查看: 5449|回復: 0
STM32F107驗證通過的CRC校驗程序
ID:158141 發(fā)表于 2016-12-27 19:40 | 顯示全部樓層 |閱讀模式
STM32F107之CRC循環(huán)冗余校驗碼
下載:
代碼 CRC循環(huán)冗余校驗碼.7z (699.97 KB, 下載次數: 56)
  1. /**
  2. /* Includes ------------------------------------------------------------------*/
  3. #include "stm32f10x.h"
  4. /** @addtogroup STM32F10x_StdPeriph_Examples
  5.   * @{
  6.   */
  7. /** @addtogroup CRC_Calculation
  8.   * @{
  9.   */
  10. /* Private typedef -----------------------------------------------------------*/
  11. /* Private define ------------------------------------------------------------*/
  12. #define BUFFER_SIZE    114
  13. /* Private macro -------------------------------------------------------------*/
  14. /* Private variables ---------------------------------------------------------*/
  15. static const uint32_t DataBuffer[BUFFER_SIZE] =
  16.   {
  17.     0x00001021, 0x20423063, 0x408450a5, 0x60c670e7, 0x9129a14a, 0xb16bc18c,
  18.     0xd1ade1ce, 0xf1ef1231, 0x32732252, 0x52b54294, 0x72f762d6, 0x93398318,
  19.     0xa35ad3bd, 0xc39cf3ff, 0xe3de2462, 0x34430420, 0x64e674c7, 0x44a45485,
  20.     0xa56ab54b, 0x85289509, 0xf5cfc5ac, 0xd58d3653, 0x26721611, 0x063076d7,
  21.     0x569546b4, 0xb75ba77a, 0x97198738, 0xf7dfe7fe, 0xc7bc48c4, 0x58e56886,
  22.     0x78a70840, 0x18612802, 0xc9ccd9ed, 0xe98ef9af, 0x89489969, 0xa90ab92b,
  23.     0x4ad47ab7, 0x6a961a71, 0x0a503a33, 0x2a12dbfd, 0xfbbfeb9e, 0x9b798b58,
  24.     0xbb3bab1a, 0x6ca67c87, 0x5cc52c22, 0x3c030c60, 0x1c41edae, 0xfd8fcdec,
  25.     0xad2abd0b, 0x8d689d49, 0x7e976eb6, 0x5ed54ef4, 0x2e321e51, 0x0e70ff9f,
  26.     0xefbedfdd, 0xcffcbf1b, 0x9f598f78, 0x918881a9, 0xb1caa1eb, 0xd10cc12d,
  27.     0xe16f1080, 0x00a130c2, 0x20e35004, 0x40257046, 0x83b99398, 0xa3fbb3da,
  28.     0xc33dd31c, 0xe37ff35e, 0x129022f3, 0x32d24235, 0x52146277, 0x7256b5ea,
  29.     0x95a88589, 0xf56ee54f, 0xd52cc50d, 0x34e224c3, 0x04817466, 0x64475424,
  30.     0x4405a7db, 0xb7fa8799, 0xe75ff77e, 0xc71dd73c, 0x26d336f2, 0x069116b0,
  31.     0x76764615, 0x5634d94c, 0xc96df90e, 0xe92f99c8, 0xb98aa9ab, 0x58444865,
  32.     0x78066827, 0x18c008e1, 0x28a3cb7d, 0xdb5ceb3f, 0xfb1e8bf9, 0x9bd8abbb,
  33.     0x4a755a54, 0x6a377a16, 0x0af11ad0, 0x2ab33a92, 0xed0fdd6c, 0xcd4dbdaa,
  34.     0xad8b9de8, 0x8dc97c26, 0x5c644c45, 0x3ca22c83, 0x1ce00cc1, 0xef1fff3e,
  35.     0xdf7caf9b, 0xbfba8fd9, 0x9ff86e17, 0x7e364e55, 0x2e933eb2, 0x0ed11ef0
  36.   };
  37. __IO uint32_t CRCValue = 0;
  38. /* Private function prototypes -----------------------------------------------*/
  39. void Delay(__IO uint32_t nCount);
  40. /* Private functions ---------------------------------------------------------*/
  41. /**
  42.   * @brief  Main program.
  43.   * @param  None
  44.   * @retval None
  45.   */
  46. int main(void)
  47. {
  48.   /*!< At this stage the microcontroller clock setting is already configured,
  49.        this is done through SystemInit() function which is called from startup
  50.        file (startup_stm32f10x_xx.s) before to branch to application main.
  51.        To reconfigure the default setting of SystemInit() function, refer to
  52.        system_stm32f10x.c file
  53.      */
  54.
  55.   /* Enable CRC clock */
  56.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC, ENABLE);
  57.   /* Compute the CRC of "DataBuffer" */
  58.   CRCValue = CRC_CalcBlockCRC((uint32_t *)DataBuffer, BUFFER_SIZE);
  59.   while (1)
  60.   {
  61.   }
  62. }
  63. /**
  64.   * @brief  Inserts a delay time.
  65.   * @param  nCount: specifies the delay time length.
  66.   * @retval None
  67.   */
  68. void Delay(__IO uint32_t nCount)
  69. {
  70.   for(; nCount != 0; nCount--);
  71. }
  72. #ifdef  USE_FULL_ASSERT
  73. /**
  74.   * @brief  Reports the name of the source file and the source line number
  75.   *         where the assert_param error has occurred.
  76.   * @param  file: pointer to the source file name
  77.   * @param  line: assert_param error line source number
  78.   * @retval None
  79.   */
  80. void assert_failed(uint8_t* file, uint32_t line)
  81. {
  82.   /* User can add his own implementation to report the file name and line number,
  83.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  84.   /* Infinite loop */
  85.   while (1)
  86.   {
  87.   }
  88. }
  89. #endif
  90. /**
  91.   * @}
  92.   */
  93. /**
  94.   * @}
  95.   */
  96. /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
主站蜘蛛池模板: 加勒比一区二区三区 | 国产精品欧美精品 | 日本黄色录像 | 在线播放亚洲 | 欧美日韩一区二 | 成人午夜在线观看 | 亚洲一区在线视频 | 久久免费高清视频 | 又黄又爽又刺激的视频 | 欧美精品在线观看视频 | 日韩国产在线播放 | 国产高潮在线观看 | 日本黄色一级视频 | 三级福利视频 | 成人高潮片免费网站 | 欧美综合久久 | 国产欧美日韩综合精品 | 在线观看日韩精品 | 六月激情 | 亚洲综合天堂 | 国产一区在线看 | 一区二区三区四区在线 | 欧美在线不卡 | 中文字幕在线观看日本 | 亚洲成人免费在线观看 | 日韩在线观看一区 | 国产一级大片 | 深夜福利网址 | 亚洲乱码一区二区 | 久久黄色免费视频 | 成人理论影院 | 国产成人一区二区三区 | 簧片在线免费观看 | 在线观看视频91 | av不卡在线播放 | 天天爽天天爽 | 国产传媒视频在线观看 | 亚洲欧美日韩国产 | 狠狠干网站 | 黄色片久久 | 免费看黄色aaaaaa 片 |
