查看: 4162|回復: 0
AVR怎么讀取905的數據,我這個讀不到啊,spi_read();沒有用
ID:99453 發表于 2016-7-22 13:55 | 顯示全部樓層 |閱讀模式
* nrf905_reseive.c
* Created: 2016/7/17 11:18:37
*  Author: Knight
#define F_CPU 8000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define uchar unsigned char
#define uint unsigned int
#define TXEN_set PORTA|=(1<<PA7)//PA7
#define TXEN_clr PORTA&=~(1<<PA7)
#define PWR_set PORTA|=(1<<PA6)
#define PWR_clr PORTA&=~(1<<PA6)
#define CE_set PORTC|=(1<<PC7)
#define CE_clr PORTC&=~(1<<PC7)
#define AM (PINC&(1<<PC6))//PC6
#define DR (PINA&(1<<PA5))//PA5
#define CSN_clr PORTB&=~(1<<PB4)
#define CSN_set PORTB|=(1<<PB4)
#define CLK_H PORTB|=(1<<PB2)
#define CLK_L PORTB&=~(1<<PB2)
#define SID_H PORTB|=(1<<PB1)
#define SID_L PORTB&=~(1<<PB1)
uint buffer[4]={0x39,0x38,0x37,0x36};
uint i;
void write_hz(uchar *hz)
while(*hz!='\0')
  write_data(*hz); //寫入漢字
  hz++;
void send_byte(uchar byte)
uint i;
for (i=0;i<8;i++)
  CLK_L;//低電平
  if(byte&0x80)
  SID_H; //為1 給1
  SID_L;  //為0 給0
  CLK_H;//高電平
  byte=byte<<1;
void write_com(uchar com)
send_byte(0xf8);//step 1
send_byte(0xf0&com);//step 2
send_byte(0xf0&(com<<4));//step 3
_delay_ms(10);
void write_data(uchar data)
send_byte(0xfa);
send_byte(0xf0&data);
send_byte(0xf0&(data<<4));
_delay_ms(10);
void lcd12864_init()
write_com(0x30);
_delay_ms(10);
write_com(0x0c);//整體和游標顯示
_delay_ms(10);
write_com(0x01);
_delay_ms(10);
void SPI_Master_init()
SPCR=0x5c;//使能SPI,主機模式,2分頻
SPSR=0x00;
void spi_write(char wData)
SPDR = wData;
while(!(SPSR&(1<<SPIF)));
uchar spi_read(void)
return SPDR;
uint TX_RF[11]={0x00,//寫RF寄存器
0x4c,
0x0c,
0x44,//RXTX地址寬度
0x04,//RX32有效字節
0x04,//TX32有效字節
0xcc,
0xcc,
0xcc,
0xcc,
0x58//CRC16位效驗允許
void nrf905_init()//RF寄存器的配置
PORTC&=~(1<<PC6);
PORTA&=~(1<<PA5);
PWR_set;
TXEN_set;//standby模式
CE_clr;
CSN_clr;
for(i=0;i<11;i++)
  spi_write(TX_RF[i]);
CSN_set;
void RX_packet()
TXEN_clr;//接收模式
CE_set;
_delay_us(500);
i=10;
while(!AM)//地址匹配后進入standby模式,開始接收數據
  i--;
  _delay_us(100);
  if(i==0)break;
CE_clr;//進入standby模式   !!!!!!!!!!!!!!!!!接收數據的時候是在哪個模式??
CSN_clr;
spi_write(0x24);//開始接收數據
for(i=0;i<4;i++)
  buffer[i]=spi_read();write_data(9);//第二波的時候停在了這里!!讀905時停下
CSN_set;
while(!DR);//數據接收完成后置位DR
CE_clr;
void display()
for(i=0;i<4;i++)
  write_data(buffer[i]);
int main(void)
DDRA=0xc0;//DDRA|=(1<<PA6)|(1<<PA7)|(0<<PA5);
DDRC|=(1<<PC7);DDRC&=~(1<<PC6);//DDRC|=(0<<PC6)|(1<<PC7);
DDRB=0xbf;//DDRB|=(1<<PB1)|(1<<PB2)|(1<<PB4)|(1<<PB5)|(0<<PB6)|(1<<PB7);
SPI_Master_init();
lcd12864_init();
nrf905_init();
  write_com(0x80);
  RX_packet();//停在這
  display();
我試了下他只讀出一個值就停在那了,上面的spi_read();
怎么辦,大神們能看看嗎
主站蜘蛛池模板: 91在线亚洲 | 国产精品午夜视频 | 人人插人人爱 | 国产一区二区三区四区 | 黄色精品视频 | 免费成人深夜夜行网站 | 18色av| 国产精品久久久久久久久久久久久久久 | 中文字幕一区二区在线播放 | 一本不卡 | 九色在线视频 | 免费黄色一级视频 | 精品久久一区二区三区 | 国产在线黄色 | 亚洲91视频| 狠狠干 | 日韩成人免费 | 日韩精品极品视频在线观看免费 | 九九久久久 | 亚洲精品网站在线观看 | 丁香激情五月 | 欧美色图一区二区三区 | 久久国产精品免费视频 | 天天干天天草 | 蜜桃色999 | 私库av在线 | 毛片一级片| 欧美另类z0zx974 | 波多野结衣视频在线 | 久久视频这里只有精品 | 国产精品三级在线观看 | 国产精品国产精品国产专区不卡 | 不卡免费视频 | 久久久久女教师免费一区 | 国产一区二区视频在线播放 | 三上悠亚一区 | 新av在线 | 亚洲永久免费 | 日韩av免费在线观看 | 天天澡天天狠天天天做 | 一区二区三区久久久 |
