查看: 11886|回復(fù): 13
51單片機多點溫度采集系統(tǒng)(8路)仿真+源程序+電路原理圖
ID:137190 發(fā)表于 2016-8-31 18:57 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機多點溫度采集系統(tǒng)仿真電路原理圖(清晰版請下載本帖最后的附件)
下面是51單片機多點溫度采集系統(tǒng)源程序:
  1. #include <AT89X52.h>
  2. #include <Intrins.h>
  3. #define                DATA        P1      //1602驅(qū)動端口
  4. //ROM操作命令
  5. #define                 READ_ROM                       0x33                    //讀ROM
  6. #define                 SKIP_ROM                       0xCC                    //跳過ROM
  7. #define                 MATCH_ROM               0x55                    //匹配ROM
  8. #define                 SEARCH_ROM              0xF0                    //搜索ROM
  9. #define                 ALARM_SEARCH            0xEC                    //告警搜索
  10. //存儲器操作命令
  11. #define                 ANEW_MOVE                     0xB8                    //重新調(diào)出E^2數(shù)據(jù)
  12. #define                 READ_POWER              0xB4                    //讀電源
  13. #define                 TEMP_SWITCH             0x44                    //啟動溫度變換
  14. #define                 READ_MEMORY             0xBE                    //讀暫存存儲器
  15. #define                 COPY_MEMORY             0x48                    //復(fù)制暫存存儲器
  16. #define                 WRITE_MEMORY            0x4E                    //寫暫存存儲器
  17. //數(shù)據(jù)存儲結(jié)構(gòu)
  18. typedef struct tagTempData
  19. {
  20.         unsigned char                                         btThird;                                                        //百位數(shù)據(jù)
  21.         unsigned char                                         btSecond;                                                        //十位數(shù)據(jù)
  22.         unsigned char                                         btFirst;                                                        //個位數(shù)據(jù)
  23.         unsigned char                                         btDecimal;                                                        //小數(shù)點后一位數(shù)據(jù)
  24.         unsigned char                                        btNegative;                                                        //是否為負數(shù)
  25. }TEMPDATA;
  26. TEMPDATA m_TempData;
  27. //引腳定義
  28. sbit                                                         DQ = P2^7;                                                        //數(shù)據(jù)線端口
  29. sbit                 RS=                P2^0;
  30. sbit                 RW=                P2^1;
  31. sbit                 E=                P2^2;
  32. //DS18B20序列號,通過調(diào)用GetROMSequence()函數(shù)在P1口讀出(讀8次)
  33. const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
  34. const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
  35. const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
  36. const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
  37. const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
  38. const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
  39. const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
  40. const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
  41. //判斷忙指令
  42. void Busy()
  43. {
  44.         DATA = 0xff;
  45.         RS = 0;
  46.         RW = 1;
  47.            while(DATA & 0x80)
  48.            {
  49.                 E = 0;
  50.                    E = 1;
  51.            }
  52.            E = 0;
  53. }
  54. //寫指令程序
  55. void WriteCommand(unsigned char btCommand)
  56. {
  57.         Busy();
  58.         RS = 0;
  59.         RW = 0;
  60.         E = 1;
  61.         DATA = btCommand;
  62.         E = 0;
  63. }
  64. //寫數(shù)據(jù)程序
  65. void WriteData(unsigned char btData)
  66. {
  67.         Busy();
  68.         RS = 1;
  69.         RW = 0;
  70.         E = 1;
  71.         DATA = btData;
  72.         E = 0;
  73. }
  74. //清屏顯示
  75. void Clear()
  76. {
  77.         WriteCommand(1);
  78. }
  79. //初始化
  80. void Init()
  81. {
  82.         WriteCommand(0x0c);        //開顯示,無光標(biāo)顯示
  83.         WriteCommand(0x06);        //文字不動,光標(biāo)自動右移
  84.         WriteCommand(0x38);        //設(shè)置顯示模式:8位2行5x7點陣
  85. }
  86. //顯示單個字符
  87. void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
  88. {
  89.         if (bRow)                 WriteCommand(0xc0 + btColumn);
  90.         else                      WriteCommand(0x80 + btColumn);
  91.         if (bIsNumber)         WriteData(btData + 0x30);
  92.         else                   WriteData(btData);
  93. }
  94. //顯示字符串函數(shù)
  95. void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
  96. {
  97.         while (*pData != '\0')
  98.            {
  99.                    if (bRow) WriteCommand(0xc0 + btColumn);        //顯示在第1行
  100.                    else            WriteCommand(0x80 + btColumn);        //顯示在第0行
  101.                 WriteData(*(pData++));                                                //要顯示的數(shù)據(jù)
  102.                 btColumn++;        //列數(shù)加一
  103.            }
  104. }
  105. //延時16us子函數(shù)
  106. void Delay16us()
  107. {
  108.         unsigned char a;
  109.         for (a = 0; a < 4; a++);
  110. }
  111. //延時60us子函數(shù)
  112. void Delay60us()
  113. {
  114.         unsigned char a;
  115.         for (a = 0; a < 18; a++);
  116. }
  117. //延時480us子函數(shù)
  118. void Delay480us()
  119. {
  120.         unsigned char a;
  121.         for (a = 0; a < 158; a++);
  122. }
  123. //延時240us子函數(shù)
  124. void Delay240us()
  125. {
  126.         unsigned char a;
  127.         for (a = 0; a < 78; a++);
  128. }
  129. //延時500ms子函數(shù)
  130. void Delay500ms()
  131. {
  132.         unsigned char a, b, c;
  133.         for (a = 0; a < 250; a++)
  134.         for (b = 0; b < 3; b++)
  135.         for (c = 0; c < 220; c++);
  136. }
  137. //芯片初始化
  138. void Initialization()
  139. {
  140.         while(1)
  141.         {
  142.                 DQ = 0;
  143.                 Delay480us();                         //延時480us
  144.                 DQ = 1;
  145.                 Delay60us();                        //延時60us
  146.                 if(!DQ)                                  //收到ds18b20的應(yīng)答信號
  147.                 {
  148.                         DQ = 1;
  149.                         Delay240us();                //延時240us
  150.                         break;
  151.                 }
  152.         }
  153. }
  154. //寫一個字節(jié)(從低位開始寫)
  155. void WriteByte(unsigned char btData)
  156. {
  157.         unsigned char i, btBuffer;
  158.         for (i = 0; i < 8; i++)
  159.         {
  160.                 btBuffer = btData >> i;
  161.                 if (btBuffer & 1)
  162.                 {
  163.                         DQ = 0;
  164.                         _nop_();
  165.                         _nop_();
  166.                         DQ = 1;
  167.                         Delay60us();
  168.                 }
  169.                 else
  170.                 {
  171.                         DQ = 0;
  172.                         Delay60us();
  173.                         DQ = 1;
  174.                 }
  175.         }
  176. }
  177. //讀一個字節(jié)(從低位開始讀)
  178. unsigned char ReadByte()
  179. {
  180.         unsigned char i, btDest;
  181.         for (i = 0; i < 8; i++)
  182.         {
  183.                 btDest >>= 1;
  184.                 DQ = 0;
  185.                 _nop_();
  186.                 _nop_();
  187.                 DQ = 1;
  188.                 Delay16us();
  189.                 if (DQ) btDest |= 0x80;
  190.                 Delay60us();
  191.         }
  192.         return btDest;
  193. }
  194. //序列號匹配
  195. void MatchROM(const unsigned char *pMatchData)
  196. {
  197.         unsigned char i;
  198.         Initialization();
  199.         WriteByte(MATCH_ROM);
  200.         for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
  201. }
  202. //得到64位ROM序列(在P1口顯示,必須與Proteus聯(lián)調(diào)且在單步調(diào)試下才能得到)
  203. /*void GetROMSequence()
  204. {
  205.         unsigned char i;
  206.         Initialization();
  207.         WriteByte(READ_ROM);
  208.         for (i = 0; i < 8; i++)
  209.         P1 = ReadByte();
  210. }*/
  211. //讀取溫度值
  212. TEMPDATA ReadTemperature()
  213. {
  214.         TEMPDATA TempData;
  215.         unsigned int iTempDataH;
  216.         unsigned char btDot, iTempDataL;
  217.         static unsigned char i = 0;
  218.         TempData.btNegative = 0;                                                //為0溫度為正
  219.         i++;
  220.         if (i == 9) i = 1;
  221.         Initialization();
  222.         WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
  223.         WriteByte(TEMP_SWITCH);                                                        //啟動轉(zhuǎn)換
  224.         Delay500ms();        //調(diào)用一次就行
  225.         Delay500ms();
  226.         Initialization();
  227.         //多個芯片的時候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
  228.         switch (i)
  229.         {
  230.                 case 1 : MatchROM(ROMData1); break;                        //匹配1
  231.                 case 2 : MatchROM(ROMData2); break;                        //匹配2
  232.                 case 3 : MatchROM(ROMData3); break;                        //匹配3
  233.                 case 4 : MatchROM(ROMData4); break;                        //匹配4
  234.                 case 5 : MatchROM(ROMData5); break;                        //匹配5
  235.                 case 6 : MatchROM(ROMData6); break;                        //匹配6
  236.                 case 7 : MatchROM(ROMData7); break;                        //匹配7
  237.                 case 8 : MatchROM(ROMData8); break;                        //匹配8
  238.         }
  239.         //WriteByte(SKIP_ROM);                                                        //跳過ROM匹配(單個芯片時用這句換掉上面的switch)
  240.         WriteByte(READ_MEMORY);                                                        //讀數(shù)據(jù)
  241.         iTempDataL = ReadByte();
  242.         iTempDataH = ReadByte();
  243.         iTempDataH <<= 8;
  244.         iTempDataH |= iTempDataL;
  245.         if (iTempDataH & 0x8000)
  246.         {
  247.                 TempData.btNegative = 1;
  248.                 iTempDataH = ~iTempDataH + 1;                                //負數(shù)求補
  249.         }
  250.         //為了省去浮點運算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
  251.         btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小數(shù)部分
  252.         iTempDataH >>= 4;        //得到整數(shù)部分
  253.         btDot *= 5;        //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
  254.         btDot >>= 3;
  255.         //數(shù)據(jù)處理
  256.         TempData.btThird   = (unsigned char)iTempDataH / 100;
  257.         TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
  258.         TempData.btFirst   = (unsigned char)iTempDataH % 10;
  259.         TempData.btDecimal = btDot;
  260.         return TempData;
  261. }
  262. //數(shù)據(jù)處理子程序
  263. void DataProcess()
  264. {
  265.         m_TempData = ReadTemperature();
  266.         if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
  267.         else DisplayOne(1, 6, m_TempData.btThird, 1);
  268.         DisplayOne(1, 7, m_TempData.btSecond, 1);
  269.         DisplayOne(1, 8, m_TempData.btFirst, 1);
  270.         DisplayOne(1, 10, m_TempData.btDecimal, 1);
  271. }
  272. void main()
  273. {
  274.         //GetROMSequence();
  275.         Clear();
  276.         Init();
  277.         DisplayString(0, 0, "  Temperature");
  278.         DisplayOne(1, 9, '.', 0);
  279.         while (1) DataProcess();
  280. }
51單片機多點溫度采集系統(tǒng)仿真工程文件及所有資料下載:
http://m.zg4o1577.cn/bbs/dpj-54940-1.html
參與人數(shù) 3黑幣 +12 收起 理由
FlynnX + 3
lebron_zxy + 5
來不及了 + 4
收藏收藏9 分享淘帖 頂2 踩
ID:137795 發(fā)表于 2016-9-2 12:38 來自觸屏版 | 只看該作者
資料不錯
ID:154595 發(fā)表于 2017-4-26 15:55 | 只看該作者
謝謝分享
ID:194844 發(fā)表于 2017-5-1 06:39 | 只看該作者
資料不錯
ID:246595 發(fā)表于 2017-12-10 09:13 | 只看該作者
可以可以,很給力
ID:400182 發(fā)表于 2018-9-19 19:56 | 只看該作者
謝謝您,很棒!
ID:411697 發(fā)表于 2018-10-30 23:13 來自觸屏版 | 只看該作者
謝謝您的分享
ID:477774 發(fā)表于 2019-2-18 16:06 | 只看該作者
誰能做一個采集溫度,并通過gprs模塊上傳到云端的
ID:484633 發(fā)表于 2019-3-5 08:39 | 只看該作者
謝謝分享 受教了
ID:486223 發(fā)表于 2019-3-7 14:54 | 只看該作者
新手,怎么加入8點的平均溫度程序?
ID:751167 發(fā)表于 2020-5-13 21:15 | 只看該作者
用源程序,什么都沒改,重新生成了一個hex文件,放到Proteus里就無法仿真。請問哪里錯了?
ID:892352 發(fā)表于 2021-3-15 22:47 | 只看該作者
資料不錯,感謝感謝
ID:513213 發(fā)表于 2024-2-28 11:41 | 只看該作者
小源同志 發(fā)表于 2017-4-26 15:55
**** 作者被禁止或刪除 內(nèi)容自動屏蔽 ****
謝謝分享
主站蜘蛛池模板: 在线一区二区三区 | 久久视频免费 | 欧美精品二区三区四区免费看视频 | 午夜网站在线观看 | 久久福利网 | 日韩一区二区在线观看视频 | 国产亚洲欧美在线 | 亚洲精品一区二区三区在线 | 国产白丝精品91爽爽久久 | 黄色大片在线免费观看 | 中文字幕不卡视频 | 欧美日韩在线精品 | 欧洲一区二区 | 日韩欧美国产成人 | 欧美亚洲 | 在线亚洲精品 | 色伊人网 | 国产一区二区三区精品视频 | 538在线视频| 夜夜夜夜操 | av在线免费观看网站 | 国产一区二区三区久久 | 国产超碰在线观看 | 国产一级特黄 | 免费午夜视频 | 亚洲精品a| 日韩中文字幕免费 | 在线视频a | 一区二区小视频 | 毛片一级片 | 四虎影视在线播放 | 国产精品欧美在线 | 理论片中文字幕 | 亚洲综合图片区 | 成人免费黄色大片 | 天天干天天干天天操 | www.sihu| 久久久久久久久国产精品 | 欧美九九九 | 国产精品视频一区二区三区 | 久久九九视频 |
