查看: 1935|回復: 0
矩陣鍵盤顯示0—f
ID:146913 發表于 2016-11-8 21:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <STC15Fxxxx.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
unsigned char code duan[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0
unsigned char code wei[]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f
uchar num,temp;
sbit SDA1=P4^0;
sbit SCL1=P4^3;
sbit SCL2=P5^4;
uchar keyscan();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void Whc_in(unsigned char Data)
unsigned char i;
for(i=0;i<8;i++)
SCL1=0;
SDA1=Data&0x80;
Data<<=1;
SCL1=1;
void Whc_out(void)
SCL2=0;
_nop_();
SCL2=1;
void Disp(unsigned char m,unsigned char n)
Whc_in(wei[n]);
Whc_in(duan[m]);
Whc_out();
delay(10);
            Disp(keyscan(),0);
uchar keyscan()
            P0=0xfe;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xee:num=1;
                                break;
                            case 0xde:num=2;
                                break;
                            case 0xbe:num=3;
                                break;
                            case 0x7e:num=4;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xfd;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xed:num=5;
                                break;
                            case 0xdd:num=6;
                                break;
                            case 0xbd:num=7;
                                break;
                            case 0x7d:num=8;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xfb;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xeb:num=9;
                                break;
                            case 0xdb:num=10;
                                break;
                            case 0xbb:num=11;
                                break;
                            case 0x7b:num=12;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xf7;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xe7:num=13;
                                break;
                            case 0xd7:num=14;
                                break;
                            case 0xb7:num=15;
                                break;
                            case 0x77:num=16;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
return num;
主站蜘蛛池模板: 成人影| 成人片免费看 | 国产普通话对白 | 综合网伊人 | 欧美在线播放视频 | 亚洲av毛片 | 香蕉视频在线观看网站 | 五月天激情国产综合婷婷婷 | 午夜激情影院 | 黄色激情视频网站 | 欧美日韩一区二区在线 | 成人黄色大片 | 高潮毛片又色又爽免费 | 国产乱码一区二区三区 | 国产手机在线视频 | 亚州av在线 | 天天看天天干 | 黄色小视频免费看 | 久久久福利视频 | 国产精品免费av | 黑人精品xxx一区一二区 | 欧美日韩综合网 | 天天综合av | 亚洲第一色网 | 日韩视频精品 | 国产精品入口66mio男同 | 欧美日韩国产在线播放 | 中文字幕在线免费播放 | 国产欧美精品一区二区三区 | 精品久久网站 | 成人在线观看免费爱爱 | 国产伦精品一区二区三毛 | 一区二区三区影院 | www国产| 免费黄色小说网站 | 日韩精品综合 | 成年视频在线观看 | 手机av免费| 九九在线免费视频 | 国产成人精品免费视频 | 五月播播 |
