scrollbar
- fill (250,0,0);
- if ((rollover == true) || (locked == true)){
- stroke(250,0,0);
- strokeWeight(8); // make the scale dot bigger if you're on it
- ellipse(pos, y, sh, sh); // create the scaling dot
- strokeWeight(1); // reset strokeWeight
- // returns the current value of the thumb
- float getPos() {
- float scalar = sw / sw; // (sw - sh/2);
- float ratio = (pos-(x-sw/2)) * scalar;
- float p = minVal + (ratio/sw * (maxVal - minVal));
- return p;
- //...........................................serialevent (name of file)..........................................................................................................
- void serialEvent(Serial port){
- String inData = port.readStringUntil('\n');
- inData = trim(inData); // cut off white space (carriage return)
- if (inData.charAt(0) == 'S'){ // leading 'S' for sensor data
- inData = inData.substring(1); // cut off the leading 'S'
- Sensor = int(inData); // convert the string to usable int
- if (inData.charAt(0) == 'B'){ // leading 'B' for BPM data
- inData = inData.substring(1); // cut off the leading 'B'
- BPM = int(inData); // convert the string to usable int
- beat = true; // set beat flag to advance heart rate graph
- heart = 20; // begin heart image 'swell' timer
- if (inData.charAt(0) == 'Q'){ // leading 'Q' means IBI data
- inData = inData.substring(1); // cut off the leading 'Q'
- IBI = int(inData); // convert the string to usable int
瞧瞧結果
