arduino的卡爾曼濾波融合算法,非原創,我只是封裝了算法。
H文件:
* KalmanFilter.h
* Non-original
* Author: x2d
* Copyright (c) 2012 China
#ifndef KalmanFilter_h
#define KalmanFilter_h
#include <WProgram.h>
class KalmanFilter
public:
KalmanFilter();
卡爾曼融合計算
angle_m: 加速度計測量并通過atan2(ax,ay)方法計算得到的角度(弧度值)
gyro_m:陀螺儀測量的角速度值(弧度值)
dt:采樣時間(s)
outAngle:卡爾曼融合計算出的角度(弧度值)
outAngleDot:卡爾曼融合計算出的角速度(弧度值)
void getValue(double angle_m, double gyro_m, double dt, double &outAngle, double &outAngleDot);
private:
double C_0, Q_angle, Q_gyro, R_angle;
double q_bias, angle_err, PCt_0, PCt_1, E, K_0, K_1, t_0, t_1;
double angle, angle_dot;
double P[2][2];
double Pdot[4];
CPP文件:
* KalmanFilter.cpp
* Non-original
* Author: x2d
#include "KalmanFilter.h"
KalmanFilter::KalmanFilter()
C_0 = 1.0f;
Q_angle = 0.001f;
Q_gyro = 0.003f;
R_angle = 0.5f;
q_bias = angle_err = PCt_0 = PCt_1 = E = K_0 = K_1 = t_0 = t_1 = 0.0f;
angle = angle_dot = 0.0f;
P[0][0] = 1.0f;
P[0][1] = 0.0f;
P[1][0] = 0.0f;
P[1][1] = 1.0f;
Pdot[0] = 0.0f;
Pdot[1] = 0.0f;
Pdot[2] = 0.0f;
Pdot[3] = 0.0f;
void KalmanFilter::getValue(double angle_m, double gyro_m, double dt, double &outAngle, double &outAngleDot)
Serial.print("angle_m = ");
Serial.print(angle_m);
Serial.print(";");
Serial.print("gyro_m = ");
Serial.print(gyro_m);
Serial.print(";");
angle+=(gyro_m-q_bias) * dt;
angle_err = angle_m - angle;
Pdot[0] = Q_angle - P[0][1] - P[1][0];
Pdot[1] = -P[1][1];
Pdot[2] = -P[1][1];
Pdot[3] = Q_gyro;
P[0][0] += Pdot[0] * dt;
P[0][1] += Pdot[1] * dt;
P[1][0] += Pdot[2] * dt;
P[1][1] += Pdot[3] * dt;
PCt_0 = C_0 * P[0][0];
PCt_1 = C_0 * P[1][0];
E = R_angle + C_0 * PCt_0;
K_0 = PCt_0 / E;
K_1 = PCt_1 / E;
t_0 = PCt_0;
t_1 = C_0 * P[0][1];
P[0][0] -= K_0 * t_0;
P[0][1] -= K_0 * t_1;
P[1][0] -= K_1 * t_0;
P[1][1] -= K_1 * t_1;
angle += K_0 * angle_err;
q_bias += K_1 * angle_err;
angle_dot = gyro_m-q_bias;
outAngle = angle;
outAngleDot = angle_dot;
Serial.print("angle = ");
Serial.print(angle);
Serial.print(";");
Serial.print("angle_dot = ");
Serial.print(angle_dot);
Serial.print(";");
#endif
