查看: 110910|回復: 338
別人的altium designer常用元件庫和封裝庫下載-非常全面初學者有福了
ID:168433 發表于 2017-3-6 00:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 三分鐘熱度ooo 于 2017-3-6 00:13 編輯
http://m.zg4o1577.cn/bbs/dpj-31103-1.html     原網址
1.
  我的元件庫\74LS595.LibPkg
  ..........\78穩壓塊.SCHLIB
  ..........\8-8點陣.LibPkg
  ..........\8-8點陣.PcbLib
  ..........\8-8點陣.SchLib
  ..........\altium\PCB_lib\IC.PCBLIB
  ..........\......\.......\IC.PCBLIB.htm
  ..........\......\.......\jointbar.PCBLIB
  ..........\......\.......\jointbar.PCBLIB.htm
  ..........\......\.......\Miscellaneous Connectors.PcbLib
  ..........\......\.......\Miscellaneous Connectors.PcbLib.htm
  ..........\......\.......\photounit.PCBLIB
  ..........\......\.......\photounit.PCBLIB.htm
  ..........\......\.......\RCDQLY.PCBLIB
  ..........\......\.......\RCDQLY.PCBLIB.htm
  ..........\......\.......\rest.PCBLIB
  ..........\......\.......\rest.PCBLIB.htm
  ..........\......\.......\常用元件封裝.PCBLIB
  ..........\......\.......\常用元件封裝.PCBLIB.htm
  ..........\......\.......\常用元件封裝庫(pcb).PCBLIB
  ..........\......\.......\常用元件封裝庫(pcb).PCBLIB.htm
  ..........\......\SCH_lib\CD4000系列IC.SCHLIB
  ..........\......\.......\CMOS&TTL74.SCHLIB
  ..........\......\.......\IC.SCHLIB
  ..........\......\.......\Miscellaneous Devices.SCHLIB
  ..........\......\.......\MyInt_Lib.LIBPKG
  ..........\......\.......\photounit.SCHLIB
  ..........\......\.......\RCDQLY.SCHLIB
  ..........\......\.......\rest.SCHLIB
  ..........\......\.......\TTL74系列IC.SCHLIB
  ..........\......\.......\二極管.SCHLIB
  ..........\......\.......\單片機及相關.SCHLIB
  ..........\......\.......\場效應管及可控硅.SCHLIB
  ..........\......\.......\聲亮元件.SCHLIB
  ..........\......\.......\常用元件庫.SCHLIB
  ..........\......\.......\開關.SCHLIB
  ..........\......\.......\感應元件.SCHLIB
  ..........\......\.......\接口與插座.SCHLIB
  ..........\......\.......\插件.SCHLIB
  ..........\......\.......\數字符號.SCHLIB
  ..........\......\.......\雜元件庫.SCHLIB
  ..........\......\.......\模擬符號.SCHLIB
  ..........\......\.......\模擬集成電路.SCHLIB
  ..........\......\.......\電容.SCHLIB
  ..........\......\.......\電源.SCHLIB
  ..........\......\.......\電阻.SCHLIB
  ..........\......\.......\繼電器類元件.SCHLIB
  ..........\CD4000系列IC.SCHLIB
  ..........\Composite Drawing.pdf
  ..........\DIP-16.LibPkg
  ..........\DIP-16.PcbLib
  ..........\DIP-16.SchLib
  ..........\Final Artwork Prints.pdf
  ..........\GT_PCB\專用A.PcbLib
  ..........\......\專用B.PcbLib
  ..........\......\專用C.PcbLib
  ..........\......\劉強PCB.PcbLib
  ..........\...SCH\ARM.SchLib
  ..........\......\劉強SCH.SchLib
  ..........\......\常用1.SchLib
  ..........\......\常用2.SchLib
  ..........\......\模塊\51單片機.SchLib
  ..........\......\....\555.SchLib
  ..........\......\....\74HC164.SchLib
  ..........\......\....\74HC595.SchLib
  ..........\......\....\AD7416.SchLib
  ..........\......\....\AD轉換器件.SchLib
  ..........\......\....\AVR單片機.SchLib
  ..........\......\....\BIS0001.SchLib
  ..........\......\....\C8051Fx.SchLib
  ..........\......\....\CH375.SchLib
  ..........\......\....\CHXXXSCH.SchLib
  ..........\......\....\CMOS系列.SchLib
  ..........\......\....\HT單片機.SchLib
  ..........\......\....\ICD2.SchLib
  ..........\......\....\MSP430.SchLib
  ..........\......\....\PIC單片機.SchLib
  ..........\......\....\SLE4442.SchLib
  ..........\......\....\TMS320f2812.SchLib
  ..........\......\....\TTL74系列.SchLib
  ..........\......\....\中央處理器.SchLib
  ..........\......\....\傳感器.SchLib
  ..........\......\....\光電器件.SchLib
  ..........\......\....\變壓器.SchLib
  ..........\......\....\可控硅.SchLib
  ..........\......\....\場效應管.SchLib
  ..........\......\....\存儲器.SchLib
  ..........\......\....\接口器件.SchLib
  ..........\......\....\數碼管.SchLib
  ..........\......\....\時鐘芯片.SchLib
  ..........\......\....\模擬器件.SchLib
  ..........\......\....\液晶.SchLib
  ..........\......\....\電子管.SchLib
  ..........\......\....\電控開關.SchLib
  ..........\......\....\穩壓器件.SchLib
  ..........\......\....\語音芯片.SchLib
  ..........\History\8-8點陣.~(1).LibPkg.Zip
  ..........\.......\8-8點陣.~(1).PcbLib.Zip
  ..........\.......\8-8點陣.~(1).SchLib.Zip
  ..........\.......\8-8點陣.~(2).LibPkg.Zip
庫文件1下載: Altium-Designer-PCB.rar (2.63 MB, 下載次數: 10359)
----------------------------------我是分隔線-------------------------------------------------------
下面是另一個我收藏的更全面的庫
AD元件庫
.....\AD庫
.....\....\單片機8051.IntLib
.....\....\我的 封裝
.....\....\....\AD轉換.lib
.....\....\....\CMOS系列.Lib
.....\....\....\IC.SCHLIB
.....\....\....\TTL74系列IC.SCHLIB
.....\....\....\中央處理器.lib
.....\....\....\元件
.....\....\....\...\4000 CMOS.SchLib
.....\....\....\...\4位共陽極數碼管.SchLib
.....\....\....\...\74xxTTL.SchLib
.....\....\....\...\CPU.SchLib
.....\....\....\...\CRY晶振.SchLib
.....\....\....\...\C電容.SchLib
.....\....\....\...\DIODE.SchLib
.....\....\....\...\D硅堆.SchLib
.....\....\....\...\J繼電器.SchLib
.....\....\....\...\LCD顯示.SchLib
.....\....\....\...\LED數碼管.SchLib
.....\....\....\...\Linear.SchLib
.....\....\....\...\LM317-337....SchLib
.....\....\....\...\L電感.SchLib
.....\....\....\...\OpAmp比較器.SchLib
.....\....\....\...\Operational 運放.SchLib
.....\....\....\...\OP光耦.SchLib
.....\....\....\...\ORDER其它.SchLib
.....\....\....\...\R電阻.SchLib
.....\....\....\...\Schematic Linear集成芯片.SchLib
.....\....\....\...\Schlib2.SchLib
.....\....\....\...\SCR單向可控硅.SchLib
.....\....\....\...\SW開關.SchLib
.....\....\....\...\TRIAC雙向可控硅.SchLib
.....\....\....\...\T變壓器.SchLib
.....\....\....\...\USB.SchLib
.....\....\....\...\V三極管.SchLib
.....\....\....\...\功放IC.SchLib
.....\....\....\...\常用IC.SchLib
.....\....\....\...\開關.SchLib
.....\....\....\...\接口.SchLib
.....\....\....\...\接觸器.SchLib
.....\....\....\...\電機驅動.SchLib
.....\....\....\...\電阻.SchLib
.....\....\....\...\穩壓管.SchLib
.....\....\....\...\集成塊.SchLib
.....\....\....\單片機及相關.SCHLIB
.....\....\....\變壓器.lib
.....\....\....\可控硅.Lib
.....\....\....\場效應管.LIB
.....\....\....\封裝
.....\....\...\LM317-337封裝.PcbLib
.....\....\...\PCB Footprints.PcbLib
.....\....\...\PCBLIB2.PcbLib
.....\....\...\三極管.PcbLib
.....\....\...\二極管.PcbLib
.....\....\...\共陽極LED.PcbLib
.....\....\...\變壓器.PcbLib
.....\....\...\可調電阻.PcbLib
.....\....\...\常用...封裝庫(pcb).PCBLIB
.....\....\...\開關.PcbLib
.....\....\...\接頭-功率型插座.PcbLib
.....\....\...\插座.PcbLib
.....\....\...\數碼管.PcbLib
.....\....\...\晶振.PcbLib
.....\....\...\液晶顯示器.PcbLib
.....\....\...\電子管.PcbLib
.....\....\...\電感.PcbLib
.....\....\...\硅堆.PcbLib
.....\....\...\繼電器.PcbLib
.....\....\...\蜂鳴器.PcbLib
.....\....\...\貼片-DIP轉換.PcbLib
.....\....\...\貼片.PcbLib
.....\....\...\阻容.PcbLib
.....\....\...\集成塊.PcbLib
.....\....\....\常用器件.SCHLIB
.....\....\....\數碼管光耦.SCHLIB
.....\....\....\雜元件庫.lib
.....\....\....\模擬器件.lib
.....\....\....\電子管.LIB
.....\....\....\電控開關.Lib
庫文件2下載: AD常用元件封裝庫.zip (7.05 MB, 下載次數: 3369)
參與人數 23黑幣 +90 收起 理由
dnsam + 5 很給力!
ckwx123456 + 3 很給力!
stu + 5 共享資料的黑幣獎勵!
hhhlllbbb + 5 很給力!
466167790 + 5 很給力!
hnhkccdyx + 1 贊一個!
zrz111 + 4 很給力!
一世琉璃白 + 5 很給力!
takeafail + 5 很給力!
a1048495714 + 5 共享資料的黑幣獎勵!
76412464 + 1 很給力!
qq383570990 + 4 很給力!
swdsmy + 4 很給力!
zk333 + 3 絕世好帖!
feng005 + 5 共享資料的黑幣獎勵!
drymango + 1 絕世好帖!
劉玉清上 + 5 回帖助人的獎勵!
zlnseu + 5 很給力!
angelboygo3 + 5 贊一個!
X927048000 + 5 回帖助人的獎勵!
guanggong + 5 回帖助人的獎勵!
Hope時代 + 1 很給力!
娛樂天空 + 3 很給力!
收藏收藏28 分享淘帖 頂23 踩
ID:170143 發表于 2017-3-12 19:35 | 只看該作者
很好,好東西,很全面
ID:124911 發表于 2017-3-21 21:29 | 只看該作者
這個真的不錯很有用
ID:188301 發表于 2017-4-13 21:49 | 只看該作者
樓主可以做個朋友嗎?
ID:189667 發表于 2017-4-14 21:21 | 只看該作者
多謝樓主分享
ID:189940 發表于 2017-4-15 20:06 | 只看該作者
好東西,頂一個
ID:191665 發表于 2017-4-20 16:12 | 只看該作者
為啥下載不了,直接說出錯了啊~
ID:193475 發表于 2017-4-25 17:13 | 只看該作者
很好,東西很全
ID:193262 發表于 2017-4-25 21:56 | 只看該作者
我又來了 東西很好
ID:193630 發表于 2017-4-25 22:00 | 只看該作者
好東西大家分享
ID:195306 發表于 2017-5-1 17:25 | 只看該作者
謝謝謝謝
ID:194759 發表于 2017-5-2 19:08 | 只看該作者
好東西大家分享
ID:194700 發表于 2017-5-5 20:21 | 只看該作者
多謝樓主分享
ID:197334 發表于 2017-5-6 15:10 | 只看該作者
感謝樓主分享
ID:197334 發表于 2017-5-6 15:11 | 只看該作者
多謝分享!!
ID:168697 發表于 2017-5-7 17:03 來自觸屏版 | 只看該作者
贊一個
ID:137511 發表于 2017-5-24 20:25 | 只看該作者
謝謝 樓主分享~好多元件  都要自己一個一個創建 好麻煩啊~
ID:137511 發表于 2017-5-24 20:26 | 只看該作者
謝謝樓主分享啊  元件庫很的元件有沒有啊 ~~
ID:204574 發表于 2017-5-25 03:31 | 只看該作者
謝謝分享
ID:205567 發表于 2017-5-28 10:21 | 只看該作者
太感謝樓主了,在做彩燈的實驗,正愁找不到器件,謝謝!!!
ID:199744 發表于 2017-5-30 08:44 | 只看該作者
謝謝樓主大哥分享!!
ID:208555 發表于 2017-6-6 20:34 | 只看該作者
好給力啊
ID:212567 發表于 2017-6-19 14:02 | 只看該作者
好東西~~感謝樓主分享
ID:205199 發表于 2017-6-30 08:48 | 只看該作者
有沒STM的
ID:190995 發表于 2017-7-19 23:33 | 只看該作者
謝謝!受用了
ID:230546 發表于 2017-9-2 12:58 | 只看該作者
十分感謝!!!
ID:237262 發表于 2017-10-4 18:47 | 只看該作者
謝謝樓主分享
ID:237262 發表于 2017-10-4 18:48 | 只看該作者
Thanks
ID:239368 發表于 2017-10-14 13:23 | 只看該作者
我好像下載不了
ID:240085 發表于 2017-10-16 22:13 | 只看該作者
謝謝樓主分享
ID:77669 發表于 2017-10-18 10:02 | 只看該作者
好東西,謝謝分享
ID:164340 發表于 2017-10-20 20:11 | 只看該作者
太給力了,太棒了,非常感謝樓主
ID:220046 發表于 2017-10-22 13:14 | 只看該作者
樓主超級棒!!
ID:243141 發表于 2017-10-26 15:06 | 只看該作者
非常感謝
ID:247653 發表于 2017-11-9 12:41 | 只看該作者
很強,拿走謝謝了
ID:247653 發表于 2017-11-9 12:42 | 只看該作者
這個資源很好
ID:248489 發表于 2017-11-11 22:31 | 只看該作者
樓主黑幣不夠啊
ID:248581 發表于 2017-11-12 13:04 | 只看該作者
很全面,謝謝
ID:248659 發表于 2017-11-12 17:31 | 只看該作者
看到好東西了
ID:249388 發表于 2017-11-14 16:59 | 只看該作者
謝謝樓主分享,正迫切需要。
主站蜘蛛池模板: 在线a视频 | 中文字幕在线观看一区二区三区 | 欧美午夜视频 | 中文字幕黄色片 | 丰满少妇av | 欧美综合在线视频 | 欧美日韩综合在线 | 国产精品hd | 国产精品伦理一区 | 日韩精品不卡 | 伊人久久综合 | 日韩一区二区视频在线观看 | 快播少女爱欢乐 | av高清在线| 亚洲天堂成人 | 久久靖品 | 成人一二区 | 影音先锋国产精品 | 国产精品视频一区二区三区 | 香蕉视频一区二区三区 | 免费观看a级片 | 天天干天天弄 | 欧美一区二区在线观看 | 国产色视频一区二区三区qq号 | 一区二区三区四区在线 | 视频一区在线观看 | 激情av在线 | 日本乱子伦 | 蜜桃av一区 | 日韩精品无| 一区二区免费看 | 国产精品www | 人成在线| 神马九九| 亚洲伦理在线观看 | 日本不卡视频在线观看 | 日韩av不卡在线 | 日韩亚洲欧美在线观看 | 国产黄视频在线观看 | 国产免费无遮挡 | 日韩综合在线观看 |
