查看: 2248|回復: 0
家校互聯通報 自動查詢器
ID:127496 發表于 2016-6-20 23:10 | 顯示全部樓層 |閱讀模式
''''''''''''''''''''''''''''''''''''''代碼開始''''''''''''''''''''''''''''''''''''''
'版本:V1.0
'by ten
On Error Resume Next
Set Sh = CreateObject("Wscript.Shell")
Set xmlh = CreateObject("msxml2.xmlhttp")
Set Fso = Createobject("Scripting.FileSystemObject")
if Not Fso.FileExists("C:\TB.Txt") Then
Set txt = Fso.CreateTextFile("C:\TB.Txt")
txt.writeline "[C1009通報]:"
txt.close
Set txt=nothing
End if
i = 1
j = 0
b = ""
op = True
Set txt = Fso.OpenTextFile("C:\TB.Txt",1)
kb = txt.readall
Txt.close
Set txt=nothing
Do
WScript.Sleep 3000
xmlh.open "GET","http://61.187.64.231/index.aspx?pkId=3379",False
xmlh.send
If Err.Number<>0 Then    '=-2146697211 Then
  WScript.Sleep 1000*60
  Sh.Run Chr(34) & Wscript.ScriptFullName & Chr(34)
  Exit Do
End If
x = xmlh.responseText
b = "[C1009通報]:"
While j<7
  j = j+1
  c = instr(i,x," ",""),vbcrlf,"")<>"[C1009通報]:" then
  s=msgbox("通報有更新!" & vbcrlf & b & vbcrlf & "查看嗎?",vbYesNo)
  txt.write b
  txt.close
  Set txt=nothing
  kb=b
  if s=vbyes then createobject("wscript.shell").run "http://61.187.64.231/index.aspx?pkId=3379"
End if
wscript.sleep 1000*30
If op=true Then op=False:Msgbox Weather(),64,"天氣預報"
Loop
Function Weather()
xmlh.open "GET","http://www.baidu.com/s?wd=%CC%EC%C6%F8&f=12&rsp=0&oq=tianqi&tn=baiduhome_pg",False
xmlh.send
html = xmlh.responseText
str_temp = "</a></div><strong altemp_special" & Chr(34) & ">"
a = InStr(html,str_temp) + Len(str_temp)
b = InStr(a,html,"</strong><br><strong>")
c = b + Len("</strong><br><strong>")
d = InStr(c,html,"</strong><br><span>")
Today_Temp = Mid(html,a,b - a)
Today_Weather = Mid(html,c,d - c)
Today_Wind = Mid(html,d + Len("</strong><br><span>"),InStr(d,html,"</span></td>") - (d + Len("</strong><br><span>")))
a = InStr(d,html,"</a></div>") + Len("</a></div>")
b = InStr(a,html,"<br>")
c = InStr(b + 4,html,"<br><span>")
Tomorrow_Weather = Mid(html,b + 4,c - b - 4)
Tomorrow_Temp = Mid(html,a,b - a)
Tomorrow_Wind = Mid(html,c + Len("<br><span>"),InStr(c,html,"</span></td>") - (c + Len("<br><span>")))
a = InStr(c,html,"</a></div>") + Len("</a></div>")
the_weather = Mid(html,b + 4,c - b - 4)
the_Temp = Mid(html,a,b - a)
The_Wind = Mid(html,c + Len("<br><span>"),InStr(c,html,"</span></td>") - (c + Len("<br><span>")))
Line1 = "近日天氣預報"
Line2 = "今日" & today_temp & "," & today_weather & "," & today_wind
Line3 = "明日" & tomorrow_temp & "," & tomorrow_weather & "," & tomorrow_wind
Line4 = "后天" & the_temp & "," & the_weather & "," & the_wind
Weather = line1 & vbCrLf & line2 & vbCrLf & line3 & vbCrLf & line4
End Function
''''''''''''''''''''''''''''''''''''''代碼結束''''''''''''''''''''''''''''''''''''''
效果簡介:
檢查通報是否有更新,如果有更新就會提示你,如果沒有更新就會守在那里(這個程序基本不會占用多少CPU),一有更新就會提示你。
并附帶有自動查詢天氣預報功能。
圖:
動作簡介:
為了記住各個通報的標題,該程序會創建C:\TB.txt用于記錄,若殺軟報毒是正常現象,加入白名單即可。
若沒有聯網,會出現錯誤。
若出現錯誤,不會出現提示報錯,程序會1分鐘后自動重新運行自己。
使用方法簡介:
將以上代碼復制,打開Notepad(記事本),粘貼。將該文件保存,然后放到 開始菜單》所有程序》啟動 文件夾下。保存時擴展名一定要是".vbs",文件名可以隨便填。如:通報查詢.vbs,123.vbs,都可以。
下次開機時,你就可以看見效果了。
注1:僅限于C1009班通報,若需檢查其他班則需要改程序。
注2:若殺軟報毒,是誤報,加入白名單即可。(若是360報毒,純屬360的技術有問題。。。)
注3:稍作更改還可以有更多用途。
附:登陸QQ模塊。
如果你需要開機就登陸QQ,可以把下面這個過程寫進去,然后再在適當的地方調用它。前提是你勾選了“保存密碼”。當然,如果你沒有保存密碼,你也可以用SendKeys方法實現自動輸入密碼。
Sub LoginQQ()
Sh.Run Chr(34) & "E:\Program Files\Tencent\QQ\Bin\QQ.exe" & Chr(34) '啟動QQ
Do Until Sh.Appactivate("QQ2012") = True '等待QQ被啟動
  WScript.Sleep 500
Loop
WScript.Sleep 500
Sh.SendKeys "{Enter}"
End Sub
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
主站蜘蛛池模板: 国产精品福利在线观看 | 日本一级黄色 | 中文字幕一区在线观看 | 国产成人精品网站 | 国产一区二区不卡 | 国产一区二区免费看 | 午夜av在线播放 | 日韩免费成人 | 国产精品久久久久久妇女6080 | 国产成人aⅴ | aaa黄色片 | 成年人一级片 | 国产日韩欧美日韩大片 | 欧美成年人视频 | 91成人在线观看喷潮蘑菇 | 毛片网站视频 | 中文字幕免费视频 | 日韩精品免费一区二区夜夜嗨 | 中文字幕国产视频 | 黄色成人小视频 | 黄色免费一级片 | 日韩一区二区三区av | 久久精彩 | 91看片在线 | 亚洲黄色在线 | 99爱视频 | 性色av一区二区 | 91性视频| 天天爽夜夜爽夜夜爽 | 欧美中文字幕在线观看 | 亚洲日本国产 | 黄色一级毛片 | 日韩不卡av | 国产黄色片在线观看 | 五月天婷婷网站 | 成人在线精品 | 亚洲一区视频在线 | 欧美日韩精品 | 亚洲黄色av | 欧美日韩精品在线 | 三上悠亚激情av一区二区三区 |
