查看: 4990|回復: 4
光立柱
ID:108715 發表于 2016-11-19 13:31 | 顯示全部樓層 |閱讀模式
部分代碼:
#include <stc12c5a60s2.h>
#include <intrins.h>
#define LongToBin(n) (((n>>21)&0x80)|((n>>18)&0x40)|((n>>15)&0x20)|((n>>12)&0x10)|((n>>9)&0x08)|((n>>6)&0x04)|((n>>3)&0x02)|((n)&0x01))
#define BIN(n) LongToBin(0x##n##)
#define uchar unsigned char
#define uint unsigned int
sbit H  =P0^4;
sbit L1=P3^4;
sbit L2=P3^5;
sbit L3=P3^6;
sbit L4=P3^7;
sbit hwx=P3^3;                //紅外接收數據引腳,
uchar buf[8];
int temp[20];
int ztemp;
unsigned char ly_lhj[4];                                        //保存NEC的四個字節數據
bit ly_flag=1;        //成功接收標志
void test();
void delayh(void){
        unsigned char i=200;
        while(i--);
void delay(uint i){while(--i);}
uchar code zm[][8]=
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // - -
        0x04,0x04,0x04,0x04,0x04,0x00,0x04,0x00, // -!-
        0x0A,0x0A,0x0A,0x00,0x00,0x00,0x00,0x00, // -"-
        0x0A,0x0A,0x1F,0x0A,0x1F,0x0A,0x0A,0x00, // -#-
        0x04,0x1E,0x03,0x0E,0x14,0x0F,0x04,0x00, // -$-
        0x03,0x13,0x08,0x04,0x02,0x19,0x18,0x00, // -%-
        0x02,0x05,0x05,0x02,0x15,0x09,0x16,0x00, // -&-
        0x0C,0x04,0x02,0x00,0x00,0x00,0x00,0x00, // -'-
        0x08,0x04,0x02,0x02,0x02,0x04,0x08,0x00, // -(-
        0x02,0x04,0x08,0x08,0x08,0x04,0x02,0x00, // -)-
        0x04,0x15,0x0E,0x04,0x0E,0x15,0x04,0x00, // -*-
        0x04,0x04,0x04,0x1F,0x04,0x04,0x04,0x00, // -+-
        0x00,0x00,0x00,0x00,0x06,0x02,0x01,0x00, // -,-
        0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00, // ---
        0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x00, // -.-
        0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, // -/-
        0x00,0x00,0x1C,0x22,0x2A,0x08,0x07,0x00, // -0-//ok
        0x00,0x00,0x38,0x44,0x54,0x10,0xE0,0x00, // -1-//ok
        0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55, // -2-//ok
        0xFF,0x00,0x3C,0x24,0x24,0x3C,0x00,0xFF, // -3-//ok
        0x00,0x20,0x50,0x88,0x05,0x02,0x02,0x02, // -4-//ok
        0x0C,0x1E,0x3F,0x3F,0x1F,0x0F,0x07,0x03, // -5-
        0x30,0x78,0xFC,0xFC,0xF8,0xF0,0xE0,0xC0, // -6-
        0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01, // -7-
        0x0E,0x11,0x11,0x0E,0x11,0x11,0x0E,0x00, // -8-
        0x0E,0x11,0x11,0x1E,0x10,0x08,0x07,0x00, // -9-
        0x00,0x06,0x06,0x00,0x06,0x06,0x00,0x00, // -:-
        0x00,0x06,0x06,0x00,0x06,0x06,0x01,0x00, // -;-
        0x08,0x04,0x02,0x01,0x02,0x04,0x08,0x00, // -<-
        0x00,0x00,0x1F,0x00,0x1F,0x00,0x00,0x00, // -=-
        0x02,0x04,0x08,0x10,0x08,0x04,0x02,0x00, // ->-
        0x0E,0x11,0x08,0x04,0x04,0x00,0x04,0x00, // -?-
        0x0E,0x11,0x1D,0x15,0x1D,0x01,0x1E,0x00, // -@-
        0x04,0x0A,0x11,0x11,0x1F,0x11,0x11,0x00, // -A-
        0x0F,0x11,0x11,0x0F,0x11,0x11,0x0F,0x00, // -B-
        0x0E,0x11,0x01,0x01,0x01,0x11,0x0E,0x00, // -C-
        0x0F,0x11,0x11,0x11,0x11,0x11,0x0F,0x00, // -D-
        0x1F,0x01,0x01,0x0F,0x01,0x01,0x1F,0x00, // -E-
        0x1F,0x01,0x01,0x0F,0x01,0x01,0x01,0x00, // -F-
        0x0E,0x11,0x01,0x01,0x1D,0x11,0x1E,0x00, // -G-
        0x11,0x11,0x11,0x1F,0x11,0x11,0x11,0x00, // -H-
        0x0E,0x04,0x04,0x04,0x04,0x04,0x0E,0x00, // -I-
        0x1C,0x08,0x08,0x08,0x08,0x09,0x06,0x00, // -J-
        0x11,0x09,0x05,0x03,0x05,0x09,0x11,0x00, // -K-
        0x01,0x01,0x01,0x01,0x01,0x01,0x1F,0x00, // -L-
        0x11,0x1B,0x15,0x15,0x11,0x11,0x11,0x00, // -M-
        0x11,0x11,0x13,0x15,0x19,0x11,0x11,0x00, // -N-
        0x0E,0x11,0x11,0x11,0x11,0x11,0x0E,0x00, // -O-
        0x0F,0x11,0x11,0x0F,0x01,0x01,0x01,0x00, // -P-
        0x0E,0x11,0x11,0x11,0x15,0x09,0x16,0x00, // -Q-
        0x0F,0x11,0x11,0x0F,0x05,0x09,0x11,0x00, // -R-
        0x0E,0x11,0x01,0x0E,0x10,0x11,0x0E,0x00, // -S-
        0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x00, // -T-
        0x11,0x11,0x11,0x11,0x11,0x11,0x0E,0x00, // -U-
        0x11,0x11,0x11,0x11,0x11,0x0A,0x04,0x00, // -V-
        0x11,0x11,0x11,0x15,0x15,0x1B,0x11,0x00, // -W-
        0x11,0x11,0x0A,0x04,0x0A,0x11,0x11,0x00, // -X-
        0x11,0x11,0x0A,0x04,0x04,0x04,0x04,0x00, // -Y-
        0x1F,0x10,0x08,0x04,0x02,0x01,0x1F,0x00, // -Z-
        0x0F,0x03,0x03,0x03,0x03,0x03,0x0F,0x00, // -[-
        0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00, // -\-
        0x1E,0x18,0x18,0x18,0x18,0x18,0x1E,0x00, // -]-
        0x04,0x0E,0x15,0x04,0x04,0x04,0x04,0x00, // -^-
        0x00,0x04,0x02,0x1F,0x02,0x04,0x00,0x00, // -_-
        0x04,0x08,0x10,0x00,0x00,0x00,0x00,0x00, // -`-
        0x00,0x00,0x07,0x08,0x0E,0x09,0x16,0x00, // -a-
        0x01,0x01,0x0D,0x13,0x11,0x13,0x0D,0x00, // -b-
        0x00,0x00,0x0E,0x11,0x01,0x01,0x0E,0x00, // -c-
        0x10,0x10,0x16,0x19,0x11,0x19,0x16,0x00, // -d-
        0x00,0x00,0x0E,0x11,0x0F,0x01,0x0E,0x00, // -e-
        0x0C,0x12,0x02,0x0F,0x02,0x02,0x02,0x00, // -f-
        0x00,0x00,0x0E,0x11,0x11,0x1E,0x10,0x0F, // -g-
        0x01,0x01,0x0D,0x13,0x11,0x11,0x11,0x00, // -h-
        0x04,0x00,0x00,0x04,0x04,0x04,0x04,0x00, // -i-
        0x08,0x00,0x00,0x0C,0x08,0x08,0x08,0x06, // -j-
        0x01,0x01,0x09,0x05,0x03,0x05,0x19,0x00, // -k-
        0x06,0x04,0x04,0x04,0x04,0x04,0x0E,0x00, // -l-
        0x00,0x00,0x0A,0x15,0x15,0x15,0x15,0x00, // -m-
        0x00,0x00,0x0D,0x12,0x12,0x12,0x12,0x00, // -n-
        0x00,0x00,0x0E,0x11,0x11,0x11,0x0E,0x00, // -o-
        0x00,0x00,0x0F,0x11,0x11,0x0F,0x01,0x01, // -p-
        0x00,0x00,0x1E,0x11,0x11,0x1E,0x10,0x10, // -q-
        0x00,0x00,0x0D,0x12,0x02,0x02,0x02,0x00, // -r-
        0x00,0x00,0x1E,0x01,0x0E,0x10,0x0F,0x00, // -s-
        0x02,0x02,0x1F,0x02,0x02,0x12,0x0C,0x00, // -t-
        0x00,0x00,0x09,0x09,0x09,0x09,0x16,0x00, // -u-
        0x00,0x00,0x11,0x11,0x11,0x0A,0x04,0x00, // -v-
        0x00,0x00,0x15,0x15,0x15,0x15,0x0A,0x00, // -w-
        0x00,0x00,0x11,0x0A,0x04,0x0A,0x11,0x00, // -x-
        0x00,0x00,0x11,0x11,0x19,0x16,0x10,0x0F, // -y-
        0x00,0x00,0x1F,0x08,0x04,0x02,0x1F,0x00, // -z-
        0x00,0x36,0x7F,0x7F,0x3E,0x1C,0x08,0x00, // -{-//OK
        0x04,0x04,0x04,0x00,0x04,0x04,0x04,0x00, // -|-
        0xFF,0x55,0xFF,0x55,0xFF,0x55,0xFF,0x55, // -}-//OK
        0x00,0x00,0x02,0x15,0x08,0x00,0x00,0x00, // -~-
        0x15,0x0A,0x15,0x0A,0x15,0x0A,0x15,0x00, // --
void delay_1ms(uint q)
        uint i,j;
        for(i=0;i<q;i++)
                for(j=0;j<120;j++);
uint count=0;
uchar slen;
uchar zmMov(uchar i,j,uchar *s)
        uchar si=count/8+j;
        uchar mi=count%8;
        return (zm[s[(si+1)%slen]-32][i]<<8-mi)|(zm[s[si%slen]-32][i]>>mi);
void dispmov(uchar *s)
        uchar i=0;
        uchar row=0x01;
        for(slen=0;s[slen]!=0;slen++)
        while(i<8)
                P2=zmMov(i,0,s);L1=1;L1=0;
                P2=zmMov(i,1,s);L2=1;L2=0;
                P2=zmMov(i,2,s);L3=1;L3=0;
                P2=zmMov(i,3,s);L4=1;L4=0;
                P2=row;H=1;H=0;
                delay(1500);i++;
                row=_crol_(row,1);
                P2=0;
                H=L1=L2=L3=L4=1;
                H=L1=L2=L3=L4=0;
uchar STC_ADC()                   //!!根據數據手冊寫一個ad讀取函數
     uchar i;
     ADC_RES   = 0;
     ADC_RESL  = 0;
         ADC_CONTR = BIN(10001000);
         i=3;
     while(i--);
     while (1)
         if (ADC_CONTR & BIN(10000))
                             break;
     ADC_CONTR = BIN(10000000);
           return( ADC_RESL<<2) ;
光立柱資料.rar
4.77 MB, 下載次數: 36, 下載積分: 黑幣 -5
ID:432687 發表于 2019-5-26 05:01 來自觸屏版 | 顯示全部樓層
完美一直在尋找它很長一段時間! 謝謝你的分享。
ID:561805 發表于 2019-6-13 15:14 | 顯示全部樓層
大佬大佬
ID:379452 發表于 2022-4-7 14:01 | 顯示全部樓層
獻上感謝
ID:242298 發表于 2024-4-12 05:07 | 顯示全部樓層
這個柱子不用三極管催生一下,光靠單片機能點亮‘’‘’‘’‘’‘’
主站蜘蛛池模板: 国产精品高潮呻吟久久 | 在线观看黄色小视频 | 免费成人在线观看 | 在线观看一区 | 欧美日韩激情视频 | 在线观看黄色av | 国产在线不卡 | 一区二区三区在线观看视频 | 欧美久久久久久久 | 亚洲一区二区精品视频 | 欧美狠狠干 | 亚洲精品久久久蜜桃 | 欧美日韩视频 | 成年人在线播放 | 久久久不卡| 天天草天天干 | 成人自拍视频在线观看 | 亚洲欧美日韩一区二区三区四区 | 97成人在线 | 国产精品一级二级 | 中文字幕欧美激情 | 国语对白做受欧美 | 欧美一区二区三区在线观看 | 欧美三级韩国三级日本三斤在线观看 | 免费性网站 | 欧美色综合 | 成年免费视频黄网站在线观看 | 九九热视频在线观看 | 欧美在线日韩 | 一级片在线视频 | 色站综合| 男女h黄动漫啪啪无遮挡软件 | 欧美国产日韩精品 | 成人毛片在线 | 在线播放a| 永久免费看片在线播放 | 精品1区| 黄色网址入口 | 一级黄色小视频 | 麻豆av网 | 亚洲美女网站 |
