查看: 4467|回復: 0
單片機碼表設計 帶Proteus仿真 源代碼 可用于自行車等
ID:182942 發表于 2017-3-24 18:12 | 顯示全部樓層 |閱讀模式
一個自行車碼表的設計,個人還不是特別的透徹,希望大家一起學習,帶proteus仿真工程文件,和51單片機源代碼。
碼表計時實物圖:
產品方案與論證:
程序流程:
狀態切換:
碼表的仿真原理圖:
自行車碼表源程序:
  1. #include<reg52.h>
  2. typedef unsigned char u8;
  3. typedef unsigned int  u16;
  4. /********端口定義*********/
  5. #define DATA P0
  6. sbit seg_sel = P1^4;
  7. sbit bit_sel = P1^5;
  8. sbit start = P3^2;
  9. sbit store = P3^3;
  10. sbit diskey = P3^4;
  11. sbit reset = P3^5;
  12. sbit led = P1^0;
  13. /********變量定義*********/
  14. u16 tem_ms;
  15. u8        n_ten_ms,n_sec,n_min;
  16. u8        run_flag;//當run_flag為1,代表開始計數
  17. u8  temp_buf[5][3];
  18. u8  arr_pt;
  19. u8 code seg_tab[]={
  20.                           0xc0,0xf9,0xa4,0xb0,
  21.                           0x99,0x92,0x82,0xf8,
  22.                           0x80,0x90,0x88,0x83,
  23.                           0xc6,0xa1,0x86,0x8e
  24.                          };
  25. u8 code bit_tab[]={
  26.                           0x10,0x20,0x40,0x80,
  27.                           0x01,0x02,0x04,0x08
  28.                          };
  29. void delay(unsigned int y)
  30. {
  31.         unsigned int x,z;
  32.         for(x=y; x>0; x--)
  33.                 for(z=110; z>0; z--);
  34. }
  35. void display_led(u8 which_bit, u8 which_number)
  36. {
  37.         bit_sel = 1;//Q[7..0]=D[7..0]
  38.         DATA = bit_tab[which_bit];
  39.         bit_sel = 0;//BIT[7..0]=0x80
  40.         seg_sel = 1;//Q[7..0]=D[7..0]
  41.         DATA = seg_tab[which_number];
  42.         seg_sel = 0;
  43. }
  44. void display(u8 which_bit, u8 which_number)
  45. {
  46.         u8 x,y;
  47.         x = which_number/10;//分離十位
  48.         y = which_number%10;//分離個位
  49.         if (which_bit == 1)
  50.         {
  51.                 display_led(1, x);
  52.                 delay(2);
  53.                 display_led(0, y);
  54.                 delay(2);
  55.         }
  56.         if (which_bit == 2)
  57.         {
  58.                 display_led(4, x);
  59.                 delay(2);
  60.                 display_led(3, y);
  61.                 delay(2);
  62.         }
  63.         if (which_bit == 3)
  64.         {
  65.                 display_led(7, x);
  66.                 delay(2);
  67.                 display_led(6, y);
  68.                 delay(2);
  69.         }
  70. }
  71. void reflash (void)
  72. {
  73.         display(1, n_ten_ms);
  74.         display(2, n_sec);
  75.         display(3, n_min);
  76. }
  77. void main (void)
  78. {
  79.         TMOD = 0x01;//設置定時/計數器T0
  80.         TH0 = (65535-10000) / 256;
  81.         TL0 = (65535-10000) % 256;
  82.         EA = 1;//開放總中斷
  83.         ET0 = 1;//開放定時器0的溢出中斷
  84.         //TR0 = 1;
  85.         while (1)
  86.         {
  87.                 if (start == 0)
  88.                 {
  89.                         delay(5);
  90.                         if (start == 0)
  91.                         {
  92.                                 run_flag = ~run_flag;
  93.                         } while(!start);
  94.                 }
  95.                 if (run_flag)
  96.                 {
  97.                         TR0 = 1; //開始計數
  98.                 }
  99.                 else if (!run_flag)
  100.                 {
  101.                         TR0 = 0;
  102.                         if (diskey == 0)
  103.                         {
  104.                                 delay (5);
  105.                                 if (diskey == 0)
  106.                                 {
  107.                                         arr_pt --;
  108.                                         n_ten_ms = temp_buf[arr_pt][0];
  109.                                         n_sec = temp_buf[arr_pt][1];
  110.                                         n_min = temp_buf[arr_pt][2];
  111.                                 } while (!diskey);
  112.                         }
  113.                 }
  114.                 if (reset == 0)
  115.                 {
  116.                         delay(5);
  117.                         if (reset == 0)
  118.                         {
  119.                                 n_ten_ms = 0;
  120.
  121. ………余下代碼請下載附件…………
資料下載:
碼表設計.zip (2.54 MB, 下載次數: 46)
主站蜘蛛池模板: 日韩精品久久久久久 | 欧美日韩一区二区三区四区 | 久久精品视频免费 | 国产美女精品 | 一级片在线播放 | 能看毛片的网站 | 国产精彩视频 | 国产欧美综合一区二区三区 | www.一区| 在线免费观看黄 | 欧美视频一二三区 | www.操| 国产精品国产三级国产 | 在线观看成年人视频 | 欧美福利视频 | 三级黄色片 | 欧美一区二区在线播放 | 黄色片在线免费观看 | 国内自拍xxxx18 | 国产成人一区二区 | 在线观看免费av网站 | 欧美1级片| 毛片视频免费 | 精品久久久久久久久久 | 四虎黄色片| 欧美视频精品 | 亚洲免费看片 | 国产欧美一区二区精品忘忧草 | 三级黄色片免费看 | 插插插av | 欧美激情视频一区 | 国产精品一区二区在线免费观看 | 婷婷在线视频 | 长河落日连续剧48集免费观看 | www.日韩在线| 中文字幕偷拍 | 色综合一区二区 | 久久靖品 | 欧美日韩中文字幕 | 福利av在线| 91亚洲精品在线 |
