主要器件:
使用LCD1602顯示
電源可調模塊用到LM2596
模數轉換ADC0832
主要功能:
理論電壓范圍 1.25V~40V
電壓、電流顯示
短路保護電路
資料下載:
LM2596 數控電源.rar
(2.1 KB, 下載次數: 771)
2016-10-11 20:15 上傳
點擊文件名下載附件
源程序:
- #include"reg52.h"
- #include<stdio.h>
- #include <intrins.h>
- typedef unsigned char uchar;
- typedef unsigned int uint;
- #define LCD_Data P0
- #define Busy 0x80 //用于檢測LCD狀態字中的Busy標識
- sbit ADC0832_CLK = P1^5;
- sbit ADC0832_DODI = P1^6;
- sbit ADC0832_CS = P1^7;
- sbit LCD_RS=P2^7;//定義引腳
- sbit LCD_RW=P2^6;
- sbit LCD_E=P2^5;
- float volts,amps;
- //5ms延時
- void Delay5Ms(void)
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //400ms延時
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //讀狀態
- unsigned char ReadStatusLCD(void)
- LCD_Data = 0xFF;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- while (LCD_Data & Busy); //檢測忙信號
- return(LCD_Data);
- //寫數據
- void WriteDataLCD(unsigned char WDLCD)
- ReadStatusLCD(); //檢測忙
- LCD_Data = WDLCD;
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_E = 0; //若晶振速度太高可以在這后加小的延時
- LCD_E = 0; //延時
- LCD_E = 1;
- //寫指令
- void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時忽略忙檢測
- if (BuysC) ReadStatusLCD(); //根據需要檢測忙
- LCD_Data = WCLCD;
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- //讀數據
- unsigned char ReadDataLCD(void)
- LCD_RS = 1;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- return(LCD_Data);
- void LCDInit(void) //LCM初始化
- LCD_Data = 0;
- WriteCommandLCD(0x38,0); //三次顯示模式設置,不檢測忙信號
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCD(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
- WriteCommandLCD(0x08,1); //關閉顯示
- WriteCommandLCD(0x01,1); //顯示清屏
- WriteCommandLCD(0x06,1); // 顯示光標移動設置
- WriteCommandLCD(0x0C,1); // 顯示開及光標設置
- //按指定位置顯示一個字符
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
- X |= 0x80; // 算出指令碼
- WriteCommandLCD(X, 0); //這里不檢測忙信號,發送地址碼
- WriteDataLCD(DData);
- //按指定位置顯示一串字符
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
- unsigned char ListLength;
- ListLength = 0;
- Y &= 0x1;
- while (DData[ListLength]>=0x20) //若到達字串尾則退出
- if (X <= 0xF) //X坐標應小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
- ListLength++;
- X++;
- //讀取ADC0832轉換值函數
- //入口函數:channel選擇通道
- uchar ADC0832_Read(uchar channel)
- uchar i = 0;
- uchar tmp = 0; //高字節數據
- uchar tmp1 = 0; //低字節數據
- //開始標志位
- ADC0832_DODI = 1;
- _nop_(); _nop_();
- ADC0832_CS = 0; //片選信號
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- //選擇通道
- switch(channel)
- case 0: //通道0
- ADC0832_DODI = 1; //SGL = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- ADC0832_DODI = 0; //ODD = 0;
- _nop_(); _nop_();
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- break;
- case 1: //通道1
- _nop_(); _nop_();
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- ADC0832_DODI = 1; //ODD = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- break;
- default:
- break;
- ADC0832_DODI = 1;
- _nop_(); _nop_();
- //讀取8位轉換數值
- for(i=0;i<8;i++)
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- if(ADC0832_DODI)
- tmp |= 0x01;
- else
- tmp &= 0xfe;
- if(i<7)
- tmp <<= 1;
- tmp1 = tmp & 0x01;
- tmp1 <<= 6;
- for(i=0;i<7;i++)
- ADC0832_CLK = 1;
- _nop_(); _nop_();
- ADC0832_CLK = 0;
- _nop_(); _nop_();
- if(ADC0832_DODI)
- tmp1 |= 0x80;
- else
- tmp1 &= 0x7f;
- if(i<6)
- tmp1 >>= 1;
- ADC0832_CS = 1;
- if(tmp == tmp1) //當高字節與低字節相同時,該值有效
- return tmp; //返回數值
- void DisPlayValue(uint volts,uint amps)
- DisplayOneChar(0,0,'U');
- DisplayOneChar(1,0,'=');
- if(volts/10000 == 0)
- DisplayOneChar(2,0,'0' + (volts/1000%10));
- DisplayOneChar(3,0,'.');
- DisplayOneChar(4,0,'0' + (volts/100%10));
- DisplayOneChar(5,0,'0' + (volts/10%10));
- DisplayOneChar(6,0,'0' + (volts%10));
- DisplayOneChar(7,0,' ');
- DisplayOneChar(8,0,'V');
- DisplayOneChar(9,0,' ');
- else
- DisplayOneChar(2,0,'0' + (volts/10000));
- DisplayOneChar(3,0,'0' + (volts/1000%10));
- DisplayOneChar(4,0,'.');
- DisplayOneChar(5,0,'0' + (volts/100%10));
- DisplayOneChar(6,0,'0' + (volts/10%10));
- DisplayOneChar(7,0,'0' + (volts%10));
- DisplayOneChar(8,0,' ');
- DisplayOneChar(9,0,'V');
- DisplayOneChar(0,1,'I');
- DisplayOneChar(1,1,'=');
- DisplayOneChar(2,1,'0' + (amps/1000));
- DisplayOneChar(3,1,'.');
- DisplayOneChar(4,1,'0' + (amps/100%10));
- DisplayOneChar(5,1,'0' + (amps/10%10));
- DisplayOneChar(6,1,'0' + (amps/1%10));
- DisplayOneChar(7,1,' ');
- DisplayOneChar(8,1,'A');
- void GetValue(void)
- uchar tmp,i;
- uint ntmp;
- for(i=0;i<10;i++)
- tmp = ADC0832_Read(0);
- ntmp += tmp;
- volts = (ntmp/10)*0.1137*1000;
- Delay5Ms();
- ntmp = 0;
- for(i=0;i<20;i++)
- tmp = ADC0832_Read(1);
- ntmp += tmp;
- amps = (ntmp/20)*0.0196*1000;
- Delay5Ms();
- DisPlayValue(volts,amps);
- void main(void)
- Delay400Ms(); //啟動等待,等LCD講入工作狀態
- LCDInit(); //LCM初始化
- Delay5Ms(); //延時片刻(可不要)
- ReadDataLCD();//測試用句無意義
- while(1)
- GetValue();
