查看: 3730|回復: 0
avr繼電器+1602程序 湊合著可以了
ID:128229 發表于 2016-6-27 21:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <iom8v.h>
#include <macros.h>
#define  uchar unsigned char
#define  uint unsigned int
#define  rs_L     PORTD&=~BIT(0)
#define  rs_H     PORTD|=BIT(0)
#define  rs_out   DDRD|=BIT(0)
#define  rw_L     PORTD&=~BIT(1)
#define  rw_H     PORTD|=BIT(1)
#define  rw_out   DDRD|=BIT(1)
#define  en_L     PORTD&=~BIT(2)
#define  en_H     PORTD|=BIT(2)
#define  en_out   DDRD|=BIT(2)
#define  s1_L     PORTD&=~BIT(4)
#define  s1_H     PORTBD|=BIT(4)
#define  s1_out   DDRD|=BIT(4)
#define  s2_L     PORTD&=~BIT(5)
#define  s2_H     PORTD|=BIT(5)
#define  s2_out   DDRD|=BIT(5)
#define  s3_L     PORTD&=~BIT(6)
#define  s3_H     PORTD|=BIT(6)
#define  s3_out   DDRD|=BIT(6)
#define  s4_L     PORTD&=~BIT(7)
#define  s4_H     PORTD|=BIT(7)
#define  s4_out   DDRD|=BIT(7)
uchar miu=0;
signed char t,tt,z,zz,a,b,c,d,e,f,g;
uchar table1[]="<Himetech>~00~00";
uchar table2[]="Z00~X00~z00~x0  ";
const table3[10]={20,40,60,80,100,120,140,160,180,200};
void delay(uint ms)//yan shi han shu
uchar a;
uint b;
for(a=0;a<ms;a++)
for(b=0;b<1141;b++);
uchar key_press()//pan dan an jian shi fu an xia
    uchar j;
    DDRC|=0X0f;
        PORTC|=0X0f;
        DDRC&=0XF0;
        j=PINC;
        j=j&0X0F;//00001111
        if(j==0X0F)
          return 0;
         return 1;
void key_scan()//pan dan an xia de  jian
    uchar key;
    delay(10);
        if(key_press())
        key=PINC;
        key&=0X0F;
        switch(key)
           case 0X0E: //guang biao zuo yi
                      zhilin(0x0f);
                      miu--;
              if(miu==1){zhilin(0x80+11);}
                      if(miu==2){zhilin(0x80+12);}
                          if(miu==3){zhilin(0x80+14);}
                          if(miu==4){zhilin(0x80+15);}
                  if(miu==5){zhilin(0x80+0x40+1);}
                      if(miu==6){zhilin(0x80+0x40+2);}
                          if(miu==7){zhilin(0x80+0x40+5);}
                          if(miu==8){zhilin(0x80+0x40+6);}
                          if(miu==9){zhilin(0x80+0x40+9);}
                          if(miu==10){zhilin(0x80+0x40+10);}
                          if(miu==11){zhilin(0x80+0x40+13);}
                          if(miu==-1){miu=12;}
                   }break;
                   case 0X0B: //guang biao you yi
                      zhilin(0x0f);
                      miu++;
                          if(miu==12){miu=0;}
                   }break;
           case 0X0D://dui guang biao suo zai xiang, jin xin jia shu
                          if(miu==1){t++;if(t==2)t=0;zhilin(0x0c);dizhishujv((0x80+11),(0x30+t));}
                      if(miu==2){tt++;if(tt==10)tt=0;zhilin(0x0c);dizhishujv((0x80+12),(0x30+tt));}
                          if(miu==3){z++;if(z==2)z=0;zhilin(0x0c);dizhishujv((0x80+14),(0x30+z));}
                          if(miu==4){zz++;if(zz==2)zz=0;zhilin(0x0c);dizhishujv((0x80+15),(0x30+zz));}
                      if(miu==5){a++;if(a==2)a=0;zhilin(0x0c);dizhishujv((0x80+0x40+1),(0x30+a));}
                      if(miu==6){b++;if(b==10)b=0;zhilin(0x0c);dizhishujv((0x80+0x40+2),(0x30+b));}
                      if(miu==7){c++;if(c==2)c=0;zhilin(0x0c);dizhishujv((0x80+0x40+5),(0x30+c));}
                      if(miu==8){d++;if(d==10)d=0;zhilin(0x0c);dizhishujv((0x80+0x40+6),(0x30+d));}
                      if(miu==9){e++;if(e==2)e=0;zhilin(0x0c);dizhishujv((0x80+0x40+9),(0x30+e));}
                          if(miu==10){f++;if(f==10)f=0;zhilin(0x0c);dizhishujv((0x80+0x40+10),(0x30+f));}
                      if(miu==11){g++;if(g==2)g=0;zhilin(0x0c);dizhishujv((0x80+0x40+13),(0x30+g));}
           }break;
           case 0X07:
                   DDRC&=~BIT(4);
                   PORTC|=BIT(4);
                   //ji qi shi xv
           if(t)PORTD|=BIT(6);else PORTD&=~BIT(6);//qi
         if(z)PORTD|=BIT(7);else PORTD&=~BIT(7);//zhu zhou
           if(a){PORTD|=BIT(4); }else PORTD&=~BIT(4);//z  zou en
            delay(table3);
           if(c)PORTD|=BIT(5);else PORTD&=~BIT(5);   //x zou en
           while(PINC&0x10);
           delay(table3[d]);
           if(e)PORTD&=~BIT(4);else PORTD|=BIT(4);  //z shou en
                   PORTD&=~BIT(7);
           delay(table3[f]);
                   PORTD&=~BIT(6);
                   delay(table3[tt]);
           if(g)PORTD&=~BIT(5);else PORTD|=BIT(5);  // x shou  en
                   break;
           default:
               key=0;
          while(key_press());
void zhilin(uchar zhi)
rs_H; rw_H; en_L;
rs_L; rw_L;
PORTB=zhi;
delay(1);
en_H;
delay(1);
en_L;
void shujv (uchar shu)
rs_L; rw_H; en_L;
rs_H; rw_L;
PORTB=shu;
delay(1);
en_H;
delay(1);
en_L;
void init_lcd (void)
uchar e;
DDRB=0xff;  PORTB=0xff;
rs_out;     rw_out;     en_out;
delay(1);
zhilin(0x38);
delay(1);
zhilin(0x38);
delay(1);
zhilin(0x38);
zhilin(0x38);
zhilin(0x08);
zhilin(0x01);
zhilin(0x06);
zhilin(0x0c);
zhilin(0x80+0x00);
         for(e=0;e<16;e++)
         shujv (table1[e]);
        delay(1);
zhilin(0x80+0x40);
         for(e=0;e<16;e++)
         shujv (table2[e]);
        delay(1);
void dizhishujv(uchar dizhi,uchar shu)
   zhilin(dizhi);
  shujv(shu);
void init_time(void) //din shi qi chu shi hua
TCCR1B=0X00;//wu fen pin
TCNT1H=0X80;//chu zhi H
TCNT1H=0X80;//chu zhi L
TIMSK|=BIT(2);//kai din shi qi 1 zhong dan
SREG|=BIT(7);//kai zong zhong dan
void main (void)
   init_lcd ();
   init_time();
   DDRD|=0xf0;
      key_scan();
#pragma interrupt_handler timer1:9
void timer1(void)//din shi qi 1 zhong dan
TCNT1H=0X80;
TCNT1H=0X80;
主站蜘蛛池模板: 欧美不卡一区二区三区 | 超碰天天操 | 国产一区二区视频在线播放 | 欧美一级淫片免费视频黄 | 蜜桃视频一区 | 涩久久 | 婷久久 | 性欧美69| 黄色片观看 | 能看毛片的网站 | 免费精品视频 | 欧美激情一区二区 | a级毛毛片 | 一区二区三区视频在线播放 | 久久91视频| 久久久久久久久久久国产 | 国产成人免费视频 | 中文字幕av一区 | av福利网 | 久久久久久久久国产 | 狠狠做深爱婷婷久久综合一区 | 亚洲啪啪网 | 亚洲三级在线播放 | 国产黄色一区 | 网站av | 青青草91| 性爱一级视频 | 成年视频在线观看 | 视频一区二区三区在线观看 | 高清视频一区二区 | 日韩欧美国产一区二区三区 | 久久一级片 | 国产精品美女在线 | 日本久久久久久久久 | 国产理论在线 | 成人一区二区在线 | 亚洲在线一区二区 | 亚洲不卡视频 | 欧美在线观看一区 | 玖草在线 | 天天爽天天操 |
