查看: 2223|回復: 2
沒有測試過的PId
ID:130679 發表于 2016-7-16 11:18 | 顯示全部樓層 |閱讀模式
#include <I2Cdev.h>
#include<Wire.h>
#include<Stepper.h>
#include "MPU6050.h"
#include <PWM.h>
#include "PID_v1.h"
#define Gry_offset 296   //陀螺儀X軸的靜態漂移
#define Gyr_Gain -0.00763  //X軸讀數轉化為角速=1/131,向前方向與X軸相反
#define ACC_Gain 0.000061  //讀數轉化為加速度值=1/16384
#define pi 3.1415926
#define k 0.715    //一階互補濾波權重取值
//步數等于360/電機的步距角 1.8
#define STEPS 200
//電機對象stepper
Stepper stepper(STEPS, 8, 9, 10, 11);
int previous = 0;  //儲存歷史讀數
int val;
const int aInPin = A0;
//設置每臺電機的速度和方向引腳
int speed1 = 3;
int speed2 = 11;
int direction1 = 12;
int direction2 = 13;
int Speed_need = 0;
int Turn_need = 0;
float LSpeed_Need=0.0,RSpeed_Need=0.0;// 轉彎設置
float speeds,speeds_filter,positions;
float diff_speeds,diff_speeds_all;
float Kp = 10, Kd = 0.06, Ksp = 2.8, Ksi = 0.11;
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
//motor
int dirPin1 = 8;
int stepperPin1 = 9;
int dirPin2 = 6;
int stepperPin2 = 7;
/*   角度參數 */
float Gyro_y;   //Y軸陀螺儀數據暫存
float Accel_x;  //X軸加速度值暫存
float Angle_ax;  //由加速度計算的傾斜角度
float Angle_gy;  //由角速度計算的傾斜角度
float Angle;     //小車最終傾斜角度
int Setpoint = 0;
/********** 互補濾波器參數 *********/
unsigned long now ;
unsigned long preTime = 0;
float angleG = 0;
/*********** PID控制器參數 *********/
unsigned long lastTime = 0;           // 前次時間
float ITerm = 0.0, lastInput = 0.0;    // 積分項、前次輸入
float Output = 0.0;        // PID輸出值
float LOutput,ROutput;
bool blinkState = false;
//******卡爾曼參數************
float Q_angle=0.001; //相對于加速度計的噪音協方差
float Q_gyro=0.003;
float R_angle=0.5;   //測量噪聲協方差
float dt=0.01; //dt為kalman濾波器采樣時間;
char C_0 = 1;
float Q_bias, Angle_err;   //Q_bias相對于陀螺儀的噪音協方差
float PCt_0, PCt_1, E;
float K_0, K_1, t_0, t_1;
float Pdot[4] ={0,0,0,0};
float PP[2][2] = { { 1, 0 },{ 0, 1 } };   //協方差誤差矩陣
// 卡爾曼濾波20MHz的處理時間約0.77ms;
void Kalman_Filter(float Accel,float Gyro)
  Angle+=(Gyro - Q_bias) * dt; //先驗估計
  Pdot[0]=Q_angle - PP[0][1] - PP[1][0]; // Pk-先驗估計誤差協方差的微分
  Pdot[1]=- PP[1][1];
  Pdot[2]=- PP[1][1];
  Pdot[3]=Q_gyro;
  PP[0][0] += Pdot[0] * dt; // Pk-先驗估計誤差協方差微分的積分
  PP[0][1] += Pdot[1] * dt; // =先驗估計誤差協方差
  PP[1][0] += Pdot[2] * dt;
  PP[1][1] += Pdot[3] * dt;
  Angle_err = Accel - Angle;//zk-先驗估計
  PCt_0 = C_0 * PP[0][0];
  PCt_1 = C_0 * PP[1][0];
  E = R_angle + C_0 * PCt_0;
  K_0 = PCt_0 / E;
  K_1 = PCt_1 / E;
  t_0 = PCt_0;
  t_1 = C_0 * PP[0][1];
  PP[0][0] -= K_0 * t_0; //后驗估計誤差協方差
  PP[0][1] -= K_0 * t_1;
  PP[1][0] -= K_1 * t_0;
  PP[1][1] -= K_1 * t_1;
  Angle+= K_0 * Angle_err; //后驗估計
  Q_bias+= K_1 * Angle_err; //后驗估計
  Gyro_y = Gyro - Q_bias; //輸出值(后驗估計)的微分=角速度
void PID1()
  now = millis();                                         // 當前時間(ms)
  float TimeChange = (now - lastTime) / 1000.0;               // 采樣時間(s)
  float Kp = 10.0, Ki = 0.23, Kd = 0.0;                    // 比例系數、積分系數、微分系數
  float SampleTime = 0.1;                                 // 采樣時間(s)
  float Setpoint =-2.0;                                  // 設定目標值(degree)
    //float outMin = -400.0, outMax = +400.0;                   // 輸出上限、輸出下限
  if(TimeChange >= SampleTime) {                              // 到達預定采樣時間時
    float Input = angleG;                              // 輸入賦值
    float error = Setpoint - Input;                     // 偏差值
    ITerm+= (Ki * error * TimeChange);                      // 計算積分項
       // ITerm = constrain(ITerm, outMin, outMax);           // 限定值域
    float DTerm = Kd * (Input - lastInput) / TimeChange;    // 計算微分項
    Output = Kp * error + ITerm + DTerm;                // 計算輸出值
       // Output = constrain(Output, outMin, outMax);         // 限定值域
    LOutput=Output+RSpeed_Need;                         //左電機
    ROutput=Output-RSpeed_Need;                         //右電機
    lastInput = Input;                                  // 記錄輸入值
    lastTime = now;                                     // 記錄本次時間
void PWM1(){
  if(Output > 0){
    step_forwards(Output);
  if (Output < 0){
    step_backwards(abs(Output));
//電機運轉控制
void step_forwards(int speeds){
    digitalWrite(dirPin1,0);
    digitalWrite(dirPin2,1);
    digitalWrite(stepperPin1, HIGH);
    digitalWrite(stepperPin2, HIGH);
    delayMicroseconds(speeds);
    digitalWrite(stepperPin1, LOW);
    digitalWrite(stepperPin2, LOW);
void step_backwards(int speeds){
    digitalWrite(dirPin1,1);
    digitalWrite(dirPin2,0);
const int MPU_addr=0x68;  // I2C address of the MPU-6050
void setup(){
  stepper.setSpeed(200);
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  Serial.begin(38400);
  accelgyro.initialize();   //MPU6050初始化
  pinMode(dirPin1, OUTPUT);
  pinMode(stepperPin1, OUTPUT);
  pinMode(dirPin2, OUTPUT);
  pinMode(stepperPin2, OUTPUT);
void loop()
  //獲取傳感器讀數
  val = analogRead(aInPin);
  val = map(val, 0, 1023, 0, 99);
  Serial.println(val);
  if(val > 50)
    stepper.step(STEPS / 2);
    delay(500);
    stepper.step(-STEPS / 2);
    delay(500);
  //移動步數
  stepper.step(val - previous);
  //保存歷史讀數
  previous = val;
  //MP6050
  accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);//讀取六軸數值
  float Y_Accelerometer = ay * ACC_Gain;//轉換為向前的加速度(g),為負值
  float Z_Accelerometer = az * ACC_Gain;//轉換為向下的加速度(g)
  float angleA= atan(Y_Accelerometer/ Z_Accelerometer)* (-180)/ pi;//加速度儀,反正切獲得弧度值,乘以180度/pi
  now = millis();  //當前時間ms
  float dt = (now - preTime) / 1000.0;  //微分時間
  preTime = now;  //上一次采樣時間
  float gx_revised = gx + Gry_offset;//陀螺儀x軸靜態時修正后的角速度讀數,向前為負值
  float omega= Gyr_Gain* gx_revised;//陀螺儀,轉換為向前的角速度(o/s),Gyr_Gain取負,故負負得正
  float angle_dt = omega * dt;//角度的單次積分值
  //angleG+= angle_dt;//陀螺儀,積分獲得角度值
  angleG+= (Gyr_Gain * (gx + Gry_offset)) * dt;
  float A= k/ (k+ dt);//陀螺儀的權值
  angleG= A* (angleG+ omega* dt)+ (1-A)* angleA;//一階互補濾波后的輸出角度(o)
  if (abs(angleG)<45) /////////////////up-right judge
    PID1();
    PWM1();
   Serial.print(angleG); Serial.print("\t");
   Serial.println(Output);
ID:130679 發表于 2016-7-17 11:19 | 顯示全部樓層
正在修改中
ID:135550 發表于 2016-8-2 17:41 | 顯示全部樓層
樓主加油,正在學pid
主站蜘蛛池模板: 97精品在线观看 | 日本在线视频一区 | 午夜久久 | 日韩欧美国产综合 | 色播五月婷婷 | 在线免费观看黄 | 黄色片在线播放 | 欧美黄色网 | 国产精品2 | 色啪视频| 91蝌蚪少妇偷拍 | 日本不卡二区 | 国产成人精品一区二区 | 国产视频一二区 | 国产精品一区二区三区免费 | 欧美日韩一区二 | 夜夜嗨av一区二区三区 | 久久久精品国产sm调教 | 天天操免费视频 | 日韩视频在线观看免费 | 日韩成人中文字幕 | 国产成人亚洲精品自产在线 | 在线观看视频一区 | 久久精品美女 | 欧美日韩视频 | 欧美丰满少妇 | 久久久久久久久久久久久久久久久 | 一级免费视频 | 一二三四区在线观看 | 久久国产成人 | 日韩欧美视频一区 | 亚洲成人免费 | 四虎在线观看 | 久久99久久久| 免费看黄色录像 | 欧美久久一区二区 | 超碰在线观看97 | 男女啪啪免费网站 | 精品黄色片 | 日韩精品久久久久久久酒店 | 日日干天天射 |
