1.問: C6712怎樣訪問 I/O空間?
答: Acturally, C6000 have only one memory space, include Data and Prog memory.
The I/O also be mapping to memory space, can be accessed through EDMA and
EMIF bus.
2.問: TMS320C6712 的 32 位浮點特性與以往推出系列相比,有哪些優勢,可提
供哪些性能,存在哪些不足?
答: It support IEEE_SP32 and IEEE_DP32 and IEEE_DP64 float_point. Compare
with C3x, it has strong C compiler and also good development tool CCS.
3.問: TI 能否盡可能將閃存集成在今后的 DSP產品中,以減少外設和提高線路精
度?
答: TI 具備將 FLASH 集成到 DSP中的能力。但是不同的用途有不同的要求。所
以我們針對用量較大的客戶會進行集成以滿足客戶要求。
4.問: Is 6712, 6711 and 6701 all pin compatible?
答: Yes, they are all compatible.
5.問: 以 5409 為例,很多 DSP 產品在使用前必需進行內存分配,該工作目前由
用戶自己進行,雖提供了很大的靈活性,但對經驗較少的人來說會耗費很多不必
要的精力,所以請問 TI 能否在發貨時就為芯片提供標準的配置文件?
答: DSP link comand file is effective tool to manage DSP memory configuration to
improve system feature. DSP BIOS has visuable tool to deliver the function.
6.問: 請問 DSP與 CPU、MPU有什么區別?
答: The structure of DSP is difference from CPU/MPU. In DSP, there are different
memory for data and instruction. And it focus on computing not flow management.
7.問: TI 能否為其 DSP產品提供更加靈活的外設以滿足多樣的應用需要?
答 : Yes. In C6000, we have peripherals as these McBSP, HPI/Expension
BUS/PCI,EMIF(can connect with SBSRAM, SDRAM, Async RAM flush ROM
SRM), DMA/EDMA, timers etc.
8.問: 請問"數字信號處理器"的對象是什么?
答: wireless communication, broadband internet access, image process, modem,
disital motor control ... We believe it can be used in every internet action, every bit.
9.問: TI的DSP產品的C代碼編譯效率低, 常使開發者感到其結果不能達到預期,
請問 TI 有無應對之策?(11:01:19 AM)
答: The C6000 C compiler performance can reach 70-80%. This is just because the
from the beginning time of C6000 core design, the RISC like structure have make the
C compiler and optimizer can be easy design and reach high performance. That means
the C optimizer is begin from basic hardware design. So the question is true for other
DSP, for C6000 good C compiler is our strong point.
10.問: TI 公司的 DSP 有什么特點?即在處理速度、存儲量、接口以及軟件編程
等方面有什么特點?
答: For C6000, it is the most advanced DSP, our C64x can run at 700Mhz to 1.1Ghz,
the memory space for C6000 can be 32 bits wide. And we have DSP/BIOS which is
industry proved and free real time kernal can help engineer design more easy and
focus on their application.
11.問: DSP是不是擴大了功能的單片機?
答: No.
12.問: 在未來,DSP是否有代替 CPU的可能?
答: TI believe that in the coming internet era, many application engines will be driven
by DSP such as image, communication, digital consumer appliances. CPU can be
used as a controller, DSP will be used for specific functions.
13.問: DSP 與 FPGA 的區別?性能及用途方面。
答: DSP can be reprogramble offline and online, have more flexible than FPGA.
14.問: 請問貴公司的 6712 可用在民用的哪些方面?
答: C6000 的特點是高性能,應用比較容易(用 C 開發) ,如用在應用復雜的場
合, 會很有優勢,如網絡相機,用戶端網絡加密等。
15.問: TMS320C6712 高頻特性適用于跳頻、擴頻的哪些具體應用?是否適用于
藍牙技術?
答: 跳頻、擴頻 Yes,藍牙技術 No because its power consumption.
16.問: 除了眾所周知的 DSP外。TI 在模擬器件領域最關心的方向是什么?
答: TI is taking effort for provide all kinds of analog products portfolio.
17.問: 5000系列做便攜式現場數據采集合適嗎?
答:C5000 is suitable for portable application such as for low power requirement.
18.問:DSP的電源設計和時鐘設計應該特別注意哪些方面?
答:時鐘一般使用晶體,電源可用 ti 的配套的電源。
19.問:DSP 一般有二種供電方式:一種是開關電源,另外一種是 TI 有許多的
LDO,開關電源電路相對復雜,而 LDO相對非常簡單。我想問一下電路相對簡
單的 LDO 供電會有什么缺點,還是沒有缺點。例如 TI的 TPS75933已經可以提
供最大 7.5A 的電流,按功率來說已經完全足夠了。如果沒有缺點,我是否能夠
把 LDO用于其它功耗相對較多的 CPU。
答:一般是沒有什么問題的,是可以用在其它的cpu的。
20.問:TI的 DSP是否可以真正實現實時進行 MPEGII 編解碼,技術支持是否能
足夠?
答:Yes. You need to do MPEG codec with c64x。
21.問:TI 的 DSP產品中,對 USB的支持情況是什么樣的?我要做一個 USB接
口的高速數據采集卡,應該選用什么型號的DSP和 AD芯片?
答:We do have c5509 DSP which support USB。
22.問:dsp/bios 中的 system clock,是否是用于系統的任務、調度、周期任務的
管理?如果不用外部事件,使用 system clock將要占用一個定時器硬件資源,那
么這個定時器就不能用于定時、計數等正常。我的理解對嗎?
答:是的。
23.問:C6000的 BIOS 的工作過程是怎樣的?
答:BIOS 是一種實時多任務的操作系統,用戶只需編寫各項任務的進程,程序
的進程由 BIOS 的管理。
24.問:TMS320LF2407 的工作電壓為 3.3V,DSP 的抗干擾能力能允許多大的電
源毛刺?
答:5%。
25.問:1、CORE 和 I/O 供電的時序有那些要求?如果 I/O 供電超前于 CORE,
超前時間應限制在多少以內?2、最新的高速DSP對供電電源的動態特性有何要
求?要求 di/dt 為多少?
答:對 DSP本身而言,沒有上電次序要求。
26.問:堆棧尋址和 dp 指針尋址哪一個效率高?
答:dp 指針尋址效率高。
27.問:請問,DSP在與前向通道(比如說 AD)接口的時候,布線過程中要注意哪
些問題,以保證 AD采樣的穩定性?
答:模擬地和數字地分開,但在一點接地。
28.問:請簡單介紹 DSP與 89C52接口方式(HPI 方式)
答:可把 HPI 口作為一個上位機的 Io 口來處理。
29.問:用 dsp 硬件仿真設備調試 usb 接口板等設備時,與脫機調試,在時序及其
它方面有何不同。謝謝!
答:沒有不同。
30.問:1.3.3V的 DSP 能否與 5V的 A/D相連接 2.目前設計一個浮點的系統采用
哪一種芯片較好?
答:1. No. You need a level shifting IC between them.2. If you need an high
performance floating DSP, I recommend C6000. For more details, you could refer to
the DSP selection guide http://www.dspvillage.ti.com/dspguide.
31.問:器件布局應重點考慮哪些因素?如在集中抄表系統中應用系統成本臺
何?
答:可用Tms320vc5402,成本不是很高,器件布局應重點應是存貯器與DSP 的
接口。
32.問:請問如何通過仿真器把.HEX 程序直接燒到 FLASH 中去? 所用 DSP 為
5402.是否需要自己另外編寫一個燒寫程序,如何實現?謝謝!!
答:直接寫.OUT。是 DSP中寫一段程序,把主程序寫到 FLASH中。
33.問:設計 c6701 的計算機 pci板卡時,怎樣通過計算機下載程序到 c6701 中?
如果板卡有 flash,仿真器可以直接寫flash 嗎?flash 地燒寫程序由誰提供,是自
己編寫嗎(c6701 程序)?
答:可以,要自己寫。
34.問:1.DSP芯片內是否有單個的隨機函數指令?2.DSP內的計算速度是快的,
但是它的I/O口的交換速度有多快呢?3.DSP如何配合EPLD或FPGA工作呢?
答:1. No.2. Depeneded on which I/O you are referring. For HPI, the transfer rate
(in bytes) could be about 1/4 of CPU clock. For McBSP, the bit rate (kbps) could be
about 1/2 CPU clcok.3. You could cascade the emuation interface with the one on
EPLD/FPGA. Please see the following application notes for
details.http://www.ti.com/sc/docs/psheets/abstract/apps/spra439a.htm
35.問:請問在 DSP硬件電路板 Layout 時,EMI 方面的問題應主要注意哪幾點?
答:信號的完整。
36.問:1、c5416 的 pcb 板設計是否需要考慮高速數字電路板設計?2、c5416 的
電源,EEPROM,擴展 SRAM,雙口 RAM 設計;能否介紹較詳細的管腳圖?3、剛
進行 c5416 的硬件設計和軟件設計時,是否有較好的中文或英文參考書。
答:1. Yes. Since the operating frequency could be higher than 100MHz. 2. You could
refer to our C5416 DSK design.3.For S/W development, you could try the examples
from our CCS. For H/W design, you could refer to our EVM/DSK design.
37.問:我有關于C240的一個問題,為何有時程序從外部運行正常,燒進 FLASH
就不正常。是何原因。
答:可能性較多,建議檢查空間設置或初始化段是否寫入 FLASH。
38.問: 我想了解TMS320C240及其相關 DSP的設計方法, 用于全橋電源的 PWM
控制,謝謝。
答: You could download our Developer"s Kits from the following web
page,http://www.dspvillage.com/c2000devkit
39.問:我在使用 5402DSK時,一上電,不接 MIC,只接耳機,不運行任何程序,
耳機中有比較明顯的一定頻率的噪聲出現。有時上電后沒有出現,但接 MIC,
運行范例中的 CODEC 程序時,又會出現這種噪聲。上述情況通常都在 DSK 工
作一段時間后自動消失。 我在DSP論壇上發現別人用DSK時也碰到過這種情況,
我自己參照 5402DSK 做了一塊板,所用器件基本一樣,也是這現象,請問怎么
回事,如何解決。
答: 始時沒有有效的程序代碼, 所以上電后是隨機狀態, 出現這種情況是正常的。
40.問:請問 TMS320LF2407 與 TMS320C6201 的 HPI 接口怎樣連接,有特別的
時序要求嗎?
答:沒有特別的時序要求。HPI 接口作為 2407 的外圍設備,直接接口。
41.問:請介紹一款專用于 FFT,數字濾波,卷積,相關等算法的 DSP,最好集成
12BIT以上的 ADC功能。
答:I recommend TMS320LF240x, if your application is about motor/energy control.
Please also see our DSP selection guide for more information on
it,http://www.dspvillage.ti.com/dspguide
42.問:電路中用到DSP,有時當復位信號為低時,電壓也屬于正常范圍,但DSP
加載程序不成功。電流也偏大,有時時鐘也有輸出。不知為什么?
答:復位時無法加載程序。
43.問:c5510 芯片如何接入 E1信號?在接入時有什么需要注意的地方?
答:通過 McBSP同步串口接入注意信號電平必須滿足要求
44.問:ccs2.0 中有 gel 文件,可以初始化外設。那有了 gel 文件后,我在我的程
序中還需要不需要編寫初始化外設的語句。我的程序將脫離調試環境運行。
答:需要。
45.問: 我設計的TMS320C5402板子在調試軟件時會經常出現memory錯誤報告,
排除是映射的問題,是不是板子不穩定的因素?還是 DSP 工作不正常的問題?
如何判別?
答:你可以利用 MEmoryfill 功能,填入一些數值,然后刷新一下,看是不是在
變,如果是在變化,則 MEmory 是有問題。
46.問:VC33的哪些接口可接 AD?最好是無縫連接。
答:You could find recommended data converters for VC33 from the following web
site, http://www.ti.com/sc/docs/msp/c3x.htm
47.問:DSP的程序編寫用匯編好還是 C好?
答:You can use C coding and compiler for assemble code to do the function
verifiction, for better code optimize, you can modify with assemble code.
48.問:TI 公司推出了一款 TS320多媒體處理器(DSP),可以應用在安防系統,可以
開發成硬盤錄象機(DVR).再什么地方可以找到這個應用方案.
答: If you are talking about DSC24, please visit the following web
site,http://www.prodsys.com/DMDK2400/
49.問:我使用的是 TMS320LF2407,但是仿真時不能保證每次都能 GO MAIN。
我想詳細咨詢以下CMD文件的設置用法,還有 VECTOR的定義。
答:可能看門狗有問題,關掉看門狗。
50.問:系統調試時發現紋波太大主要是哪主面的問題?
答:如果是電源紋波大,加大電容濾波。
