查看: 4015|回復: 11
dht11測試溫濕度,1602顯示,溫濕度固定為15?求助大神
回帖獎勵 35 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 1 次(中獎概率 80%)
ID:167739 發表于 2017-3-2 20:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 lx490004 于 2017-3-2 20:09 編輯
這是小弟的程序,在開發板上試的程序,89c52rc
不知道為什么溫濕度固定顯示15
下面是程序,麻煩各位了
#include <reg52.h>
#define uint unsigned int
#define uchar unsigned char
typedef bit BOOL;
sbit io = P3^0;
sbit rs = P1^0;
sbit rw = P1^1;
sbit ep = P2^5;
uchar data_byte;
uchar RH,RL,TH,TL;
/********延時模塊***********/
void delay(uchar ms)
{       // 延時子程序
        uchar i;
        while(ms--)
                for(i = 0;i<250;i++);
void delay1()//延時10us
        uchar i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
void longdelay(uchar s) //長延時
        while(s--)
                delay(60);
BOOL lcd_bz()//測試LCD忙碌狀態
        BOOL result;
        rs = 0;
        rw = 1;
        ep = 1;
        result = (BOOL)(P0 & 0x80);
        ep = 0;
        return result;
void write_cmd(uchar cmd)// 寫指令
        while(lcd_bz());
        rs = 0;
        rw = 0;
        ep = 0;
        P0 = cmd;
        ep = 1;
        ep = 0;
void write_addr(uchar addr)//寫地址
        write_cmd(addr|0x80);
void write_byte(uchar dat)//寫字節
        while(lcd_bz());
        rs = 1;
        rw = 0;
        ep = 0;
        P0 = dat;
        ep = 1;
        ep = 0;
void lcd_init()// 初始化
        write_cmd(0x38);
        delay(1);
        write_cmd(0x08);
        delay(1);
        write_cmd(0x01);
        delay(1);
        write_cmd(0x06);
        delay(1);
        write_cmd(0x0c);
        delay(1);
void display(uchar addr, uchar q)//在某一地址上顯示一字節
        delay(10);
        write_addr(addr);
        write_byte(q);
        longdelay(2);
void start()//開始信號
        io=1;
        delay1();
        io=0;
        delay(20);//>18ms
        io=1;
        delay1();//20-40us
        delay1();
        delay1();
        delay1();
        delay1();
uchar receive_byte()//接收一個字節
        uchar i,temp,count;
        for(i=0;i<8;i++)
                count=2;
                while((!io)&&count++)//等待50us低電平結束
                temp=0;
                delay1();
                delay1();
                delay1();
                delay1();
                if(io==1)
                temp=1;
                count=2;
                while((io)&&count++);
                if(count==1)break;
                data_byte<<=1;
                data_byte|=temp;
        return data_byte;
void receive()//接收數據
        uchar T_H,T_L,R_H,R_L,check,num_check;
        uchar count;
        start();//開始信號
        io=1;
        if(!io)//讀取DHT11響應信號
                count=2;
                while((!io)&&count++);//DHT11高電平80us是否結束
                count=2;
                R_H=receive_byte();
                R_L=receive_byte();
                T_H=receive_byte();
                T_L=receive_byte();
                check=receive_byte();
                io=0;//拉低延時50us
                delay1();
                delay1();
                delay1();
                delay1();
                delay1();
                io=1;
                num_check=R_H+R_L+T_H+T_L;
                if(num_check=check)
                        RH=R_H;
                        RL=R_L;
                        TH=T_H;
                        TL=T_L;
                        check=num_check;
        lcd_init();
        delay(10);
                receive();
                delay(100);
                display(0x00,'R');
                display(0x01,':');
                display(0x02,RH/10+0x30);
                display(0x03,RH%10+0x30);
                display(0x04,'%');
                display(0x40,'T');
                display(0x41,':');
                display(0x42,TH/10+0x30);
                display(0x43,TH%10+0x30);
                display(0x44,0xdf);
                display(0x45,0x43);
ID:167739 發表于 2017-3-2 20:10 | 只看該作者
跪求各位大神
ID:85726 發表于 2017-3-3 09:43 | 只看該作者
注意延時,DHT11對延時要求比較高!注意你的單片機速度和晶振的頻率!
ID:167739 發表于 2017-3-4 20:20 | 只看該作者
我的晶振用的是12M的啊
ID:193152 發表于 2017-5-3 16:40 | 只看該作者
回帖獎勵 +5 黑幣
沒錯誤
我下我單片機上都挺對的
ID:193152 發表于 2017-5-3 16:41 | 只看該作者
我下我單片機上都挺對
ID:169944 發表于 2017-5-3 17:07 | 只看該作者
回帖獎勵 +5 黑幣
固定顯示的話是不是1602沒有清屏
ID:82765 發表于 2017-5-3 17:16 | 只看該作者
回帖獎勵 +5 黑幣
提示: 作者被禁止或刪除 內容自動屏蔽
ID:140489 發表于 2017-7-26 12:54 | 只看該作者
11.0592的晶振可以正常顯示的,在開發板上測試過的
ID:105206 發表于 2017-7-28 19:40 | 只看該作者
我發個帖,看看
ID:213173 發表于 2017-7-29 08:06 | 只看該作者
        if(num_check=check)  這里少個=號
主站蜘蛛池模板: a天堂在线| 草草视频在线观看 | 欧美a在线观看 | 夜夜操天天操 | 岛国av噜噜噜久久久狠狠av | 国产美女视频网站 | 在线成人免费视频 | 日本在线免费观看 | a级毛毛片 | 久热国产精品 | 免费成人结看片 | 天天操狠狠干 | 国产精品一区视频 | 538精品视频| 黄色国产在线观看 | 成人免费福利视频 | 青青草网址 | 亚洲精品欧美 | 国产精品一区二区三 | 国产欧美一区二区三区在线看蜜臀 | 午夜免费福利视频 | 亚洲第十页 | 91禁在线观看 | 成人午夜小视频 | 欧美日韩在线观看视频 | 亚洲亚洲人成综合网络 | 国产一区高清 | 国产视频在线观看视频 | 欧美黑粗大 | 亚洲黄色大片 | 欧美一级欧美三级在线观看 | 国产一区二区在线看 | 深夜福利免费 | 日韩在线成人 | 日韩久久久 | 色综合天天综合网国产成人网 | 成人午夜网 | www.久久久久| 日韩欧美在线看 | 亚洲在线视频 | 青青国产 |
