查看: 5890|回復: 2
AT24C02
ID:25346 發表于 2010-7-30 14:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
有關AT24C02芯片的斷電記憶功能總是無法實現  望各位指點指點!
/*12M晶振實現數碼管顯示時間,日期與年月,星期,鬧鐘,并實現信息可調*/
#include<at89x52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
bit write=0;  //寫24c02的標志
sbit sda=P1^0;
sbit scl=P1^1;
sbit dula=P3^6;//段選
sbit wela=P3^7;//位選
uchar sec,tcnt;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff};
uchar n,a;
uchar hh,mm,ss;
uchar nhh,nmm,nss;
uint year,year3;
uchar day,mon,week,year1,year2;
uchar hhs,hhg,mms,mmg,sss,ssg;
uchar days,dayg,mons,mong;
uchar nhhs,nhhg,nmms,nmmg,nsss,nssg;
uchar set1=1,set2=1;
sbit fm=P3^4;
sbit k1=P3^0;   //時間顯示切換鍵
sbit k2=P3^1;   //移位功能鍵
sbit k3=P3^2;  //加法按鍵
sbit k4=P3^3;  //減法按鍵
uchar table1[]={31,31,29,31,30,31,30,31,31,30,31,30,31}; //閏年
uchar table2[]={31,31,28,31,30,31,30,31,31,30,31,30,31}; //非閏年
 void baoshi();
void alarm();
void set_time();
void set_alarm();
void set_mdw();
void key_change();
void key_set();
void display(uchar,uchar,uchar);
void display5(uchar);
void delay1()
void delay(uchar xms)
   uint i,j;
   for(i=xms;i>0;i--)
      for(j=0;j<300;j++);
 void di()
   fm=0;
   delay(10);
   fm=1;
void delayms(uint xms)
  uint i,j;
  for(i=xms;i>0;i--)
     for(j=110;j>0;j--);
 void start()  //開始函數
    sda=1;
 delay1();
 scl=1;
 delay1();
 scl=0;
 delay1();
  void stop()   //停止函數
    sda=0;
 delay1();
 scl=1;
 delay1();
 sda=1;
 delay1();
  void respons()  //回應函數
    uchar i;
 scl=1;
 delay1();
 while((sda==1)&&(i<250))i++;
 scl=0;
 delay1();
   void write_byte(uchar date)    //寫一個字節函數
    uchar temp,i;
 temp=date;
 for(i=0;i<8;i++)
   temp=temp<<1;
   scl=1;
   delay1();
   sda=CY;
   delay1();
   scl=1;
   delay1();
 scl=0;
 delay1();
 sda=1;
 delay1();
  uchar read_byte()   //讀一個字節函數
    uchar i,k;
 scl=0;
 delay1();
 sda=1;
 delay1();
 for(i=0;i<8;i++)
   scl=1;
   delay1();
   k=(k<<1)|sda;
   scl=0;
   delay1();
 return k;
  void write_add(uchar address,uchar date)   //指定地址寫一個字節
    start();
 write_byte(0xa0);
 respons();
 write_byte(address);
 respons();
 write_byte(date);
 respons();
 stop();
  uchar read_add(uchar address)   //指定地址讀一個字節
    uchar date;
    start();
 write_byte(0xa0);
 respons();
 respons();
 start();
 write_byte(0xa1);
 respons();
 date=read_byte();
 stop();
 return date;
  void init_24c02()    //I2C初始化函數
    sda=1;
 delay1();
 scl=1;
 delay1();
 void init()
   dula=0;    //關閉兩個鎖存器鎖存端,防止數碼管出現亂碼
   wela=0;
   hh=8;mm=0;ss=0;        //時鐘
   nhh=6;nmm=0;nss=0;      //鬧鐘
   year=2010;mon=7;day=3;week=6;
   year3=year-year/100*100;
   init_24c02();
   display(year3,mon,day);
   display(hh,mm,ss);
   display(nhh,nmm,nss);
   //display1(); //正常顯示年月日
   year3=read_add(1);mon=read_add(2);day=read_add(3);
   delay(500);
   hh=read_add(4);mm=read_add(5);ss=read_add(6);
   display(hh,mm,ss);
   delay(500);
   nhh=read_add(7);nmm=read_add(8);nss=read_add(9);
   delay(500);
   TMOD=0x11;
   TH0=0x3c;TL0=0xb1;
   TH1=0x3c;TL1=0xb1;
   EA=1;
   TR0=1;ET0=1;
   TR1=1;ET1=1;
   hhs=hh/10%10;//時
   hhg=hh%10;
   mms=mm/10%10;  //分
   mmg=mm%10;
   sss=ss/10%10;  //秒
   ssg=ss%10;
   nhhs=nhh/10%10;//鬧鐘時
   nhhg=nhh%10;
   nmms=nmm/10%10;  //鬧鐘分
   nmmg=nmm%10;
   nsss=nss/10%10;  //鬧鐘秒
   nssg=nss%10;
   dayg=day/10%10;  //日
   days=day%10;
   mons=mon/10%10;  //月
   mong=mon%10;
   year1=year3/10%10;  //年個位
   year2=year3%10;     //年十位
   init();
   key_change();       //k1按鍵掃描
   key_set();         //k2按鍵掃描
   set_time();        //設置時間
   set_mdw();         //設置年月日
   set_alarm();      //設置鬧鐘
 if(set1==1)display(read_add(1),read_add(2),read_add(3));
 if(set1==2)display(read_add(1),read_add(2),read_add(3));
 if(set1==3)display(read_add(4),read_add(5),read_add(6));
 if(set1==4)display(read_add(4),read_add(5),read_add(6));
 if(set1==5)display5(read_add(7));
 if(set1==6)display(read_add(8),read_add(9),read_add(10));
 if(set1==7)display(read_add(8),read_add(9),read_add(10));
void display(uchar a,uchar b,uchar c) //
  uchar a1,a2;uchar b1,b2;uchar c1,c2;
  a1=a/10%10;a2=a%10;
  b1=b/10%10;b2=b%10;
  c1=c/10%10;c2=c%10;
  dula=1;P0=tab[a1];dula=0;P2=0xff;wela=1;P2=0x01;wela=0;delay(1);
  dula=1;P0=tab[a2];dula=0;P2=0xff;wela=1;P2=0x02;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x04;wela=0;delay(1);
  dula=1;P0=tab[b1];dula=0;P2=0xff;wela=1;P2=0x08;wela=0;delay(1);
  dula=1;P0=tab[b2];dula=0;P2=0xff;wela=1;P2=0x10;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x20;wela=0;delay(1);
  dula=1;P0=tab[c1];dula=0;P2=0xff;wela=1;P2=0x40;wela=0;delay(1);
  dula=1;P0=tab[c2];dula=0;P2=0xff;wela=1;P2=0x80;wela=0;delay(1);
void diplay5(uchar a)    //
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x01;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x02;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x08;wela=0;delay(1);
  dula=1;P0=tab[a];dula=0;P2=0xff;wela=1;P2=0x10;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x40;wela=0;delay(1);
  dula=1;P0=tab[10];dula=0;P2=0xff;wela=1;P2=0x80;wela=0;delay(1);
uchar incone(uchar n) //加1函數
  if(k3==0)
   {delay(20);
    if(k3==0)
       n++;
       while(!k3);
    di();
   return(n);
uchar decone(uchar m) //減1函數
   if(k4==0)
  delay(20);
  if(k4==0)
         m--;
         while(!k4);
   di();
         if(m<0)
           {m=0;}
   return(m);
void key_change() //k1按鍵掃描
  if(k1==0)
     delay(20);
     if(k1==0)   //確認切換鍵被按下
         set1++;    //紀錄切換鍵被按下次數
          while(!k1); //釋放確定
    di();
        if(set1==8)
             {set1=1;}
void key_set() //k2按鍵掃描
  if(k2==0)
     delay(20);
     if(k2==0)
         set2++;
         while(!k2);
   di();
         if(set2==4)
           {set2=1;}
void baoshi() //整點報時函數
  if(mm==00&&ss==00)
    {fm=0;}
   if(ss==1)
    {fm=1;}
void alarm() //鬧鐘函數
  uchar x;
  if(nhh==0)
     goto end;
   if(hh==nhh&&mm==nmm&&ss==nss)
   for(x=0;x<6;x++)
       fm=0;delay(30);fm=1;delay(20);
       fm=0;delay(30);fm=1;delay(160);
   end:;
void set_time() //設置時間函數
  if(set1==4)
    if(set2==1)
        hh=incone(hh);
        if(hh==24)
          {hh=0;}
        if(hh==-1)
          {hh=23;}
        hh=decone(hh);
  write_add(4,hh);
     if(set2==2)
        mm=incone(mm);
        if(mm==60)
          {mm=0;}
        if(mm==-1)
          {mm=59;}
        mm=decone(mm);
     write_add(5,mm);
      if(set2==3)
        ss=incone(ss);
        if(ss==60)
          {ss=0;}
        if(ss==-1)
          {ss=59;}
        ss=decone(ss);
     write_add(6,ss);
void set_mdw() //設置年月日
if(set1==2)
  if(set2==1)
    year3=incone(year3);
 if(year3>99)
   { year3=0;}
 year3=decone(year3);
 if(year3<0)
   { year3=0;}
 write_add(1,year3);   //在24C02的地址1中寫入數據year3年
  if(set2==2)
    mon=incone(mon);
    if(mon==13)
      { mon=1;}
    mon=decone(mon);
    if(mon==0)
      {mon=12;}
    write_add(2,mon);       //在24C02的地址2中寫入數據mon年
  if(set2==3)
    day=incone(day);
    if(day==32)
      {day=1;}
    day=decone(day);
    if(day==0)
      {day=31;}
    write_add(3,day);     //在24C02的地址1中寫入數據day日
void set_alarm() //設置鬧鐘函數
  if(set1==7)
      if(set2==1)
          nhh=incone(nhh);
          if(nhh==24)
            {nhh=0;write_add(8,nhh);}
          if(nhh==-1)
            {nhh=23;write_add(8,nhh);}
          nhh=decone(nhh);
    write_add(8,nhh);
     if(set2==2)
         nmm=incone(nmm);
         if(nmm==60)
           {nmm=0;write_add(9,nmm);}
         nmm=decone(nmm);
         if(nmm==-1)
           {nmm=59;write_add(9,nmm);}
   write_add(9,nmm);
     if(set2==3)
         nss=incone(nss);
         if(nss==60)
           {nss=0;write_add(10,nss);}
         nss=decone(nss);
         if(nss==-1)
           {nss=59;write_add(10,nss);}
   write_add(10,nss);
void timer1() interrupt 3
   TH1=(65536-50000)/256;//再次裝定時器初值
 TL1=(65536-50000)%256;
 a++;
 if(a<100)display(year3,mon,day);
    if(a>100&&a<200)display(hh,mm,ss);
    if(a>200&&a<300)display(nhh,nmm,nss);
 if(a>300)a=0;
void timer0() interrupt 1//定時器0中斷服務程序
 TH0=(65536-50000)/256;//再次裝定時器初值
 TL0=(65536-50000)%256;
 n++;  //中斷次數累加
 if(n==20) //20次50毫秒為1秒
  n=0;
  ss++;
  if(ss==60)//秒加到60則進位分鐘
   ss=0;//同時秒數清零
   mm++;
   if(mm==60)//分鐘加到60則進位小時
    mm=0;//同時分鐘數清零
    hh++;
    if(hh==24)//小時加到24則小時清零
     hh=0;
     day++;week++;
     if(week==8)
       {week=0;}
     write_add(7,week);
     if(year%4==0&&year%100!=0||year%400==0) //閏年
       {if(day==table1[mon]+1)
           { day=0;mon++;
             if(mon==13)
                {mon=0;year++;
           write_add(1,year3);
             write_add(2,mon);
        write_add(3,day);
      else    //非閏年
        if(day==table2[mon]+1)
          {day=0;mon++;
        if(mon==13)
           {mon=0;year++;
         write_add(1,year3);
        write_add(2,mon);
      write_add(1,day);
    write_add(4,hh);//數據改變立即存入24C02
    write_add(5,mm);//數據改變立即存入24C02
   write_add(6,ss);//數據改變立即存入24C02
ID:1 發表于 2010-7-30 19:31 | 只看該作者
給你一個 100% 沒有問題的程序
http://m.zg4o1577.cn/bbs/dpj-2807-1.html
ID:188935 發表于 2017-9-14 10:55 | 只看該作者
admin 發表于 2010-7-30 19:31
給你一個 100% 沒有問題的程序
謝謝分享
主站蜘蛛池模板: 激情影院在线观看 | 亚洲精品乱码久久久久久 | 精东影业一区二区三区 | 国产精品黄色 | 日本在线观看 | 成人久久网 | 色香蕉视频 | 国产精品免费一区二区三区 | 久草资源站 | 北岛玲在线 | 日本免费不卡视频 | 日本免费毛片 | 狠狠躁夜夜躁人爽 | 天天拍天天操 | a视频在线观看 | 91五月天| 曰本毛茸茸性生活 | 久久精品在线 | www久久| 久久中文视频 | 欧美精品在线观看视频 | 青青草网站| 日日夜夜精品免费 | 欧美精品一区二区三区四区 | 亚洲另类av| 黄色片免费看 | 在线欧美日韩 | 国产第一福利 | 欧美成人精品欧美一级私黄 | 成人在线观看网站 | 日韩av专区 | 国产又黄又爽 | 一区二区三区在线看 | 男人天堂av网 | 日本视频免费 | 玖玖色资源 | 免费一区二区三区 | av网址在线播放 | 伊人精品久久 | 成人国产精品免费观看 | 久久大 |
