查看: 8687|回復(fù): 14
TFT320 240A的proteus仿真與模型及源程序
ID:137190 發(fā)表于 2016-9-25 13:22 | 顯示全部樓層 |閱讀模式
proteus的TFT320x240彩屏仿真模型,能仿真的,能顯示彩色圖片,編程方法與實(shí)際的彩屏類似。把解壓出來
的TFT320240.LIB文件放到proteus安裝目錄的LIBRARY文件夾里,TFT320240A.dll放到proteus安裝目錄的MODE
LS文件夾里,然后再proteus的器件窗口搜索TFT320240 即可找到彩屏。(libray proteus8.0在C:\Documents
and Settings\All Users\Application Data\Labcenter Electronics\Proteus 8 Professional\LIBRARY)
(8.0 dll文件還要復(fù)制到C:\Documents and Settings\All Users\Application Data\Labcenter Electronics
\Proteus 8 Professional\MODELS
源程序:
  1. #include        <LPC21XX.h>
  2. #include        "picture.h"
  3. #define                RS                8
  4. #define                RW                9
  5. #define                EN                10
  6. void delay( unsigned int x )
  7. {
  8.         while ( x-- )
  9.         {
  10.
  11.         }
  12. }
  13. void PortInit( void )
  14. {
  15.         PINSEL0                &=                0xffc00000;
  16.         IO0DIR                |=                0x7ff;
  17.         IO0SET                |=                0xff;
  18.         IO0SET                |=                (1<<RS);
  19.         IO0SET                |=                (1<<RW);
  20.         IO0CLR                |=                (1<<EN);
  21. }
  22. void TFTWriteCmd( unsigned char Command )
  23. {
  24.         IO0SET        |=        Command;
  25.         IO0CLR        |=        ~Command;
  26.
  27.         IO0CLR        |=        (1<<RS);
  28.         IO0CLR        |=        (1<<RW);
  29.         IO0SET        |=        (1<<EN);
  30.         delay( 10 );
  31.         IO0CLR        |=        (1<<EN);
  32. //        IO0SET        |=        (1<<RW);
  33. }
  34. void TFTWriteData( unsigned char Data )
  35. {
  36.         IO0SET        |=        Data;
  37.         IO0CLR        |=        ~Data;
  38.
  39.         IO0SET        |=        (1<<RS);
  40.         IO0CLR        |=        (1<<RW);
  41.         IO0SET        |=        (1<<EN);
  42.         delay( 10 );
  43.         IO0CLR        |=        (1<<EN);
  44. //        IO0SET        |=        (1<<RW);
  45. }
  46. void TFTInit( void )
  47. {
  48.         unsigned int i;
  49.         unsigned short temp;
  50.         TFTWriteCmd( 0x00 );
  51.         TFTWriteCmd( 0x00 );
  52.         TFTWriteCmd( 0x00 );
  53.         TFTWriteCmd( 0x00 );
  54.         for ( i = 0; i < 320*240; i++ )
  55.         {
  56.
  57.                 temp        =        girl[i];
  58.
  59.                 TFTWriteData( temp%256 );
  60.                 TFTWriteData( temp/256 );
  61.         }
  62. }
  63. int main( void )
  64. {
  65.         PortInit();
  66.         TFTInit();
  67.         while ( 1 )
  68.         {
  69.
  70.         }
  71. }
proteusTFT320x240彩屏仿真模型.zip
512.65 KB, 下載次數(shù): 220, 下載積分: 黑幣 -5
ID:64765 發(fā)表于 2017-5-20 20:46 | 顯示全部樓層
下載學(xué)習(xí)了,謝謝分享。
ID:44037 發(fā)表于 2017-7-18 11:09 | 顯示全部樓層
謝謝分享   運(yùn)行后 數(shù)據(jù)點(diǎn)在動(dòng)  但是沒有圖像
ID:69408 發(fā)表于 2019-10-21 13:35 來自觸屏版 | 顯示全部樓層
下載看看,先前那個(gè)沒有測(cè)試成功,可能沒有元件的DLL
ID:69408 發(fā)表于 2019-10-21 20:36 | 顯示全部樓層
這個(gè)不錯(cuò)經(jīng)過測(cè)試可以正常運(yùn)行形勢(shì)的,謝謝分享。。。!
ID:685237 發(fā)表于 2020-3-31 23:20 | 顯示全部樓層
好東西,已下載,可以用。謝謝樓主。
ID:723102 發(fā)表于 2020-5-11 14:07 | 顯示全部樓層
謝謝分享,正好可以試試程序
ID:743654 發(fā)表于 2020-5-28 15:31 | 顯示全部樓層
壓縮包已損壞
ID:302325 發(fā)表于 2020-6-1 01:57 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:202617 發(fā)表于 2020-7-7 10:54 | 顯示全部樓層
用不了呢
ID:720658 發(fā)表于 2020-8-7 21:55 | 顯示全部樓層
沒有圖表設(shè)計(jì)引擎,啟動(dòng)不成功
ID:501297 發(fā)表于 2021-4-26 18:57 | 顯示全部樓層
denminshen 發(fā)表于 2019-10-21 20:36
這個(gè)不錯(cuò)經(jīng)過測(cè)試可以正常運(yùn)行形勢(shì)的,謝謝分享。。。。
為什么不能運(yùn)行,出來不了圖像呀,求解答
ID:899981 發(fā)表于 2021-11-26 14:11 | 顯示全部樓層
老大,我的出不來啊,是8.9的
ID:77589 發(fā)表于 2021-12-9 14:08 | 顯示全部樓層
里面有TFT320240A.DLL
ID:748788 發(fā)表于 2022-11-21 20:50 | 顯示全部樓層
親測(cè)壓縮包ok,仿真ok
主站蜘蛛池模板: 久久小视频| 国产成人在线视频 | 97视频在线 | 视频一二三区 | 99视频在线观看免费 | 欧洲一级片 | av一级在线 | 天堂中文在线视频 | 黄色小视频在线免费观看 | 欧美日韩国产在线播放 | 欧美韩日 | 欧美成人综合 | 国产com | 麻豆一级片 | 破处视频在线观看 | 国产h在线 | 五月天婷婷社区 | 91日韩在线 | 色羞羞| yy6080午夜| 日韩av在线影院 | 国产在线中文字幕 | 欧美色图一区 | av第一页| 久久综合99 | 夜夜夜夜操| 国产在线一区二区 | 草逼视频免费看 | 日韩在线观看中文字幕 | 欧美亚洲| 国产美女一区二区三区 | 中国特级毛片 | 欧美日韩在线看 | 九色自拍 | 青青草国产成人av片免费 | 综合色在线| 国产美女久久 | 国产午夜一区二区三区 | 88av视频| 精品久久久久久久久久久久久久 | 超碰在线免费公开 |
